Wifi Candle - illuminate with ESPEasy (WS2812)
Re: Wifi Candle - illuminate with ESPEasy (WS2812)
For anyone interested, I created a circuit board for use with this plugin.
Uses APA 106 Neopixel LEDs (preferably 5mm as 8mm may not fit)
Positions for 0.1uF decoupling capacitors in 1206 SMD size
Position for large (1000uf) electrolytic filter cap on 5V input
Designed to be cascaded.
I had these built by JLCPCB and they work fine.
Board design can be found here.. https://easyeda.com/anthony.calia/indiv ... -led-board
Let me know if you use it successfully or have ideas for improvement
maybe an illustrating picture of your candles?
jonathan-orsel wrote: ↑02 May 2018, 05:27 Hello,
I made some updates on your plugin for my own usage :
> Led count and column count in plugin configuration (need a restart to apply)
> Some more effects ( find some inspiration at https://www.tweaking4all.com/hardware/a ... p-effects/ )
Feel free to take these changes.
can anybody tell if the devs put this in the last automatic builds,
or do i have to compile this myself into espeasy at 2018-10-10 ?
thanks, guys,
tozett
Hi, i tried to compile with espeasy source 20181002. but i got errors.jonathan-orsel wrote: ↑02 May 2018, 05:27 Hello,
#ifdef USES_P042 //####################################################################################################### //######################################## Plugin 042: NeoPixel Candle ################################## } #endif // USES_P042
without your source (i mean the original plugin-code) compiles and runs without hassle.
could you give me a hint, what to fix?
:\daten\olaf.arduino\arduino-1.6.11mega20181002\sketches\ESPEasy\_P042_Candle.ino: In function 'boolean Plugin_042(byte, EventStruct*, String&)':
_P042_Candle:171: error: no matching function for call to 'addFormNumericBox(String&, const __FlashStringHelper*, const __FlashStringHelper*, int16_t&, int, int)'
addFormNumericBox(string,F("Led Count"), F("web_Leds"), Settings.TaskDevicePluginConfig[event->TaskIndex][6],1,999);
D:\daten\olaf.arduino\arduino-1.6.11mega20181002\sketches\ESPEasy\_P042_Candle.ino:171:123: note: candidates are:
D:\daten\olaf.arduino\arduino-1.6.11mega20181002\sketches\ESPEasy\WebServer.ino:2930:6: note: void addFormNumericBox(const String&, const String&, int, int, int)
void addFormNumericBox(const String& label, const String& id, int value, int min, int max)
D:\daten\olaf.arduino\arduino-1.6.11mega20181002\sketches\ESPEasy\WebServer.ino:2930:6: note: candidate expects 5 arguments, 6 provided
D:\daten\olaf.arduino\arduino-1.6.11mega20181002\sketches\ESPEasy\WebServer.ino:2936:6: note: void addFormNumericBox(const String&, const String&, int)
void addFormNumericBox(const String& label, const String& id, int value)
D:\daten\olaf.arduino\arduino-1.6.11mega20181002\sketches\ESPEasy\WebServer.ino:2936:6: note: candidate expects 3 arguments, 6 provided
_P042_Candle:172: error: no matching function for call to 'addFormNumericBox(String&, const __FlashStringHelper*, const __FlashStringHelper*, int16_t&, int, int)'
addFormNumericBox(string,F("Led per columns"), F("web_Columns"), Settings.TaskDevicePluginConfig[event->TaskIndex][7],1,999);
Remove the first entry (the string) of the calls to these functions in your ino file.
I am Not Sure, What to Change in the Code exactly. I can Experiment later with your hint.
Anyway Thanks for quick Response
(Mobile Edited), tozett
Thanks, i removed the "string" word, these errors are gone.
the code seems to need somehow some polish, but it compiled to the end.
maybe these errors/warings can be re-coded to better code?
