Tipping bucket rain gauge -> Pulse counter
Re: Tipping bucket rain gauge -> Pulse counter
Can you post a schematic? I suspect a short or maybe wind tripping it, but without knowing more it is impossible to know. The Optocupler should eliminate any noise issue I would think. It takes more than a little noise to trigger it, it takes 5V. Someone with more electrical engineering experience could tell you if noise could make it look like it is pulling it to ground, I have some doubts but I am not an EE.
I have tested this using a generic rain bucket without the optocupler, but only only indoors with very short cables, mostly for configuring Node-red and database. Never had any problems.
I have never seen an explanation for the optocupler, protection or noise, but I suspect it is there for a reason. Someone said they could not find one. The 4N25 (EL is probably the manufacturer) is available, Mouser has several, I expect Digi-key does as well. It also comes up on aliexpress and e-bay, although they are not as reliable in my experience. Just check the data sheets and make sure the specs are what you need.
there is not mutch schematic. Between ground and gpio 0 (d8 on wemos d1)
Generic - Pulse counter, counter type : delta/total, mode type : rising.
tried diffrent Debounce Time (mSec): but cant find any diffrent. right now it is set to 5000 .
i have also try to set it as Switch input - Switch and when use that it never got strange activity only shows when the bucket it tipping.
If I understand correctly, you have a 15 meter wire from a GPIO on the wemos going to the rain bucket and another from the other terminal on the rain bucket to wemos ground?
Which rain bucket are you using?
1. GPIO 0 is used for programming so probably not a good idea to use for this application. Try GPIO 12, 13 or 14 they do not have any internal use.
2. Check the Hardware tab for the GPIO you use. I am not sure how it should be set, but try different settings to see what works best.
3. Using an optocupular next to the ESP essentially takes the 30 meters away. You can use the 5V from the wemos power to drive the rain bucket/optocupler loop (see schematic earlier in the thread).
Starting with what has been tested and works is generally a good place to start.
You could just use a DS2423 as a counter and get ESPEasy to wake up every x min. to read the counter.
Battery backed and low power.
https://www.maximintegrated.com/en/prod ... S2423.html
As the DS2423 is no longer manufactured, you can follow this link and make your own 1-Wire device.
Here is the source code on a DS2423 "Clone" - https://www.tm3d.de/elektronik-projekte ... it-avr-alt
It is in German, but i am sure you can use Goole translate and get the hang of it.
With a similar challenge to the OP, I thought I'd pick up on this thread.
I plan to use a good old CMOS Binary counter to count the bucket tips while the ESP8266 sleeps. The CD4520 is my chosen device which has a quiescent current drain of just 2.5uA.
With a small RC debounce circuit on the reed switch actuated Clock input, here's my proving prototype for this plan in action...
https://youtu.be/XmtVZqeBoqc
I plan to have the binary count (5 or six bits should be sufficient for anything up to a monsoon over 10 minutes) read by a PCF8574 I/O expander. Then (and this is the bit I am currently a little unsure of) in ESP Easy, read each 'bit' as a switch and calculate the count within a rule (1's plus 2's plus 4's plus 8's etc) Unless there's a simpler way!? When this is gathered and sent to the controller (thingspeak initially) a spare I/O on the expander can be sent high to reset the counter prior to the ESP going to sleep.
I have cut down an 8266/32 double sided breadboard to match the board that fits inside the rain gauge and added the reed switch in the same relative position...
(This is the reverse side)
I reckon, with SMD passives, I can get all the components on this board along with a TP4056 Solar charge control board to fit everything including a LIPO battery inside the rain gauge with a Solar panel outside to make it an all in one standalone device. There looks like there is also enough room at the fat end of the PCB housing to fit a BME280 Pressure/Temp/Humidity sensor in there also to complete a full (ish) weather station!
Have you thought of using a Attiny?Vic20 wrote: ↑27 Aug 2018, 20:26 With a similar challenge to the OP, I thought I'd pick up on this thread.
Let the Attiny do the counting and use serial communication to set a Dummy device in ESP Easy. I think you could then also make the ESP sleep and only wake it before serial communication. You can only send commands from Attiny to ESP, not the other way round, but that shouldnt be required for your project
http://www.ernstc.dk/arduino/tinycom.html
https://arduino.stackexchange.com/quest ... lock-speed
I think your approach is difficult to achieve in ESP Easy. You would either need to write your own plugin, or try to write the 8 bits into 2xQuadruple Dummy devices, then use rules to do the calculation.
Never heard of it to be honest! Quite a lot thirstier in current consumption by the looks of it too..And another learning curve!Have you thought of using a Attiny?
If this current design doesn't work under ESP-Easy then it'll be back to using C under the Arduino IDE!
Nice concept except any temperature/humidity sensor will need significant shading to be at all accurate when the sun is out. This of course doesn't go well with the whole rain gauge structure.
Also I would be a bit concerned about building all the advanced circuit you have proposed without testing along the way.
Also be careful with charging batteries where they might become hot from solar radiation. Depends on your climate, but direct sunlight is very strong where I live.
Hi Whatsupskip,
Construction is well under way. I've phased this so that testng can be done as it progresses. First the mount pins for the charger board and the 3.3v LDO regulator and capacitors beneath. The whole power supply side can then be tested first There's also the resistor bridge across the battery pins for monitoring the voltage on the ADC
Next, I wired the supply rails and installed the IC's , I was able to check the counter IC was working correctly. I then linked all the count outputs to the PCF8574 inputs. The BME was then placed on some pins and I have taken out the I2C lines to be read on a Nodemcu, thus able to check a large majority of the circuit without even installing an ESP on the breadboard yet!
Not looking too bad eh? Yes I get your point about the temperatures and humidity will, though useful for internal status need to be disregarded when the sun is out but they'll be fine in the rain and I only really need the pressure reading anyway. There's plenty of free GPIOs for the option to hang a DSB18B20 out of the unit.
The counter and I/O expander all seems to be working.
I'll cover the Devices and Rule in a later post. I'll plan to use a high pulsing GPIO on the ESP to reset the CD4520 before the ESP goes to sleep (hopefully after a succesful thingspeak controller update if that's possible so no counts are lost)
As for the battery getting hot, I'll ensure that side will be largely shielded by the solar panel. There is natural ventilation inside the unit and I'll probably paint it white to protect it from UV anyway. It's not a production unit after all!
Update: Due to THIS problem I could not use ESP-Easy to continue my project until that was resolved unfortunately.
I therefore decided to use the Arduino IDE and C++ to get it working...
On Wake of the ESP, A "pcf8574.read8()" instruction reads in the count from the Binary counter as decimal which I can multiply by the bucket volume to get the amount of rain over the ten minute period that the ESP was asleep.
The unit sends it's data to Thingspeak and returns to sleep in around ten seconds. A mathworks routine in Thingspeak produces another chart of total rain over the last 24 hours.
It has ran uninterrupted for over a week now on an ex nokia BL5 battery core and a small 6v Solar panel.
I will also get it to send me a Telegram message when it is 'Chucking it down' , a rain rate over a pre defined amount in 10 mins to be determined from evaluation ..just for fun.
ESP-Easy just wasn't that Easy ...though I do miss the ease of reconfiguration/reprogramming that brings.
Users browsing this forum: No registered users and 66 guests
