RFID Access control / door lock actuator
Re: RFID Access control / door lock actuator
I think you miss some libraries (at least the PubSub related to MQTT) in order to be able to compile ESPEasy...
* Arduino project "ESP Easy" © Copyright www.esp8266.nu
* This program is free software: you can redistribute it and/or modify it under the terms of the GNU General Public License
* as published by the Free Software Foundation, either version 3 of the License, or (at your option) any later version.
* This program is distributed in the hope that it will be useful, but WITHOUT ANY WARRANTY; without even the implied warranty
* of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public License for more details.
* You received a copy of the GNU General Public License along with this program in file 'License.txt'.
* IDE download : https://www.arduino.cc/en/Main/Software
* ESP8266 Package : https://github.com/esp8266/Arduino
* Source Code : https://sourceforge.net/projects/espeasy/
* Support : http://www.esp8266.nu
* Discussion : http://www.esp8266.nu/forum/
* Additional information about licensing can be found at : http://www.gnu.org/licenses
// This file incorporates work covered by the following copyright and permission notice:
* Arduino project "Nodo" © Copyright 2010..2015 Paul Tonkes
* Voor toelichting op de licentievoorwaarden zie : http://www.gnu.org/licenses
* Uitgebreide documentatie is te vinden op : http://www.nodo-domotica.nl
* Compiler voor deze programmacode te downloaden op : http://arduino.cc
// Simple Arduino sketch for ESP module, supporting:
// Dallas OneWire DS18b20 temperature sensors
// DHT11/22 humidity sensors
// BH1750 I2C Lux sensor
// BMP085 I2C Barometric Pressure sensor
// RFID Wiegand-26 reader
// MCP23017 I2C IO Expanders
// Analog input (ESP-7/12 only)
// LCD I2C display 4x20 chars
// Pulse counters
// Simple switch inputs
// Direct GPIO output control to drive relais, mosfets, etc
// User specific configuration
// Set default configuration settings if you want (not mandatory)
// You can allways change these during runtime and save to eeprom
// After loading firmware, issue a 'reset' command to load the defaults.
#define DEFAULT_NAME "" // Enter your device friendly name
#define DEFAULT_SSID "" // Enter your network SSID
#define DEFAULT_KEY "" // Enter your network WPA key
#define DEFAULT_SERVER "192.168.1.0" // Enter your Domoticz Server IP address
#define DEFAULT_PORT 8080 // Enter your Domoticz Server port value
#define DEFAULT_DELAY 60 // Enter your Send delay in seconds
#define DEFAULT_AP_KEY "configesp" // Enter network WPA key for AP (config) mode
#define DEFAULT_PROTOCOL 1 // Protocol used for controller communications
// 1 = Domoticz HTTP
// 2 = Domoticz MQTT
// 3 = Nodo Telnet
#define UNIT 0
#define KEYS_MAX 8
#define KEY1 1
#define KEY2 2345678
#define KEY3 3456789
#define KEY4 4567890
#define KEY5 1234567
#define KEY6 2345678
#define KEY7 3456789
#define KEY8 4567890
#define BUZZERPIN 5
#define BUZZERSHORTDELAY 200
#define BUZZERLONGDELAY 500
#define BUZZERPULSES 3
#define DOORPIN 14
#define DOORSHORTDELAY 100
#define DOORLONGDELAY 200
#define DOORPULSES 20
// DO NOT CHANGE ANYTHING BELOW THIS LINE
// sensor types
// 1 = single value, general purpose (Dallas, LUX, counters, etc)
