Sonde THGR810 difficilement décodée
French support forum, post can be done in French, answers will either be in French or in English.
Moderators: Voyager, BertB, rtenklooster, Stuntteam, Deennoo
lesommer35
#1 Post by lesommer35 » 15 Mar 2017, 11:18
Bonjour,
J'ai un souci avec mes sondes THGR810. Elles sont très difficilement décodées par mon RFLink (Arduino Mega 2560 Mini + récepteur RXB6).
Ci dessous, un paquets reçu d'une des mes sondes non décodé :
2017-03-15 11:00:21 - 20;BE;DEBUG;Pulses=172;
Pulses(uSec)=240,90,690,270,480,330,390,390,390,420,360,420,360,420,360,420,330,450,360,450,330,450,330,450,330,450,330,450,330,480,330,510,300,510,270,480,330,510,270,480,300,510,240,480,300,480,300,480,300,960,810,960,810,480,300,480,300,480,300,510,300,960,300,480,300,540,720,960,780,990,270,480,300,510,300,480,750,1020,270,510,750,1050,210,540,720,570,210,1050,240,570,690,1110,660,630,120,630,180,1110,150,630,150,630,150,630,150,630,150,660,600,1140,150,660,120,660,120,690,90,690,570,1200,90,660,120,660,150,630,150,660,120,660,120,660,600,1140,120,660,120,690,120,660,600,1140,150,630,150,660,600,1140,150,660,150,660,630,1140,150,630,150,630,630,1110,180,630,150,630,630,1110,150,630,630,1110,660,6990;
Température=20.8°C / Humidité=42%
Et voici un paquet correctement décodé :
2017-03-15 11:15:06 - 20;92;DEBUG;Pulses=172;
Pulses(uSec)=390,150,480,300,480,300,450,330,450,330,450,330,420,360,420,360,420,390,390,360,420,360,420,360,420,360,420,390,390,390,390,420,360,390,390,420,360,420,390,390,390,420,360,420,390,420,330,870,900,870,870,420,360,390,390,390,360,450,360,900,360,390,390,420,840,900,840,930,390,420,360,420,360,450,810,930,330,450,810,930,330,450,810,480,270,960,330,450,780,960,810,480,300,480,330,960,330,450,330,480,330,420,360,450,810,960,330,450,330,450,330,450,360,450,330,420,810,960,330,450,330,450,330,450,330,480,300,480,300,450,330,480,300,450,330,450,330,450,330,480,780,960,330,450,330,480,330,450,780,990,780,990,300,480,300,510,270,510,750,1020,270,510,750,1050,210,540,240,540,240,570,720,6990;
20;93;Oregon TempHygro;ID=222017-03-15 11:15:07 - 8D3;TEMP=00cc;HUM=40;HSTATUS=2;BAT=OK;
Qu'est ce qui gène RFLink pour décoder le premier paquet ?
Merci
Stuntteam
Site Beheer
Re: Sonde THGR810 difficilement décodée
#2 Post by Stuntteam » 15 Mar 2017, 11:28
The first packet is probably a bad copy/paste.. check the end..
110,150,630,630,1110,62017-03-15 11:00:22 - 60,6990;
can you log some more packets that are skipped?
post them here or send them via email to frankzirrone@gmail.com
lesommer35
#3 Post by lesommer35 » 15 Mar 2017, 11:55
I corrected the first packet
I activated "timestamps" in RFLink Loader and sometimes timestamps are inserted in the middle of the packets.
Below a full log of packets (about 5 minutes).
In the first part, the sensor is at about 3 meters => not decoded.
In the second part, the sensor is at about 10 centimeters => decoded.
I have a "Xiron" temperature sensor perfectly decoded at about 10 meters through walls.
20;00;Nodo RadioFrequencyLink - RFLink Gateway V1.1 - R46;
10;version;
20;01;VER=1.1;REV=46;BUILD=0c;
10;status;
20;02;STATUS;setRF433=ON;setNodoNRF=OFF;setMilight=OFF;setLivingColors=OFF;setAnsluta=OFF;setGPIO=OFF;setBLE=OFF;setMysensors=OFF;
10;rfdebug=on;
20;03;RFDEBUG=ON;
10;rfudebug=on;
20;04;RFUDEBUG=ON;
20;05;DEBUG;Pulses=35;Pulses(uSec)=270,420,360,480,300,480,330,510,270,510,270,420,360,450,300,480,360,390,360,480,270,450,360,450,330,480,300,510,300,450,330,510,330,450,150;
20;06;DEBUG;Pulses=66;Pulses(uSec)=480,3930,420,3900,420,1860,420,3930,420,1830,390,1860,390,3960,390,1860,360,3960,360,1890,360,3960,390,1860,360,3960,390,3930,390,3960,360,1890,360,1920,330,1920,360,1890,330,1920,330,1920,300,3990,330,3990,330,1920,330,3990,330,3990,330,1920,330,1920,330,1920,330,3990,330,3990,330,4110,330,6990;
20;07;DEBUG;Pulses=48;Pulses(uSec)=420,1800,330,3750,360,1800,360,3960,360,3960,360,3960,390,1860,360,1890,360,1890,360,1890,360,1890,360,1890,360,3960,360,3960,360,1890,360,3960,390,3960,390,1860,390,1860,360,1890,360,3960,390,3960,390,4050,390,6990;
20;08;DEBUG;Pulses=58;Pulses(uSec)=450,1770,360,1770,360,3750,360,1860,390,3930,390,1860,360,3960,390,1860,360,3960,390,3930,390,3960,390,1860,390,1860,360,1860,390,1860,390,1890,360,1890,360,3960,390,3960,390,1860,360,3960,390,3960,390,1860,390,1860,390,1860,390,3960,390,3930,390,4050,390,6990;
20;09;DEBUG;Pulses=52;Pulses(uSec)=450,1770,360,3750,360,1770,390,3960,390,1860,390,3930,390,3930,390,3930,390,1860,390,1860,390,1860,390,1890,360,1860,390,1890,360,3960,390,3960,390,1890,360,3930,390,3930,390,1860,390,1890,390,1890,360,3960,390,3930,390,4080,390,6990;
20;0A;DEBUG;Pulses=54;Pulses(uSec)=420,3720,390,1740,390,3870,390,1860,390,3930,390,1860,390,3930,390,3930,390,3930,390,1860,360,1860,390,1860,390,1860,390,1860,360,1890,360,3960,390,3930,420,1830,390,3930,390,3930,390,1860,390,1890,390,1860,360,3930,390,3930,390,4050,420,6990;
20;0B;DEBUG;Pulses=54;Pulses(uSec)=450,3720,390,1740,360,3780,420,1860,390,3930,390,1860,360,3960,390,3930,390,3960,390,1860,390,1860,390,1860,390,1890,360,1890,360,1860,390,3960,360,3960,390,1860,390,3930,390,3960,390,1860,390,1890,360,1860,390,3930,390,3930,390,4050,390,6990;
20;0C;DEBUG;Pulses=38;Pulses(uSec)=420,3750,390,1740,390,3750,390,1860,390,3930,390,1860,390,3930,390,3930,390,3930,420,1830,390,1860,390,1860,390,1860,390,1860,360,1890,360,3960,390,3930,390,1860,390,3810;
20;0D;DEBUG;Pulses=62;Pulses(uSec)=480,1830,390,3930,390,1860,390,1860,390,3930,390,1890,360,3960,360,1860,390,3960,360,1890,390,3960,360,3960,360,3960,360,1890,360,1890,330,1950,330,1920,330,1920,330,1920,330,3990,330,3990,360,1890,330,3990,360,3990,330,1920,330,1920,330,1890,360,3990,330,3990,360,4080,360,6990;