D:\daten\olaf.arduino\arduino-1.6.11mega20181002\sketches\ESPEasy\_P042_Candle.ino:318:16: warning: enumeration value 'SIMTYPE_LEN' not handled in switch [-Wswitch]
switch (Candle_type)
D:\daten\olaf.arduino\arduino-1.6.11mega20181002\sketches\ESPEasy\_P042_Candle.ino: In function 'void type_Police()':
D:\daten\olaf.arduino\arduino-1.6.11mega20181002\sketches\ESPEasy\_P042_Candle.ino:614:44: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
for (unsigned int i = 0; i < NUM_PIXEL / 5; i++) {
:\daten\olaf.arduino\arduino-1.6.11mega20181002\libraries\AS_BH1750\AS_BH1750A.cpp: In member function 'bool AS_BH1750A::startMeasurementAsync(TimeFuncPtr)':
D:\daten\olaf.arduino\arduino-1.6.11mega20181002\libraries\AS_BH1750\AS_BH1750A.cpp:518:7: warning: unused variable '_lastResult' [-Wunused-variable]
int _lastResult = -1;
D:\daten\olaf.arduino\arduino-1.6.11mega20181002\libraries\AS_BH1750\AS_BH1750A.cpp: In member function 'bool AS_BH1750A::delayExpired()':
D:\daten\olaf.arduino\arduino-1.6.11mega20181002\libraries\AS_BH1750\AS_BH1750A.cpp:533:19: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
if (timestamp < _lastTimestamp)
D:\daten\olaf.arduino\arduino-1.6.11mega20181002\libraries\AS_BH1750\AS_BH1750A.cpp:536:45: warning: statement has no effect [-Wunused-value]
delayTime = MAX_U_LONG - _lastTimestamp + timestamp;
D:\daten\olaf.arduino\arduino-1.6.11mega20181002\libraries\AS_BH1750\AS_BH1750A.cpp:542:24: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
return (delayTime >= _nextDelay);
Bug in PLUGIN_WEBFORM_LOAD, should not append to string, use addHtml() instead
i also discoverd a web-error in the (patched) plugin 042.
again, i dont know where to look, the source seems big meanwhile...
and it does not work
- esp002.png (196.47 KiB) Viewed 42626 times
this is the place with the error, but what to do?
(sadly, i am no coder...)
- esp003.png (67.41 KiB) Viewed 42364 times
i used my brain, exhanged the old string += "" method with addhtml(),
and it works now.
the waring about symtype_len seems to me ignorable,
i googled it and it seem to be a coder-trick to get the length of the enum.
as far as it is working at the moment, i am happy.
lets see, how many updates we can go with it..
and it works now.
- esp04.png (236.17 KiB) Viewed 42363 times
version from 2018/10/10, running with espeasy source 20181002:
(i first had a bug in the brightness-value web-form. but here it is fixed):
#ifdef USES_P042
// PROJECT INFO
// Wifi Candle for ESPEasy by Dominik Schmidt (10.2016)
// INCLUDE jscolor (http://jscolor.com/)
// * Download the lib from here: http://jscolor.com/release/latest.zip
// * Extract jscolor.min.js
// * Now open the Web UI of your ESPEasy with this URL:
// http://<IP-ESPEasy>/upload
// * Select Browse ... and choose the extracted jscolor.min.js File (ensure the ...min... version !!)
// * Press Upload und you are done.
// Add the Adafruit Neopixel Library to your library path. You will find it here:
// https://github.com/adafruit/Adafruit_NeoPixel
// That´s all :-) Now ESPEasy has a new 25ms "Timer loop" and Neopixel Support.
// NOTES
// Please keep in mind that you can add tasks which produce a very large delay while reading the sensor.
// For example the DS18B20 is very slow in reading the values. This can slow down the simulation and you
// will notice that the candle did not run smooth. So keep an eye on your tasks and don't add to much other tasks.
// HARDWARE
// The Wifi Candle uses 20 WS2812 RGB pixels. They are all connected in one row.
// I build a wooden wick with 5 pixels on each side. (A picture is here : http://www.esp8266.nu/forum/viewtopic.php?f=2&t=2147)
// The pixels are connected to 5V and the data pin I use is GPIO13 (but you can choose another one).
// Please ensure that you use a strong power supply because the pixels consume a lot of power when they
// shine in white with high brightness!
// I also placed a 100µF capacitor at the end of the WS2812 chain on +5/GND just to ensure a good power stability.
// btw ... My Testboard was a NodeMCU V3.
