ESP Easy Mega
Forum rules
Re: ESP Easy Mega
I encountered a new error it seems ..
After some tweaking within the Framed Oled part, mainly on positioning and sensor names
i got several flash error messages in the head of the html-response of the Esp.
Hooked up the usb cable into something serial and found that i have to finish that tomorrow ..
FS : Daily flash write rate exceeded!
Good that its there, but did not encounter it untill now,
what is the maxvalue flash-savings parameter Martinus ?
Re: ESP Easy Mega
NietGiftig wrote:The name mega puts you on the wrong foot.anarro wrote:Hi,
I have a littel confusion,
It is a normal esp8266, but with more memory then the esp8266/01
so a wemos/nodemcu or any esp8266 with more memory (4mb recommended) is the way to go.
see the very first line in this topic
Experimenting with an ESP Easy Mega edition (so only for modules with larger flash chips)
Thank you very much for clarifying it, all I have are NodeMCU with ESP8266 / E12 with 4Mb ....
Re: ESP Easy Mega
I try the wemos-sd-shield-mini, it does not work. Which pin do you use?
Re: ESP Easy Mega
This Mega version is great?!
Just if anyone have an example of the rule to send notifications via the email client that they could share that would be much appreciated. Happy new year to everyone !
Re: ESP Easy Mega
Any updated information on this? I see there is a neopixel device, no idea how to do anything with it.
Re: ESP Easy Mega, Errormessage
today i flashed my first, thx a lot, great work.
After i had installed the two libs i can compile and send the file to one living esp, who manage my second pellet stove.
I learned, the setting files are not compatible, or? i´m too stupid.
After the module is integrated in the own WLAN there are some tiny errors,
can´t get direct to the new homepage, he would like allways contact the 192.168.4.1.
but thats not my problem.
When i want to set up the devices and would like to set up no.5
i get an "Error saving to flash!"
The device No.5 is running, but No. 7 he´s ignoring, value: nan
after i had set up no 7 he´s running, but then i attached
task 9 and 10.
Some ideas?
best wishes
BerndJ
task 9 and 10.
Some ideas?
best wishes
BerndJ
Re: ESP Easy Mega
Hello BerndJ,
In your previous post you say that you have compiled ESP Easy Mega so, I guess you have a pointer to source code. If so, could you please share it with us?
Thanks in advance,
Thanks in advance,
Re: ESP Easy Mega
https://github.com/letscontrolit/ESPEasyMegaut1545 wrote:....... please share it ...
Re: ESP Easy Mega
Thank you BerndJ.
Ready to play with it now.....
[quote="BerndJ"]Hi,
BerndJ that is something which is there to protect your flash-ram,
is set in the ESPEasy.ino file i believe it is 100 writes / 24 hour period default.
because some config changes trigger four or five flash-writes that magical number
is reached quite fast when fiddeling aroud wit some lines / devices during setup
24h later you are allowed to take another 100 retries / Or tweak the 100 value up a bit ..
I still have many faults trying to compile the esp-easy-MEGA branch, would you please mention
which revision Arduino IDE and which libs you addes, i seem to have the wrong LiquidCrystal_i2C lib
but was not able to find the right one yet. And ther working Framed Oled is one of the reasons for using Mega..
Please summ up the magic version numbers with Lib Urls please ..
Pwassink
Pwassink
Hi,pwassink wrote:... to protect your flash-ram....
thx for the information, something new to learn.
Arduino IDE 1.6.11pwassink wrote:.... which revision Arduino IDE and which libs you addes,
Boards: esp8266 by EsP8266 Community Version 2.3.0
now i take a copy of my notes in german language, hope u get it:
beim ersten mal fehlte die Lib für OLED:
https://github.com/letscontrolit/ESPEas ... sd1306.zip
laden und unter library auf D unter Arduino gespeichert,
Fehler war dann weg.
dann der nächste:
P038 adafruit_Neopixel.h fehlt
https://github.com/adafruit/Adafruit_Ne ... master.zip
dito,
danach lief es
at this time i can compile and it runs, but at the end of the compiling a message window (open left,down) openend and tell me that there are a lot of lib updates available:
I take only 2 of them:
Arduino AVR Boards, installiert war 1.6.13 update auf 1.6.17
ESP OLED von 2.0.0 auf 3.2.5
After that i did´nt see these message window again.
