Hi , i succesfuly connected the lcd and bmp280 to espeasy , recognised in webinterface.
i can use %systime% on the display , but cannot show the BMP280 values. what should i insert in the 3 and 4 line to be able to read the values from the bmp280?
Thank you
ESP8266 BMP-280 & LCD 2004 display values problem
Re: ESP8266 BMP-280 & LCD 2004 display values problem
You have to name your sensor. For example the very original name "bmp"
The default label for the 1st value is "Temperature" That's a bit long, so change it to "temp"
Then use "[bmp#temp]" in the string to display on the screen.
It was the first thig that i tried.
The one that is working should look like this :
T: [BMP280#Temp]%
P: [BMP280#Pressure]%
Now it's working
Topic closed
T: [BMP280#Temp]%
Now it's working
Topic closed