// QUESTIONS
// Send me an email at dominik@logview.info
// or place a comment in the Forum:
// http://www.esp8266.nu/forum/viewtopic.php?f=2&t=2147
// Candle Infos
// http://www.howtodotip.com/how+to+do+arduino+candle++3
// https://codebender.cc/sketch:129316#Neopixel%20Candle.ino
// http://www.instructables.com/id/Garden-Arduino-Lights/?ALLSTEPS Garten Beleuchtung
// http://www.instructables.com/id/Arduino-Controlled-Electric-Candle/?ALLSTEPS InstaMorph Kerze
// https://github.com/danesparza/Halloweenfire/blob/master/halloweenfire.ino Halloweenfire
// RGB / HSV Converter
// https://github.com/ratkins/RGBConverter Lib
// https://www.ruinelli.ch/rgb-to-hsv Code
// http://stackoverflow.com/questions/3018313/algorithm-to-convert-rgb-to-hsv-and-hsv-to-rgb-in-range-0-255-for-both Code Sammlung
#include <Adafruit_NeoPixel.h>
//#define NUM_PIXEL 150 // Defines the amount of LED Pixel
//#define NUM_PIXEL_ROW 1 // Defines the amount of LED Pixel per Row
int NUM_PIXEL = 150 ; // Defines the amount of LED Pixel
int NUM_PIXEL_ROW = 1 ; // Defines the amount of LED Pixel per Row
#define RANDOM_PIXEL 70 // Defines the Flicker Level for Simple Candle
#define BRIGHT_START 128 // Defines the Start Brightness
#define BASE_TEMP 21 // Defines the Base Temp for TempRange Transformation
enum SimType {
TypeOff,
TypeSimpleCandle,
TypeAdvancedCandle,
TypeStaticLight,
TypePolice,
TypeBlink,
TypeStrobe,
TypeColorFader,
TypeCylon,
TypeSparkle,
TypeRainbow,
SIMTYPE_LEN
enum ColorType {
ColorDefault,
ColorSelected
byte Candle_red = 0;
byte Candle_green = 0;
byte Candle_blue = 0;
byte Candle_bright = 128;
SimType Candle_type = TypeSimpleCandle;
ColorType Candle_color = ColorDefault;
// global variables
unsigned long Candle_Update = 0;
word Candle_Temp[4] = { 0, 0, 0 }; // Temp variables
int Candle_Temp4 = 0;
boolean GPIO_Set = false;
Adafruit_NeoPixel *Candle_pixels;
#define PLUGIN_042
#define PLUGIN_ID_042 42
#define PLUGIN_NAME_042 "Output - NeoPixel (Candle)"
#define PLUGIN_VALUENAME1_042 "Color"
#define PLUGIN_VALUENAME2_042 "Brightness"
#define PLUGIN_VALUENAME3_042 "Type"
boolean Plugin_042(byte function, struct EventStruct *event, String& string)
boolean success = false;
switch (function)
case PLUGIN_DEVICE_ADD:
Device[++deviceCount].Number = PLUGIN_ID_042;
Device[deviceCount].Type = DEVICE_TYPE_SINGLE;
Device[deviceCount].VType = SENSOR_TYPE_TRIPLE;
Device[deviceCount].ValueCount = 3;
Device[deviceCount].GlobalSyncOption = false;
case PLUGIN_GET_DEVICENAME:
string = F(PLUGIN_NAME_042);
strcpy_P(ExtraTaskSettings.TaskDeviceValueNames[0], PSTR(PLUGIN_VALUENAME1_042));
strcpy_P(ExtraTaskSettings.TaskDeviceValueNames[1], PSTR(PLUGIN_VALUENAME2_042));
strcpy_P(ExtraTaskSettings.TaskDeviceValueNames[2], PSTR(PLUGIN_VALUENAME3_042));
case PLUGIN_WEBFORM_LOAD:
addHtml(F("<script src=\"jscolor.min.js\"></script>\n"));
char tmpString[128];
String options[SIMTYPE_LEN];
// int optionValues[8];
options[0] = F("Off");
options[1] = F("Static Light");
options[2] = F("Simple Candle");
options[3] = F("Advanced Candle");
options[4] = F("Police");
options[5] = F("Blink");
options[6] = F("Strobe");
options[7] = F("Color Fader");
options[8] = F("Cylon");
options[9] = F("Sparkle");
options[10] = F("Rainbow");
byte choice = Settings.TaskDevicePluginConfig[event->TaskIndex][4];
if (choice > sizeof(options) - 1)
choice = 2;
// strip properties selection
//addFormNumericBox(string,F("Led Count"), F("web_Leds"), Settings.TaskDevicePluginConfig[event->TaskIndex][6],1,999);
addFormNumericBox(F("Led Count"), F("web_Leds"), Settings.TaskDevicePluginConfig[event->TaskIndex][6],1,999);
//addFormNumericBox(string,F("Led per columns"), F("web_Columns"), Settings.TaskDevicePluginConfig[event->TaskIndex][7],1,999);
