The original ID is displayed when you press the button on the remote.
You make a small change to this ID and assign that as a second remote to the motor controller.
If RFLink does not detect your remote, it is not supported yet. As explained make a debug log in that case.
[Solved] RTS problems in R42
Re: [Solved] RTS problems in R42
Ok i test it probably tomorrow and give you an info.
How i can clear eeprom.?
Thanks for help.
But i have a question. WHen i have remote Smoove Origin and second remote Somfy Telis 4 , i can use RFLink as third remote ?
Thanks for help.
Goedenavond
Ik ben ook zopas eigenaar geworden van een Rflink Gateway Synology module.
Firmware R42 werd geïnstalleerd.
Ook ik heb problemen met het koppelen van de Somfy rolluiken met mijn RFlink.
Zou er iemand zo vriendelijk willen zijn een "monkey proof" shortlist te maken met de te nemen stappen voor het koppelen van de Rflink met de Somfy RTS rolluiken a.u.b.?
bvb. hoe begin je met het toevoegen van de Rflink als een secundaire afstandsbediening?
Alvast bedankt!
Grtz Dim
Alvast bedankt!
Grtz Dim
I done next test and nothing news. Still Somfy with RFLink not working. I try read log in debug mode by RFLoader but when i push button on remote Somfy Telis 4 or Smoove Origin but RFLink noit show any data in debug. In serial port logging also not show any data after push button on remote.
But when i pair by manual as i show in previous post my somfy run for abou 3 sec. Once i run it and close full. But it was only once. Never again. I pair my somfy with example ID 212F32. But nothing... For me RFLink not working with somfy blinds facade C80. I think that problem is in firmware code...
Anybody help me ? Why in RFLoader debug mode not show any code from remote my Somfy but when i pair with RFLink , my RFLink run for about 3 secunds my blinds ? If run send any code and and something reconized from somfy RTS. Stuntteam please help us and help verify this problem.
Wat is een id dicht bij de originele id? Mijn originele id begint nl met 00, en dat mag je niet gebruiken had ik gelezen. Als ik de originele id pak met 01 als startbit, is dat dan "close enough"?
Thx!
Bart
Thx!
Bart
1b602b
