i bought some Door Contact Sensors.
They send two signals for CLOSED with CMD=ON and two signals for OPEN with CMD=ON.
I wanted to ask if it is possible to change the CLOSED signal to CMD=OFF?
I have read something about RFFind but i don't understand how to use it.
Here are the Signal Codes of the Sensor (with 10;rffind=off;):
CLOSED Sensor:
20;0C;EV1527;ID=0cebe0;SWITCH=0e;CMD=ON;
20;0B;SelectPlus;ID=0141f1;SWITCH=02;CMD=ON;CHIME=01;
OPEN Sensor:
20;0E;EV1527;ID=0cebe0;SWITCH=0a;CMD=ON;
20;0F;SelectPlus;ID=00a0fa;SWITCH=02;CMD=ON;CHIME=01;
Here are the Signal Codes of the Sensor (with 10;rffind=on;):
CLOSED Sensor:
20;22;EV1527;ID=0cebe0;SWITCH=0e;CMD=ON;
20;23;SelectPlus;ID=00a0f8;SWITCH=02;CMD=ON;CHIME=01;
OPEN Sensor:
20;1B;EV1527;ID=0cebe0;SWITCH=0a;CMD=ON;
20;1C;SelectPlus;ID=00a0fa;SWITCH=02;CMD=ON;CHIME=01;
Domoticz set up 4 devices:
I would like to have only one Device witch sends a CMD=ON when OPEND and CMD=OFF when CLOSED. Is it possible?
Can somebody tell me exactly what I have to do.
Door Sensor sends ON/ON instead of ON/OFF
Re: Door Sensor sends ON/ON instead of ON/OFF
Try the rffind option
Yes but i dont understand to use the rffind Option.
The FAQ dont help very much (http://www.rflink.nl/blog2/faq#RFFind).
Can you maybe give me a example?
Is there really nobody who could possibly help?
I just do not understand the system of RFFind and would need an example based on my case.
Would be glad if someone could take some time who knows it.
Thank you!
Thank you!
I did a bit of research and found out that in 1 of the 100 OPEN and CLOSE operations via RFFind a style scheme like
is found.
Problem is that the RFRecord is then working in 1 of 100 trys.
Is there a Way to fix this? In above post you can see the Signals RFFind is reciving every try!
I need some help please
Thanks everybody
20;28;RFFind;x;D6290A;B;2F;1;
20;32;RFFind;x;D6290E;D;2C;1;
Thanks everybody