addFormNumericBox(F("Led per columns"), F("web_Columns"), Settings.TaskDevicePluginConfig[event->TaskIndex][7],1,999);
// Candle Type Selection
//addFormSelector(string, F("Flame Type"), F("web_Candle_Type"), SIMTYPE_LEN, options, NULL, choice);
addFormSelector(F("Flame Type"), F("web_Candle_Type"), SIMTYPE_LEN, options, NULL, choice);
// Advanced Color options
Candle_color = (ColorType)Settings.TaskDevicePluginConfig[event->TaskIndex][5];
addHtml(F("<TR><TD>Color Handling:<TD>")); // checked
addHtml(F("<input type='radio' id='web_Color_Default' name='web_Color_Type' value='0'"));
if (Candle_color == ColorDefault) {
addHtml(F(" checked>"));
} else {
addHtml(F(">"));
addHtml(("<label for='web_Color_Default'> Use default color</label><br>"));
addHtml(("<input type='radio' id='web_Color_Selected' name='web_Color_Type' value='1'"));
if (Candle_color == ColorSelected) {
} else {
addHtml(F(">"));
addHtml(F("<label for='web_Color_Selected'> Use selected color</label><br>"));
// Color Selection
char hexvalue[7] = {0};
sprintf(hexvalue, "%02X%02X%02X", // Create Hex value for color
Settings.TaskDevicePluginConfig[event->TaskIndex][0],
Settings.TaskDevicePluginConfig[event->TaskIndex][1],
Settings.TaskDevicePluginConfig[event->TaskIndex][2]);
// http://jscolor.com/examples/
addHtml(F("<TR><TD>Color:<TD><input class=\"jscolor {onFineChange:'update(this)'}\" value='"));
addHtml(hexvalue);
addHtml(F("'>"));
//addFormNumericBox(string, F("RGB Color"), F("web_RGB_Red"), Settings.TaskDevicePluginConfig[event->TaskIndex][0], 0, 255);
//addNumericBox(string, F("web_RGB_Green"), Settings.TaskDevicePluginConfig[event->TaskIndex][1], 0, 255);
//addNumericBox(string, F("web_RGB_Blue"), Settings.TaskDevicePluginConfig[event->TaskIndex][2], 0, 255);
addFormNumericBox(F("RGB Color"), F("web_RGB_Red"), Settings.TaskDevicePluginConfig[event->TaskIndex][0], 0, 255);
addNumericBox(F("web_RGB_Green"), Settings.TaskDevicePluginConfig[event->TaskIndex][1], 0, 255);
addNumericBox(F("web_RGB_Blue"), Settings.TaskDevicePluginConfig[event->TaskIndex][2], 0, 255);
// Brightness Selection
//addHtml(F("<TR><TD>Brightness:<TD>min<input type='range' id='web_Bright_Slide' min='0' max='255' value='"));
//addHtml(Settings.TaskDevicePluginConfig[event->TaskIndex][3]);
//addHtml(F("'> max"));
//sprintf_P(tmpString, PSTR("<TR><TD>Brightness:<TD>min<input type='range' id='web_Bright_Slide' min='0' max='255' value='"), Settings.TaskDevicePluginConfig[event->TaskIndex][3],"'> max");
//addHtml(tmpString);
//sprintf_P(tmpString, PSTR("<TR><TD>Brightness Value:<TD><input type='text' name='web_Bright_Text' id='web_Bright_Text' size='3' value='%u'>"), Settings.TaskDevicePluginConfig[event->TaskIndex][3]);
addHtml(String(Settings.TaskDevicePluginConfig[event->TaskIndex][3]));
addHtml(tmpString);
// Some Javascript we need to update the items
addHtml(F("<script script type='text/javascript'>"));
addHtml(F("function update(picker) {"));
addHtml(F(" document.getElementById('web_RGB_Red').value = Math.round(picker.rgb[0]);"));
addHtml(F(" document.getElementById('web_RGB_Green').value = Math.round(picker.rgb[1]);"));
addHtml(F(" document.getElementById('web_RGB_Blue').value = Math.round(picker.rgb[2]);"));
addHtml(F("}"));
addHtml(F("</script>"));
addHtml(F("<script type='text/javascript'>window.addEventListener('load', function(){"));
addHtml(F("var slider = document.getElementById('web_Bright_Slide');"));
addHtml(F("slider.addEventListener('change', function(){"));
addHtml(F("document.getElementById('web_Bright_Text').value = this.value;"));
addHtml(F("});"));
addHtml(F("});</script>"));
success = true;
case PLUGIN_WEBFORM_SAVE:
Settings.TaskDevicePluginConfig[event->TaskIndex][6] = getFormItemInt(F("web_Leds"));
