RTS only detects long press keys
About receivers, transmitters, transceivers, connections, antennas etc.
Moderators: BertB, rtenklooster, Voyager, Stuntteam, Martinus
#1 Post by fanegas54 » 23 Oct 2017, 15:56
I have 4 RTS somfy J4 motors in a automated roof and I successfully paired these motors with RFLINK with the PAIR command. The motors are registered in the Rolling Code table and I can send commands UP, DOWN and STOP, but the problem is that the motors receive the comands as if I was pressing and holding the buttons in the remote controller. So it ups for a while and stops. Sending the DOWN command it goes down for 2 seconsd and stops. And sending STOP it goes to the favorite position (in the remote controller Telis4 is the MY button -- when it is press&hold).
I have the version 47 in the RFLINK and a 432.92MHZ (not the RTS one), but I have the receiver at only 5 meters and detects all commands from the remote and the commands I send with RFLINK are received successfully by the motors receptors.
I have try to change the comand 10;RTSLONGTX wich Toggle RTS long transmit ON/OFF , but it works worse than before. With this option the motors take a lot of time in receive the commands and the problem is the same. Also the motors not respond to any command with this feature togled.
Any suggestions?
