Meek Wifi wall switch ESP8266
papperone
Re: Meek Wifi wall switch ESP8266
#31 Post by papperone » 17 Nov 2017, 10:00
Shardan wrote: 16 Nov 2017, 22:22I avoid all copper on the antenna area + 2..4 mm around. For some devices i'm using an ESP-07S. It's the ESP-12 without any antenna, it has an antenna plug instead so i can use a standard WiFi Antenna or an antenna pcb glued inside the case.
Indeed I have experienced strange behaviour in my first PCB prototype when I was not paying attention to this, now I cut the PCB in order to even avoid mistakes running traces won't be possible if there's no PCB underneath :D
I will look for the ESP07 module, should be not too bad in specific scenarios to implement by deafault external connector for antenna...
#32 Post by Shardan » 17 Nov 2017, 13:04
ESP-07S for example here:
https://de.aliexpress.com/item/1-Piece- ... eLevelAB=0
PCB-antenna example for inside case mounting:
https://de.aliexpress.com/item/Notebook ... eLevelAB=0
Standard Wifi antenna example:
https://de.aliexpress.com/item/WIFI-SUP ... eLevelAB=0
HTH
Meek
#33 Post by Meek » 23 Nov 2017, 23:53
Hello, as promised, the Meek A5v1 has been assembled.
I’ve uploaded a short video of YouTube : https://www.youtube.com/watch?v=7RES49RK4Bw
During the assembling process, I’ve discover an inconvenience (my way of saying that I’ve made a childish error :oops: ), therefore some amendments had to be made during the assembling process.
This caused a misalignment of the WS2812B and therefore the illumination of the switch is way off.
Nevertheless, it’s been a successful Alpha/trial and in the Beta versions, some extra modules will be placed like the RCWL-0516 and perhaps a DHT11 sensor as a test.
Meek
#34 Post by Meek » 24 Nov 2017, 00:09
papperone wrote: 16 Nov 2017, 16:10 Nice job, if I may suggest for next revision, I don't see any protection on the AC board (at least a replaceable fuse and an optional varistor to filter...) which shoudl be highly advisable beign those units fitting inside a small wall-box...
Good point, for now, the only protection I've installed was a glass fuse on the 230V side.
From the testing I've done locally in The Netherlands, this was adequate for the time being as our net 230V is "pretty clean and stable".
For the future Meek switches, I most likely will be adding more protection on both sides (230V & 5V/3.3V) just to be on the safe side.
Thank you for your suggestion.
papperone
#35 Post by papperone » 24 Nov 2017, 06:54
Meek wrote: 24 Nov 2017, 00:09Good point, for now, the only protection I've installed was a glass fuse on the 230V side.
You are welcome; I'm designing my own touch switch (to fit my electrical boxes standard) since months! I've been too ambitius as I wanted it modular and covering as many combination as possible then I'm struggling still with the PCBs design.
Happy to see you at least moved to ALPHA stage, I'm not close to even send PCB for manufacturing!!! May I ask you if you can share some picture of the inside? I'm curious I know :mrgreen:
Meek
#36 Post by Meek » 13 Dec 2017, 22:58
Update Dec2017:
The switches are evolving and I’ve already reached the Beta phase. The main functions are fully operational.
I’m now concentrating on the extra modules/functions that can be integrated into the Meek switches.
At this stage I’m trying to integrating a RWCL-0516 radar motion sensor into the Meek switch. I’m struggling to resolve the interference between the ESP8266 and the RWCL-0516 sensor.
In the new Beta’s, the antennas of the ESP8266 & RWCL-0516 are separated as “far as possible” on the PCB’s, also added some extra electronic components to eliminate fluctuations on the power lines.
If you have any thoughts on resolving the interference, please let me know.
Next week, I hope to receive all the components to assemble the Beta 7 versions of the Meek switch.
As we’re nearing the release of the first switches, I’ve included extra safety measures like a varistor, thermal fuses and off course a regular fuse.
If you have any thoughts or remarks, please let me know.
#37 Post by TD-er » 13 Dec 2017, 23:53
I have done some playing with the RWCL-0516 radar motion sensor myself.
They are great, but you have to 'tunnel' them to get a bit directional detection.
