On startwatering do
Pulse,4,1,40
Pulse,5,0,40 //start watering (open valve)
Publish aussen/state/WM/Garten01/watering,startwatering
timerSet,1,60 //timer 1 set for 1 minutes
On startwatering do
Pulse,4,1,40
On startwatering do
Pulse,4,1,40
event,MQTTwatering=startwatering
msg: aussen/state/WM/Garten01/watering/cmd
payload: event,MQTTwatering
You're calling an event that you have not defined, try this:werner_g wrote: ↑04 May 2018, 00:05 Thanks. So I modified my rules in adding the event-command:
But nothing happens when I set this command:Code: Select all
On startwatering do Pulse,4,1,40 Pulse,5,0,40 //start watering (open valve) Publish aussen/state/WM/Garten01/watering,startwatering event,MQTTwatering=startwatering timerSet,1,60 //timer 1 set for 1 minutes endon
So still I am looking for help.Code: Select all
msg: aussen/state/WM/Garten01/watering/cmd payload: event,MQTTwatering
payload: event,startwatering
the sky is the limit.
i don't think the espeasy is really meant to be used as a control panel (of sorts). it's more for setting up the device to control things (motors, lights, etc). what you need is home automation software that sends the commands to the esp and then the esp makes it happen.
ESPeasy has a number of possibilities.
ChickenBot_4/Chickenbot
ChickenBot_4/Chickenbot/cmd
Users browsing this forum: Bing [Bot] and 30 guests
