Domoticz dropping TCP/IP connections
manjh
#1 Post by manjh » 21 Mar 2017, 19:39
OK, I'm not sure if this problem is at all related to ESPEasy or RFLink, but I thought I'd give it a try.
Until today I was using a USB connected RFLink. Also use an OTGW, and a P1 interface, both based on ESPEasy.
Today I finally assembled my new LAN connected RFLink. All seems to work OK, after changing the device type in Domoticz from USB to LAN based RFLink.
But after looking in the Domoticz log file, I found that the P1 and OTGW connections have become unstable. TCP/IP links are dropped, and later reconnected.
When connected, I see data coming in so the link works OK.
I checked the ports that are used, they are different for all three devices and correct on both sides.
Has anyone seen this? Any ideas?
ensingg
Re: Domoticz dropping TCP/IP connections
#2 Post by ensingg » 19 Aug 2017, 10:54
Like this? I have the same problem.
And with a putty to the ip address the connection drops also.
(RFLink) Temp + Humidity (WoonkamerTemp)
2017-08-19 10:47:44.763 (RFLink) Temp + Humidity (TempTuinschuurtje)
2017-08-19 10:47:54.004 TCP: Reconnecting...
2017-08-19 10:47:54.882 RFLink: Connection reset!
2017-08-19 10:47:54.882 TCP: Reconnecting in 30 seconds...
2017-08-19 10:47:55.004 RFLink: connected to: 192.168.0.25:8181
2017-08-19 10:48:00.619 dzVents: Testje
2017-08-19 10:48:24.899 TCP: Reconnecting...
2017-08-19 10:48:25.021 RFLink: Connection reset!
2017-08-19 10:48:25.021 TCP: Reconnecting in 30 seconds...
2017-08-19 10:48:25.899 RFLink: connected to: 192.168.0.25:8181
2017-08-19 10:48:29.741 (RFLink) Temp + Humidity (WoonkamerTemp)
2017-08-19 10:48:40.709 (RFLink) Temp + Humidity (TempTuinschuurtje)
2017-08-19 10:48:55.042 TCP: Reconnecting...
2017-08-19 10:48:55.919 RFLink: Connection reset!
2017-08-19 10:48:55.919 TCP: Reconnecting in 30 seconds...
2017-08-19 10:48:56.043 RFLink: connected to: 192.168.0.25:8181
2017-08-19 10:49:00.347 dzVents: Testje
2017-08-19 10:49:17.723 (RFLink) Temp + Humidity (WoonkamerTemp)
2017-08-19 10:49:25.936 TCP: Reconnecting...
2017-08-19 10:49:26.064 RFLink: Connection reset!
2017-08-19 10:49:26.064 TCP: Reconnecting in 30 seconds...
2017-08-19 10:49:26.939 RFLink: connected to: 192.168.0.25:8181
manjh
#3 Post by manjh » 19 Aug 2017, 23:22
yes. It is usually stable, but sometimes......
