K-Type / MAX6675 build in
Re: K-Type / MAX6675 build in
Problem solved. Seems it was an internally Problem with different Builds ( R120, R147 ) an th evalues in Eprom.
After Reset the module, the R120 with the _P120_Thermocouple.ino works on the ESP. Now i am waiting for my Max6675 Modul and then K Type Needles from China.
I have tested the plugin with my MAX31855K breakout boards. Unfortunately, the interface only displays incorrect temperatures:
If no probe is connected, it shows 0 C / 32 F
I've tried it with 3 different MAX31855k and various TYP-K thermocouples. Always these values ....
Do I need to change something at the code?
mattes
MainConfigHardwareDevices Tools
log
334685: WD: Uptime 5 ConnectFailures 28 FreeMem 28288
336546: P120: C: 2152.75 - F: 3906.95
336552: HTTP: connection failed
346814: P120: C: 2048.00 - F: 3718.40
346819: HTTP: connection failed
357164: P120: C: 2263.75 - F: 4106.75
357170: HTTP: connection failed
364686: WD: Uptime 6 ConnectFailures 31 FreeMem 28272
367295: P120: C: 2234.50 - F: 4054.10
367300: HTTP: connection failed
Powered by www.esp8266.nu
mattes
I just started to explore ESPEasy and it has a lot of possibilities. My second project is wiring up the MAX6677 to an esp8266 12f. I followed the samples and all the posts here on the board and ended up with an log file showing me:
So that is not what I expected to see
What could be the problem here? Broken board? Lack of power? I have it running on two batteries, since I want to have it portable for outdoor use.
I wired it up exactly as shown in the sketch:
Any advice?
Thanks. Wiechert
5105189 : WD : Uptime 85 ConnectFailures 0 FreeMem 28352
5109843 : P120 : C : nan - F : nan
5114847 : P120 : C : nan - F : nan
5119852 : P120 : C : nan - F : nan
5124857 : P120 : C : nan - F : nan
5129862 : P120 : C : nan - F : nan
// MISO Master Input GPIO12
// SCK Clock Output GPIO14
// CS Chip Select GPIO15 (CS 15 is configured in the web interface)
Gnd to Gnd
and Vcc to Vcc
Thanks. Wiechert
Any thoughts on this? Will give it a try connecting it to usb power.
W.
W.
Sorry, I can't help you. I don't have that MAX.
However, did you check the enable SPI in the hardware tab?
No I did not do that. Did not know that I was supposed to do that. So I will have a look. Might be the solution.
If I have a look at the hardware tab I do not see any SPI mentioned. So what do you mean. Gpio12 and Gpio14 ? or pin mode?
What firmware version do you use?
Hourly Build 2017/01/17 If that's the version (in the ReleaseNotes.ino it says R120 )? Could the problem also be that I have a regular esp 12f but arduino has NodeMcu 1.0 12e module? as a board ?
No that is not the problem since you can upload and run the firmware.
I think in 120, SPI is not supported. You could try to use the release candidate 147-RC8
Ok. Can not find that on Github only the master/ dev branche where is it located? Sorry I found it while sending this message This is the one? http://www.letscontrolit.com/downloads/ ... 47_RC8.zip
So I can still use this _P120_Thermocouple.ino sketch?
Ok the hardware tab is now showing the SPI part. Give it a try later-on Thanks.
Init SPI: (Note : Chip Select (CS) config must be done in the plugin)
Must still over-see something I guess. Now I get this:
34710 : P120 : C : 0.00 - F : 32.00
39714 : P120 : C : nan - F : nan
Which sensor do you have?
Can you measure between t- wire and ground? Is there a connection?
Is the thermocouple not connectoed to other stuff?
I guess you have to do some more research.
Now I got it working. I tried an other MAX6675 module and that worked. So the other module might have been broken. Nice!
Next part is connecting an display.
W.
W.
Keep us updated
I am working on a standalone Version for mobil use.....
HI Guys
Does he work with ESP Easy Mega ?
Edit: Yes he works :D , In the first post I can see reported 2 temperature in the plugin P039 only one is displayed How get the second value ?
hello everybody, thanks for the information on this topic.
I try to use the sensor but on esp easy the temperature doesn't change, always 30.5°C .. any info about the refresh ?
Hi. I have nodemcu and a MAX6675. Problem is that i only get 0C/32F readings in ESPeasy mega - same as the whose sensor board was disconnected.
What settings do i have to change in Espeasy mega? Enable SPI interface - already did that.
Checked pins thrice, VCC is in 3.3V output...i dont have a clue what is wrong.
Any advice? i already ordered a second sensor board..maybe i got a lemon from china.
Hi, what SPI clock or speed is set for max6675 in SPI.begin() ?
thx
thx
maybe a stupid question but I have a max31865 with a P100. Does this plugin also works with this breakout?
I know this thread is quite old but I try to control my solar system with the espeasy. Is it possible, that the output temperature of this module is in Fahrenheit?
In the screenshot of the module there are 2 temperatures °C and °F , in the actual module I got only 1 value line.
Did anyone already try the MAX31855? If I connect the same PT1000 from the Max6675 to the 31855 the shown temperature value is getting lower as the sensor temperature rises and the values are completely different (Sensor is about 50°C value of module shows 9°)
Kind regards
Max
Kind regards
Max
You can also convert the Celcius value using a formula, which is also shown on the system variables page (not present in 1M or testing builds)
{D}C to {D}F: %c_c2f%(20.4)
°C to °F: 68.72
Users browsing this forum: No registered users and 59 guests