Settings.TaskDevicePluginConfig[event->TaskIndex][7] = getFormItemInt(F("web_Columns"));
NUM_PIXEL = Settings.TaskDevicePluginConfig[event->TaskIndex][6] ; // Defines the amount of LED Pixel
NUM_PIXEL_ROW = Settings.TaskDevicePluginConfig[event->TaskIndex][7]; // Defines the amount of LED Pixel per Row
Settings.TaskDevicePluginConfig[event->TaskIndex][0] = getFormItemInt(F("web_RGB_Red"));
Settings.TaskDevicePluginConfig[event->TaskIndex][1] = getFormItemInt(F("web_RGB_Green"));
Settings.TaskDevicePluginConfig[event->TaskIndex][2] = getFormItemInt(F("web_RGB_Blue"));
Settings.TaskDevicePluginConfig[event->TaskIndex][3] = getFormItemInt(F("web_Bright_Text"));
Settings.TaskDevicePluginConfig[event->TaskIndex][4] = getFormItemInt(F("web_Candle_Type"));
Settings.TaskDevicePluginConfig[event->TaskIndex][5] = getFormItemInt(F("web_Color_Type"));
Candle_red = Settings.TaskDevicePluginConfig[event->TaskIndex][0];
Candle_green = Settings.TaskDevicePluginConfig[event->TaskIndex][1];
Candle_blue = Settings.TaskDevicePluginConfig[event->TaskIndex][2];
if (Candle_bright > 255) {
Candle_bright = 255;
Candle_bright = Settings.TaskDevicePluginConfig[event->TaskIndex][3];
Candle_type = (SimType)Settings.TaskDevicePluginConfig[event->TaskIndex][4];
success = true;
case PLUGIN_INIT:
NUM_PIXEL_ROW = Settings.TaskDevicePluginConfig[event->TaskIndex][7] ; // Defines the amount of LED Pixel per Row
if (Candle_red == 0 && Candle_green == 0 && Candle_blue == 0) {
Candle_bright = BRIGHT_START;
if (!Candle_pixels || GPIO_Set == false)
GPIO_Set = Settings.TaskDevicePin1[event->TaskIndex] > -1;
if (Candle_pixels) {
delete Candle_pixels;
Candle_pixels = new Adafruit_NeoPixel(NUM_PIXEL, Settings.TaskDevicePin1[event->TaskIndex], NEO_GRB + NEO_KHZ800);
SetPixelsBlack();
Candle_pixels->setBrightness(Candle_bright);
Candle_pixels->begin();
String log = F("CAND : Init WS2812 Pin : ");
log += Settings.TaskDevicePin1[event->TaskIndex];
addLog(LOG_LEVEL_DEBUG, log);
success = true;
case PLUGIN_ONCE_A_SECOND:
Candle_pixels->show(); // This sends the updated pixel color to the hardware.
success = true;
case PLUGIN_FIFTY_PER_SECOND:
case 0: // "Update" for OFF
type_Off();
case 1: // Update for LIGHT
type_Static_Light();
case 2: // Random Updates for Simple Candle, Advanced Candle, Fire Simulation
case 3:
if (timeOutReached(Candle_Update)) {
if (Candle_type == 2) {
type_Simple_Candle();
if (Candle_type == 3) {
type_Advanced_Candle();
Candle_Update = millis() + random(25, 150);
case 4: // Update for Police
type_Police();
Candle_Update = millis() + 150;
case 5: // Update for Blink
type_BlinkStrobe();
Candle_Update = millis() + 100;
case 6: // Update for Strobe
type_BlinkStrobe();
case 7: // Update for ColorFader
type_ColorFader();
Candle_Update = millis() + 2000;
//effects addition
case 8: // Update for Cylon
type_Cylon(5);
Candle_Update = millis() + NUM_PIXEL/20;
case 9: // Update for type_Sparkle
type_Sparkle();
case 10: // Update for type_rainbow
type_Rainbow();
Candle_Update = millis() + 20;
success = true;
case PLUGIN_READ:
UserVar[event->BaseVarIndex] = Candle_red * 65536 + Candle_green * 256 + Candle_blue;
UserVar[event->BaseVarIndex + 1] = Candle_bright;
UserVar[event->BaseVarIndex + 2] = Candle_type;
success = true;
case PLUGIN_WRITE:
String tmpString = string;
// Test
// MQTT : mosquitto_pub -d -t sensors/espeasy/ESP_Candle/cmd -m "CANDLE_OFF"
// HTTP : http://192.168.30.183/tools?cmd=CANDLE%3A5%3AFF0000%3A200
// http://192.168.30.183/tools?cmd=CANDLE:4:FF0000:200
// SERIAL : CANDLE:4:FF0000:200<CR><LF>
// Commands
// CANDLE:<FlameType>:<Color>:<Brightness>
// <FlameType> : 1 Static Light, 2 Simple Candle, 3 Advanced Candle, 4 Police, 5 Blink, 6 Strobe, 7 Color Fader , ...