I used some aluminium soda cans to play with and those also reduced the sensitivity.
You have to place some metal (completely closed) in the direction where you do not want sensitivity.
How do you plan to incorporate these shields inside the wall switch?
I guess such a shield will affect WiFi performance.
Meek
#38 Post by Meek » 14 Dec 2017, 09:51
It's a very good question and the answer is : I don't know it……. yet :roll:
With the test I've conducted, separating the antenna of the sensor and ESP unit with a couple of centimeters, reduced the false positives in a great matter.
Adding filters close to the power input of the sensor, had also a positive effect.
Combining these 2 will increase the reliability, but at this stage, I'm not sure if these countermeasures completely eliminate the false positives.
Furthermore, tweaking the software side might also be something to look at.
Last resource will be adding an “electronic fence” around the sensor.
But with the small compartment to work with, this might be the last resort.
I’ll explore alternative solutions and conduct more testing to see how I can incorporate this sensor into the Meek switch.
If you have more concerns or perhaps idea’s, please be welcome to share.
Meek
#39 Post by Meek » 14 Dec 2017, 10:06
papperone wrote: 24 Nov 2017, 06:54
Next week, I hope to assemble the (hopefully)final Beta switch.
I will shoot some pictures of the assembling process and also of the components.
If you can and willing, you could also consider sharing some info/pictures and perhaps we can learn something from each other.
Perhaps this will give us an extra boost in the development process ?
Meek
#40 Post by Meek » 21 Dec 2017, 21:39
I’ve assembled the Meek (Beta 7) switch with an integrated RCWL-0516 module and with all the filters, the accuracy improved enormously.
That been said/written, in the first night where I tested the Meek switch, he gave 3 “false positives” during a 9 hours trial.
I’ve setup the switch in my kitchen that overlooks at our garden. It could be possible that there were some animal activities that has been captured by the sensor but I cannot tell for sure.
But no matter what caused the “false positives” the results were not satisfactory.
So I went back to do more testing and measuring and found that by repositioning the sensor (although it’s a 360degree sensor) the accuracy improved even more !
Tonight, I will conduct a test in my attic to rule out “jammers”.
I’ll keep you posted and in the meantime, here are some pictures of some of the components :
papperone
#41 Post by papperone » 22 Dec 2017, 12:46
great progress!!!
I'm finalizing my PCb to send them out for manufacturing...
Can you please let me know the names of these screw connectors (and maybe a link) as I'd like to use them but never found them online for purchase?
Immagine 2.png (170.49 KiB) Viewed 36049 times
Meek
#42 Post by Meek » 22 Dec 2017, 13:11
I know, it was indeed a difficult search for me too.
I've found them at AliExpress :
https://nl.aliexpress.com/item/circuit- ... eLevelAB=5
If you find alternatives, please do share and thank you for your interest in this project !
papperone
#43 Post by papperone » 22 Dec 2017, 13:58
Meek wrote: 22 Dec 2017, 13:11 I know, it was indeed a difficult search for me too.
Thanks, so far the plan was to use standard screw terminal, now I will evaluate these ones :)
I'm less advanced than you but I promise I'll share as soon as I will go to prototyping my solution (even thou it'll be pretty much customized to italian wall-box standard size :( )
PS: I did not plan to have any type of proximity/radar sensor yet but would be interesting to see your final design...
As well I plan to use mechanical/SSR relays instead of Triacs, to be able to switch different type of loads and to separate the switched circuits from the rest of electronics, but I'm curious to see your final product behaviour and performances!
ManS-H
#44 Post by ManS-H » 22 Dec 2017, 19:07
What do you think of these?
https://nl.aliexpress.com/item/PCB-wiri ... 99971.html
Meek
#45 Post by Meek » 23 Dec 2017, 09:04
ManS-H wrote: 22 Dec 2017, 19:07
Thank you for pointing these out, unfortunately, these were not compatible with the casing dimensions that I use.
Perhaps someone else would find this link useful as it was really hard to find these connectors.
I'm still searching for alternative connectors of a height of 9mm with a PCB fitting that could only be connected in a certain angle. The reason is simply that with the round bottoms, it’s really hard to solder them in a 0’degree angle in relation to the PCB.
