current measure
current measure
I'm excited about this project. I control so that all blinds.
Also have many of my light switch refitted and made inteligent
A big wish of mine, it is to measure the current of devices. Washingmachine, Refrigerator, ...
Which component does this with EspEasy?
thx
thx
Re: current measure
Have a look here http://www.esp8266.nu/forum/viewtopic.p ... dishwasher
But be careful. Some Chinese boards with this chip on it, like http://nl.aliexpress.com/item/NEW-20A-H ... 4589af03fb
are not realy save or capable of dealing with 20 Amps.
Re: current measure
Thanks for your answer.
Is it ok like this?:
Re: current measure
I think it is a good starting point, but some of the Chinese products do not keep the minimum safety clearance between 230 volt and 5 volt tracks.
If that is the case, it is likely there are no electrical safety issues as long as you do not attach any other sensor to the esp that has conductive elements that can be touched from the outside.
Furthermore, you probably need some capacitors on the HLK-PM01. In mine I have also mounted an electronic fuse and a VDR.
Re: current measure
BertB, is it possible to extend the scheme with your options? Or what capacitors and VDR you used and where did you placed them. Its a learning aspect for me.BertB wrote:I think it is a good starting point, but some of the Chinese products do not keep the minimum safety clearance between 230 volt and 5 volt tracks.
Re: current measure
I do not think it is possible to measure 50/60Hz line current with ESPEasy and a ACS712 module.
It is true that the output of the ACS module produces a voltage that is proportional to the current ......... but this proportional voltage is an alternating voltage of the same frequency and waveform as the AC-line current waveform has.
ESPEasy will sample the momentary value of the voltage and this momentary value will IN NO WAY be proportional to the original effective/average AC line current.
There must be some extra hardware to convert the alternating voltage to a effective/average DC voltage that can be measured with ESPEasy.
The simpel method would be a diode with a smoothing capacitor but this will give very inaccurate results at lower currents.
This article http://www.instructables.com/id/How-to- ... ct-Sensor/ will give a way to use the ACS712 together with ESPEasy.
Re: current measure
My wife is asking of it's possible to get a notification on her mobile when the washing machine is ready, that why i was looking at this solution.
Re: current measure
thank you for your information
@BertB: If you tell me in detail where I need which components, I will update the scheme here.
@costo: I am aware that I can not use them to measure the exact power consumption.
By several measurements in quick succession, i hope can see a trend.
E.g. the mode in which just the washing machine is.
Does not exist a finished product(board)? ...what you've linked.
I'm curious about the result.
Re: current measure
I am compiling information on my project using current measurements here http://hilo90mhz.com/remote-power-monit ... surements/
I am using espEasy to send data to thingspeak that is triggering a txt message through twillo on condition met with AC current sent along in text message - it is working.
I will write up full documentation in the coming days...
Suffice to say you want to use these current sensors for your application: https://openenergymonitor.org/emon/buil ... -interface
I have integrated their emonLib library into the MiniProExtender Arduino code on an arduino pro mini - emulating the analog read output and ESPEasy doesn't know its not just straight analog read but actually formatted current data you get 6 channels current/voltage with the ADCs in MiniPro and its cheaper than going with dedicated external I2C ADC.
https://thingspeak.com/channels/101562
Re: current measure
@andy-ich and @ManS-H
Apologies for the late response.
The manufacturer of the HLK-PM1claims a ripple of <= 50 mVpp when a 10 uF (electrolytic) and a 0.1 uF (ceramic) are connected across the output.
At the mains side of the HLK-PM1, across the AC pins, I have a VDR 10K391. That short circuits higher tension values. In series between one of the mains inputs and the HLK-PM1, I have a electronic fuse of 1 Amp.
What program did you use to make the schematic?
