Ansluta ERROR
Redfeather
Re: Ansluta ERROR
#11 Post by Redfeather » 18 Feb 2017, 18:01
I have the same issue. For whatever reason I had it (24TRGC2 ) working once when I upgraded from 44 to 45. I was able to receive the Philips LivingColors Gen1 commands and I was able to send commands to which the Philips LivingColors Gen1 light responded. However I can't get it working any more.
What i do think is that either;
  • A. The RFLink is either extremely picky on timing.
    B. That an reset loop for the CC2500/24TRGC2 is not implemented correctly.
However I can't find the sourcecode anywhere. For now I am a little bit disappointed :oops: that after 2 hours of soldering and debugging the result is :( -----
Please let me know what I can do in order to assist in debugging / developing
Stuntteam
Site Beheer
Re: Ansluta ERROR
#12 Post by Stuntteam » 21 Feb 2017, 17:29
The wiring page has been updated with some level shifters that I have tested and that work.
This means that you connect the 5 volt side to the mega pins as listed and the 3 volt side to the cc2500 as listed.
This means that the level shifter fits inbetween the mega and the cc2500.
For the listed modules no additional hardware is needed.
Dr_Genestealer wrote:It's also odd that the TXB0108 is not working for you, it is working for me with other arduino software, just not with the RFLink firmware.
I have tested the TXB0108 (actually received TXB while ordering TXS) made some code changes etc. and now it seems to work more reliable.
In your photos it shows that you are using an additional power converter. That could help but I am not using it.
However, there seem to be plenty of issues with the TXB reading this: http://forum.arduino.cc/index.php?topic=262104.0 and other threads
Dr_Genestealer
Re: Ansluta ERROR
#13 Post by Dr_Genestealer » 22 Feb 2017, 16:25
Hey Guys,
That's great, thank you for adding the extra detail. I will give it a go with the added instructions. I also have another CC2500 to try.
I will give it a go with the latest rfl4607_tst.zip (REV=46, BUILD=07) or is Build 06 the best to test?
Also, I see Rev 46 is not officially on the web page yet?
Stuntteam
Site Beheer
Re: Ansluta ERROR
#14 Post by Stuntteam » 22 Feb 2017, 17:22
Rev 46 will be public soon.
Redfeather
Re: Ansluta ERROR
#15 Post by Redfeather » 25 Feb 2017, 15:06
Stuntteam wrote:Rev 46 will be public soon.
On a funny note:
I am ready :geek:
Bryan Adams - I'm Ready https://goo.gl/ZZ2ezy (Youtube Link)
On a more serious note:
Is there an ETA for the Rev 46?
techsoz
Re: Ansluta ERROR
#16 Post by techsoz » 01 Jun 2017, 12:34
hi there,
I am a newby. I bought an arduino mega, and an nodo rf link 868 kit. also bought a NRF24L01+ module because i thought it might control my ikea omlopp/ansluta setup. It is soldered an fits together neatly.
I assume I was wrong there with the ansluta however.
So I am getting an cc2500 and some level shifterts now. I found some wiring, but this seems to be more complicated than i thought. Do I need the rf link modle at all
how do i connect the cc2500 wo the whole thing, as some of the ports stated here http://www.nemcon.nl/blog2/wiring (under cc2500) are blocked by my rflink module
(47...53) .
SO can I use only one of toth, rflink 858 or cc2500, or how do i wire both of them?
I found some wiring here: https://github.com/Genestealer/Home-Ass ... ay-ESP8266 but I am more condused than before. what is all this!?
please point me to easy ressources if possible (i searched some other forums unsuccessuflly). I am a beginner, so I might miss out some basic principoles.
thank you.
rene
