TD-er wrote: ↑12 Aug 2018, 21:39
I guess that's somewhere inbetween a "bug" and a "very much desired feature"
Can you make an issue for it on Github?
I agree that it’s not really a bug.
According to the SMTP-Syntax in
https://tools.ietf.org/html/rfc5321#section-4.1.1 the command RECIPIENT (RCPT) “is used to identify an individual recipient of the mail data; multiple recipients are specified by multiple uses of this command.”
I took a look inside the SMTP handling inside sources of ESPEasy and found the piece of code responsible for setting together the string for RCPT. There is foreseen the command only once for the one-and-only recipient:
if (!NPlugin_001_MTA(client, String(F("RCPT TO:<")) + notificationsettings.Receiver + ">", F("250 "))) break;
Seems it would be necessary to seek the string for (different) separators and distinguish the receivers. For each optional receiver there needs to be an extra RCPT command.
Are you sure it’s worth to create an issue for that (if nobody else has asked this feature)?
The alternative is to mention it in the Wiki that only one Receiver is allowed and you can create another notification with a second Receiver.
What do you think?