// <Color> : n.def. Use the default color
// RRGGBB Use color in RRGGBB style (red, green blue) as HEX
// <Brightness> : 0-255
// Samples: CANDLE:2::100 Simple Candle with Default color and Brigthness at 100
// CANDLE:5:FF0000:200 Blink with RED Color and Brigthness at 200
// CANDLE:0:: Candle OFF
// CANDLE:1::255 Candle ON - White and full brigthness
if (tmpString.startsWith("CANDLE:")){
int idx1 = tmpString.indexOf(':');
int idx2 = tmpString.indexOf(':', idx1+1);
int idx3 = tmpString.indexOf(':', idx2+1);
int idx4 = tmpString.indexOf(':', idx3+1);
String val_Type = tmpString.substring(idx1+1, idx2);
String val_Color = tmpString.substring(idx2+1, idx3);
String val_Bright = tmpString.substring(idx3+1, idx4);
if (val_Type != "") {
if (val_Type.toInt() > -1 && val_Type.toInt() < SIMTYPE_LEN) {
Settings.TaskDevicePluginConfig[event->TaskIndex][4] = val_Type.toInt(); // Type
String log = F("CAND : CMD - Type : ");
log += val_Type;
if (val_Bright != "") {
if (val_Bright.toInt() > -1 && val_Bright.toInt() < 256) {
Settings.TaskDevicePluginConfig[event->TaskIndex][3] = val_Bright.toInt(); // Brightness
String log = F("CAND : CMD - Bright : ");
log += val_Bright;
if (val_Color != "") {
long number = strtol( &val_Color[0], NULL, 16);
// Split RGB to r, g, b values
byte r = number >> 16;
byte g = number >> 8 & 0xFF;
byte b = number & 0xFF;
Settings.TaskDevicePluginConfig[event->TaskIndex][0] = r; // R
Settings.TaskDevicePluginConfig[event->TaskIndex][1] = g; // G
Settings.TaskDevicePluginConfig[event->TaskIndex][2] = b; // B
Settings.TaskDevicePluginConfig[event->TaskIndex][5] = 1;
Candle_color = (ColorType)Settings.TaskDevicePluginConfig[event->TaskIndex][5]; // ColorType (ColorSelected)
String log = F("CAND : CMD - R ");
log += r;
log += F(" G ");
log += g;
log += F(" B ");
log += b;
} else {
Settings.TaskDevicePluginConfig[event->TaskIndex][5] = 0;
Candle_color = (ColorType)Settings.TaskDevicePluginConfig[event->TaskIndex][5]; // ColorType (ColorDefault)
addLog(LOG_LEVEL_DEBUG, F("CAND : CMD - Color : DEFAULT"));
//SaveTaskSettings(event->TaskIndex);
//SaveSettings();
success = true;
return success;
void SetPixelsBlack() {
for (int i = 0; i < NUM_PIXEL; i++) {
Candle_pixels->setPixelColor(i, Candle_pixels->Color(0, 0, 0));
void SetPixelToColor(int PixelIdx) {
Candle_pixels->setPixelColor(PixelIdx, Candle_pixels->Color(Candle_red, Candle_green, Candle_blue));
void type_Off() {
SetPixelsBlack();
void type_Static_Light() {
Candle_pixels->setPixelColor(i, 255, 255, 255); // Default is white
} else {
Candle_pixels->setPixelColor(i, Candle_red, Candle_green, Candle_blue);
void type_Simple_Candle() {
int r, g, b;
r = 226, g = 042, b = 35; // Regular (orange) flame
//r = 158, g = 8, b = 148; // Purple flame
//r = 74, g = 150, b = 12; // Green flame
} else {
r = Candle_red, g = Candle_green, b = Candle_blue;
// Flicker, based on our initial RGB values
int flicker = random(0, RANDOM_PIXEL);
int r1 = r - flicker;
int g1 = g - flicker;
int b1 = b - flicker;
if (g1 < 0) g1 = 0;
if (r1 < 0) r1 = 0;
if (b1 < 0) b1 = 0;
Candle_pixels->setPixelColor(i, r1, g1, b1);
void type_Advanced_Candle() {
Candle_Temp[0] = random(1, 4); // 1..4 LEDs in RED
Candle_Temp[1] = random(1, 4) + Candle_Temp[0]; // 1..3 LEDs in Yellow / Orange
Candle_Temp[2] = random(0, 2); // 0..1 Choose Yellow = 0 / Orange = 1
int colorbase[3];
int color1[3];
int color2[3];
