ESP easy+nodemcu+HC-SR501 problem
Re: ESP easy+nodemcu+HC-SR501 problem
Now it seems to work (at least now I see it on HA). I connected the pir sensor to the vin pin of nodeMCU and then gnd and GPIO10. the problem now is that it continues to detect movement even if it is not there. passes continuously from 0 to 1. I tried to rotate the trimmers but nothing.
Dear all, i bought this pir wifi sensor with esp8266. Can yoy help me to program it with espeasy and domoticz?
- 20180703_194424.jpg (3.11 MiB) Viewed 15514 times
- 20180703_194024.jpg (3.1 MiB) Viewed 15514 times
- 20180703_193808.jpg (2.79 MiB) Viewed 15514 times
- 20180703_193721.jpg (2.78 MiB) Viewed 15514 times
- 20180703_193533.jpg (2.4 MiB) Viewed 15514 times
If you are able to send me one I can make an official guide.
Sure but I don't have the funds to buy it myself right now. We'll have to wait then
I bought only one for the same reason.
I'll try to flash it with espeasy and do some testing.
Thank for your support
Seems like the visa are accessable easily for RX/TX. Look at the ESP-01 guide and you will most likely get it working. Please give us info on your progress
I'm trying to flash it, but where is the vcc + chpd connected?
- ontatti.jpg (185.05 KiB) Viewed 15477 times
You may also want to connect the GPIO-0 to GND during flash.
And on the images I could not find the 3.3V point, so that one may be tricky.
Also double-check those USB => serial converters output 3.3V. Some just give 5V on the pins labelled 3.3V
It seems that there's another notation about RX/TX as well. But I believe I found the 3.3V via. See attached pictures.
- IMG_20180714_081103.jpg (506.86 KiB) Viewed 15451 times
- IMG_20180714_081201.jpg (629.62 KiB) Viewed 15451 times
I had seen the 3v3 pin but I can not find the chpd pin that goes bridged with the 3v3. I keep trying
nothing to do, I inserted a 10k resistor between the GPIO and the sensor data output but I continue to have fakes, it goes continuously between the two states
nothing to do probably the sensor model has problems .. I will try to change the manufacturer ..
Users browsing this forum: No registered users and 43 guests
