I can't find the way to program 1st channel on Macean Energy MCE07 power sockets.
There are 4 sockets and a remote in box. 3 sockets works great (remote buttons from 2 to 4), but channel (button no 1) doesn't work. After switching the 1st channel socket to other channel it's working great - so I guess that it's not the hardware related problem.
Learning procedure for all 4 channels is 100% the same.
Best Regards,
Konrad
Maclean Energy MCE07 - 1st channel problem
Re: Maclean Energy MCE07 - 1st channel problem
Ca you make a debug log for channel 1 and channel 2?
Here you can find how to do that: http://www.nemcon.nl/blog2/development
Yes - of course
Here is log on ON button:
and OFF:
20;12;DEBUG;Pulses=88;Pulses(uSec)=420,390,330,390,3300,3390,330,420,330,1230,330,420,330,420,330,1260,330,420,330,420,330,1260,330,420,330,420,330,420,330,420,330,1230,330,420,330,1230,330,1290,330,1230,330,420,330,1230,330,1230,330,420,330,1230,330,1230,330,450,330,1230,330,1230,330,1230,330,1230,330,420,330,1230,330,420,330,450,330,1260,330,420,330,420,330,420,330,420,330,1230,330,1230,330,1260,330,6990;
20;13;Maclean;ID=b6f4;SWITCH=01;CMD=ON;
20;14;DEBUG;Pulses=88;Pulses(uSec)=420,390,330,390,3300,3390,330,420,330,1230,330,420,330,420,330,1230,330,420,330,420,330,1260,330,420,330,420,330,420,330,420,330,1230,330,420,330,1230,330,1290,330,1230,330,420,330,1230,330,1230,330,420,330,1230,330,1230,330,450,330,1230,330,1230,330,1230,330,1230,330,420,330,1260,330,420,330,450,330,1230,330,420,330,420,330,420,330,420,330,1230,330,1230,330,1230,330,6990;
20;15;DEBUG;Pulses=88;Pulses(uSec)=390,390,330,390,3300,3390,330,420,330,1260,330,420,330,420,330,1230,330,420,330,420,330,1260,330,420,330,420,330,420,330,420,330,1230,330,420,330,1230,330,1290,330,1230,330,420,330,1230,330,1230,330,420,330,1260,330,1230,330,450,330,1230,330,1230,330,1230,330,1260,330,420,330,1230,330,420,330,450,330,1230,330,420,330,420,330,420,330,420,330,1230,330,1230,330,1260,330,6990;
20;18;DEBUG;Pulses=88;Pulses(uSec)=420,390,330,390,3300,3390,330,420,330,1230,330,420,330,420,330,1260,330,420,330,420,330,1260,330,420,330,420,330,420,330,420,330,1260,330,420,330,1260,330,1290,330,1230,330,420,330,1260,330,1230,330,420,330,1230,330,1260,330,450,330,1230,330,1230,330,1230,330,1230,330,420,330,1230,330,420,330,450,330,420,330,1260,330,1260,330,1230,330,1260,330,420,330,420,330,420,330,6990;
20;19;Maclean;ID=b6f4;SWITCH=01;CMD=OFF;
20;1A;DEBUG;Pulses=88;Pulses(uSec)=420,390,330,390,3300,3390,330,420,330,1260,330,420,330,420,330,1230,330,420,330,420,330,1290,330,420,330,420,330,420,330,420,330,1230,330,420,330,1230,330,1290,330,1260,330,420,330,1230,330,1260,330,420,330,1260,330,1230,330,450,330,1260,330,1260,330,1230,330,1230,330,420,330,1260,330,420,330,450,330,420,330,1230,330,1230,330,1260,330,1230,330,420,330,420,330,420,330,6990;
20;1B;DEBUG;Pulses=88;Pulses(uSec)=420,390,330,390,3270,3390,330,420,330,1230,330,420,330,420,330,1230,330,420,330,420,330,1260,330,420,330,420,330,420,330,420,330,1230,330,420,330,1260,330,1290,330,1230,330,420,330,1260,330,1230,330,420,330,1260,330,1260,330,450,330,1230,330,1230,330,1260,330,1260,330,420,330,1230,330,420,330,450,330,420,330,1260,330,1260,330,1230,330,1260,330,420,330,420,330,420,330,6990;
20;1C;DEBUG;Pulses=28;Pulses(uSec)=390,1170,300,420,330,1170,300,390,330,420,330,390,300,1170,300,1230,330,1230,330,1260,330,420,330,420,330,420,330,6990;
20;1D;DEBUG;Pulses=74;Pulses(uSec)=390,1170,300,420,300,420,300,1200,300,390,330,390,300,390,330,390,330,1230,330,420,330,1260,330,1290,330,1230,330,420,330,1260,330,1260,330,420,330,1230,330,1260,330,480,330,1260,330,1260,330,1260,330,1260,330,420,330,1260,330,420,330,450,330,420,330,1230,330,1260,330,1260,330,1230,330,420,330,420,330,420,330,6990;
I can see that you asked for log for channel 2 also. Should I prepare it also, or the one provided above is enough?
Channels 2-4 works without any issues.
