I spent hours trying, but no matter what I change, I'm always stuck with the problem of having to press the button twice, when triggerd by domoticz.
Here is my setup at this time:
<< DOMOTICZ: >>
kitchen dummy switch, IDX 76
actions:
On: http://192.168.25.156/control?cmd=event,kitchenon
Off: http://192.168.25.156/control?cmd=event,kitchenoff
ESP devices:
Type: input switch (normal switch, inversed),
IDX: 76
GPIO: 14
Send data = on
Value name: Switch
Type: Push button type input switch (push btn, active low).
IDX: 76
GPIO: 3
Send data = on
Value name: Switch
<< RULES: >>
on kitchen_btn#Switch do
if [kitchen_btn#Switch]=1
event kitchenon
event kitchenoff
on kitchenon do
gpio,14,0
inputswitchstate,3,1
on kitchenoff do
gpio,14,1
inputswitchstate,3,0
What am I doing wrong?
I tried taskvalueset... it changes the value under devices tab, but still need to press twice to take the action.
inputswitchstate doesnt do anything.
Switch value not updating when operated from Domoticz
Re: Switch value not updating when operated from Domoticz
I just had an idea, and it worked for me... maybe it's not the best solution, but it's simple and works fine.
if [kitchen_light#Switch]=0
gpio,14,0
gpio,14,1
It's a very basic toggle event...
Before this, I tried this one:
SendToHTTP domoticz_ip,8080,/json.htm?type=command¶m=switchlight&idx=174&switchcmd=Toggle
but the "¶m=" gets replaced by a weird symbol and the toggle doesn't work...
gpio,14,0
gpio,14,1
Hi all,
regarding momentary push button, It can be wired to the Sonoff to turn it off/on or pair a remote control to it.
You just need to solder it on contacts on current momentary button.
But be aware, it will not allow you to use classic wall switch, you need something like a "doorbell switch".
Whole job described here
http://support.iteadstudio.com/support/ ... /page/last
Users browsing this forum: No registered users and 59 guests