20;0E;DEBUG;Pulses=50;Pulses(uSec)=450,3750,330,1800,360,3810,390,1860,360,3960,390,3930,390,3930,390,1890,360,1890,390,1890,360,1890,360,1890,330,1920,360,3930,390,3960,390,1860,390,3960,390,3930,390,1890,360,1860,360,1890,360,3960,360,3960,390,4080,390,6780;
20;0F;DEBUG;Pulses=56;Pulses(uSec)=450,1770,360,3750,390,1740,360,3930,420,1830,390,3930,390,1860,390,3960,390,3930,390,3930,390,1860,390,1860,360,1890,360,1860,390,1890,360,1860,360,3960,390,3960,360,1860,390,3960,390,3930,390,1860,390,1890,360,1890,360,3960,390,3930,390,4050,390,6990;
20;10;DEBUG;Pulses=52;Pulses(uSec)=450,1770,360,3750,360,1860,360,3960,390,1860,390,3930,420,3930,390,3930,420,1860,390,1890,360,1860,390,1860,360,1860,390,1860,360,3960,390,3930,390,1860,390,3930,390,3930,390,1860,360,1890,360,1890,360,3930,390,3930,390,4050,390,6990;
20;11;DEBUG;Pulses=54;Pulses(uSec)=420,3750,360,1770,360,3840,390,1860,390,3930,420,1860,360,3960,390,3930,390,3930,390,1860,390,1860,390,1860,390,1860,360,1890,360,1860,360,3990,360,3930,390,1860,390,3930,390,3960,390,1860,390,1860,360,1860,390,3960,390,3960,390,3990,450,6990;
20;12;DEBUG;Pulses=54;Pulses(uSec)=420,3720,360,1770,360,3780,420,1860,390,3930,360,1860,390,3960,390,3930,390,3930,390,1860,360,1860,390,1860,390,1860,390,1860,390,1890,390,3930,390,3960,390,1860,390,3930,390,3930,390,1860,390,1860,360,1860,390,3960,360,3960,360,4080,390,6990;
20;13;DEBUG;Pulses=54;Pulses(uSec)=420,3750,360,1770,360,3780,390,1860,390,3930,390,1860,390,3930,390,3930,420,3900,390,1860,390,1860,390,1860,360,1890,390,1860,390,1860,360,3960,390,3960,390,1860,390,3930,420,3900,420,1860,360,1860,390,1890,360,3960,390,3960,390,4050,390,6990;
20;14;DEBUG;Pulses=101;Pulses(uSec)=270,270,480,330,570,210,450,360,390,390,420,360,390,390,390,420,360,420,360,420,360,420,360,420,360,420,360,420,360,420,360,450,330,420,360,420,360,450,330,420,360,420,360,450,330,450,330,900,870,930,840,420,330,450,330,420,360,450,360,900,360,420,390,390,840,930,840,930,330,450,330,450,330,450,810,960,300,480,810,960,300,480,780,510,270,990,270,510,720,1050,690,660,60,1170,30,1710,90,720,60,720,60;
20;15;DEBUG;Pulses=28;Pulses(uSec)=150,960,330,480,360,480,270,450,810,960,330,510,780,930,330,480,300,480,780,960,810,480,330,450,330,930,330,510;
20;16;DEBUG;Pulses=62;Pulses(uSec)=480,1830,420,3930,360,1890,390,1860,360,3960,390,1860,390,3930,390,1890,360,3960,360,1890,330,3990,330,3960,360,3960,360,1890,360,1890,330,1890,330,1920,330,1890,330,1920,330,4020,330,3990,330,1920,330,3990,330,3990,360,1890,330,1920,330,1920,330,3990,360,3960,360,4110,330,6990;
20;17;DEBUG;Pulses=50;Pulses(uSec)=420,3750,360,1800,330,3840,360,1860,390,3960,390,3960,360,3960,360,1890,360,1890,360,1890,360,1890,360,1890,360,1890,360,3960,360,3930,390,1860,390,3930,390,3960,390,1860,360,1860,360,1890,360,3960,390,3960,390,4050,390,6990;
20;18;DEBUG;Pulses=56;Pulses(uSec)=450,1770,360,3720,390,1770,390,3900,390,1860,390,3930,390,1890,360,3960,360,3960,360,3960,390,1860,360,1860,390,1860,360,1890,360,1890,390,1860,360,3960,390,3930,390,1860,360,3960,390,3960,390,1860,390,1860,360,1890,360,3960,390,3930,390,4080,390,6990;
20;19;DEBUG;Pulses=52;Pulses(uSec)=420,1770,360,3750,390,1830,390,3930,390,1860,390,3930,390,3930,420,3930,390,1860,390,1860,360,1890,390,1860,390,1860,360,1890,360,3960,390,3960,390,1860,390,3960,390,3930,390,1860,390,1890,360,1860,390,3960,390,3960,420,4020,390,6990;
20;1A;DEBUG;Pulses=54;Pulses(uSec)=420,3720,360,1770,360,3870,390,1860,390,3930,390,1860,390,3930,390,3930,390,3960,390,1860,420,1830,390,1860,360,1860,390,1890,360,1890,360,3930,390,3930,390,1860,390,3930,390,3930,420,1860,390,1890,360,1890,360,3960,390,3960,390,4020,420,4740;
20;1B;DEBUG;Pulses=56;Pulses(uSec)=300,1770,360,3720,390,1770,390,3870,390,1860,390,3930,390,1890,390,3930,390,3930,420,3930,420,1830,390,1860,360,1860,390,1860,390,1890,360,1890,360,3960,390,3960,390,1860,390,3930,390,3960,390,1860,360,1860,390,1890,390,3930,390,3930,390,4080,390,6990;
20;1C;DEBUG;Pulses=52;Pulses(uSec)=420,1770,390,3720,360,1860,390,3930,420,1860,390,3930,420,3930,390,3960,390,1860,390,1860,390,1890,360,1860,360,1890,360,1890,390,3930,390,3930,390,1860,390,3960,390,3930,390,1860,420,1860,360,1890,390,3960,390,3930,390,4050,420,6990;
20;1D;DEBUG;Pulses=26;Pulses(uSec)=450,30,360,330,420,360,420,390,360,450,330,480,300,450,330,510,270,480,330,420,330,510,300,510,270,510;
20;1E;DEBUG;Pulses=52;Pulses(uSec)=390,450,330,420,360,450,300,480,330,450,300,510,300,420,840,930,330,450,780,960,780,1020,750,960,330,450,810,480,300,480,330,960,330,450,360,480,300,450,780,930,360,420,810,930,330,450,390,390,840,930,810,510;
20;1F;DEBUG;Pulses=168;Pulses(uSec)=720,300,450,330,450,330,420,360,420,360,420,360,360,390,390,390,390,390,390,390,390,450,330,420,360,420,360,420,360,420,330,450,330,420,360,420,360,450,330,450,330,450,330,450,330,450,330,900,870,900,840,420,330,450,360,420,330,420,360,930,360,420,390,390,840,930,840,930,360,420,360,420,360,420,810,930,330,450,810,960,300,480,780,510,270,990,300,510,750,1020,720,570,180,1080,690,1110,180,630,150,630,270,1530,120,660,600,1140,150,660,630,660,120,1110,180,660,120,630,150,630,150,630,180,600,180,630,660,1080,180,600,210,570,210,600,180,600,660,1080,180,600,180,570,210,570,210,570,240,570,690,1080,210,570,210,570,210,600,690,1080,210,600,690,570,180,1080,210,570,720,1080,690,6990;
20;20;DEBUG;Pulses=62;Pulses(uSec)=450,1860,390,3930,390,1860,360,1890,360,3960,390,1860,360,3960,360,1890,330,3990,360,1890,330,3990,330,3990,360,3960,360,1860,360,1890,360,1890,330,1950,300,1950,330,1920,330,3990,330,3990,330,1920,330,3990,330,3990,330,1920,360,1890,330,1920,360,3960,390,3990,360,4080,360,6990;
