868Mhz issue
Phoenix-Blue
868Mhz issue
#1 Post by Phoenix-Blue » 16 Sep 2017, 12:27
I have running an 434Mhz set on an Arduino Mega 2560 board without any problem, but I try to run an second set with an 868Mhz (Aurel Tranceiver RTX MID 868.3 OOK) but when I run the RF Link loader and check the monitor I see:
20;00;Nodo RadioFrequencyLink - RFLink Gateway V1.1 - R47;
10;version;
20;01;VER=1.1;REV=47;BUILD=08;
10;status;
20;02;STATUS;setRF433=ON;setNodoNRF=OFF;setMilight=OFF;setLivingColors=OFF;setAnsluta=OFF;setGPIO=OFF;setBLE=OFF;setMysensors=OFF;
10;rfdebug=on;
20;03;RFDEBUG=ON;
10;rfudebug=on;
20;04;RFUDEBUG=ON;
Is it normal that setRF433 is showing?
Because i'm not receiving anything.
Stuntteam
Site Beheer
Re: 868Mhz issue
#2 Post by Stuntteam » 16 Sep 2017, 12:41
Yes, dont worry about it..
Phoenix-Blue
Re: 868Mhz issue
#3 Post by Phoenix-Blue » 16 Sep 2017, 13:12
Ok, good to know.
An is there an command to use to check everything is working ok?
Because I send knowing from knowing devices but see nothing :(
Small update, I have (re) solder al the connections and it's now working.
Think that there was an bad connection.....
