Ansluta - I can recieve but not send
Just got a cc2500 and wired it up. I am able to receive commands from the ansluta remote control, but when I send...
10;ANSLUTA;ID=d3d2;SWITCH=0;CMD=OFF
I get no response. I have the cc2500 wired through a two way level converter and powered by the 3.3v pin on the Arduino mega. I tried adding a 10uf cap between power and ground.
As I understand it, if I am recieving, then my wiring must be ok as the module is talking through the spi bus. Can you suggest anything I should be looking out for?
Re: Ansluta - I can recieve but not send
I sent this as an email, but it might be helpful to other users to duplicate it in the forums...
Switching debug on I get this.
Receiving…..
20;43;Ansluta DEBUG;Bytes=06;5501d3d202aa;
20;44;ANSLUTA;ID=d3d2;SWITCH=0;CMD=SET_LEVEL=8;
20;45;Ansluta DEBUG;Bytes=06;5501d3d202aa;
20;46;ANSLUTA;ID=d3d2;SWITCH=0;CMD=SET_LEVEL=8;
20;49;Ansluta DEBUG;Bytes=06;5501d3d203aa;
20;4A;ANSLUTA;ID=d3d2;SWITCH=0;CMD=ON;
20;4B;Ansluta DEBUG;Bytes=06;5501d3d203aa;
20;4C;ANSLUTA;ID=d3d2;SWITCH=0;CMD=ON;
20;51;Ansluta DEBUG;Bytes=06;5501d3d201aa;
20;52;ANSLUTA;ID=d3d2;SWITCH=0;CMD=OFF;
20;53;Ansluta DEBUG;Bytes=06;5501d3d201aa;
20;54;ANSLUTA;ID=d3d2;SWITCH=0;CMD=OFF;
Sending…
10;ANSLUTA;ID=d3d2;SWITCH=0;CMD=OFF;
20;47;Ansluta DEBUG;0f0f0f0f0f0f;
20;48;OK;
Any idea what I have done wrong?
Receiving…..
Sending…
20;48;OK;
Send you a test version..
For those who are wondering, Ikea made 2 versions of Ansluta.
A 433mhz version and a 2.4 ghz version.
For the 433mhz version you will need a 433mhz transceiver I have no debug data yet for this type so I do not know if it is supproted....
For the 2.4Ghz version you will need a CC2500 transceiver, this one is supported if you have the right hardware module and you have unlocked Ansluta support. Do not unlock hardware features without the hardware. Although there are tests for the hardware availability it might not work on each and every clone versions out there..
I'm having the same problem... Can receive data, but sending it has no effect.
Any ideas?
When I turn on debug, I see similar patterns as the previous post
20;00;Nodo RadioFrequencyLink - RFLink Gateway V1.1 - R44;
20;01;setAnsluta=ON;
10;version;
20;02;VER=1.1;REV=44;BUILD=08;
10;status;
20;03;STATUS;setRF433=ON;setNodoNRF=OFF;setMilight=OFF;setLivingColors=OFF;setAnsluta=ON;setGPIO=OFF;setBLE=OFF;setMysensors=OFF;
20;04;ANSLUTA;ID=36ba;SWITCH=0;CMD=ON;
20;05;ANSLUTA;ID=36ba;SWITCH=0;CMD=ON;
20;06;ANSLUTA;ID=36ba;SWITCH=0;CMD=SET_LEVEL=8;
20;07;ANSLUTA;ID=36ba;SWITCH=0;CMD=SET_LEVEL=8;
20;08;ANSLUTA;ID=36ba;SWITCH=0;CMD=SET_LEVEL=8;
20;09;ANSLUTA;ID=36ba;SWITCH=0;CMD=OFF;
20;0A;ANSLUTA;ID=36ba;SWITCH=0;CMD=OFF;
10;ANSLUTA;ID=36ba;SWITCH=0;CMD=ON;
20;0B;OK;
20;11;Ansluta DEBUG;0f0f0f0f0f0f;
20;12;OK;
20;13;Ansluta DEBUG;Bytes=06;550136ba02aa;
20;14;ANSLUTA;ID=36ba;SWITCH=0;CMD=SET_LEVEL=8;
20;15;Ansluta DEBUG;Bytes=06;550136ba02aa;
20;16;ANSLUTA;ID=36ba;SWITCH=0;CMD=SET_LEVEL=8;
20;17;Ansluta DEBUG;Bytes=06;550136ba01aa;
20;18;ANSLUTA;ID=36ba;SWITCH=0;CMD=OFF;
20;19;Ansluta DEBUG;Bytes=06;550136ba01aa;
20;1A;ANSLUTA;ID=36ba;SWITCH=0;CMD=OFF;
20;1B;Ansluta DEBUG;Bytes=06;550136ba02aa;
20;1C;ANSLUTA;ID=36ba;SWITCH=0;CMD=SET_LEVEL=8;
20;1D;Ansluta DEBUG;Bytes=06;550136ba02aa;
20;1E;ANSLUTA;ID=36ba;SWITCH=0;CMD=SET_LEVEL=8;
Yes...
10;ANSLUTA;36ba;0;SET_LEVEL=8
10;ANSLUTA;36ba;0;ON
10;ANSLUTA;36ba;0;OFF
- Dr_Genestealer
Can you please let me know what type of level converter you used and confirm your wiring. A photo would be great too.Justblair wrote:I have the cc2500 wired through a two way level converter
Many thanks,
Richard