// 2 = temp + hum (DHT)
// 3 = temp + hum + baro (BMP085)
// 10 = switch
#define ESP_PROJECT_PID 2015050101L
#define ESP_EASY
#define VERSION 4
#define BUILD 15
#define REBOOT_ON_MAX_CONNECTION_FAILURES 30
#define LOG_LEVEL_ERROR 1
#define LOG_LEVEL_INFO 2
#define LOG_LEVEL_DEBUG 3
#define LOG_LEVEL_DEBUG_MORE 4
#define CMD_REBOOT 89
#define CMD_WIFI_DISCONNECT 135
#define DEVICE_DS18B20 1
#define DEVICE_DHT11 2
#define DEVICE_DHT22 3
#define DEVICE_BMP085 4
#define DEVICE_BH1750 5
#define DEVICE_ANALOG 6
#define DEVICE_RFID 7
#define DEVICE_PULSE 8
#define DEVICE_SWITCH 9
#define DEVICES_MAX 10
#define TASKS_MAX 8
#define DEVICE_TYPE_SINGLE 1 // connected through 1 datapin
#define DEVICE_TYPE_I2C 2 // connected through I2C
#define DEVICE_TYPE_ANALOG 3 // tout pin
#define DEVICE_TYPE_DUAL 4 // connected through 2 datapins
#include <ESP8266WiFi.h>
#include <WiFiUdp.h>
#include <ESP8266WebServer.h>
#include <EEPROM.h>
#include <Wire.h>
#include <PubSubClient.h>
#include <ArduinoJson.h>
#include <LiquidCrystal_I2C.h>
// MQTT client
PubSubClient MQTTclient("");
// LCD
LiquidCrystal_I2C lcd(0x27, 20, 4); // set the LCD address to 0x27 for a 16 chars and 2 line display
// WebServer
ESP8266WebServer WebServer(80);
// syslog stuff
WiFiUDP portRX;
WiFiUDP portTX;
struct SettingsStruct
unsigned long PID;
int Version;
byte Unit;
char WifiSSID[26];
char WifiKey[26];
byte Controller_IP[4];
unsigned int ControllerPort;
byte IP_Octet;
char WifiAPKey[26];
unsigned long Delay;
unsigned int _Dallas;
unsigned int _DHT;
byte _DHTType;
unsigned int _BMP;
unsigned int _LUX;
unsigned int _RFID;
unsigned int _Analog;
unsigned int _Pulse1;
byte _BoardType;
int8_t Pin_i2c_sda;
int8_t Pin_i2c_scl;
int8_t _Pin_wired_in_1;
int8_t _Pin_wired_in_2;
int8_t _Pin_wired_out_1;
int8_t _Pin_wired_out_2;
byte Syslog_IP[4];
unsigned int UDPPort;
unsigned int Switch1;
byte Protocol;
byte IP[4];
byte Gateway[4];
byte Subnet[4];
byte Debug;
char Name[26];
byte SyslogLevel;
byte SerialLogLevel;
byte WebLogLevel;
unsigned long BaudRate;
char ControllerUser[26];
char ControllerPassword[26];
char Password[26];
unsigned long MessageDelay;
byte TaskDeviceNumber[TASKS_MAX];
unsigned int TaskDeviceID[TASKS_MAX];
int8_t TaskDevicePin1[TASKS_MAX];
int8_t TaskDevicePin2[TASKS_MAX];
int Keys[KEYS_MAX];
int buzzerPin;
int buzzerShortDelay;
int buzzerLongDelay;
int buzzerPulses;
int doorPin;
int doorShortDelay;
int doorLongDelay;
int doorPulses;
} Settings;
struct LogStruct
unsigned long timeStamp;
char Message[80];
} Logging[10];
int logcount = -1;
struct DeviceStruct
byte Number;
char Name[26];
byte Type;
} Device[DEVICES_MAX];
boolean printToWeb = false;
String printWebString = "";
float UserVar[2 * TASKS_MAX];
unsigned long pulseCounter[TASKS_MAX];
unsigned long pulseTotalCounter[TASKS_MAX];
byte switchstate[TASKS_MAX];
unsigned long timer;
unsigned long timer100ms;
unsigned long timer1s;
unsigned long timerwd;
unsigned int NC_Count = 0;
unsigned int C_Count = 0;
boolean AP_Mode = false;
byte cmd_within_mainloop = 0;
unsigned long connectionFailures;
unsigned long wdcounter = 0;
unsigned long pulseCounter1 = 0;
byte switch1state = 0;
boolean WebLoggedIn = false;
int WebLoggedInTimer = 300;
void setup()
EEPROM.begin(1024);
