I have 4 RTS somfy J4 motors in a automated roof and I successfully paired these motors with RFLINK with the PAIR command. The motors are registered in the Rolling Code table and I can send commands UP, DOWN and STOP, but the problem is that the motors receive the comands as if I was pressing and holding the buttons in the remote controller. So it ups for a while and stops. Sending the DOWN command it goes down for 2 seconsd and stops. And sending STOP it goes to the favorite position (in the remote controller Telis4 is the MY button -- when it is press&hold).
I have the version 47 in the RFLINK and a 432.92MHZ (not the RTS one), but I have the receiver at only 5 meters and detects all commands from the remote and the commands I send with RFLINK are received successfully by the motors receptors.
I have try to change the comand 10;RTSLONGTX wich Toggle RTS long transmit ON/OFF , but it works worse than before. With this option the motors take a lot of time in receive the commands and the problem is the same. Also the motors not respond to any command with this feature togled.
Any suggestions?
RTS only detects long press keys
Users browsing this forum: No registered users and 33 guests
