HDC1080 is not showing any value in Domoticz
I have just tried to connect two HDC1080 sensors, but the sensor is not showing any value in Domoticz. Other sensors like DHT11, HTU21D are working without any issue. In Config page of ESP Easy there is a value, but it looks like it is not sending it to domoticz... I use the ESPEasy_v2.0.0-dev12_dev_4096 firmware and ESP8266 dev board with 4MB.
Thank you in advance for any help!
Re: HDC1080 is not showing any value in Domoticz
A screenshot of the device config would be good. Have you checked the IDX is the same as in Domoticz?
I will send it later, but on the same ESP I have HDU21 and it is working, but the HDC1080 not... I will send later a screen from ESP, here screens from domoticz:
- HTU21D+HDC1080 not showing temperature.PNG (43.24 KiB) Viewed 6955 times
- HTU21D+HDC1080 hw config.PNG (12.14 KiB) Viewed 6955 times
Before blaming the plugin you shoudl read the datasheet of what you are using
Both HDC1080 and HTU21D uses same I2C address (0x40) so it's normal that both can't work in the same ESP!
For the future please always try to run basic tests, like connecting just one sensor at one time and verify it can work alone whcih probably you didn't do it here...
Then I advise you to always read the datasheets/documentation of your sensors and I'm sure you can understand immediately where the problem is
But look at this, in esp it is showing value ok. I have also second esp with only hdc1080 and it is also not working with domoticz, but in esp see it show values...
- IMG_20171021_230922.jpg (96.76 KiB) Viewed 6922 times
I'm not familiar with Domoticz so I can't help further; what did you get when you run I2C scanner?
Definitely 2 devices on same address is not an optimal setup, then I'm not sure how yours 2 sensors works
The only thing I have to set to send value to domoticz is Domoticz Index of device. I already tried also to change these ID's in EspEASY between other sensor and HDC. The my domoticz was showing other sensor's value as HDC1080, but the real signal from HDC1080 should be shown as the other sensor, but it was also not working. So it do not look like Domoticz problem. I'm afraid, there is an issue with HDC1080 in ESP easy...
Well, sensor plugin has nothign to do with controller data sending as far as I know...
Just tested again my HDC1080 and it's correctly sending MQTT messages to my Raspberry mosquitto so no idea how to help as from my point of view plugin seems to work ok either when I develop it or now when I test it again...
After update to: Release mega-20180524 the problem is gone
Thank you for your support!
Users browsing this forum: Bing [Bot] and 67 guests