int color3[3];
colorbase[0] = 255; colorbase[1] = 120; colorbase[2] = 0; // Light Orange #FF7800
color1[0] = 115; color1[1] = 50; color1[2] = 0; // Brown #733200
color2[0] = 180; color2[1] = 80; color2[2] = 0; // Orange #B45000
color3[0] = 70; color3[1] = 30; color3[2] = 0; // Dark brown #4A2000
} else {
colorbase[0] = Candle_red; colorbase[1] = Candle_green; colorbase[2] = Candle_blue;
double hsv[3];
// Calc HSV
RGBtoHSV(Candle_red, Candle_green, Candle_blue, hsv);
double newH = hsv[0] - 5;
if (newH < 0) { newH += 359; }
double newV = hsv[2] / 2;
double newV2 = hsv[2] / 4;
// Calc new RGBs
HSVtoRGB(newH, hsv[1], hsv[2], color1);
HSVtoRGB(hsv[0], hsv[1], newV, color2);
HSVtoRGB(newH, hsv[1], newV2, color3);
for (int j = 0; j < NUM_PIXEL/5; j++) {
for (unsigned int i = 1; i < 6; i++){
if (i <= Candle_Temp[0]) {
Candle_pixels->setPixelColor(j * 5 + i - 1, colorbase[0], colorbase[1], colorbase[2]);
if (i > Candle_Temp[0] && i <= Candle_Temp[1]) {
if (Candle_Temp[2] == 0){
Candle_pixels->setPixelColor(j * 5 + i - 1, color1[0], color1[1], color1[2]);
} else {
Candle_pixels->setPixelColor(j * 5 + i - 1, color2[0], color2[1], color2[2]);
if (i > Candle_Temp[1]) {
Candle_pixels->setPixelColor(j * 5 + i - 1, color3[0], color3[1], color3[2]);
void type_Police() {
Candle_Temp[0]++;
if (Candle_Temp[0] > NUM_PIXEL / 5) {
Candle_Temp[0] = 0;
if (i == Candle_Temp[0])
for (int j = 0; j < 5; j++) {
Candle_pixels->setPixelColor(i * 5 + j, 0, 0, 255);
} else {
Candle_pixels->setPixelColor(i * 5 + j, Candle_red, Candle_green, Candle_blue);
} else {
Candle_pixels->setPixelColor(i * 5 + j, 0, 0, 0);
void type_BlinkStrobe() {
Candle_Temp[0]++;
if (Candle_Temp[0] > 1) {
Candle_Temp[0] = 0;
if (Candle_Temp[0] == 0) {
Candle_pixels->setPixelColor(i, 0, 0, 0);
} else {
} else {
void type_ColorFader() {
int colors[3];
double hsv[3];
if (Candle_color != ColorDefault) {
if (Candle_Temp[0] > 254 && Candle_Temp[1] == 1) {
Candle_Temp[1] = 0;
if (Candle_Temp[0] < 55 && Candle_Temp[1] == 0) {
Candle_Temp[1] = 1;
if (Candle_Temp[1] > 0) {
Candle_Temp[0]++;
} else {
Candle_Temp[0]--;
// Calc HSV
// void RGBtoHSV(byte r, byte g, byte b, double hsv[3])
// Calc RGB with new V
// HSVtoRGB(int hue, int sat, int val, int colors[3])
// hue: 0-359, sat: 0-255, val (lightness): 0-255
HSVtoRGB(hsv[0], hsv[1], Candle_Temp[0], colors);
Candle_pixels->setPixelColor(i, colors[0], colors[1], colors[2]);
} else {
Candle_Temp[0]++;
if (Candle_Temp[0] > 359) {
Candle_Temp[0] = 0;
HSVtoRGB(Candle_Temp[0], 255, 255, colors);
// Effects additions
void type_Cylon(int EyeSize){
byte red = 255; byte green = 255 ; byte blue = 255 ; // Default is white
red = Candle_red; green = Candle_green ; blue = Candle_blue ;
if (Candle_Temp[0] >= NUM_PIXEL-EyeSize-1 ) { //max value
Candle_Temp[1] = 0; //decrease
} else if (Candle_Temp[0] <=0 ) { //min value
Candle_Temp[1] = 1; //increase
if ( Candle_Temp[1] == 0 ) { // decrease
Candle_Temp[1] = 0;
Candle_Temp[0]--;
} else { //increase
Candle_Temp[1] = 1;
Candle_Temp[0]++;
for(int i = 0; i < NUM_PIXEL-EyeSize-1; i++) {
if (Candle_Temp[0]==i) {
Candle_pixels->setPixelColor(i-1, 0, 0, 0);
Candle_pixels->setPixelColor(i, red/10, green/10, blue/10);
for(int j = 1; j <= EyeSize; j++) {
Candle_pixels->setPixelColor(i+j, red, green, blue);
Candle_pixels->setPixelColor(i+EyeSize+1, red/10, green/10, blue/10);
Candle_pixels->setPixelColor(i+EyeSize+2, 0, 0, 0);
