ESP Easy development status
Re: ESP Easy development status
Just wondering if the ESP8266 will have sufficient RAM to run both the microPython engine and a large project like ESPEasy?
I've just installed microPython and without any 'sketch' there's only 26k left (?)
lisam, is it possible to use 3rd party libraries like adafruit or IR in micropython? i know its possible with normal python to link against c-stuff, i was wondering how that works with micropython? can you just upload the .py file plus a object-file?
regarding size: i also dont like overkill for hardware, but on the other hand: stuff gets cheaper and more resources all the time. i think the esp32 is almost as cheap as the esp8266 already. we also have to develop with the future in mind: the next 2 or 3 years there will probably lots of new powerfull and cheap hardware to choose from. there's a big chance that most of them will support micropython.
regarding speed: python is indeed orders of magnitude slower than regular c. but in practice this is no problem: low level stuff like networking is still handle by very efficient C code in python. if we need high speed for some device: normally is possible with python to still use C for those parts.
also i think its possible to let espyeasy download a plugin from internet realtime. this way the user can only "install" the needed plugins via the same webinterfaces. and even update plugins via the webinterface.
edwin
edwin
What you probably see is just the stack, uPyEasy modules are not stored in there but are 'Frozen' modules. Frozen means that the modules become part of the micropython firmware (that what i'm currently also doing with all the other standard micropython modules like picoweb to). It still gives you the ability to add additional modules/python programs, but eat up the stack (which is not what you want to do on a large scale in limited environments like the ESP8266).
uPyEasy is overwhelming this thread, shall we continue here: viewtopic.php?f=14&t=3577&p=19287#p19287
Ok, I just want to mention that I'd prefer if we (with "we" I mean the developers) focused a bit on closing the issues found in the milestones of v2.0.0. I'd like us to squash "all" the bugs and release it to the crowd.
https://github.com/letscontrolit/ESPEasy/milestone/1
Do I hear a "YES we can!"?
Instead of micropython, has anyone looked at golang’s gobot, seems they are pushing multi-platform, even has stuff for esp8266.
https://gobot.io/documentation/platforms/esp8266/
I do not understand all that doing. Before fixing all the known issues, the devs start working on implementing new CPUs like ESP32 and whatever we normal user don't need (yet)! We want a firmware that works without all that bugs! That doing remembers me at Micro$oft, that makes all of us to beta testers with unfinished and crappy products. So keep the focus on a bug-free firmware first!!!
The development of ESP32 is being done on the "mega" branch. So it is for the new stuff after this release.vader wrote: ↑05 Nov 2017, 11:02 I do not understand all that doing. Before fixing all the known issues, the devs start working on implementing new CPUs like ESP32 and whatever we normal user don't need (yet)! We want a firmware that works without all that bugs! That doing remembers me at Micro$oft, that makes all of us to beta testers with unfinished and crappy products. So keep the focus on a bug-free firmware first!!!
At this moment there is a 2.0 branch which contains all that is going to be in the new upcoming release.
My personal preference would be to develop the ESP32 support into a separate branch and then merge into mega, but that is just one of the many flavors in software development and branching strategies.
Typical development is one master branch (which is called 'mega' here at the moment) for which new features are developed.
The feature-freezes are then split into a separate branch which only have bugfixes.
Spot on TD, we need a strategy for the branches and releases.
The more I study ESP32 architecture the more I think that a simple "porting" won't be using full chip capabilites...TD-er wrote: ↑05 Nov 2017, 11:40The development of ESP32 is being done on the "mega" branch. So it is for the new stuff after this release.vader wrote: ↑05 Nov 2017, 11:02 I do not understand all that doing. Before fixing all the known issues, the devs start working on implementing new CPUs like ESP32 and whatever we normal user don't need (yet)! We want a firmware that works without all that bugs! That doing remembers me at Micro$oft, that makes all of us to beta testers with unfinished and crappy products. So keep the focus on a bug-free firmware first!!!
Specially now that Espressiff provided RTOS functionality with possibility to run code on both cores in parallel, but this will require major modification to ESPEasy I guess
Yep, the Espressiff ESP32 libs are completely different from the Espressiff ESP8266 libs. I looked at it and gave up the hope of ever uniting both ESP platforms. Even for micropython they are taking some time to develop micropython on a ESP32 with a complete team. They now have a multi threaded micropython and capable of using 4MB of psRAM (yes 4MB of free ram instead of 80KB...)papperone wrote: ↑05 Nov 2017, 15:01 The more I study ESP32 architecture the more I think that a simple "porting" won't be using full chip capabilites...
And even if you succeed, it's not async so not benefiting from the dual core. uPyEasy is async from the beginning, meaning the webserver can handle one request on one core and the other core can handle the IO. Arm soc's like the STM32 series are now also available in dual-core (cortex-r4). The $10 OrangePi is another competitor with loads of cores and IO available.
If i need this kind of power? For most apps not, but for some controls in my house (CO2, heating) it's even essential. I need a LOT more local node power to do AI, inter-node communication, wifi mesh networking, etc. None of that can be done with the current limited capabilities of ESPEasy.
For an ESP-01 all of this might not matter, but even the mighty ESP-01 doesn't live forever...
Hardly any code development has been done, nor is it planned for ESPEasy on ESP32 (unless some developer volunteers?)vader wrote: ↑05 Nov 2017, 11:02 I do not understand all that doing. Before fixing all the known issues, the devs start working on implementing new CPUs like ESP32 and whatever we normal user don't need (yet)! We want a firmware that works without all that bugs! That doing remembers me at Micro$oft, that makes all of us to beta testers with unfinished and crappy products. So keep the focus on a bug-free firmware first!!!
Current changes to the mega dev branch are limited to some precompiler directives to select the ESP32 specific libraries and function calls. Mainly because they were named ESP8266xxx and now ESP32xxx or ESPxxx....
All all the actual hard work on ESP32 Arduino core is done by other developers (me-no-dev as lead developer).
Their aim is to get typical Arduino sketches to run on ESP32.
And ESPEasy actually runs on ESP32 as we speak.
Because of me-no-dev and his team...
(to avoid possible confusion, me-no-dev and co-developers are not members of the ESP Easy team, so we can't influence their work. In case one doubts the usefulness of their work on ESP32, better ask them directly)