So please, if you find alternatives please share it here, perhaps your link would be useful for me or someone else who’s in need of these connectors.
Once again, thank you for pointing this out, I really appreciate it !
Meek
#46 Post by Meek » 23 Dec 2017, 09:05
The last test over a period of 10 hours, had a hit rate of 100%.
Now I need to finalize the code/rules to operate on motion once the Lux meter drops to a certain level.
After that, I will install it in my kitchen an post a video of the operation.
Meek Beta7 RCWL0516.PNG (110.21 KiB) Viewed 36000 times
papperone
#47 Post by papperone » 23 Dec 2017, 09:47
Meek wrote: 23 Dec 2017, 09:05 The last test over a period of 10 hours, had a hit rate of 100%.
So you mean you succeed to position/screen the radar sensor in order to avoid false triggering?
Woudl be interestign to see how you accomplished that goal!!
#48 Post by TD-er » 23 Dec 2017, 18:25
Indeed, adjusting sensor direction and sensitivity of these sensors is something I'm very interested in.
enesbcs
#49 Post by enesbcs » 23 Dec 2017, 19:20
papperone wrote: 23 Dec 2017, 09:47 So you mean you succeed to position/screen the radar sensor in order to avoid false triggering?
I am using RCWL radar sensor output + a normal PIR such as SR501/SR505 together with a logical AND gate and i did not see false triggers yet.
I think some aluminum foil can be used to mask the detection area, but not tested. :)
Anyway it's a very nice project!
Meek
#50 Post by Meek » 26 Dec 2017, 18:17
I have finally accomplished the fully integration of a Doppler radar into the Meek switch. As promised, I’ve uploaded a video on YouTube of the newest Meek switch in action.
https://www.youtube.com/watch?v=vO8sSX1eiEU
The development continues and I’m almost ready to release the first small quantities of the Meek switches to the public. I’ll keep you informed ;)
Meek
#51 Post by Meek » 05 Jan 2018, 18:16
Herewith a picture of the PCB designs that will make it into the production models.
As the development of these Meek switches are nearing completion, I’m shifting my focus on the expansions.
One of the most requested expansion is, by far, the Meek dimmable Wifi Enabled Smart Switch. Once I have some info to share, I will report it here.
I’m also doing my utmost to have the website available at : http://www.meek-ha.com/
In the future, I will post some manuals and programming guides for the home automation systems and, ofcourse, manuals with the Meek Switches.
Thank you for your interest in this project !
ManS-H
#52 Post by ManS-H » 05 Jan 2018, 18:24
Looks good.
Meek, do you also think of a kind of remote control switch, especially for Sonoff users?
#53 Post by TD-er » 06 Jan 2018, 14:41
It looks like the big pads will have 230V~ on them. Do they have at least 3 mm distance from eachother?
And perhaps round the edges of these pads?
Meek
#54 Post by Meek » 15 Feb 2018, 17:29
TD-er wrote: 06 Jan 2018, 14:41 It looks like the big pads will have 230V~ on them. Do they have at least 3 mm distance from eachother?
The big pads will indeed carry 230V. Due to design of the casing, it does not allow me to have a 3mm clearing between the 230V and the switching connectors.
The clearance between the 230V and Neutral will be exceeding 10mm.
Besides the clearances, I have included a fuse and an overvoltage protector on the 230V side.
On the 5V side, an overcurrent protection is applied and air gaps are also a part of the design.
The “sharp corners” are also been addresses on the new design Meek Switches.
From a safety perspective these switches are equipped with several safety features that makes this switch safe to operate.
Before the end of this month (Feb2018), I will send the latest design PCB’s to the manufacturers and hope to assemble them short after.
If you have other comments on how to improve the Meek switches, I’m all ears.
#55 Post by TD-er » 15 Feb 2018, 19:23
Meek wrote: 15 Feb 2018, 17:29[...]
Do you have a link to the latest designs?
Meek
#56 Post by Meek » 17 Feb 2018, 13:34
Just uploaded a video with regards to the development of Meek MD1 ( Meek Wi-Fi enabled Dimmer)
https://www.youtube.com/watch?v=Y9hVDwKcEDw
Meek
#57 Post by Meek » 25 Feb 2018, 22:52
TD-er wrote: 15 Feb 2018, 19:23
I have send the newest PCB designs for production.