Re: current measure
That's exactly the power supply setup I plan to use.. 5 of the hlk modules are in the mail. Looks good!BertB wrote:This works for me:
Re: current measure
Thanks for the Power Supply scheme.BertB wrote:This works for me:
Re: current measure
Pleased to see that there are people looking for real solutions to do some AC current/power measurements in combination with ESPEasy.hilo90mhz wrote:I am compiling information on my project using current measurements here http://hilo90mhz.com/remote-power-monit ... surements/
I found a simple solution here : https://forum.arduino.cc/index.php?topic=179541.0 (by dc42) that I plan to use on a proMiniExtender.
I am waiting for a ACS712 currentsensor to arrive from china, when I have it I will certainly try the library from your link too, thanx for the good info you provided.
Re: current measure
I am very curious where this will go in the reality of the day, since many loads are not truly sinusoidal.
Re: current measure
Hi, the same author on Instructables you quoted and linked to his project to get AC current smoothed to measure it, published a new / improved project now for AC hall effect measurement with Arduino. See it here http://www.instructables.com/id/Simplif ... -Using-AC/. He does not need the smoothing circuit anymore, but uses the Arduino "Filters" library. See the filters Arduino sketch here http://playground.arduino.cc/Code/Filters. Any chance we can ask dev's to include this in order to read AC current with hall effect sensors like the ACS709, or ACS712 or similar?
Re: current measure
Hello @costo, I see you are playing with the AC712 as well, and you already posed No '15 you have ordered parts and want to try current AC measurement,have you got it woking yet? Would love to learn from you.costo wrote:hilo90mhz wrote: I am waiting for a ACS712 current sensor to arrive from china, when I have it I will certainly try the library from your link too, thanx for the good info you provided.
Re: current measure
I think it is not a good idea to use an ESPEasy for this purpose, since accurate measurements require many samples per second.
Re: current measure
Hi JR01,JR01 wrote:Hi, the same author on Instructables you quoted and linked to his project to get AC current smoothed to measure it, published a new / improved project now for AC hall effect measurement with Arduino. See it here http://www.instructables.com/id/Simplif ... -Using-AC/. He does not need the smoothing circuit anymore, but uses the Arduino "Filters" library. See the filters Arduino sketch here http://playground.arduino.cc/Code/Filters. Any chance we can ask dev's to include this in order to read AC current with hall effect sensors like the ACS709, or ACS712 or similar?
Looked at the instructable article. I have experimented with exact the same sensor but do not really like that sensor . The electrical isolation between the Line current and the low voltage part (arduino) is very small.
There is a safer ACS712 module that is only a little more expensive but it has better isolation properties. (Greater distance of the conducting parts.)
http://www.aliexpress.com/item/Original ... 83198.html
I have been experimenting with ACS712 and a PME pro Mini Extender and have very usable results.
Though the combination of ACS and PME have some difficulties.
1) The noise in the ACS is about 0.12 Ampere on the 5Amp module, so there is never a zero reading.
2) Accuracy and foremost resolution is limited by the PME AD converter which is 10 bit (1024 steps)
As the 5Amp has an output of 0.185V/Ampere and the ADC has a resolution of 5V/1024 there are only about 26.4 mA resolution.
The good thing is that you can do a lot of measurements in a short period.
In 0.1 second (100.000 micros) the PME does 250 measurements, so you sample exactly 5 periods of a 50Hz or 6 cycles of 60Hz. The PME calculates the square root of the sum of the squared values, which is very close to the true RMS value.
It needs some more to calculate the power. It is acceptable to assume that the line voltage is always 230 volt (+- 5%) But the Cos φ value needs to be calculated. For that you need a circuit to measure the zero crossing of the voltage and calculate the difference with the zero crossing of the current. Preferrable that circuit needs to have line isolation with a opto-coupler.
Power used/generated is then: measured current * 230 * Cos φ.
I am working on that.