Here are my libs:
Sorry, i make 5 Pictures of them, but the boards setting says that the limit of attachments are reached.
Take this:
http://berndjung.gmxhome.de/Homecontrol/Libs_1.png
http://berndjung.gmxhome.de/Homecontrol/Libs_2.png
http://berndjung.gmxhome.de/Homecontrol/Libs_3.png
http://berndjung.gmxhome.de/Homecontrol/Libs_4.png
http://berndjung.gmxhome.de/Homecontrol/Libs_5.png
P036, which lib is running
after i had solved some problems with my used libs, that is what i haved found.
P036:
https://github.com/squix78/esp8266-oled-ssd1306
use V2.0.0 !!!
i had updatet to V3.2.5 and got errors,
also the V2.0.2 gave me tons of errors.
The best way is to give the information in https://github.com/letscontrolit/ESPEas ... meOLED.ino Line 6.
That would be nice and were a good idea for all files.
P036:
use V2.0.0 !!!
ESP Easy Mega, global sync not running
today i set up the 3.rd Module and got problems regarding the globals:
Tools --> Advanced --> Global sync is set
also there the UDP Port to 12000,
Devices --> Task10 --> Global sync is set,
and the 18B20 get´s values,
also the check boxes Enabled and send to Controler1.
In the receiving Modules i see no values,
not in ESP Easy MEGA AND also in the not touched ESP easy who received values until the update.
Any ideas?
best wishes
BerndJ
PS: If u take a look on the main tab, Node List, then you realize that the MEGAs only seeing herself
Any ideas?
best wishes
BerndJ
Re: ESP Easy Mega
thanks for good work.
Missing
"IDX / Var:" for Devices in ESPEasy_R146M_4096.bin.
Think I`m doing something wrong.
Thanks for help.
BR
Missing
Thanks for help.
BR
Re: ESP Easy Mega
These should only show up if a controller that requires them is setup (not required for MQTT)ritterkun wrote:Hello,
Missing
Thanks for help.
BR
See the release notes (line 23 to be exact)
https://github.com/letscontrolit/ESPEas ... eNotes.ino
Re: ESP Easy Mega
Thanks for answering.
Trying to get fhem connected to my Sensor data over Mosquito/MKTT again.
BR
BR
Re: ESP Easy Mega
Firstly, thanks for ESP Easy Mega, I am already using ESP Easy and ESP Easy Mega in my house.
I will appreciate if somebody can please upload a compiled image of ESP Easy 148 Mega? I am experiencing difficulty to compile the current source code due to my limited knowledge of the Arduino IDU and it's libraries.
Also, if you know of a good place that provides a step by step (NOOB) instruction on how to setup the Adruino IDU for ESP Easy, this will be highly appreciated. I am following the general instructional material and I am getting stuck with the IDU failing to find many for the referenced modules.
Stephen
Stephen
Re: ESP Easy Mega
Any short howto how to configure the Arduino IDE for compiling the ESPEasy Mega?
I tried with the usual config that works for ESPEasy and ran into several error messages
about double libraries, then compiling is stopped.
Thanks in Advance
Thanks in Advance
Re: ESP Easy Mega
I just discovered that ESPEasyMega was supposed to be the next version after R148.
Martinus made a seperate repository for it (ESPEasyMega), but it should have been a ESPEasy branch. Later this could become the master-branch of ESPEasy.
So now i'm creating a platformio build environment with the correct libraries and adding it to Travis for automated building.
Then we have to figure out whats changed in ESPEasy since martinus made the new ESPEasyMega repo. He told me he forked it from R142, but it seems there are changes up to R148 in it as well, so i'm confused.
He also incorperated some playground plugins already, something I also started with in the ESPEasy repo.
What SHOULD have happened in the first place was: Create a mega branch and redirect all people that wanna do pull requests to this branch, so development would have continued with the mega-branch from the beginning. (and use the github issue tracker for bug-tracking)
Unfortunately we now have a bit of a mess, since we have 2 repositories with 2 different sets of changes/pull requests, and bug-reports that are spread out all over the forum with no clear oversight.