20;21;DEBUG;Pulses=50;Pulses(uSec)=420,3750,330,1800,360,3810,390,1860,390,3960,390,3930,390,3960,360,1860,360,1890,360,1860,360,1890,360,1890,360,1890,360,3960,360,3960,390,1890,360,3960,390,3960,390,1860,390,1890,360,1860,360,3960,390,3960,390,4050,390,6990;
20;22;DEBUG;Pulses=48;Pulses(uSec)=450,1770,360,3930,390,1860,360,3960,420,1860,360,3960,390,3960,360,3930,390,1860,390,1860,390,1890,360,1860,390,1860,360,1860,360,3960,390,3930,390,1860,390,3930,390,3960,390,1860,390,1860,390,1860,390,3930,390,2310;
20;23;DEBUG;Pulses=64;Pulses(uSec)=450,3720,420,1740,390,3900,390,1830,420,1860,390,3930,390,1860,390,3930,390,1890,390,3930,390,1860,390,3930,390,3930,420,3930,390,1860,390,1860,390,1860,360,1890,390,1860,390,1890,390,3930,390,3930,390,1860,420,3930,390,3930,390,1830,390,1860,390,1890,390,3930,390,3930,390,4050,390,5250;
20;24;DEBUG;Pulses=48;Pulses(uSec)=450,1770,390,3810,390,1860,390,3930,390,3930,390,3930,390,1860,390,1860,390,1860,390,1860,390,1860,390,1860,390,3930,360,3960,390,1890,390,3930,390,3930,390,1860,390,1860,390,1860,360,3960,390,3930,420,4020,420,570;
20;25;DEBUG;Pulses=66;Pulses(uSec)=480,3930,420,3900,390,1860,390,3960,390,1860,360,1890,360,3960,390,1860,390,3930,360,1890,390,3930,390,1860,390,3960,390,3930,450,3900,390,1860,390,1860,390,1860,390,1860,390,1860,360,1890,360,3960,390,3930,390,1860,390,3930,390,3930,390,1860,390,1860,360,1890,360,3960,390,3930,420,4080,390,5100;
20;26;DEBUG;Pulses=34;Pulses(uSec)=390,360,480,300,390,390,420,360,390,420,330,480,330,420,330,480,300,510,300,510,270,420,330,510,270,540,240,510,270,600,180,480,300,510;
20;27;DEBUG;Pulses=36;Pulses(uSec)=750,510,300,450,300,990,360,420,780,510,270,990,330,450,300,480,780,960,330,480,270,480,330,450,330,480,330,480,270,480,300,480,300,510,300,450;
20;28;DEBUG;Pulses=40;Pulses(uSec)=360,420,330,420,300,420,750,930,300,420,750,900,300,480,270,480,780,930,780,510,270,480,300,960,300,450,360,450,300,480,300,480,300,480,390,390,810,960,780,6990;
20;29;DEBUG;Pulses=62;Pulses(uSec)=480,1860,420,3930,390,1860,390,1860,390,3930,390,1860,390,3960,360,1890,360,3960,360,1890,360,3960,360,3960,360,3960,360,1890,360,1890,360,1920,330,1920,330,1920,330,1950,300,3990,330,3990,330,1920,330,3990,330,3990,330,1920,330,1920,330,1920,330,3990,330,3990,330,4110,360,6990;
20;2A;DEBUG;Pulses=50;Pulses(uSec)=420,3750,330,1800,330,3840,390,1890,360,3960,360,3960,390,3930,360,1860,360,1890,360,1890,330,1890,360,1890,360,1890,390,3960,360,3930,360,1860,390,3960,360,3960,390,1860,390,1860,360,1890,360,3960,360,3960,390,4050,390,6660;
20;2B;DEBUG;Pulses=56;Pulses(uSec)=450,1740,360,3750,360,1770,360,3930,390,1860,390,3930,420,1860,390,3930,390,3930,390,3930,420,1860,420,1830,390,1860,390,1890,390,1860,390,1890,360,3960,390,3960,360,1890,360,3960,390,3930,390,1860,420,1860,390,1830,390,3960,390,3960,390,4050,420,6990;
20;2C;DEBUG;Pulses=52;Pulses(uSec)=420,1800,360,3750,360,1830,390,3960,390,1860,390,3930,420,3930,390,3930,420,1830,420,1860,390,1860,390,1860,390,1860,390,1860,360,3930,390,3930,390,1860,390,3930,390,3930,390,1890,390,1860,390,1860,390,3960,360,3960,390,4050,390,6990;
20;2D;DEBUG;Pulses=48;Pulses(uSec)=450,1860,390,3930,390,1860,390,3930,390,3930,420,3960,390,1830,390,1860,390,1860,360,1860,360,1890,390,1860,360,3960,390,3930,390,1860,390,3930,390,3960,420,1830,390,1890,390,1860,420,3930,390,3930,390,4050,420,3930;
20;2E;DEBUG;Pulses=58;Pulses(uSec)=480,1740,360,1770,360,3870,390,1860,390,3930,390,1860,390,3930,390,1860,390,3930,390,3930,420,3900,420,1860,390,1860,390,1860,390,1860,390,1860,390,1860,360,3930,390,3930,390,1860,390,3930,390,3930,390,1860,390,1860,390,1860,390,3930,390,3960,390,4050,420,6990;
20;2F;DEBUG;Pulses=52;Pulses(uSec)=450,1770,360,3750,360,1770,390,3930,390,1860,420,3930,390,3930,390,3930,390,1860,420,1860,360,1860,390,1860,390,1860,360,1890,360,3960,390,3930,390,1860,390,3930,390,3930,390,1860,390,1890,390,1860,390,3930,390,3930,450,4020,390,5190;
20;30;DEBUG;Pulses=168;Pulses(uSec)=660,330,480,300,450,330,450,360,420,360,390,390,390,390,390,390,390,390,390,420,360,420,390,420,390,420,360,420,360,420,360,450,330,420,360,420,360,420,360,420,360,420,360,420,360,450,330,900,870,900,870,420,360,450,360,420,360,420,360,930,330,420,360,390,840,930,840,930,330,450,330,450,330,450,840,930,330,420,810,930,330,480,780,510,300,990,300,480,780,990,750,540,240,1020,750,1020,240,540,240,570,720,1080,210,570,690,1080,180,570,660,630,150,1110,150,630,150,600,180,600,180,630,150,630,150,630,630,1110,150,630,150,630,150,630,180,600,660,1110,150,600,180,600,210,570,210,600,180,600,660,1080,210,600,210,570,210,600,660,1080,210,600,690,600,180,1080,210,600,660,1080,690,6990;
20;31;DEBUG;Pulses=62;Pulses(uSec)=480,1860,390,3930,390,1860,390,1860,390,3930,390,1890,390,3960,360,1860,360,3960,390,1890,360,3960,360,3960,360,3990,360,1890,360,1890,360,1890,330,1950,300,1950,300,1950,300,4020,300,4020,330,1950,300,4020,330,3990,330,1920,330,1920,300,1920,330,3990,330,3990,360,4110,330,6990;
20;32;DEBUG;Pulses=38;Pulses(uSec)=420,3720,360,1800,330,3840,390,1860,390,3930,390,3930,390,3930,390,1860,390,1860,360,1890,360,1860,390,1860,390,1860,360,3960,390,3930,420,1830,420,3900,390,3930,390,930;
20;33;DEBUG;Pulses=36;Pulses(uSec)=450,1860,360,1890,390,1860,360,1860,390,1890,360,1890,360,3960,420,3930,360,1890,360,3960,390,3960,390,1860,360,1860,390,1860,390,3960,360,3960,390,4050,390,6990;
20;34;DEBUG;Pulses=62;Pulses(uSec)=450,1770,360,3750,390,1830,390,1860,390,3930,390,1860,390,3960,390,1860,360,3960,390,1860,390,3960,390,3960,360,3960,390,1860,390,1860,360,1890,360,1890,360,1890,360,1890,360,3960,390,3930,390,1860,360,3960,360,3960,390,1860,390,1860,360,1860,390,3930,390,3930,360,4080,390,5460;
20;35;DEBUG;Pulses=50;Pulses(uSec)=450,3750,360,1770,360,3900,360,1860,390,3930,420,3930,420,3930,390,1860,390,1860,390,1860,390,1860,360,1860,390,1890,360,3960,390,3930,390,1860,390,3960,390,3960,390,1860,390,1860,390,1860,390,3960,390,3930,360,3990,480,750;