For now I will publish a sketch for the PME in this topic
http://www.esp8266.nu/forum/viewtopic.p ... nder#p6385
This measures the RMS current without Cos φ calculation
Re: current measure
found this nice setup to test:
http://whatnicklife.blogspot.sk/2015/09 ... itors.html
Re: current measure
I found these articles about hacking a cheap Chinese PowerPlugMonitor to send the measuring data wireless very interesting:
Hacking the powermeter: http://gizmosnack.blogspot.nl/2014_10_01_archive.html
Making it wireless: http://gizmosnack.blogspot.nl/2014/11/p ... eless.html
The code is written for Arduino and NRF24L01 but it could be adapted to work on the ESP and even ESPEasy with the PME
This approach looks far more promising than working with a ACS712 which will never be accurate enough to measure power.
Also the cost of building a reasonable accurate powermeter yourself will be higher than using this hacked Power Plug Meter.
Re: current measure
So are there any plans to include an Analog Input device that uses filters and measures the fluctuation and/or min max values?
Re: current measure
Sonoff were promising a switch that returns the power consumption of the load.
Seems to have vanished from their website.
I'm waiting for some ACS758 devices. http://www.ebay.co.uk/itm/150653947908
There are code snippets to get this going.
I will report back....
Re: current measure
ok i did some googling and came up with this code
the majority of the code is from here
http://henrysbench.capnfatz.com/henrys- ... -tutorial/
did some changes and add some comments and it kinda works.
#define DEBUG 1
Measuring AC Current Using ACS712
http://physicsnet.co.uk/a-level-physics-as-a2/current-electricity/alternating-current-ac/
//parameters
const int sensorIn = A0;
int mVperAmp = 89; // use 100 for 20A Module and 66 for 30A Module, 5A is 185 for 5v input voltage // use this formula Vout = Vin/2 + ((Vin/2)/Imax)*I , first set I = 0 then 1 and substract them and you get the correcct values , Imax is not the Module type for example 20A but the Imax value wich is not the same
double ADCmaxVolt = 3.3 ; // arduino has 5, nodemcu esp has 3.3, esp has 1.06
int ADCRessolution = 1024;
int Offset = 7; // because values at zero Amp have different min max
int STime = 500 ; // twice that time
//end of parameters
double Voltage = 0;
double VRMS = 0;
double AmpsRMS = 0;
void setup(){
Serial.begin(115200);
void loop(){
Voltage = getVPP(); // peak to peak current in amperes shown in volts
VRMS = (Voltage/2.0) *0.707; //0.0707 is kinda the same as 1/sqroot(2) = 0.7071067.. // we divide peak to peak so we get Io= peak current in amperes shown in volts and Irms = Io / sqroot(2) all shown in volts
AmpsRMS = (VRMS * 1000)/mVperAmp; //now we convert voltage to amps // RMS is equal to the value of the direct current that would produce the same power dissipation in a resistive load
Serial.print(AmpsRMS);
Serial.println(" Amps RMS");
float getVPP()
float result;
int readValue; //value read from the sensor
int maxValue = 0; // store max value here
int minValue = ADCRessolution; // store min value here
int samplecount = 0 ;
uint32_t start_time = millis();
int substracted;
while((millis()-start_time) < STime) //sample for 1 Sec
samplecount = samplecount + 1 ;
readValue = analogRead(sensorIn);
// see if you have a new maxValue
if (readValue > maxValue)
/*record the maximum sensor value*/
maxValue = readValue;
if (readValue < minValue)
minValue = readValue;
// i do everything twice so i get a better average in the end if something peaks, could've done better but...