LoadSettings();
// if different version, eeprom settings structure has changed. Full Reset needed
// on a fresh ESP module eeprom values are set to 255. Version results into -1 (signed int)
if (Settings.Version != VERSION || Settings.PID != ESP_PROJECT_PID)
Serial.begin(9600); // Initialiseer de seriele poort
Serial.println(Settings.PID);
Serial.println(Settings.Version);
Serial.println(F("INIT : Incorrect PID or version!"));
delay(10000);
ResetFactory();
Serial.begin(Settings.BaudRate);
Serial.print(F("\nINIT : Booting Build nr:"));
Serial.println(BUILD);
if (Settings.SerialLogLevel >= LOG_LEVEL_DEBUG_MORE)
Serial.setDebugOutput(true);
Device_Init();
hardwareInit();
WifiAPconfig();
WifiConnect();
WebServerInit();
// setup UDP
if (Settings.UDPPort != 0)
portRX.begin(Settings.UDPPort);
// Setup timers
timer = millis() + 30000; // startup delay 30 sec
timer100ms = millis() + 100; // timer for periodic actions 10 x per/sec
timer1s = millis() + 1000; // timer for periodic actions once per/sec
timerwd = millis() + 30000; // timer for watchdog once per 30 sec
// Setup LCD display
lcd.init(); // initialize the lcd
lcd.backlight();
lcd.print("ESP Easy");
// Setup MQTT Client
if (Settings.Protocol == 2)
MQTTConnect();
sendSysInfoUDP(3);
Serial.println(F("INIT : Boot OK"));
addLog(LOG_LEVEL_INFO,(char*)"Boot");
void loop()
if (Serial.available())
serial();
checkUDP();
if (cmd_within_mainloop != 0)
switch (cmd_within_mainloop)
case CMD_WIFI_DISCONNECT:
WifiDisconnect();
case CMD_REBOOT:
ESP.reset();
// Watchdog trigger
if (millis() > timerwd)
wdcounter++;
char str[40];
str[0] = 0;
Serial.print("WD : ");
sprintf_P(str, PSTR("Uptime %u ConnectFailures %u FreeMem %u"), wdcounter / 2, connectionFailures, FreeMem());
Serial.println(str);
syslog(str);
sendSysInfoUDP(1);
refreshNodeList();
// Perform regular checks, 10 times/sec
if (millis() > timer100ms)
inputCheck();
// Perform regular checks, 1 time/sec
if (millis() > timer1s)
WifiCheck();
if (Settings.Password[0] != 0)
if (WebLoggedIn)
WebLoggedInTimer++;
if (WebLoggedInTimer > 300)
// Check sensors and send data to controller when sensor timer has elapsed
if (millis() > timer)
timer = millis() + Settings.Delay * 1000;
SensorSend();
if (connectionFailures > REBOOT_ON_MAX_CONNECTION_FAILURES)
Serial.println(F("Too many connection failures"));
delayedReboot(60);
backgroundtasks();
void inputCheck()
// Handle switches
for (byte x=0; x < TASKS_MAX; x++)
if(Settings.TaskDeviceNumber[x] == DEVICE_SWITCH && Settings.TaskDeviceID[x] != 0)
byte state = digitalRead(Settings.TaskDevicePin1[x]);
if (state != switchstate[x])
switchstate[x] = state;
UserVar[(x*2+1) - 1] = state;
sendData(10, Settings.TaskDeviceID[x], x*2+1);
delay(100);
// Handle rfid
boolean granted = false;
if(Settings.TaskDeviceNumber[x] == DEVICE_RFID && Settings.TaskDeviceID[x] != 0)
unsigned long rfid_id = rfid();
if (rfid_id > 0)
Serial.print("RFID : Tag : ");
Serial.println(rfid_id);
UserVar[(x*2+1) - 1] = rfid_id;
sendData(1, Settings.TaskDeviceID[x], x*2+1);
for (byte x=0; x < KEYS_MAX;x++){
if (Settings.Keys[x]==rfid_id)
granted = true;
x = KEYS_MAX;
if(granted){
sendPulse(Settings.doorPin, Settings.doorShortDelay, Settings.doorLongDelay, Settings.doorPulses);
Serial.println("Key Accepted");