So what i'm going to do now:
-create a mega branch in ESPEasy
-setup build env and get it to build with the correct libraries. (This will be the mega-branch in ESPEasy-platformio, since i'm using that to build. It will point to the ESPEasy mega-branch via a submodule)
-figure out if there are changes missing in ESPEasyMega that happend between R142 to R148
-figure out if there are any important fixes/pull requests that I already integrated after R148.
-figure out if the plugins that martinus added from the playground had some fixes/changes that still need to be integrated.
-finally change master of ESPEasy to this new mega version: This way people can start developing/submitting fixes.
-find all the bugs on the forum that still need fixing and create issues for them on github so we get a clear picture what needs to happen. (i already got a small list of bugs from Martinus)
Edwin
Edwin
Re: ESP Easy Mega
There will be a mega branch on the ESPEasy-platformio repository. That should enable you to just compile it with platformio without any hassle.Shardan wrote:Hello,
Thanks in Advance
I'll post here when its ready.
Re: ESP Easy Mega
Thank you.psy0rz wrote:There will be a mega branch on the ESPEasy-platformio repository. That should enable you to just compile it with platformio without any hassle.Shardan wrote:Hello,
Thanks in Advance
As i tend to change sources myself and test things platformio is no usable alternative to self compiling.
Even if i can upload and compile own things pleaase accept that i prefer to Keep things on my own test area until they work (or get dumped ).
it would be nice if there is a short howto like it is for the standard platform.
Re: ESP Easy Mega
You still can still change sources and test things.Shardan wrote: As i tend to change sources myself and test things platformio is no usable alternative to self compiling.
The whole reason to use platformio is so that everyone uses the same libraries. And then you dont get the compiler errors you're complaining about.
Everyone is still free to just use the normal repository with the classic Arduino gui. Maybe someone can even create a ESPEasy-arduino repository that can be used to compile with the Arduino gui and against the correct libraries.
Keep in mind that ESPEasy-platformio is only a build-environment wrapper: It has the correct libraries and settings, but it directly uses the source code from ESPEasy via git submodule. You can point that submodule to your own fork and make pull requests etc.
Re: ESP Easy Mega
Ok guys the mega environment is up and running, get it here: https://github.com/letscontrolit/ESPEas ... /tree/mega (the readme on that page explains how)
The ESPEasyMega repository is now back in the normal repository (ESPEasy), in the mega-branch. This will be called ESPEasy 2.0.0.
Let me know if you have any problems, issue tracker for 2.0.0 is here: https://github.com/letscontrolit/ESPEasy/milestone/1
More details of whats going on:
All development efforts will be focused on getting v2.0.0 out. Numbering will be as followed:
v2.0.0-devX: these are the current development releases, X changes rapidly so that we have binary releases that people can play with, without compiling. (Travis fixes this automatically)
v2.0.0-betaX: as soon as we think its stable/complete enough for real testing, we will start numbering beta's.
v2.0.0-rcX: release candidates
v2.0.0: This will be the first stable release (e.g. mega + more cool stuff )
Breakdown of the version number after this:
v2.X.X:
The first number changes only on huge changes in the core framework, that are probably not backwards compatible.
The second number changes when new plugins are added or new features are added.
The last number changes for smaller improvements or fixes.
ESPEasy repository, master branch: R142 -> R143 -> R144 -> R145 -> R146 -> R147 -> R148 -> (lot of pull requests/fixes/plugins merged by psy0rz) -> v1.1.0-beta10
ESPEasyMega repository of martinus: There is just one commit here, he made a copy of R142 and probably added all changes up until R148, and made big improvements for the Mega version.
Details are in his release notes here: https://github.com/letscontrolit/ESPEasyMega/blob/master/__ReleaseNotes.ino
To make development easier i created ESPEasy repository, mega branch:
Its a branch of ESPEasy R148 on which i copied ESPEasyMega, without the file-renames -> v2.0.0-dev1
v2.X.X:
Re: ESP Easy Mega
Yeah... upload it, have a github account and internet connect (I'm working offline often...)psy0rz wrote: You still can still change sources and test things.
And i want to be able to change libraries and such - impossible on a wrapper to a IDE that is hidden from me.
Sorryy, but that is useless for me.
Are these libraries etc such a secret that they have to be hidden from public?
Why not making a short howto like http://www.letscontrolit.com/wiki/index ... are_Upload
and a git repository with the actual libs?