float result1;
int readValue1; //value read from the sensor
int maxValue1 = 0; // store max value here
int minValue1 = ADCRessolution; // store min value here
int samplecount1 = 0 ;
uint32_t start_time1 = millis();
int substracted1;
while((millis()-start_time1) < STime) //sample for 1 Sec
readValue1 = analogRead(sensorIn);
if (readValue1 > maxValue1)
maxValue1 = readValue1;
if (readValue1 < minValue1)
minValue1 = readValue1;
// Subtract min from max
substracted = maxValue - minValue - Offset;
substracted1 = maxValue1 - minValue1 - Offset ;
if (substracted < 0)
substracted = 0;
#ifdef DEBUG
Serial.println(" Offset too big");
#endif
if (substracted1 < 0)
substracted1 = 0;
#ifdef DEBUG
#endif
result = ( (double)(substracted) * ADCmaxVolt)/ ADCRessolution; //gets the milivolt difference betweene the values
result1 = ( (double)(substracted1) * ADCmaxVolt)/ ADCRessolution; //gets the milivolt difference betweene the values
#ifdef DEBUG
Serial.print(" Try 1 min is ");
Serial.print(minValue);
Serial.print(" max is ");
Serial.print(maxValue);
Serial.print(" Try 2 min is ");
Serial.print(minValue1);
Serial.print(maxValue1);
Serial.print(" Togethe sampled ");
Serial.print(samplecount);
Serial.print(" times in 1 sec, first result is ");
Serial.print(result);
Serial.print(" second is ");
Serial.print(result1);
Serial.print(" Together ");
Serial.print((double)(result +result1) / 2);
Serial.println("");
#endif
return ((double)(result +result1) / 2) ;
Re: current measure
Well there is quite a lot of code on the internetz for DC but AC is a pain in the assdaxkamala wrote: I'm waiting for some ACS758 devices. http://www.ebay.co.uk/itm/150653947908
edit:
this sensor looks promising PmodISNS20
Re: current measure
Hi All, I read about the current monitor thread.
Since i still cannot find what i'm looking for i'm going to ask you my question!
I'm using an arduino nano clone to read data from a CT sensor (as seen on openenergymonitor.org). it works good! i'm also using a 220->9V AC transformer to have the correct measure of the voltage of my powerline.
I would like to know if there's some way to "import" the data from nano to espeasy and then to the world by mqtt or json string or emoncms website , so i could use them to trig events (like send a message when the washing machine have finished)
Re: current measure
ok here is some more test code here you won't need to calibrate the zero value, just change the mVperAmp value I think the logic behind the code is ok... it kinda measures Irms and average I and also power usage
#define DEBUG 1
//parameters
int mVperAmp = 30; // use 100 for 20A Module and 66 for 30A Module, 5A is 185 for 5v input voltage // use this formula Vout = Vin/2 + ((Vin/2)/Imax)*I , first set I = 0 then 1 and substract them and you get the correcct values , Imax is not the Module type for example 20A but the Imax value wich is not the same
float ADCmaxVolt = 3.3 ; // arduino has 5, nodemcu esp has 3.3, esp has 1.06
int Offset = 1; // because values at zero Amp have different min max
int STime = 1000 ;
float Zero = 417.1; //will get zero value based on average
float PrevZero = Zero ;
int VRMS = 230 ;//europe
//end of parameters
//double Voltage = 0;
//double VRMS = 0;
double Amps = 0;
double ARMS = 0;
double Calc = double(ADCmaxVolt) / double(ADCRessolution) * double(1000) / double(mVperAmp);
void setup(){
Serial.println(" Measuring Zero value!!!");
//get average
int readValue;
int sample = 0;
float sum = 0;
while((millis()-start_time) < 200) //sample for 1 Sec
sample = sample +1;
sum = sum + readValue ;
Zero = double(sum/sample);
Serial.print(" Zero: ");
Serial.println(Zero);
void loop(){
GetValues();