20;36;DEBUG;Pulses=40;Pulses(uSec)=450,3930,420,3930,390,1860,390,1860,390,1860,390,1860,390,1860,390,1890,390,3900,420,3930,420,1860,390,3930,390,3930,390,1860,390,1860,390,1860,390,3930,390,3930,390,4080,390,2520;
20;37;DEBUG;Pulses=62;Pulses(uSec)=480,1710,360,3750,390,1860,390,1860,390,3930,390,1860,390,3930,390,1860,390,3930,390,1860,390,3930,390,3930,390,3930,390,1860,390,1860,390,1860,390,1860,390,1860,390,1860,360,3960,390,3960,390,1860,390,3930,390,3930,390,1860,390,1860,390,1860,390,3960,390,3930,360,4080,390,6990;
20;38;DEBUG;Pulses=29;Pulses(uSec)=480,420,360,420,330,450,330,420,330,480,300,510,300,420,330,540,240,540,270,540,240,480,300,600,210,480,300,510,30;
20;39;DEBUG;Pulses=136;Pulses(uSec)=90,900,300,450,720,480,240,960,270,480,240,480,300,450,270,480,720,930,300,480,300,480,300,480,300,450,810,480,300,480,300,960,360,420,810,540,240,990,300,450,300,480,780,960,300,480,330,480,300,480,300,480,300,480,300,480,300,480,300,480,330,450,300,480,300,450,360,480,300,480,300,450,330,480,300,480,330,450,810,960,330,480,810,960,780,960,780,990,330,510,750,480,300,480,330,930,360,450,330,450,330,450,810,960,360,450,810,960,300,450,330,480,810,960,780,480,270,480,300,930,330,450,360,510,270,450,330,450,360,450,330,450,780,990,810,6990;
20;3A;DEBUG;Pulses=72;Pulses(uSec)=720,1590,420,3900,420,3930,420,3840,510,3900,420,1830,420,3930,390,1860,420,1860,360,3960,390,1860,360,3960,360,1890,360,3960,390,1890,360,3960,360,3960,360,3960,360,1890,360,1890,360,1890,360,1920,330,1920,330,1920,330,4020,330,3990,360,1920,330,3990,360,3990,360,1920,330,1920,330,1920,330,3990,360,3990,360,4110,330,6990;
20;3B;DEBUG;Pulses=46;Pulses(uSec)=300,3780,360,1770,360,3750,390,3960,360,3960,390,1860,360,1860,360,1860,390,1860,360,1890,360,1890,360,3930,360,3960,390,1860,360,3960,390,3930,390,1890,360,1890,360,1890,360,3960,390,3960,390,4080,390,6990;
20;3C;DEBUG;Pulses=58;Pulses(uSec)=450,1740,360,1770,330,3810,390,1860,390,3960,390,1830,390,3930,390,1860,360,3960,360,3960,390,3930,390,1860,390,1890,360,1890,360,1890,360,1890,390,1860,360,3960,390,3960,390,1860,390,3930,390,3960,390,1860,390,1860,390,1860,360,3960,390,3960,390,4050,390,6990;
20;3D;DEBUG;Pulses=52;Pulses(uSec)=420,1770,360,3750,360,1770,390,3930,390,1860,360,3960,390,3930,390,3930,420,1860,390,1860,390,1890,390,1860,390,1860,360,1860,390,3960,390,3960,390,1860,360,3960,390,3930,390,1860,390,1860,390,1860,390,3930,390,3930,390,4050,420,6990;
20;3E;DEBUG;Pulses=54;Pulses(uSec)=450,3720,390,1740,360,3870,390,1860,360,3960,390,1860,390,3930,390,3930,390,3930,390,1860,390,1860,390,1860,390,1890,390,1860,360,1890,360,3930,420,3930,360,1860,390,3960,360,3930,390,1890,360,1890,360,1860,390,3930,390,3930,420,4020,420,5940;
20;3F;DEBUG;Pulses=54;Pulses(uSec)=420,3750,390,1770,360,3840,390,1860,420,3930,390,1860,390,3930,360,3960,420,3930,390,1860,390,1860,390,1890,360,1890,360,1860,390,1860,390,3930,390,3930,360,1890,390,3900,420,3930,420,1860,390,1860,390,1890,360,3960,390,3930,360,4080,390,6990;
20;40;DEBUG;Pulses=34;Pulses(uSec)=480,3930,390,1860,390,1860,390,1860,390,1860,390,1860,390,1860,390,3930,420,3930,420,1830,420,3900,390,3930,390,1860,390,1860,360,1860,390,3930,390,3330;
20;41;Oregon TempHygro;ID=228D3;TEMP=00c1;HUM=41;HSTATUS=0;BAT=OK;
20;42;DEBUG;Pulses=130;Pulses(uSec)=330,990,300,510,270,510,300,480,300,510,780,960,330,540,240,480,330,480,270,480,810,480,300,480,330,960,390,420,780,510,300,990,300,510,270,510,780,990,300,480,300,480,270,450,300,480,330,510,270,480,300,480,300,510,330,420,330,450,330,480,300,480,300,420,330,480,150,630,300,480,330,450,780,930,330,450,840,930,810,990,780,990,240,480,780,510,300,450,360,930,330,420,330,450,360,450,780,960,360,420,840,960,300,480,330,480,780,960,810,480,270,480,330,930,330,450,330,480,330,450,330,450,330,450,360,420,840,930,810,6990;
20;43;DEBUG;Pulses=62;Pulses(uSec)=480,1860,390,3930,420,1860,390,1860,390,3930,390,1890,360,3960,360,1890,360,3960,390,1860,360,3990,330,3960,360,3990,360,1890,360,1890,330,1920,360,1920,300,1920,330,1920,330,3990,330,3990,330,1920,330,4020,330,3960,390,1890,330,1920,330,1890,360,3990,360,3960,360,4080,360,6990;
20;44;DEBUG;Pulses=48;Pulses(uSec)=450,1770,390,3810,360,1890,360,3960,390,3960,390,3960,390,1860,420,1830,390,1860,360,1890,360,1890,390,1890,360,3960,360,3960,390,1830,390,3930,390,3960,390,1860,390,1860,390,1860,420,3900,390,3960,390,4050,390,6990;
20;45;DEBUG;Pulses=52;Pulses(uSec)=480,1740,390,1740,390,3720,360,1860,390,3930,420,1860,390,3960,390,1860,390,3930,420,3900,390,3930,420,1860,360,1860,420,1860,390,1860,390,1860,390,1890,360,3960,390,3930,390,1890,390,3930,420,3930,390,1860,390,1860,390,1860,360,2460;
20;46;DEBUG;Pulses=40;Pulses(uSec)=450,3930,420,1830,420,1830,420,3930,360,1860,390,3930,420,1860,390,3930,420,1860,390,3930,390,3930,420,3930,390,1860,390,1860,390,1890,390,1860,390,1860,360,1890,390,3930,390,2010;
20;47;DEBUG;Pulses=48;Pulses(uSec)=450,1860,390,3960,390,1860,390,3930,390,3930,420,3900,390,1860,360,1860,390,1860,360,1890,390,1860,330,1890,390,3930,390,3930,390,1860,390,3960,390,3960,390,1860,390,1860,360,1860,390,3930,420,3900,420,4050,420,210;
20;48;DEBUG;Pulses=26;Pulses(uSec)=480,1860,420,1860,420,1830,390,1860,360,1890,390,1890,360,3960,390,3930,390,1860,390,3930,360,3960,420,1860,390,1440;
20;49;DEBUG;Pulses=26;Pulses(uSec)=480,1860,420,1830,390,1890,390,1830,390,1860,390,1860,360,3960,390,3960,390,1830,390,3930,390,3930,390,1860,390,1020;
20;4A;Oregon TempHygro;ID=228D3;TEMP=00c2;HUM=41;HSTATUS=0;BAT=OK;
