I don't have your hardware so I cannot confirm what you experience. Sounds like a problem with the plugin as you mention, open a issue on GitHub.
By the way, have you experimented with the message delay setting under the advanced menu? Setting it to 200mSec or maybe even 100mSec might speed things up?
Keypad and PCF8574
Re: Keypad and PCF8574
- budman1758
I have not tried that. Isn't that only related to the controller though? I am not using any right now. I will give it a go...grovkillen wrote: ↑12 Dec 2017, 06:29 By the way, have you experimented with the message delay setting under the advanced menu? Setting it to 200mSec or maybe even 100mSec might speed things up?
No it's related to how often it is polling the plugins, at least I think so. I use it when I need my switch presses to be more responsive.budman1758 wrote: ↑12 Dec 2017, 06:47I have not tried that. Isn't that only related to the controller though? I am not using any right now. I will give it a go...grovkillen wrote: ↑12 Dec 2017, 06:29 By the way, have you experimented with the message delay setting under the advanced menu? Setting it to 200mSec or maybe even 100mSec might speed things up?
- budman1758
Changed it to 100 and 10 ms and cannot see any difference.grovkillen wrote: ↑12 Dec 2017, 06:51No it's related to how often it is polling the plugins, at least I think so. I use it when I need my switch presses to be more responsive.budman1758 wrote: ↑12 Dec 2017, 06:47I have not tried that. Isn't that only related to the controller though? I am not using any right now. I will give it a go...grovkillen wrote: ↑12 Dec 2017, 06:29 By the way, have you experimented with the message delay setting under the advanced menu? Setting it to 200mSec or maybe even 100mSec might speed things up?
Then you might want to open a issue on GitHub.
- budman1758
Just in case anybody is interested I purchased a HT16K33 keypad/matrix driver chip and set it up and it behaves the same. Still have to wait a few seconds between keypresses so that they are not missed. This chip is designed for this sort of thing so I thought perhaps it would behave differently. Guess thats what I get for thinking... Oh well.
https://www.ebay.com/itm/HT16K33-LED-Do ... 2749.l2649
Users browsing this forum: No registered users and 78 guests