Once I receive them, I will assemble a few pieces, and as you are located in the Netherlands, perhaps we can meet somewhere so I can hand over a model to you for testing purposes ?
#58 Post by TD-er » 26 Feb 2018, 21:25
Meek wrote: 25 Feb 2018, 22:52 [...]
That would be cool :)
Where in the Netherlands do you live?
Meek
#59 Post by Meek » 27 Feb 2018, 19:23
TD-er wrote: 26 Feb 2018, 21:25
In the Netherlands, we couldn’t be further apart from each other as I’m living in Zeeland ;)
I do travel a lot, but in the past 15 years, I’ve been once in “Grunn'n”.
Let’s see how we can overcome this small “hurdle”.
#60 Post by TD-er » 27 Feb 2018, 21:33
That's indeed quite far away.
But we'll figure out something :)
Meek
#61 Post by Meek » 09 Mar 2018, 19:34
I promised to release the code for the Meek MD1 dimmer once all options are integrated and fully operational, but due to shift in priorities and limited time, I am unable to finish the coding on a short notice.
Therefore I’ll publish the “dirty” code for the time being.
It’s still work in progress and 1 of the major things that I’m currently working on, is the synchronization between the dim-levels and Domoticz. So for instance if the dim-level is on 50% on Domoticz, on the ATmega, this correspondence’s with a value around the 380. So when I manually change this to 260, Domoticz should jump to 25%. With the code below, this is fully operational. But, the manual fine-tuning part, still needs to be coded. For instance, if I manually set the dim-level at a value of 261, Domoticz will set it back to 260. So in the coding I have to build a rounding function so it’ll ignore smaller input changes send by Domoticz.
As you can see in the code, I’m trying to code the ATmega328P as flexible as possible, so you can change setting afterwards as you wish. Also flashing the ATmega328P will be somewhat cumbersome without dedicated equipment.
That’s one of the reasons why I want a full set of options and gimmicks as much as possible in the coding. So if you wish additions or have good ideas, please do inform us and if possible, amend the coding 
One of the hardcoding will be something like “disco mode” so the lights will max out and back to minimum in a loop.
Once again, if you have additions or cool idea’s, please share it with us.
Herewith a video of the dimmer in action :
Coding is borrowed from the following sources :
https://playground.arduino.cc/Main/ACPhaseControl
https://github.com/letscontrolit/ESPEas ... tender.ino
 * Arduino project "ESP Easy" � Copyright www.esp8266.nu
 * This program is free software: you can redistribute it and/or modify it under the terms of the GNU General Public License
 * as published by the Free Software Foundation, either version 3 of the License, or (at your option) any later version.
 * This program is distributed in the hope that it will be useful, but WITHOUT ANY WARRANTY; without even the implied warranty
 * of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU General Public License for more details.
 * You received a copy of the GNU General Public License along with this program in file 'License.txt'.
 * IDE download    : https://www.arduino.cc/en/Main/Software
 * ESP8266 Package : https://github.com/esp8266/Arduino
 * Source Code     : https://sourceforge.net/projects/espeasy/
 * Support         : http://www.esp8266.nu
 * Discussion      : http://www.esp8266.nu/forum/
 * Additional information about licensing can be found at : http://www.gnu.org/licenses
// This file is to be loaded onto an Arduino Pro Mini so it will act as a simple IO extender to the ESP module.
// Communication between ESP and Arduino is using the I2C bus, so only two wires needed.
// It best to run the Pro Mini on 3V3, although the 16MHz versions do not officially support this voltage level on this frequency.
// That way, you can skip levelconverters on I2C.
// Arduino Mini Pro uses A4 and A5 for I2C bus. ESP I2C can be configured but they are on GPIO-4 and GPIO-5 by default.
