hi, i think its great that you can step in to avoid stalling the project. i can help with testing and supporting on the forum, but my programming skills are nowhere good enough to write code for espeasypsy0rz wrote:I now thoroughly reviewed the framework base and a bunch of pull requests.
I dont see any problem in being able to moving the project forward as well as making a bunch of improvements in the whole development cycle:
- faster intergrating of playground plugins: mark them as TESTING in the webgui and make compiling optional.
- automated builds via Travis
- provide multiple binaries: small (<512k), normal and large (with testing plugins)
- using githubs issue tracker for features and bugs
- every plugin should have a link to the github issue tracker (or somewhere else) to report bugs. (and maybe also a link to provide feedback if the plugin has been working correctly for a while)
Sounds good?
Edwin
The way forward
Re: The way forward
Re: The way forward
I am pleased that someone who looks like they can do the project justice has taken an interest.
I have contributed to the Espurna Sonoff SC build, adding RGB to it. Can I make a suggestion?
The Arduino code for the Espurna SC uses AT+commands to control it. It would be nice to share the code for the Arduino portion between the two projects. That way one could benefit the other.
Re: The way forward
Hi Edwin!psy0rz wrote:I now thoroughly reviewed the framework base and a bunch of pull requests.
Sounds good?
Edwin
Sounds indeed great! Are you in contact with martinus (he asked for PM) about this suject?
Cheers
Re: The way forward
I'd really like to support this project, it is the most evolved project i know in this area.
Sadly my programming knowledge is completely outdated to 30 year old BASIC and FORTRAN programming..
But if i can help in any way, documenting or such, i will do.
This project is worth it.
Re: The way forward
Thank you Edwin for stepping in!!!
And Jon, re: "It would be great if ESPEasy could live on"
+1
+1
Re: The way forward
Currently i'm setting up Travis to automaticly compile every commit, and automaticly create a firmware.bin release when i tag a commit.
Its here: https://travis-ci.org/psy0rz/ESPEasy-platformio
Tagged version will be released here: https://github.com/psy0rz/ESPEasy-platformio/releases
Still working on it: need to fix it so the tag and commit will be compiled into the firmware as well.
Edwin
Edwin
Re: The way forward
Ok i've pretty much have things up and running.
Have a look at the README over here to see whats going on: https://github.com/psy0rz/ESPEasy/blob/master/README.md
I've already merged a pull request: https://github.com/letscontrolit/ESPEasy/pull/96
If you guys want to test to see if everything is working like you would expect, that would be great.
Please let me know what you think,
Edwin
Edwin
Re: The way forward
I have contact with Martinus and access to the main repository. Fortunately he will stay involved with the project, but currently doesn't have the time to do any real coding. So he'll be on the background (for now).
I'll keep you posted.
Re: The way forward
Wow, thats really great news!
Re: The way forward
Good to hear you will take over the work of Martinus, and i wish yo a lot of success.psy0rz wrote:I have contact with Martinus and access to the main repository. Fortunately he will stay involved with the project, but currently doesn't have the time to do any real coding. So he'll be on the background (for now).
Re: The way forward
Hi,psy0rz wrote:I have contact with Martinus and access to the main repository. Fortunately he will stay involved with the project, but currently doesn't have the time to do any real coding. So he'll be on the background (for now).
Your efforts are very appreciated, it would be so sad if the project were to die, it's simply too good for that
Re: The way forward
I'm not a very experienced programmer but get by, I would like to help maintain the wiki.
Re: The way forward
Re: The way forward
Awesome! it also would be nice if you could check if all the plugins have a wiki page. for the plugins that dont have one (especially the playground ones i expect), you could perhaps search for info on the forum and link the wiki page to it. (or even create a wiki page for it, if the info is complete)JustmeNL wrote:Hi,
Edwin
Re: The way forward
Hallo Leute,
really great news to see this project going on.
Is there a place where i / we can report bugs and feature request?
regards Matze
regards Matze
Re: The way forward
I asked Martinus to enable the github issue tracker. Until that time, you can use the temporary issue tracker here: https://github.com/psy0rz/ESPEasy/issues
Re: The way forward
Good Job Psy
How far are you in gettting all the permissions for the Forum and Wiki and Github?
I would gladly help where i can in supporting this project. I just recently discovered it and it has everthing to get up and running with the ESP module
Maybe we can start a thread for all the supporters that want to help out and divide some tasks
running Domoticz on a raspberry pi.
mi-light on domoticz
basic knowledge in electronics
Currently developing in python
Re: The way forward
Same from me.
As I don't have actual programming knowledge my focus would be
on hardware, and Wiki. As i'm a native German speaker a German
translation of the wiki pages would be possible too.
Re: The way forward
Hi all,
Edwin, thanks for stepping in.
I am also available for testing and revieuwing the wiki.
Furthermore I would like to continue to enhance my programming skills by making prototypes of plugins. Is that still possible in the new setup?
Some other question. How do the relases in ESPEasy-platformio relate to those mentioned in ESPEasy?
And, can you help me understanding the Platdormio way of live in a more low level language?
Re: The way forward
+1And, can you help me understanding the Platdormio way of live in a more low level language?
Re: The way forward
I will try to explain all those things on the wiki, when i'm ready with the basics of the new repostirories.
Offcourse developing plugins will stay possible. Getting plugins into the final release will be easier from now on: A plugin can be in stable, testing or development mode. We release firmware for each of those plugin sets. So people can chose if they just want the stable plugins or more.
Meanwhile i've uploaded a new update with a few improvements. Most notably the zip file has the same layout as people where used to with Martinus.
Its here: https://github.com/letscontrolit/ESPEas ... 2.0.0-dev2
Edwin
Edwin
Re: The way forward
Thanks a lot. Can't wait to learn more.
Re: The way forward
Ok i just finshed a lot of tutorials, explaining everything about platformio and github.
They are at the bottom of this page: http://www.letscontrolit.com/wiki/index ... evelopment
Re: The way forward
In the meanwhile i also fixed building in Arduino IDE again and updated the wiki.
Use at least v2.0.0-dev7 and the changes i made here: https://www.letscontrolit.com/wiki/inde ... are_Upload
Re: The way forward
Hey all
First of all, thanks to Edwin for jumping in. We sure need to keep this going as it has been such a fun platform to play with and use. I've been using this with OpenHAB for quite a while now, building addons and automating a lot of the stuff at home like my garage door, lights, security system, pool, spa etc just to name a few.
Like most of the members, I'm not a big time programmer, but can definitely help with testing, debugging and managing wiki. Do let me know know how I can help.
Cheers!
Benny
Cheers!
Benny