}else{
sendPulse(Settings.buzzerPin, Settings.buzzerShortDelay, Settings.buzzerLongDelay, Settings.buzzerPulses);
Serial.println("Key declined");
void SensorSend()
if (Settings.TaskDeviceID[x] != 0)
switch(Settings.TaskDeviceNumber[x])
case DEVICE_DS18B20:
dallas(Settings.TaskDevicePin1[x], x*2+1);
case DEVICE_DHT11:
dht(11, Settings.TaskDevicePin1[x], x*2+1);
if (!isnan(UserVar[(x*2+1) - 1]) && (UserVar[(x*2+2) - 1] > 0))
sendData(2,Settings.TaskDeviceID[x], x*2+1);
case DEVICE_DHT22:
dht(22, Settings.TaskDevicePin1[x], x*2+1);
sendData(2, Settings.TaskDeviceID[x], x*2+1);
case DEVICE_BMP085:
bmp085(x*2+1);
if ((UserVar[(x*2+2) - 1] >= 300) && (UserVar[(x*2+2) - 1] <= 1100))
sendData(3, Settings.TaskDeviceID[x], x*2+1);
case DEVICE_BH1750:
lux(x*2+1); // read BH1750 LUX sensor and store to var 6
case DEVICE_ANALOG:
analog(x*2+1); // read ADC and store to var 7
case DEVICE_PULSE:
UserVar[(x*2+1) - 1] = pulseCounter[x];
pulseCounter[x] = 0;
void backgroundtasks()
WebServer.handleClient();
MQTTclient.loop();
delay(10);
// Pulse counters
// 3 = Nodo Telnet
#define UNIT 0
#define KEYS_MAX 8
#define KEY1 1
#define BUZZERPIN 5
#define DOORPIN 14
// sensor types
// 10 = switch
#define ESP_EASY
#define VERSION 4
#define BUILD 15
#define TASKS_MAX 8
#include <EEPROM.h>
#include <Wire.h>
// MQTT client
// LCD
// WebServer
// syslog stuff
WiFiUDP portRX;
WiFiUDP portTX;
unsigned long PID;
int Version;
byte Unit;
char WifiSSID[26];
char WifiKey[26];
byte IP_Octet;
char WifiAPKey[26];
unsigned int _DHT;
byte _DHTType;
unsigned int _BMP;
unsigned int _LUX;
unsigned int _RFID;
byte _BoardType;
int8_t Pin_i2c_sda;
int8_t Pin_i2c_scl;
byte Syslog_IP[4];
byte Protocol;
byte IP[4];
byte Gateway[4];
byte Subnet[4];
byte Debug;
char Name[26];
byte SyslogLevel;
byte WebLogLevel;
char Password[26];
int Keys[KEYS_MAX];
int buzzerPin;
int buzzerPulses;
int doorPin;
int doorShortDelay;
int doorLongDelay;
int doorPulses;
} Settings;
struct LogStruct
char Message[80];
} Logging[10];
int logcount = -1;
struct DeviceStruct
byte Number;
char Name[26];
byte Type;
void setup()
EEPROM.begin(1024);
LoadSettings();
delay(10000);
ResetFactory();
Device_Init();
hardwareInit();
WifiAPconfig();
WifiConnect();
WebServerInit();
// setup UDP
// Setup timers
lcd.backlight();
MQTTConnect();
sendSysInfoUDP(3);
void loop()
serial();
checkUDP();
WifiDisconnect();
case CMD_REBOOT:
ESP.reset();
// Watchdog trigger
wdcounter++;
char str[40];
str[0] = 0;
syslog(str);
sendSysInfoUDP(1);
refreshNodeList();
inputCheck();
WifiCheck();
if (WebLoggedIn)
WebLoggedInTimer++;
SensorSend();
delayedReboot(60);
backgroundtasks();
void inputCheck()
// Handle switches
delay(100);
// Handle rfid
if (rfid_id > 0)
granted = true;
x = KEYS_MAX;
if(granted){
}else{
void SensorSend()
case DEVICE_DHT11:
case DEVICE_DHT22:
case DEVICE_BMP085:
bmp085(x*2+1);
case DEVICE_BH1750:
case DEVICE_ANALOG:
case DEVICE_PULSE:
MQTTclient.loop();
delay(10);
I checked and i do have the PubSubClient Version 2.6.0 on arduino 1.8.5 Installed... what am i missing????? Thanks in advance!!!
UPDATE:
Alright so i found a workaround just using ESPeasy rules. for what i needed it to do it works just fine! Thanks for the insight.
UPDATE:
Users browsing this forum: Bing [Bot] and 72 guests