//Voltage = getVPP(); // peak to peak current in amperes shown in volts
//VRMS = (Voltage/2.0) *0.707; //0.0707 is kinda the same as 1/sqroot(2) = 0.7071067.. // we divide peak to peak so we get Io= peak current in amperes shown in volts and Irms = Io / sqroot(2) all shown in volts
// It is worth noting that it is true only for a sinusoidal waveform... here it is not so we have to multply every value and then sqr the average
//Amps = (Voltage * 1000)/mVperAmp; //now we convert voltage to amps // RMS is equal to the value of the direct current that would produce the same power dissipation in a resistive load
float GetValues()
// float result;
int samplecountplus = 0 ;
int samplecountminus = 0 ;
int samplecountzero = 0 ;
long sumplus = 0 ;
long summinus = 0 ;
long sumzero = 0 ;
float SumSq = 0 ;
#ifdef DEBUG
int maxvalue = 0 ;
int minvalue = 1024 ;
#endif
boolean ping = true;
#ifdef DEBUG
// get min max only if you want to
if (readValue > maxvalue)
maxvalue = readValue ;
if (readValue < minvalue)
minvalue = readValue ;
#endif
// SumSq = double(SumSq) + double(sq((((double(readValue) - Zero) * double(ADCmaxVolt)) / double(ADCRessolution))))* double(1000)/ double(mVperAmp);
// Serial.print((((double(readValue) - Zero) * double(ADCmaxVolt)) / double(ADCRessolution)));
if (double(readValue - Offset) > Zero )
samplecountplus = samplecountplus +1 ;
sumplus = sumplus + readValue ;
SumSq = SumSq + sq((double(readValue) - double(Zero) - Offset ) * Calc) ;
else if (double(readValue + Offset) < Zero )
samplecountminus = samplecountminus +1 ;
summinus = summinus + readValue ;
SumSq = SumSq + sq((double(readValue) - double(Zero) + Offset) * Calc) ;
// SumSq = SumSq + sq((double(readValue) - double(Zero)) * Calc) ;
//no point doing this if it is like 0
if (ping)
ping = false;
ping = true;
samplecountzero = samplecountzero +1 ;
if (samplecountzero == 0)
samplecountzero = 1;
if (samplecountminus == 0)
samplecountminus = 1;
if (samplecountplus == 0)
samplecountplus = 1;
float plusavg = double(double(sumplus)/ double(samplecountplus)) ;
float minusavg = double(double(summinus)/ double(samplecountminus)) ;
float pmm = double((plusavg - minusavg)/2) ;
Amps = double(pmm * Calc);
// result = ( (((double)(sumplus)/ samplecountplus)- ((double)(summinus)/ samplecountminus)) * ADCmaxVolt)/ ADCRessolution; //gets the milivolt difference betweene the values... old style
float meansq = SumSq / (double(samplecountplus + samplecountminus)) ;
float RMSCurrent = sqrt(meansq);
#ifdef DEBUG
Serial.print(" min: ");
Serial.print(minvalue);
Serial.print(" max: ");
Serial.print(maxvalue);
Serial.print(" samples: ");
Serial.print(samplecountplus +samplecountminus);
Serial.print(" count plus: ");
Serial.print(samplecountplus);
Serial.print(" plus sum: ");
Serial.print(sumplus);
Serial.print(" count minus: ");
Serial.print(samplecountminus);
Serial.print(" minus sum: ");
Serial.print(summinus);
Serial.print(" count zero: ");
Serial.print(samplecountzero);
Serial.print(" zero this run: ");
Serial.print(Zero);
#endif
Zero = double(double(double(sumplus +summinus)/ double(samplecountplus+samplecountminus)) + Zero)/ 2; // prevent fast changes
#ifdef DEBUG
Serial.print(" avg and zero next: ");
Serial.print(Zero);
Serial.print(" plus avg: ");
Serial.print(plusavg);
Serial.print(" minus avg: ");
Serial.print(minusavg);
Serial.print(" Current: ");
Serial.print(Amps,4);
Serial.print(" RMS Current: ");
Serial.print(RMSCurrent,4);
Serial.print(" Power consumption: ");
Serial.print(RMSCurrent * VRMS ,4);
Serial.println("");
#endif
// return (double(result)) ;
Re: current measure
Did it worked with ACS712?
Users browsing this forum: No registered users and 85 guests