20;4B;DEBUG;Pulses=58;Pulses(uSec)=480,1860,390,1860,360,3960,390,1860,390,3930,390,1860,390,3960,360,1860,360,3960,360,3960,360,3960,360,1890,360,1890,360,1890,330,1920,330,1920,330,1950,300,3990,330,3990,330,1920,330,4020,330,3990,330,1920,330,1920,330,1920,330,3990,330,3990,330,4110,360,6990;
20;4C;DEBUG;Pulses=52;Pulses(uSec)=450,1770,360,3750,330,1800,360,3960,390,1860,390,3960,390,3930,360,3960,390,1890,360,1890,360,1860,390,1890,360,1890,360,1890,390,3930,390,3930,390,1860,390,3930,390,3930,390,1860,390,1860,390,1860,390,3960,420,3930,390,4080,390,6990;
20;4D;DEBUG;Pulses=45;Pulses(uSec)=30,930,240,60,1140,450,270,900,300,420,510,240,300,450,300,120,1050,900,360,480,300,450,660,120,330,480,1140,150,300,450,300,960,360,420,840,480,270,870,390,450,330,450,810,960,360;
20;4E;DEBUG;Pulses=38;Pulses(uSec)=30,30,1140,930,270,480,300,450,810,990,780,510,270,510,630,630,300,450,660,150,330,450,300,300,510,480,330,450,780,990,780,1860,360,3960,390,4080,390,6990;
20;4F;DEBUG;Pulses=44;Pulses(uSec)=450,1860,390,3930,390,3960,390,3930,420,1860,390,1860,390,1860,360,1890,360,1890,360,1890,360,3930,390,3960,390,1860,390,3930,390,3930,390,1860,390,1860,360,1890,360,3930,390,3930,390,4080,390,5430;
20;50;DEBUG;Pulses=60;Pulses(uSec)=450,3720,390,1740,390,1740,360,3930,390,1860,390,3930,390,1860,360,3960,420,1860,390,3930,390,3930,390,3930,420,1860,390,1860,360,1890,390,1860,360,1890,360,1890,360,3960,390,3960,390,1860,390,3960,390,3930,390,1860,390,1860,390,1860,390,3930,390,3930,390,4050,390,960;
20;51;DEBUG;Pulses=50;Pulses(uSec)=450,3660,450,1770,360,3840,390,1860,420,3930,390,1860,360,3960,390,3900,390,3930,420,1860,390,1860,390,1860,360,1860,390,1860,360,1860,390,3930,390,3960,390,1860,390,3960,390,3960,420,1830,390,1860,390,1860,360,3960,390,2550;
20;52;DEBUG;Pulses=58;Pulses(uSec)=450,1860,390,1860,360,3960,390,1860,390,3960,390,1860,390,3930,390,1860,390,3930,390,3960,390,3930,390,1860,390,1860,390,1860,390,1860,360,1890,360,1890,390,3930,390,3930,390,1860,360,3960,360,3930,390,1860,390,1860,390,1860,390,3930,390,3930,390,4050,390,6990;
Stuntteam
Site Beheer
#4 Post by Stuntteam » 15 Mar 2017, 12:00
Can you log with RFDEBUG=ON?
Do not use RFUdebug..
lesommer35
#5 Post by lesommer35 » 15 Mar 2017, 12:07
10;version;
10;status;
10;rfdebug=on;
20;03;RFDEBUG=ON;
20;04;DEBUG;Pulses=60;Pulses(uSec)=480,3900,420,1830,420,1830,390,3930,390,1860,390,1860,390,1860,360,3960,360,1890,360,3960,360,3960,390,3960,390,1890,330,1920,330,1920,330,1920,330,1920,330,1950,330,3990,330,3990,360,1920,330,3990,360,3960,360,1890,360,1890,360,3960,360,3960,390,3960,360,4080,390,6990;
20;05;DEBUG;Pulses=52;Pulses(uSec)=210,1770,360,1800,330,1770,360,3930,360,1890,360,3960,360,3960,390,3930,390,1890,360,1890,360,1890,390,1860,360,1890,390,1860,360,3960,360,3960,390,1860,390,3930,390,3930,390,1890,360,1860,390,3930,390,3960,390,3930,390,4050,390,6990;
20;06;DEBUG;Pulses=54;Pulses(uSec)=450,3750,390,1740,390,1860,390,1860,360,3930,390,1860,390,3930,390,3930,390,3930,390,1860,390,1860,390,1860,360,1860,390,1860,390,1860,390,3930,420,3930,420,1860,390,3960,420,3930,420,1830,390,1860,390,3930,420,3930,420,3930,420,4050,390,6990;
20;07;DEBUG;Pulses=54;Pulses(uSec)=420,3690,390,1740,390,1800,390,1860,390,3960,390,1860,390,3930,390,3960,390,3930,420,1860,360,1860,390,1860,390,1830,390,1860,390,1860,390,3960,390,3930,390,1860,360,3960,390,3930,390,1860,390,1890,390,3930,390,3930,390,3930,390,4080,390,6990;
20;08;DEBUG;Pulses=54;Pulses(uSec)=420,3720,390,1740,360,1800,390,1860,360,3960,390,1860,390,3930,390,3930,390,3930,390,1860,420,1860,390,1860,360,1890,390,1860,390,1860,390,3930,420,3930,390,1860,390,3930,390,3930,390,1860,390,1860,390,3930,390,3930,390,3930,390,4050,420,6990;
20;09;DEBUG;Pulses=54;Pulses(uSec)=420,3720,390,1770,360,1800,390,1860,390,3930,390,1860,390,3930,390,3930,390,3930,390,1860,390,1860,390,1860,390,1860,360,1890,360,1860,360,3930,390,3930,390,1860,390,3930,390,3930,390,1860,390,1860,390,3930,390,3930,390,3930,390,4050,390,6990;
20;0A;DEBUG;Pulses=54;Pulses(uSec)=420,3720,390,1740,390,1770,390,1860,390,3930,390,1860,390,3930,390,3930,390,3930,420,1860,390,1860,390,1860,390,1860,390,1860,390,1860,390,3930,390,3930,390,1860,390,3930,420,3930,390,1860,390,1860,390,3930,390,3930,390,3930,390,4050,420,6990;
20;0B;DEBUG;Pulses=172;Pulses(uSec)=3870,330,450,330,420,360,420,390,390,390,360,390,390,420,360,420,360,420,360,420,360,420,360,420,360,420,330,420,360,450,330,450,330,450,330,420,360,450,330,450,300,480,330,450,330,450,330,930,840,930,840,480,300,480,300,450,330,450,300,930,360,480,300,450,810,990,780,960,300,510,300,480,300,510,750,1050,240,540,600,1230,150,630,630,660,150,1110,180,630,660,1080,690,630,150,1080,210,600,180,600,180,600,210,600,180,600,180,600,660,600,150,1080,210,570,690,600,180,1050,210,600,210,540,240,570,210,570,210,570,240,540,240,570,210,570,210,570,240,540,240,570,210,570,720,1050,240,540,240,540,240,540,720,570,210,1050,720,570,180,1050,240,540,720,1050,720,1050,240,540,720,570,240,1020,750,540,240,6990;
20;0C;DEBUG;Pulses=190;Pulses(uSec)=540,240,450,360,420,390,420,390,390,390,390,420,360,420,360,480,330,450,300,510,300,450,300,510,270,510,270,540,270,480,270,510,270,480,300,510,300,510,300,480,300,510,270,480,300,990,750,1020,780,990,750,990,300,510,780,990,270,480,780,510,270,960,300,480,270,480,300,480,300,480,780,990,300,480,300,480,300,480,300,510,780,480,300,480,300,960,360,420,780,480,300,960,330,480,330,480,780,960,330,450,330,480,300,480,300,480,300,480,300,480,300,450,300,480,330,450,330,450,330,480,300,480,300,480,330,450,330,480,300,480,360,420,810,960,330,450,810,960,810,960,810,960,300,480,780,480,300,450,330,960,330,450,330,450,330,450,780,960,330,450,810,960,300,450,330,450,780,960,810,480,270,480,300,960,330,480,330,450,330,480,330,450,360,450,330,450,810,960,780,6990;
