Help newbie RFLINK
Moderators: Voyager, BertB, rtenklooster, Stuntteam
wifi75
Help newbie RFLINK
#1 Post by wifi75 » 30 Oct 2017, 09:57
Hello to all,
I want buy rflink to controll same device 433mhz by domotictz software.
but I do not understand a thing:
what do I need?
this?
https://www.nodo-shop.nl/en/home/191-rf ... print.html
Given I already have two two free nodemcu V3 can I use one on the above link??
Or it is better install tf link on arduino mega?
Stuntteam
Site Beheer
Re: Help newbie RFLINK
#2 Post by Stuntteam » 30 Oct 2017, 19:33
RFLink for now only works on an Arduino Mega.
In the future we will have support for other platforms too.
wifi75
#3 Post by wifi75 » 30 Oct 2017, 21:50
ah oK I need Arduino mega and rfkink.
nice
tnx
wifi75
#4 Post by wifi75 » 31 Oct 2017, 09:32
I have a doubt, rflink work on qnap ?
Maybe no, because there are no drivers...
Stuntteam
Site Beheer
#5 Post by Stuntteam » 31 Oct 2017, 15:39
Yes, it works on various NAS as well..
On Synology it works with the Arduino.. might need to use an Arduino with CH340 based USB port. (see http://www.jadahl.com/)
In some cases when the system does not have much choice in serial drivers you might want to use a cheap FTDI serial port.
However, we have reports that it works on QNAP.
oerli
#6 Post by oerli » 12 Dec 2017, 20:37
The rflink synology version which uses the HL-340 serial usb chip.
QNAP standard has no driver installed, but I build the ch341.ko driver for TS-xx9 platform, that is x86_64 platform.
Put it on your NAS on permanent storage so it survives reboots. /etc/config/usb would be a good location.
From console, issue: insmod /etc/config/usb/ch341.ko
That will load the driver and attach it to a USB device. In my case it is attached to ttyUSB2.
You can check with dmesg:
[111848.472078] usbcore: registered new interface driver ch341
[111848.472473] USB Serial support registered for ch341-uart
[111848.472825] ch341 7-1:1.0: ch341-uart converter detected
[111848.486300] usb 7-1: ch341-uart converter now attached to ttyUSB2
Put the insmod command in your autorun.sh (google for info)
ch341.zip
(5.54 KiB) Downloaded 41 times