void type_Sparkle() {
int Pixel ;
for (int i=0 ; i<10; i++)
Pixel = random(NUM_PIXEL);
Candle_pixels->setPixelColor(Pixel,red,green,blue);
Candle_pixels->setPixelColor(Pixel,0,0,0);
void type_Rainbow() {
byte *c;
uint16_t i;
//for(j=0; j<256*5; j++) { // 5 cycles of all colors on wheel
Candle_Temp[0]++ ;
if (Candle_Temp[0] > 256*5 ) Candle_Temp[0] = 0;
for(i=0; i< NUM_PIXEL; i++) {
c=Wheel(((i * 256 / NUM_PIXEL) + Candle_Temp[0]) & 255);
Candle_pixels->setPixelColor(i, *c, *(c+1), *(c+2));
byte * Wheel(byte WheelPos) {
static byte c[3];
if(WheelPos < 85) {
c[0]=WheelPos * 3;
c[1]=255 - WheelPos * 3;
c[2]=0;
} else if(WheelPos < 170) {
WheelPos -= 85;
c[0]=255 - WheelPos * 3;
c[1]=0;
c[2]=WheelPos * 3;
} else {
WheelPos -= 170;
c[0]=0;
c[1]=WheelPos * 3;
c[2]=255 - WheelPos * 3;
return c;
// Convert HSC Color to RGB Color
void HSVtoRGB(int hue, int sat, int val, int colors[3]) {
int r=0, g=0, b=0, base=0;
if (sat == 0) { // Achromatic color (gray).
colors[0]=val;
colors[1]=val;
colors[2]=val;
else {
base = ((255 - sat) * val)>>8;
switch(hue/60) {
case 0:
r = val;
g = (((val-base)*hue)/60)+base;
b = base;
case 1:
r = (((val-base)*(60-(hue%60)))/60)+base;
g = val;
b = base;
case 2:
r = base;
g = val;
b = (((val-base)*(hue%60))/60)+base;
case 3:
r = base;
g = (((val-base)*(60-(hue%60)))/60)+base;
b = val;
case 4:
r = (((val-base)*(hue%60))/60)+base;
g = base;
b = val;
case 5:
r = val;
g = base;
b = (((val-base)*(60-(hue%60)))/60)+base;
colors[0]=r;
colors[1]=g;
colors[2]=b;
// Convert RGB Color to HSV Color
void RGBtoHSV(byte r, byte g, byte b, double hsv[3]) {
double rd = (double) r/255;
double gd = (double) g/255;
double bd = (double) b/255;
double maxval = rd;
if (gd > maxval) { maxval = gd; }
if (bd > maxval) { maxval = bd; }
double minval = rd;
if (gd < minval) { minval = gd; }
if (bd < minval) { minval = bd; }
double h = 0, s, v = maxval;
double d = maxval - minval;
s = maxval == 0 ? 0 : d / maxval;
if (maxval == minval) {
h = 0; // achromatic
} else {
if (maxval == rd) {
h = (gd - bd) / d + (gd < bd ? 6 : 0);
} else if (maxval == gd) {
h = (bd - rd) / d + 2;
} else if (maxval == bd) {
h = (rd - gd) / d + 4;
h /= 6;
hsv[0] = h * 360;
hsv[1] = s * 255;
hsv[2] = v * 255;
#endif // USES_P042
I'm not so good at adding attachments, so hoping for the best. I have a video but can't seem to attach the .mov file type.
- IMG_1522.JPG (936.58 KiB) Viewed 41761 times
So you got it working now
I will have a look at your changes, since this plugin should be included in the current code base I guess.
See https://github.com/letscontrolit/ESPEas ... Candle.ino
I added an issue to merge the fixes: https://github.com/letscontrolit/ESPEasy/issues/1888
Is there any newbie guide of how to set up everything starting from a newly flashed wemos?
Unfortunately, moelski is not reading private messages, so I have to post it here...
Can anyone help me out to get a 24-LED-ring working?
I'm not very experienced in coding, so I don't know what to change and how to compile an "own" ESPeasy version....
I'd read somewhere that there is a plugin version where you can "Switch" the number of pixels on the ESPeasy webpage, but couldn't find it....?!?
Any help would be appreciated, my wife is killing me cause our bed light lamp are dissassembled since weeks....
Kind regards,
P406
Kind regards,
P406
Users browsing this forum: No registered users and 66 guests
