Kerui D026 inconsistently decoded
Re: Kerui D026 inconsistently decoded
Since changelog for R48 mentions that D026 handling has been improved, what is the status now?
From what I see, I still get inconsistent readings; sometimes ev1527 and then again eurodomest.
Is there anything I can do?
I have recently updated to R48
Support for the D026 has dramatically improved; I see consistent decoding now on 3 of the 4 devices i have, which makes them functional now
The 4th device seems to be working in reverse (on and off are reversed for some reason...)
Apparently Kerui D026 is still being decoded incorrectly. I have version 48 and here is how it's decoding ON/OFF actions:
Instead of decoding properly CMD=ON or CMD=OFF it's decoding switch number, where SWITCH=07 is OFF action (door/window closed) and SWITCH=0e is ON action (door/window open)
SWITCH=0b is tamper action.
Unfortunately, id value is changing after some time too. This particular sensor had ID=0b4dfa as above and 034dfa or 00c8aa
Tested with two different Kerui D026 sensor with exactly same result
2018-03-31 21:33:36.499 RFLink: 20;88;EV1527;ID=0b4dfa;SWITCH=0e;CMD=ON;
2018-03-31 21:33:40.214 RFLink: 20;8A;EV1527;ID=0b4dfa;SWITCH=07;CMD=ON;
2018-03-31 21:33:45.503 RFLink: 20;8B;EV1527;ID=0b4dfa;SWITCH=0e;CMD=ON;
2018-03-31 21:33:48.881 RFLink: 20;8C;EV1527;ID=0b4dfa;SWITCH=07;CMD=ON;
2018-03-31 21:33:53.632 RFLink: 20;8D;EV1527;ID=0b4dfa;SWITCH=0e;CMD=ON;
same here. After RFLink reset D026 decoded as Eurodomest, some time later as EV1527.
Regards Götz
Regards Götz
I got exactly the same problems as fabianonline describes.
With older rflink software I got in Domotics the following devices (for one sensor)
00265BE5 unit 0 -> Off (Sensor close)
00265BE5 unit 1 -> On (Sensor open)
00265BE5 unit 4 -> On (Sensor tamper)
Now with R48.4 I sometimes receive the data as above and sometimes as new devices, see below:
00065BE5 unit 0 -> Off (Sensor open)
00065BE5 unit 2 -> Off (Sensor tamper)
00065BE5 unit 3 -> On (Sensor close)
The main problem is that the value on/off is the other way around with the new devices. Normally I would create a single device with the 'master / slave' functionality in Domotics, but this is not possible because the newly create devices have Off for open & tamper and On for close.
Did someone find a solution for this issue?
Hello Folks,
Has any progress been made on this?
I got a few D026s that I want to read out with rflink. Is this working stabily (and correctly) now
Im using domoticz and rflink gateway to get the messages.
My first test only shows a closed notification from the doorsensor.
One question: how do you get to the details of the messages, such as Harald is showing below?
Is there a cli command or logfile? In domoticz I can not find this level of detail.
Regards,
Bert
Regards,
Bert
Same here...
Have 10 identical Kerui D026 sensors, four are decoded as you would expect, the others are all over the place...
Distance to the RFLINK doesn't seem to matter. All other 433Mhz devices work without any problems...
Could someone please reply on this issue? Even if it's just to say "we have no clue"...
Roger
Roger
That is one of the reasons why we are taking time to rewrite and redo the code
Hi Stunteam,
Great to hear. Looking forward to the rewrite and R49! The D026 is also on my issue list.
Do you have any indication on when we can expect a new release?
Is it months away, or weeks?
Or can you share any other snippet of info on the scale of the rewrite, the percentage done, etc.
We are anxious for any news.We don't know is also a valid answer though:-)
And of course we'll wait patiently for the result of your good work!
Kind regards and already happy holidays,
Bert
Bert
any plans when you are trying to release a R49 version?
It will be perfect when issue with D026 could be corrected.
Best regards,
Adrian
Best regards,
Adrian
Did anyone ever got this fixed?