#include <Wire.h>
#include <avr/io.h>
#include <avr/interrupt.h>
#define DETECT 2  //zero cross detect
#define GATE 3    //TRIAC gate
#define PULSE 4   //trigger pulse width (counts)
int Meek;
int StepDown=1;
int StepUp=1;
int InputDelay=100;
int Domoticz;
int Domoticz1;
int Difference ;
int UpperLimit = 605;
int LowerLimit = 150;
#define I2C_MSG_IN_SIZE    4
#define I2C_MSG_OUT_SIZE   4
#define CMD_DIGITAL_WRITE  1
#define CMD_DIGITAL_READ   2
#define CMD_ANALOG_WRITE   3
#define CMD_ANALOG_READ    4
#define omhoog 8
#define omlaag 12
volatile uint8_t sendBuffer[I2C_MSG_OUT_SIZE];
void setup()
  Wire.begin(0x7f);
  Wire.onReceive(receiveEvent);
  Wire.onRequest(requestEvent);
  Serial.begin(9600);
  pinMode(omhoog, INPUT);
  pinMode(omlaag, INPUT);
// set up pins
  pinMode(DETECT, INPUT);     //zero cross detect
  digitalWrite(DETECT, HIGH); //enable pull-up resistor
  pinMode(GATE, OUTPUT);      //TRIAC gate control
  // set up Timer1
  //(see ATMEGA 328 data sheet pg 134 for more details)
  OCR1A = 100;      //initialize the comparator
  TIMSK1 = 0x03;    //enable comparator A and overflow interrupts
  TCCR1A = 0x00;    //timer control registers set for
  TCCR1B = 0x00;    //normal operation, timer disabled
  attachInterrupt(0,zeroCrossingInterrupt, RISING);
void zeroCrossingInterrupt(){ //zero cross detect
  TCCR1B=0x04; //start timer with divide by 256 input
  TCNT1 = 0;   //reset timer - count from zero
ISR(TIMER1_COMPA_vect){ //comparator match
  digitalWrite(GATE,HIGH);  //set TRIAC gate to high
  TCNT1 = 65536-PULSE;      //trigger pulse width
ISR(TIMER1_OVF_vect){ //timer1 overflow
  digitalWrite(GATE,LOW); //turn off TRIAC gate
  TCCR1B = 0x00;          //disable timer stopd unintended triggers
void loop() {
Difference = round(UpperLimit / LowerLimit);
if (Meek>=0 && Meek<=100) {
  Domoticz = Meek;
if (Meek>=LowerLimit && Meek<=UpperLimit) {
  Domoticz1 = map(OCR1A , LowerLimit, UpperLimit, 0 , 100);
if (Meek>=1 && Meek<=100) {
OCR1A =map(Meek,1,100, LowerLimit,UpperLimit);
if (Meek>=LowerLimit && Meek<=UpperLimit && Difference > (Domoticz-Domoticz1)) {
  Domoticz = Domoticz1;
OCR1A = Meek;     }
if (Meek>=1500 && Meek<=1599){
  StepDown=(Meek-1500);}
if (Meek>=1600 && Meek<=1699){
  StepUp=(Meek-1600);}
if (Meek>=1700 && Meek<=1799){
  InputDelay=(Meek-1700);}
if (Meek>=1800 && Meek<=1899 && OCR1A>150 && OCR1A<=603 ){
  OCR1A=(OCR1A-(Meek-1800));}
if (Meek>=1900 && Meek<=1999 && OCR1A>=150 && OCR1A<603 ){
  OCR1A=(OCR1A+(Meek-1900));}
if (Meek==2000 && OCR1A>=150 && OCR1A<=603){
  OCR1A=(OCR1A+1);}
if (Meek==2000 && OCR1A==604){
  OCR1A=(0);}
if (Meek==2001 && OCR1A==0){
  OCR1A=(605);}
if (Meek==2001 && OCR1A<=603 && OCR1A>=150){
  OCR1A=(OCR1A-1);}
if (OCR1A>UpperLimit) {
OCR1A=UpperLimit;}
if (OCR1A>0 && OCR1A<=LowerLimit) {
OCR1A=LowerLimit;}
Serial.print("Meek = ");
Serial.print(Meek);
Serial.print("OCR1A = ");
Serial.print(OCR1A);
Serial.print("domoticz =");
Serial.print(Domoticz);
Serial.print("Difference =");
Serial.print(Difference);
Serial.print("Domoticz11111 =");
Serial.print(Domoticz1);
delay(1000);
Serial.print('\n');
int hoog = digitalRead (omhoog);
if (hoog == 1 ){
  OCR1A=(OCR1A+1) ;
int laag = digitalRead (omlaag);
if (laag == 1 ){
  OCR1A=(OCR1A-1);
delay(InputDelay);
void receiveEvent(int count)
  if (count == I2C_MSG_IN_SIZE)
    byte cmd = Wire.read();
    byte port = Wire.read();
    int value = Wire.read();
    value += Wire.read()*256;
    switch(cmd)
        case CMD_DIGITAL_WRITE:
          pinMode(port,OUTPUT);
          digitalWrite(port,value);
        case CMD_DIGITAL_READ:
          pinMode(port,INPUT_PULLUP);
          clearSendBuffer();
          sendBuffer[0] = digitalRead(port);
        case CMD_ANALOG_WRITE:
          //analogWrite(port,value);
          Meek=(value);
        case CMD_ANALOG_READ:
          clearSendBuffer();
          int valueRead = Domoticz;
          sendBuffer[0] = valueRead & 0xff;
          sendBuffer[1] = valueRead >> 8;
void clearSendBuffer()
  for(byte x=0; x < sizeof(sendBuffer); x++)
    sendBuffer[x]=0;
void requestEvent()
  Wire.write((const uint8_t*)sendBuffer,sizeof(sendBuffer));
Meek
#62 Post by Meek » 15 Mar 2018, 21:43
LisaM wrote: 02 Nov 2017, 09:29
Meek wrote: 01 Nov 2017, 18:18 several modules like : temperature sensor, humidity, PIR, Microwave radar sensor, microphone (array for speech recognition), etc..
If you put these sensors in very closed environment like a wall switch, doesn't the switch make the operation of these sensors very difficult?
For example the temperature sensor values might be corrupted by the heat dissipated by the esp due to the closed environment.
I’ve had the beta Meek MT1(1 touch button) and Meek MP1 (Meek presence with 2 outputs) equipped with a DS18b20 running for more than a month, and the temperature readings were very dependent on the power output of the triacs/power consumption of the light bulbs.
The readings and comparisons are made with an external temperature meter and in the graphics, they were put next to each other with the readings of my thermostat (Toon) placed in the living room.
The DS18b20 sensors were placed inside the casing and were 2.5cm off center from the hart of the PCB with the following results :
Meek MT1 Temperature.JPG (68.35 KiB) Viewed 34349 times
In the bedroom, I’ve had a light bulb with a power consumption of less than 50Watts, and the readings in relation to my thermostat (Toon) were pretty close. When the lights were on for a substantial time, the temperature rose on an average 1.2 Celsius degrees.
On the other hand, on the Meek MP1 with 2 outputs :
Output 1 (triac 1) , 2 LED lightbulbs with a total power consumption of ~30 Watts
Ouput 2 (triac 2), 3 transformers (inductive loads) , with 9 light bulbs, consuming >200 Watts
When all the lights were ignited, the temperature increased and peaked within 30 min. with 4.4 Celsius degrees. After this period of time, the temperature rise stagnated and stayed stable with a deviation around the 4.4 Celsius degree.
So the contamination was way off to be usable.
We have found a way to move the sensor outside the casing (almost 5cm off center), and the first trials were solid. Even with high loads (exceeding 500Watts) the temperature stayed stable and no noticeable deviation was measures in the test environment :D
Once the new PCB’s are in, we will assemble a few and put it to test to see how they function in a real life environment.
I’ll keep you updated on the results !
barrymossel
#63 Post by barrymossel » 30 Mar 2018, 15:06
Really nice work! Will you ever be designing 2-gang dimmers and switches? I would be ordering those right away!
Meek
#64 Post by Meek » 04 Apr 2018, 09:36
barrymossel wrote: 30 Mar 2018, 15:06 Really nice work! Will you ever be designing 2-gang dimmers and switches? I would be ordering those right away!
Yes we are, in fact, this week we have assembled and installed the Meek MT3 (Meek 3 touch input & 3 switch outputs).