Re: ESP Easy Mega
You can also try using the Arduino IDE:
Run: git clone --recursive https://github.com/letscontrolit/ESPEasy-platformio.git
Then the libraries are in the ESPEasy-platformio/lib dir, and the source code is in the ESPEasy-platformio/src dir.
After you put them in the usual places, you should be able to compile and upload with Arduino IDE.
I didn't try it but it should work.
Edwin
Edwin
Re: ESP Easy Mega
I understand that some people dont have the git-command and just want a zip-file that contains all the sources. I will fix that as well.
After that I will make sure people can use the Arduino IDE, and i will update the how-to's on the wiki.
Its very important to me that every one can contribute to this project as easy as possible.
This will take some time, so please be patient.
Re: ESP Easy Mega
Many thanks,
This would be really helpfull for me.
Shardan @ work
Shardan @ work
Re: ESP Easy Mega
Thank you for sorting out my flashing problem on issue I logged on git within 1 hour. I flashed the beta firmware_mini.bin, on Apple Mac, using the esptool.py with command:psy0rz wrote:I understand that some people dont have the git-command and just want a zip-file that contains all the sources.
sudo esptool.py --port /dev/cu.wchusbserial1410 write_flash 0x0 ~/Downloads/firmware_mini.bin
Re: ESP Easy Mega
as you can see the wiring diagram SD card
Re: ESP Easy Mega
I tried it, loaded down the git repository and installed Arduino IDE on a newly installed computer so everything should be clean.
Added the board manager, libs etc as usual of course.
Compiling ends up in a "missing SSD1306.h" error. i can't find the header file anywhere so this message is correct.
Where can i find the file?
Addendum:
I just tried to get atom and platformio to run on Win-7.
I can open the cloned file folder and files, that's it.
F7 just does nothing, it is not connected to any action in the settings.
Seems that it needs Python (v2? v3?) and maybe some more things on top?
Addendum2
Installed atom and git on my Server running SuSE Leapfrog , cloned the git.
Result: starting "atom ESPEasy-platformio" does nothing. Just the prompt comes back at once, that's all.
No error message, nothing in the log file.
Seems this needs some reworking.....
Addendum:
Addendum2
Re: ESP Easy Mega
Hello again,
meanwhile i got atom starting on my linux machine, was my fault.
But anyways..... starting "atom ESPEasy-platformio opens atom and the cloned repository.
Pressing [F7] does just nothing as with windows.
There is something missing on standard installations.
Re: ESP Easy Mega
Hello again...
The description is somewhat short about some installation points:
I managed to get platformio to run with Win-7. You have to install clang (LLVM), python 2.7.x and git.
Then open atom, go to file -> settings -> install and sear for "platformio-ide", install it.
With the first run it installed the tool chain without error messages but complaioned about missing source files.
I copied the source files manually, then it complained about libraries:
"fatal: Not a git repository (or any of the parent directories): .git"
This appears on different libraries debending on the build (Mini...)
That's an issue that should be fixed as many people use windows.
At least i got it to work on one of my SuSE servers.
With SuSE you have to install clang (LLVM) which is not installed by default.
Then open atom, click edit -> preferences -> install and search for "platformio-IDE", install it.
Should be mentioned that the compiled files are under ./<home folder>/ESPEasy-Platformio/.pioenvs/<version>/firmware.bin
(version = dev, mini, normal or test).
Re: ESP Easy Mega
thanks for trying and for all the info.
will try to make a nice windows howto on the wiki this weekend. tried it myself and there where a lot of little issues indeed.
(so far i used linux and had everything setup already)
Re: ESP Easy Mega
People, i made some changes, so the released zip-file has the same layout as people where used to:
https://github.com/letscontrolit/ESPEas ... 2.0.0-dev2
This should allow people to use at least the Arduini IDE to compile the sources. (until I documented some more about the new stuff with platform io)
Please let me know how it works for you. (for now testing,dev and stable all have the same plugins, I still have to add plugin sets support to version 2)
Edwin
Edwin
Re: ESP Easy Mega
I am testing the ESPEasy_v2.0.0-dev2_test_ version. Installing was no problem.
