I looked around abit for standard testsoftware, but then i decided to build something myself.
Most standard unit testing is made to test libraries and functions on the native system. We want to actually build and flash firmware and then http post and receive sensor data, while emulating actual controllers. There might be something that can do it, but as usual with python: its easier and quicker to implement something ourself for this specific usecase.
In case you find an existing framework that doesnt have a huge learning case and is better then what I have right know, let me know. For now this works and i'm actually starting to benefit from it.
The Rig
Forum rules
Re: The Rig
LisaM wrote: ↑20 Jan 2018, 18:17Ali made them for me... https://www.aliexpress.com/item/7x9CM-7 ... 46336.html
I screwed up the first board, just couldn't get the esp32 onto the board without bridging two or more pins. For now i gave up on it.
Ok, i have to rethink/find out how to solder the esp32/esp8266 onto such a board...
Re: The Rig
Sorry to hear that... hot air gun + soldering paste should do the trick, essentially smd soldering.LisaM wrote: ↑22 Jan 2018, 22:34LisaM wrote: ↑20 Jan 2018, 18:17Ali made them for me... https://www.aliexpress.com/item/7x9CM-7 ... 46336.html
https://www.ebay.de/i/282663336169?chn=ps
that one works for me
Re: The Rig
I ordered a bunch. Hopefully I get more lucky.LisaM wrote: ↑22 Jan 2018, 22:34LisaM wrote: ↑20 Jan 2018, 18:17Ali made them for me... https://www.aliexpress.com/item/7x9CM-7 ... 46336.html
