Private project [HÖRMANN REMOTE CONTROLLED GARAGE PORT CONTROLLED WITH ESP8266]
danmero
Re: Private project [HÖRMANN REMOTE CONTROLLED GARAGE PORT CONTROLLED WITH ESP8266]
#11 Post by danmero » 22 May 2018, 22:56
My unit did not have a connection for a simple NO. Only a flat cable to the membrane switch panel.
Can you post the model of your door control.
Regarding open close status. Another esp is doing that. It has a limit switch for the close status. And a rotary encoder for position if open.
I use the same NodeMCU, 2 NO contacts for Open/Close, one Dummy to hold the last state Open/Close and rules/timers to trigger the action.
- If both open and dummy value 1 , action closing.
- If both open and dummy value 0, action opening.
- If door close , dummy value 0, strobe off
- if door open , dummy value 1
For dual garage door, 2 controllers I use one NodeMcu, 4 door contacts, 2 LED strobe.
Regards,
#12 Post by grovkillen » 23 May 2018, 08:06
My model is SupraMatic E2
danmero
#13 Post by danmero » 23 May 2018, 09:16
SupraMatic E2 page 34 img 11 (best I can find) or from factory SupraMatic E3 page 24 img 12
Regards,
#14 Post by grovkillen » 23 May 2018, 09:43
Those terminals are not on my unit. I guess it's a cheap one?
danmero
#15 Post by danmero » 23 May 2018, 10:48
Do you have the original battery backup package?
#16 Post by grovkillen » 23 May 2018, 12:45
No not that I've seen.
danmero
#17 Post by danmero » 23 May 2018, 13:35
Take a look at this link
Regards,
#18 Post by grovkillen » 23 May 2018, 14:44
No I don't have that one.