The attachment MeekMT3.jpg is no longer available
A remarks with regards to the attached picture of the Meek MT3 : for visual feedback, we are using fully controllable WS2812b RGB leds. These are quit powerful, therefore you have some bleeding/Halo around the touch buttons. We are still working in resolving these issue’s. Once we have cleared these kind of minor issue’s, we will make them available for external use.
The PCB is designed for dual use, so by adding additional components we can use it to for a Meek MT2 (2 touch buttons / 2 light outputs) and Meek MT3 (as shown in the picture for 3 touch inputs and 3 light outputs).
Regarding the dimmers, by hardware design, our Meek MD dimmers are able to control 2 individual dimmable outputs. But we are still designing/programming the software for a 1 input/output Dimmer interface. Once we have successfully completed this, we have to think how we can make this dimmer easily controllable for a 2 point dimmer. Our aim is to have a dimmer that has a logical and easy interface for physical input but also easy controllable and flexible enough to control by software. The development is still in progress and the last week we have made great progress. In the coming weeks, we hope to show the Meek MD1 dimmer in action !
barrymossel
#65 Post by barrymossel » 13 Apr 2018, 11:42
Really good news. For my use case I need a dimmer + normal (or dimmer) in one. So two buttons of which at least one is a dimmer. I will be keeping an eye on this thread and your website!
Meek
#66 Post by Meek » 30 Apr 2018, 21:39
Just uploaded a video with the progress of the Meek MD1 Wi-Fi dimmer module.
https://www.youtube.com/watch?v=kOhscOB0x04
vandalon
#67 Post by vandalon » 14 May 2018, 20:31
Hi Meek,
Can I fit 2 of your awesome switches next to each other in a dutch, double socket wall outlet?
Cheers,
Joris
Meek
#68 Post by Meek » 17 May 2018, 08:53
vandalon wrote: 14 May 2018, 20:31 Hi Meek,
Cheers,
Joris
We’re still trying to acquire casings for a double-, and even a triple variant wall sockets.
We want to deliver a diversity of sockets so the Meek devices can be installed in various environments.
Till now, this has proven to be very difficult! We have not been able to acquire the double and triple sockets yet and the last resort is to develop these in-house. In this stage of the development of the Meek Smart Switches, developing the casings + matching glass panels, will add an extra complexity to the project.
But if someone knows where we can acquire, or even know a party that is willing to cooperate with us to produce the casing + glass panels, we are more than willing to listen!
For the future we have more fantastic idea’s that we would like to add to the Meek switches. For one of the options, we need to “play” with the casing structure and material choices. So we can add more functions, gimmicks and also, to be able to add even more options to personalize the switches to match your desires.
#69 Post by grovkillen » 17 May 2018, 09:35
Will these run your own FW, ESP Easy FW, or modified ESP Easy FW?
vandalon
#70 Post by vandalon » 17 May 2018, 09:42
Meek wrote: 17 May 2018, 08:53 We’re still trying to acquire casings for a double-, and even a triple variant wall sockets.
Thanks for the reply,
So it's not possible to fit 2 single switches next to each other in a double socket?
Also, All devices seem to be out of stock on your site, when do you expect new stock? :)
Meek
#71 Post by Meek » 18 May 2018, 12:45
grovkillen wrote: 17 May 2018, 09:35 Will these run your own FW, ESP Easy FW, or modified ESP Easy FW?
At this moment, all the Meek switches are running on a stock ESPEasy Mega Firmware.
For now, ESPEasy gives us all the options and flexibility we need to operate the switches and I want to thank you and the team for this magnificent piece of software!
All your efforts are appreciated and keep up the good work !
Meek
#72 Post by Meek » 18 May 2018, 12:46
vandalon wrote: 17 May 2018, 09:42
For this, we need a double socket casing and glass panel. At this moment, it’s not possible to place 2 Meek switches in a double socket. However, this is something that has our attention and it will be one of the items to tackle in the future.
We hope to have a new stock within 2 months, we will update our website once we have a hard date.
Thank you for your interest !
#73 Post by grovkillen » 18 May 2018, 15:17
Meek wrote: 18 May 2018, 12:45
Thanks for the info. We're happy to hear that stock FW is on them. Great news :D
Meek
#74 Post by Meek » 16 Jun 2018, 20:39
Herewith a pictures of the latest revisions Meek MP1 switches.