I hope you will give the 2560 version some attention to (the i2c part of it)
Re: ESP Easy Mega
i meant this side projectpsy0rz wrote:You mean the arduino mega 2560?
http://www.letscontrolit.com/wiki/index.php/ArduinoEasy
viewtopic.php?f=18&t=2234
Re: ESP Easy Mega
I didnt know about this project, and for some it can be a bit confusing: We have ESPEasy mega, which is actually for the ESP8266. (I renamed it to ESPEasy version 2 for clearance)frank wrote: i meant this side project
And now it seems there is actually a port of ESPEasy for the Arduino Mega. (and it ISNT called ESPEasy Mega...wait wut?)
I dont think i have the time and interest to support that version, nor do I have practical use myself for an arduino with ethernet. It also means yet another repository to support and fix bugs on.
If someone would extend the ESPEasy code base to also support Arduino Megas (with a bunch of ifdefs), i would be interested to merge it into ESPEasy.
Offcourse its always possible someone else will continue development of EasyArduino. (please contact Martinus if you do)
Edwin
Re: ESP Easy Mega
Quite right, Arduino is a little bit obsolete with esp8266nor do I have practical use myself for an arduino with ethernet.
Mega + ethernet shield cost + size cannot match the new solutions
Re: ESP Easy Mega
I was working on a howto for Windows when I realized that working with submodule is making things much more complex.
So i'm going to rearrange the files in the ESPEasy mega-branch in such a way that its compatible with platformio and then make a nice howto for it.
Releases will still be in the zip-file format that people are used to.
The Howto about installing platformio on windows is ready: http://www.letscontrolit.com/wiki/index ... Platformio
Re: ESP Easy Mega
Ok that escalated quickly into multiple howtos and a complete course
The links to the howtos are on the bottom of this page: http://www.letscontrolit.com/wiki/index ... evelopment
It explains everything about Atom, platformio, Github and pull requests.
Please let me know if its usefull and understandable.
Edwin
Edwin
Re: ESP Easy Mega
Wow, excellent piece of work on the documentation, very clear, now I understand these concepts that have eluded me for a long time ! Thank you!
Although I saw platformio in my research more than a year ago, I did not see a need, and as Martinus went the self-build / create route on Arduino, I did not understand the need, this probably goes for others in the community as well.
On this site: http://www.ikravets.com/computer-life/p ... ergia-ides I get a nice summary of 'why platformio'.
Anything else you could add to set our minds at ease of going platformio? I assume the build and compile process, and updating of libs are so much easier?
Last thing, what does the inclusion of platformio do to our GNU general public license? Does it influence that?
Thank you for your dedication and hard work, again !
It thus makes sense why you are taking us to it !PlatformIO Library Manager makes it extremely simple to find, install and keep libraries up-to-date.
What is more, PlatformIO is an awesome and smart cross-platform code builder. You have no need to install any IDE or compile any tool chains. PlatformIO has pre-built different development platforms including: compiler, debugger, uploader (for embedded) and many other useful tools.
Re: ESP Easy Mega
Ill post more later (type on phone)
just want to say that i also want to keep the current way of working with Arduino available. so people that dont like the new way do not have to worry its going to be 100% platformio only. (thats why im not yet using the library dependency functions of platformio for example)
i will test Arduino ide later and update the wiki accordingly.
Re: ESP Easy Mega
Anyone able to explain how the different rulesets work? Are they just more space, or can you swap entire rule sets in mega?
I.e., I could set up Ruleset #1 with time events for every half hour, and ruleset #2 with time events for once every hour. Then I can send a command to tell the firmware to operate on ruleset #1, then two days later send a command, and have it operate on ruleset #2?
Andy
Andy
Re: ESP Easy Mega
Hi.
It look like ESP Easy Mega don't work with a SENSOR_TYPE_TRIPLE and Domoticz HTTP...
I tested new I2C Soil Moisture device and have this problem, no data sent to Domoticz.
Anyone know about this?
alberto
alberto
Re: ESP Easy Mega
This is fixed in https://github.com/letscontrolit/ESPEas ... 2.0.0-dev6
Re: ESP Easy Mega
Well...It's incredible how fast is fixing ESP Easy bugs....
Great work!
Alberto
Great work!
Alberto
Re: ESP Easy Mega
finally I got platformio running, but when opening the directory containing the unzipped release 6 I find empty library folders. Consequently compilaton isn´t possible. Am I the only one? how can I download a complete zip-archive?
