Measuring Temperature, Humidy, Controlling Relais and reading Switches with fhem.
Working very good.
But I have a simple problem: write a rule letting a LED blink with 1Hz.
With PWM I can’t control the frequency.
I tried this:
On System#Boot do
gpio,13,1
timerSet,1,1
On Rules#Timer=1 do
gpio,13,0
timerSet,2,1
On Rules#Timer=2 do
gpio,13,1
timerSet,1,1
‘timerSet’ with times lower 1 seems not to work.
My next try:
On System#Boot do
pulse,13,1,500
timerSet,1,3
On Rules#Timer=1 do
pulse,13,1,500
pulse,13,0,500
pulse,13,1,500
pulse,13,0,500
pulse,13,1,500
pulse,13,0,500
pulse,13,1,500
pulse,13,0,500
pulse,13,1,500
pulse,13,0,500
pulse,13,1,500
pulse,13,0,500
timerSet,1,1
So I read about ‘longpulse’. Tried with a http command and seems that the Parameter is in seconds.
Filled in the longpulse in the example above, but did not work.
Are timer and longpulse conflict ESP internal resources???
Till now no good solution:
- Blink frequency 1Hz or faster
- Low CPU load
- Fast Web response
May be there is a simple solution. I’m not so experienced….
Thank you!
Willi