20;0D;DEBUG;Pulses=58;Pulses(uSec)=510,1830,390,1830,420,3930,390,1860,390,1860,360,1890,360,3960,360,1890,360,3960,360,3960,390,3960,360,1890,360,1890,330,1920,330,1920,330,1920,330,1920,330,3990,330,3990,360,1920,330,3990,330,3990,360,1890,330,1890,360,3990,360,3960,360,3960,390,4080,390,6990;
20;0E;DEBUG;Pulses=52;Pulses(uSec)=420,1770,360,1770,360,1800,360,3960,390,1860,390,3960,390,3930,390,3930,390,1860,390,1860,390,1890,360,1890,360,1890,360,1890,360,3960,390,3930,390,1860,390,3930,390,3960,390,1860,390,1860,360,3960,390,3930,390,3930,390,4050,390,6990;
20;0F;DEBUG;Pulses=54;Pulses(uSec)=420,3720,390,1770,390,1860,390,1860,390,3930,390,1860,390,3930,390,3930,390,3930,420,1860,390,1860,390,1860,390,1860,360,1860,390,1860,360,3930,390,3930,420,1860,390,3930,390,3930,390,1860,390,1860,390,3930,390,3930,420,3930,390,4020,420,6990;
20;10;DEBUG;Pulses=54;Pulses(uSec)=420,3720,360,1770,360,1800,390,1860,360,3960,420,1860,390,3930,390,3930,390,3930,390,1860,390,1860,390,1860,390,1860,390,1860,390,1860,390,3930,390,3930,420,1860,360,3930,420,3930,390,1860,390,1860,390,3930,390,3930,390,3930,420,4050,390,5550;
20;11;DEBUG;Pulses=54;Pulses(uSec)=450,3720,390,1740,360,1860,390,1860,390,3960,390,1860,390,3930,390,3930,420,3930,390,1860,390,1860,390,1860,390,1860,390,1860,390,1860,360,3930,390,3930,390,1860,390,3930,390,3930,390,1860,390,1860,390,3930,420,3930,390,3930,420,4020,390,6930;
20;12;DEBUG;Pulses=54;Pulses(uSec)=420,3750,390,1740,360,1800,390,1860,390,3930,420,1860,390,3930,390,3930,390,3930,420,1860,390,1860,390,1890,390,1860,360,1860,390,1860,360,3960,390,3960,390,1860,390,3930,420,3930,420,1860,390,1860,390,3930,390,3930,390,3930,390,4050,420,5460;
20;13;DEBUG;Pulses=54;Pulses(uSec)=450,3720,390,1770,360,1860,390,1860,390,3930,390,1860,390,3930,390,3930,420,3930,420,1830,390,1860,390,1860,390,1860,390,1890,360,1860,360,3960,390,3930,390,1860,390,3930,390,3930,420,1860,360,1860,390,3930,390,3930,390,3930,420,4050,390,5520;
20;14;DEBUG;Pulses=58;Pulses(uSec)=480,1830,390,1860,390,3930,390,1860,360,1890,390,1860,360,3960,390,1890,360,3990,360,3960,360,3960,360,1890,360,1890,360,1890,330,1920,330,1920,330,1920,330,3990,360,3990,330,1920,330,3990,330,3990,360,1920,330,1920,330,3990,360,3990,360,3990,360,4080,360,6990;
20;15;DEBUG;Pulses=52;Pulses(uSec)=420,1770,360,1770,330,1800,360,3960,390,1860,360,3930,420,3930,390,3930,390,1860,390,1860,390,1860,360,1890,360,1890,360,1890,360,3960,390,3930,390,1860,360,3960,390,3930,390,1860,390,1860,390,3930,390,3930,390,3930,390,4050,390,6990;
20;16;DEBUG;Pulses=54;Pulses(uSec)=450,3720,390,1740,390,1860,390,1860,390,3930,390,1860,390,3960,390,3930,390,3930,390,1860,390,1860,360,1860,390,1860,390,1860,360,1860,360,3960,390,3930,390,1860,390,3930,390,3930,420,1830,390,1860,390,3930,420,3930,390,3900,420,4080,390,6990;
20;17;DEBUG;Pulses=54;Pulses(uSec)=420,3750,390,1740,390,1770,390,1860,360,3960,390,1860,390,3930,390,3930,390,3930,390,1860,390,1860,390,1860,390,1860,390,1860,390,1860,360,3930,390,3930,390,1860,390,3930,390,3930,390,1860,390,1860,390,3930,390,3930,420,3930,390,4050,420,6990;
20;18;DEBUG;Pulses=52;Pulses(uSec)=420,3720,390,1770,360,1800,390,1860,390,3960,390,1860,390,3930,390,3930,390,3930,390,1860,360,1890,390,1860,390,1860,360,1860,390,1860,390,3930,390,3930,390,1860,390,3930,420,3930,390,1860,390,1860,390,3930,390,3930,420,3930,390,2220;
20;19;DEBUG;Pulses=60;Pulses(uSec)=480,3690,390,1740,390,1830,390,3930,420,1830,390,1860,390,1860,390,3930,390,1860,390,3930,390,3930,420,3930,390,1860,390,1860,390,1860,390,1860,390,1860,390,1860,390,3960,390,3930,390,1860,390,3930,390,3930,390,1860,390,1860,390,3930,390,3930,420,3930,390,4050,420,6990;
20;1A;DEBUG;Pulses=52;Pulses(uSec)=240,1740,390,1740,360,1770,360,3870,390,1860,390,3930,390,3930,390,3930,390,1860,390,1860,390,1860,390,1860,390,1860,390,1890,360,3930,390,3930,390,1860,390,3930,390,3930,390,1860,390,1860,390,3930,390,3930,420,3930,390,4050,420,6990;
20;1B;DEBUG;Pulses=194;Pulses(uSec)=1590,60,450,180,510,330,450,360,390,360,420,360,390,450,330,450,300,480,330,450,300,510,300,510,300,450,300,510,270,510,270,450,330,480,300,480,270,510,300,480,300,480,330,480,270,480,300,480,270,990,780,990,750,990,780,990,270,510,780,960,300,480,780,510,270,960,330,480,300,480,330,480,330,480,780,960,300,480,300,450,300,480,300,480,810,480,300,510,300,930,390,420,780,510,270,990,330,420,330,450,810,960,330,420,330,480,270,480,300,450,360,420,360,450,330,450,330,450,330,480,300,450,330,450,300,480,360,420,330,480,300,480,330,480,330,420,780,990,330,480,810,960,780,990,750,960,330,480,780,510,270,450,330,960,300,480,330,480,300,420,810,960,330,480,780,960,330,450,330,420,810,930,810,480,300,480,330,930,330,450,360,450,330,450,330,450,330,420,390,420,810,960,810,6990;
20;1C;DEBUG;Pulses=170;Pulses(uSec)=300,240,510,330,450,330,420,360,420,390,420,390,390,390,360,420,390,420,360,420,360,420,330,420,360,450,330,420,360,420,360,450,330,450,330,420,360,420,360,450,330,480,330,450,300,450,330,900,840,930,840,450,300,480,330,450,330,480,330,930,330,450,360,420,810,960,780,990,300,480,300,480,300,510,750,1020,240,540,690,1110,150,630,630,660,120,1140,180,630,630,1110,660,630,150,1110,150,600,180,600,180,600,660,600,150,600,180,1110,660,1080,180,600,660,600,180,1050,240,570,210,570,210,570,240,540,240,570,210,570,210,570,210,570,210,570,210,570,240,570,210,570,690,1050,210,570,210,570,210,570,720,1050,240,540,720,570,210,1050,240,570,720,1020,750,540,240,1020,720,1050,240,540,240,540,240,6990;
20;1D;DEBUG;Pulses=58;Pulses(uSec)=480,1860,420,1830,390,3930,390,1860,390,1860,360,1890,360,3960,360,1890,360,3960,360,3960,360,3990,360,1890,360,1890,360,1890,330,1920,330,1920,330,1950,300,4020,330,3990,330,1890,330,3990,360,3990,360,1920,330,1920,330,3990,330,3990,360,3990,330,4110,360,6990;