We’re currently assembling these to distribute them to a select group of tester.
The Meek MP1 is a :
• Wi-Fi enabled light switch
• With a Doppler presence detector
• Audi visual feedback with a RGB addressable LED and a RTTTL Speaker
• Fully programmable timers a functions
This switch operates out of the box even without a Wi-Fi connection.
Once connected to Wi-Fi you can control it with any device that has a browser (Phone, TV, Smart Watch,…) or by speech recognition enabled devices (Google Home, Alexa, Siri,..).
Ongoing, we’re expanding the functions of these devices.
For instance :
• Alarm Function ; you can “arm” the device, so whenever a movement is detected, the Meek MP1 will sound and alarm and blink the light continuously until the user disarms it.
• Doorbell ; (we will develop a doorbell in the future) if you have “Smart Doorbell”, whenever the doorbell is pressed, the Switch will mimic a doorbell and blink the lights.
• Night Modus : the presence detection will only switch the lights, if it’s in the Night Modus.
As we’re developing several other Meek devices, that will seemingly interact with each other, to truly create a smart house !
The possibilities are endless as the community is able to contribute and able to add extra functionality to our devices !
#75 Post by grovkillen » 16 Jun 2018, 20:53
Really cool! Thanks for everything you post
#76 Post by TD-er » 16 Jun 2018, 21:08
That looks nice and to be honest, I have more confidence in such a design with those well-known Hi-link power supplies than the ones included in the Sonoff's.
How much amps can these triacs (I assume) handle?
And it looks like there is room for later versions with more switches.
I was thinking about these switches lately and I guess there is also a market for these with 2 or 3 tip switch inputs, but only 1 switching output, since you can add switches near the consumers and very often still want to switch via the domotica system and not directly switching something at the position where these are mounted.
Or perhaps have multiple switch inputs to switch the same. (lights on while presence detected + lights on continuously)
#77 Post by grovkillen » 16 Jun 2018, 21:22
I wouldn't mind testing one 👍✌️😎
Meek
#78 Post by Meek » 16 Jun 2018, 21:51
TD-er wrote: 16 Jun 2018, 21:08 That looks nice and to be honest, I have more confidence in such a design with those well-known Hi-link power supplies than the ones included in the Sonoff's.
Main priority is safety!
I have several devices in my house including the rooms of my children (they like the Neopixel Candle – Color Fader  function ).
We have built several line of defenses to keep the devices safe to operate, despite missing certifications.
I (and many others) have good experiences with HLK-PM01 and it also delivers a stable power output.
For Meek MP1, I have switches from THT triacs to SMD triacs, currently it’s equipped with the BT136S, that should be able to carry 4 Amps. I have conducted test and they operate well even on high loads. Despite the theoretical high switching power, I will rate them for max. 350 Watt.
I have a 2 touch and 3 touch version in operations also, these are equipped with 2 or 3 triacs.
I have also a variant with 1 touch button, with 3 triac outputs to control home ventilation units.
In my kitchen, I have a Meek MP2(bastard version for my own use), with one touch button with 2 triac outputs. The RWCL sensor is so accurate that we do not manually switch the kitchen lights anymore. The touch button is merely to switch our garden lights. So the Doppler switches the kitchen lights and the touch button operates the garden light.
The beauty of Meek is that it’s equipped with ESPEasy !
The user is able to decide how the device reacts on a specific input. And that’s all because of you, the developpers of ESPEasy !
Thank you for all the time, efforts and energy you put into this project !
TD-er, I will PM you my phone number, , I hope that we can meet so I can personally hand over a Meek MP1 to you, for testing purposes.
neykov_t
#79 Post by neykov_t » 16 Jun 2018, 21:58
hi,
what about installation schema ?
Do this required Live + neutral or it could be powered by one wire (as VHome 433mhz wall switches) ? Thank yo
Meek
#80 Post by Meek » 16 Jun 2018, 22:03
neykov_t wrote: 16 Jun 2018, 21:58 hi,
To ensure stability, we have chosen to use a Neutral wire also. So you need Live, Neutral and switching wires to operate these switches.
Users browsing this forum: No registered users and 60 guests
