CCS811 CO2 sensor
RenedeH
CCS811 CO2 sensor
#1 Post by RenedeH » 01 Nov 2018, 19:01
I managed to get the CCS811 (on the cjmcu-8118 board) working with ESPeasy-mega. I use the wemos d1 mini and compiled the ESPEasy with the _P118_CCS811.ino plugin on the ArduinoIDE. I use Domotiz to follow the data and look at the trend. I also use a DHT11 to get the temperature and moisture readings to compensate.
When I power up the sensor the first reading is 400ppm. It slowly goes up and gets up to a relative stable value , but after a couple of hours the data freezes and when I check the espeasy log it reads 'CCS811 : No values found'. Only solution is power off and on. I tried different reading times and interval, but no improvement.
Anyone a suggestion on how to tackle this?
Barb232
Re: CCS811 CO2 sensor
#2 Post by Barb232 » 01 Nov 2018, 19:45
Same problem here, i used tasmota, got the same error after 6hs.
#3 Post by grovkillen » 01 Nov 2018, 20:18
Interested in Senseair S8 sensors? ;)
I will ship one per each enclosure: viewtopic.php?t=5973
RenedeH
#4 Post by RenedeH » 04 Nov 2018, 20:09
Some more googling revealed the possibility that the freezing is caused by the I2c clockstretching issue between the CCS811 and the Wemos. In the ESPEasymega version I use there is in the advanced section the setting I2c clockstretchlimit. I could not find anything on this parameter. The CCS requires a clockstretch value of '500'. Not sure how that works with the limit parameter. Anyone a hint?
RenedeH
#5 Post by RenedeH » 07 Nov 2018, 17:48
I did tried the clock strech limit setting in the advanced section of the ESPEasy-mega and chnaged the 0 to 460 and that did the trick. The sensor is running for 2.5 days already. There are a few ' no values found' errors, but they do not stop the unit from working. Hope this helps others with similar issues.
