MiLight gives me 20;16;CMD UNKNOWN;
I get this error when trying to pair my RGBW MiLIght?
2017-05-15 17:16:36.119 User: initiated a RFLink Device Create command: 10;MiLightv1;F746;01;34BC;PAIR;
2017-05-15 17:16:36.194 RFLink: 20;16;CMD UNKNOWN;
2017-05-15 17:16:36.194 Error: RFLink: Error/Unknown command received!...
Re: MiLight gives me 20;16;CMD UNKNOWN;
Have you turned on MiLight in the loader program?
Don't have the loader program, but gave the command 20;01;MiLigt=ON;
That should do the same thing as I understand it
I don't know if it does, someone more knowledgable than me might be able to confirm either way.
You could download the loader program from the website (it comes with the firmware download iirc). Connect mega to usb and turn on serial port logging then press the "milight on" button. When you run the serial logging it will tell you if milight is on and also if your nrf24xxx module is detected properly.
The command is not correct.. make sure you spelled it right.
The loader is windows only and dont have windowsdarkside0506 wrote: ↑15 May 2017, 21:22 I don't know if it does, someone more knowledgable than me might be able to confirm either way.
Commands starting with 20; are responses from RFLink.
Also "20;01;MiLigt=ON;" the spellign of milight is wrong.
The right command is:
10;setMilight=ON;
10;setMilight=ON;