20;1E;DEBUG;Pulses=52;Pulses(uSec)=420,1770,360,1770,330,1800,390,3930,390,1860,360,3960,390,3960,390,3960,360,1860,390,1860,390,1860,390,1860,390,1860,360,1890,360,3960,390,3960,390,1860,390,3960,390,3930,390,1860,360,1890,390,3930,390,3930,390,3930,420,4050,390,6960;
20;1F;DEBUG;Pulses=54;Pulses(uSec)=450,3720,390,1770,360,1860,390,1860,390,3930,390,1860,390,3930,390,3930,420,3930,420,1860,390,1860,390,1860,390,1860,390,1860,390,1860,390,3930,390,3930,390,1860,390,3930,390,3930,390,1860,390,1860,420,3930,390,3930,390,3930,390,4050,420,6990;
20;20;DEBUG;Pulses=54;Pulses(uSec)=420,3720,390,1770,390,1770,390,1860,390,3930,390,1860,390,3930,390,3930,390,3930,390,1860,390,1860,360,1890,390,1860,390,1860,390,1860,390,3960,390,3930,390,1860,390,3960,420,3900,390,1860,390,1860,360,3960,390,3930,390,3930,390,4050,420,6990;
20;21;DEBUG;Pulses=54;Pulses(uSec)=420,3720,390,1740,360,1800,390,1860,390,3930,420,1860,390,3930,390,3930,390,3930,390,1860,390,1860,390,1860,390,1860,390,1860,360,1860,390,3960,360,3960,390,1860,390,3930,390,3930,390,1860,390,1860,360,3930,420,3930,390,3930,390,4050,390,6990;
20;22;DEBUG;Pulses=54;Pulses(uSec)=420,3720,390,1770,360,1800,390,1860,390,3930,390,1860,390,3930,390,3930,390,3930,390,1860,390,1860,390,1860,390,1860,390,1860,390,1860,390,3930,390,3930,390,1860,390,3930,390,3930,390,1860,390,1860,390,3930,390,3930,390,3930,390,4050,420,6990;
20;23;DEBUG;Pulses=54;Pulses(uSec)=420,3720,360,1770,360,1800,390,1860,390,3930,390,1860,390,3930,390,3930,390,3930,420,1860,420,1860,390,1860,390,1860,390,1890,360,1860,390,3930,390,3930,420,1860,390,3930,390,3930,420,1860,360,1860,390,3930,390,3930,390,3930,390,4050,390,6990;
20;24;DEBUG;Pulses=190;Pulses(uSec)=570,270,420,360,390,420,360,390,390,420,360,450,330,420,360,480,300,510,300,480,300,450,330,510,270,510,270,480,300,480,300,510,270,480,300,480,300,480,300,510,300,480,300,480,300,960,780,990,780,990,780,990,270,480,780,990,300,510,750,510,270,960,300,510,270,480,330,480,300,510,780,990,300,480,300,480,300,480,300,480,780,510,300,450,330,990,360,390,810,510,270,960,300,450,300,510,780,960,330,450,300,480,330,480,300,480,330,480,300,480,300,480,300,510,330,450,300,450,300,510,300,480,330,450,330,450,330,450,330,480,360,420,810,960,330,450,810,990,780,960,810,960,300,480,780,480,300,450,330,960,330,480,330,450,330,450,780,960,330,450,810,960,330,480,330,480,780,960,810,480,300,450,360,930,300,480,330,480,330,450,330,450,300,480,330,450,810,960,780,6990;
20;25;DEBUG;Pulses=56;Pulses(uSec)=450,1860,390,3930,390,1860,360,1860,390,1860,360,3960,390,1890,330,3990,360,3990,330,3990,360,1920,360,1890,360,1890,360,1890,360,1890,330,1890,330,3960,360,3960,360,1890,360,3960,360,3960,390,1860,360,1920,360,3960,390,3930,360,3960,390,4050,390,6990;
20;26;DEBUG;Pulses=52;Pulses(uSec)=450,1740,360,1770,360,1860,390,3960,390,1860,390,3930,390,3930,390,3930,420,1860,390,1860,390,1860,390,1860,390,1860,390,1860,360,3960,390,3930,390,1860,390,3930,390,3930,390,1860,390,1860,390,3930,390,3930,390,3930,420,4050,420,5370;
20;27;DEBUG;Pulses=36;Pulses(uSec)=450,1860,390,1860,390,1860,390,1860,390,1860,390,1860,390,3930,390,3900,390,1860,390,3930,420,3930,420,1860,390,1860,390,3930,390,3930,390,3930,420,3990,420,840;
20;28;DEBUG;Pulses=34;Pulses(uSec)=420,1860,390,1860,420,1830,390,1860,390,1860,390,3930,390,3930,390,1860,390,3930,420,3900,420,1860,390,1860,390,3960,390,3930,390,3900,420,4020,420,5010;
20;29;DEBUG;Pulses=56;Pulses(uSec)=480,1860,390,1860,390,3930,420,1860,390,1860,420,1860,390,3930,390,1860,390,3930,390,3930,420,3930,420,1830,390,1860,390,1860,390,1860,390,1860,390,1860,390,3930,390,3930,390,1860,390,3930,420,3900,420,1830,390,1860,390,3960,390,3930,390,3930,420,3780;
20;2A;DEBUG;Pulses=56;Pulses(uSec)=450,1740,390,1770,360,3840,390,1860,420,1860,390,1860,390,3960,390,1860,390,3930,420,3930,390,3930,420,1830,390,1860,390,1830,420,1830,390,1860,390,1860,390,3930,390,3930,390,1860,390,3960,390,3930,420,1830,390,1860,390,3930,390,3930,420,3930,420,3900;
20;2B;DEBUG;Pulses=44;Pulses(uSec)=450,1860,390,3930,390,1860,390,3930,420,3930,420,3930,420,1830,390,1860,390,1860,390,1860,390,1860,390,1860,390,3900,420,3930,420,1860,390,3930,390,3930,420,1860,390,1860,390,3930,390,3930,390,3330;
20;2C;DEBUG;Pulses=168;Pulses(uSec)=1200,270,510,360,420,360,390,360,420,360,390,390,390,390,390,420,360,420,330,450,330,420,360,420,360,420,330,450,360,450,330,450,330,450,330,450,330,450,330,450,300,480,300,450,330,930,810,930,840,480,300,510,300,480,300,510,270,960,330,480,300,480,780,960,780,990,300,480,300,480,300,480,780,990,270,510,780,990,270,540,750,540,240,1020,270,510,720,1020,750,570,210,1050,240,540,240,540,240,540,750,540,240,540,240,1020,720,1050,240,540,720,570,240,1020,240,510,270,540,240,540,240,540,240,540,240,540,240,540,240,600,210,510,270,540,240,540,240,540,720,1050,240,540,270,540,240,540,690,1050,240,540,720,570,210,1050,210,570,690,1050,720,570,210,1020,720,1080,180,600,210,540,240,6990;
20;2D;Oregon TempHygro;ID=228D3;TEMP=00c5;HUM=40;HSTATUS=2;BAT=OK;
20;2E;DEBUG;Pulses=29;Pulses(uSec)=450,180,420,360,420,390,420,420,330,450,330,450,330,510,270,480,300,450,330,480,300,510,270,480,300,480,270,510,30;
20;2F;DEBUG;Pulses=40;Pulses(uSec)=360,420,720,900,300,450,720,510,240,960,270,420,300,420,300,420,330,450,810,990,270,510,300,480,300,480,300,510,780,510,300,450,330,960,390,390,840,450,300,960;
20;30;DEBUG;Pulses=54;Pulses(uSec)=750,960,720,900,780,900,300,420,780,420,300,450,270,930,330,450,360,450,330,420,840,960,360,450,810,960,330,450,330,450,810,930,840,510,270,480,300,960,330,450,330,450,330,420,330,450,300,480,360,420,840,900,810,5490;
