MQTT Relay turning on and off by itself
Forum rules
javier77
#1 Post by javier77 » 20 Jun 2017, 03:06
Hey guys I really look forward to the 2.0 stable version :P . I have setted a relay which is turned on and off using home assistant using MQTT. It works ok but yesterday I've turned off the relay and 20 minutes later it turned itself on and a couple of minutes later it turned off again. I couldn't find in the logs if the mqtt command was actually send or if it's another problem. Any hints? It might be nice that the log was a little bit larger cos its all full with uptime info and the rest of the things are kinda erased.
Re: MQTT Relay turning on and off by itself
#2 Post by grovkillen » 20 Jun 2017, 06:15
javier77
#3 Post by javier77 » 22 Jun 2017, 23:26
grovkillen wrote: 20 Jun 2017, 06:15 You can set up a log server.
https://www.letscontrolit.com/wiki/inde ... anced_page
Yeah, for debugging purposes it might be a good idea. I am gonna look if I could use my NAS as a log server.
Thanks man!
Javier
Users browsing this forum: No registered users and 44 guests