20;31;DEBUG;Pulses=56;Pulses(uSec)=480,1860,390,3960,390,1860,390,1860,360,1890,360,3990,360,1890,330,3990,330,3990,360,3990,360,1890,360,1920,330,1920,300,1920,330,1920,330,1890,330,3990,360,3990,330,1920,360,3990,330,3960,360,1860,360,1890,360,3960,360,3960,360,3960,360,4110,390,5550;
20;32;DEBUG;Pulses=54;Pulses(uSec)=240,3750,330,1800,360,1800,390,1860,360,3960,360,1860,360,3960,390,3930,390,3930,390,1860,390,1860,360,1860,390,1860,360,1890,360,1890,360,3960,390,3930,390,1860,360,3960,390,3960,390,1890,360,1860,360,3960,390,3960,390,3930,390,4050,390,6870;
20;33;DEBUG;Pulses=54;Pulses(uSec)=420,3750,360,1770,330,1830,390,1860,360,3960,390,1860,390,3960,390,3930,390,3930,390,1860,360,1860,390,1890,360,1860,360,1860,360,1890,360,3960,390,3960,390,1860,390,3960,360,3930,390,1860,390,1890,360,3930,390,3930,390,3930,390,4050,390,6990;
20;34;DEBUG;Pulses=54;Pulses(uSec)=420,3720,390,1740,360,1800,360,1860,390,3960,390,1860,390,3960,390,3930,390,3930,390,1860,360,1860,390,1860,360,1890,360,1890,360,1890,360,3960,390,3930,390,1860,390,3930,390,3930,390,1860,390,1860,390,3930,390,3930,390,3930,390,4050,420,6990;
20;35;DEBUG;Pulses=54;Pulses(uSec)=420,3750,360,1770,360,1800,390,1860,390,3930,390,1890,360,3960,390,3930,390,3960,390,1860,390,1860,360,1890,390,1860,360,1890,360,1890,390,3930,360,3960,390,1860,390,3930,390,3930,390,1860,390,1860,360,3930,390,3930,390,3930,390,4050,390,6990;
20;36;DEBUG;Pulses=54;Pulses(uSec)=420,3720,360,1770,330,1800,390,1860,390,3930,390,1860,390,3930,390,3930,420,3930,390,1860,390,1860,390,1860,360,1860,390,1860,390,1860,360,3960,390,3960,390,1860,390,3930,390,3930,360,1890,360,1860,390,3930,390,3930,390,3930,390,4050,420,6990;
20;37;DEBUG;Pulses=54;Pulses(uSec)=420,3720,390,1740,390,1800,360,1860,390,3930,390,1860,390,3930,390,3930,390,3960,390,1860,390,1860,390,1860,390,1890,360,1860,390,1860,360,3960,390,3930,390,1860,360,3930,390,3930,390,1860,390,1860,390,3960,390,3930,390,3960,390,4050,390,5460;
20;38;DEBUG;Pulses=170;Pulses(uSec)=420,60,480,300,480,330,420,360,420,390,390,390,360,390,360,420,390,390,390,450,330,420,360,420,360,450,330,450,300,480,330,450,330,480,300,450,330,450,330,450,300,480,300,480,300,480,300,960,810,930,840,480,300,480,300,480,300,480,270,960,330,450,330,480,780,960,810,990,270,480,300,510,270,510,720,1020,240,510,750,990,270,510,750,540,240,1020,240,510,750,1050,720,540,210,1050,270,540,240,570,240,540,720,570,240,570,180,1020,750,1020,270,510,720,540,240,1020,240,510,270,540,240,540,270,510,270,540,240,540,240,570,210,540,240,540,240,570,210,570,240,570,690,1050,240,540,240,540,240,540,720,1050,240,570,720,570,210,1050,210,540,720,1080,690,570,210,1050,690,1080,240,600,180,570,210,6990;
20;39;Oregon TempHygro;ID=228D3;TEMP=00c5;HUM=40;HSTATUS=2;BAT=OK;
20;3A;DEBUG;Pulses=62;Pulses(uSec)=510,1830,420,3930,420,1830,390,1860,390,3930,390,1860,360,1890,360,1920,330,3990,360,1890,330,3990,360,3960,360,3990,330,1890,360,1890,330,1920,330,1920,330,1950,300,1950,330,3990,330,3990,330,1920,330,3990,330,3990,360,1920,330,1920,360,3960,360,3960,360,3960,360,4110,360,6990;
20;3B;DEBUG;Pulses=50;Pulses(uSec)=450,1770,330,1800,330,3840,360,1860,390,3960,360,3930,390,3960,390,1890,390,1860,360,1890,360,1860,360,1920,390,1860,360,3960,360,3960,390,1890,390,3930,360,3960,390,1890,360,1860,360,3960,390,3960,390,3930,390,4050,390,6990;
20;3C;DEBUG;Pulses=40;Pulses(uSec)=420,1770,360,3750,360,1830,390,1860,390,1860,390,3930,390,1860,390,3930,390,3930,390,3930,420,1860,390,1860,390,1860,390,1860,390,1890,360,1860,390,3960,390,3900,390,1890,390,2700;
20;3D;DEBUG;Pulses=38;Pulses(uSec)=450,3930,420,1860,390,1860,360,1860,390,1860,390,1890,360,1860,360,3960,390,3930,390,1860,390,3930,390,3930,390,1860,390,1860,360,3960,420,3930,390,3930,390,4050,420,6300;
20;3E;DEBUG;Pulses=48;Pulses(uSec)=450,1890,360,3960,390,1860,390,3930,390,3930,420,3930,360,1890,390,1860,390,1860,390,1860,390,1860,390,1860,360,3930,390,3930,390,1860,390,3930,390,3930,390,1860,390,1860,390,3930,390,3960,390,3930,390,4050,420,4800;
20;3F;DEBUG;Pulses=58;Pulses(uSec)=420,1740,390,1740,390,3840,390,1860,390,1860,390,1860,390,3930,390,1890,360,3960,390,3930,390,3930,390,1890,390,1860,390,1890,360,1860,390,1860,360,1890,390,3930,390,3960,390,1890,390,3930,390,3930,420,1860,360,1860,390,3930,390,3930,420,3930,420,4020,420,5220;
20;40;DEBUG;Pulses=52;Pulses(uSec)=450,1740,390,1770,360,1860,390,3960,390,1890,390,3930,420,3900,420,3930,420,1830,420,1860,390,1860,390,1860,390,1890,360,1890,390,3930,390,3930,390,1860,390,3930,390,3930,420,1830,420,1860,390,3930,420,3930,390,3930,420,4050,390,990;
20;41;DEBUG;Pulses=24;Pulses(uSec)=420,420,390,390,360,420,360,420,360,450,330,450,300,480,300,480,300,510,270,510,270,510,270,510;
20;42;DEBUG;Pulses=142;Pulses(uSec)=420,930,720,930,270,450,750,930,270,480,750,450,240,960,300,510,300,480,300,480,300,480,780,960,330,480,300,480,300,480,300,480,810,480,300,510,270,990,360,420,780,510,270,960,330,450,300,510,780,990,300,480,300,480,300,450,300,480,330,480,300,450,300,450,330,480,330,480,300,480,300,450,330,480,330,450,330,480,300,480,300,450,360,450,810,930,330,480,810,960,780,960,810,960,330,480,780,510,270,450,330,960,300,480,330,420,330,480,780,960,330,480,780,960,300,480,330,510,750,960,810,480,300,450,330,960,300,480,330,450,300,480,300,480,300,450,330,480,810,960,780,6990;
Stuntteam
Site Beheer
#6 Post by Stuntteam » 15 Mar 2017, 16:57
check your email..
dugolf
#7 Post by dugolf » 29 Oct 2017, 19:18
Domoticz V3.8153 + Rflink version R46
I use from osv3_dock_sensor.zip (j'utilise de l'archive osv3_dock_sensor.zip)
- osv3_thgr810_sensor.h
- osv3_thgr810_sensor.cpp
to simulate Oregon Thgr810 sensor (pour simuler un capteur Oregon Thgr810)
and i have the same problem (et j'ai le même problème)
Transmission distance is low and random decoding (La distance de transmission est faible et le décodage aléatoire)
