Axa remote 2 with esp easy
remko2000
#1 Post by remko2000 » 09 Dec 2018, 11:44
Finally I make progress with my axa remote 2.0 which I want to control with domoticz. I bought a linbus converter on superhouse:https://www.google.nl/url?sa=t&rct=j&q= ... h8hKy-Rx39
I connected it with a wemos d1 and use the arduinoscript from:
https://www.letscontrolit.com/forum/vie ... php?t=2245
I'm almost there but I have noticed that I have to repeat every command. I have no knowledge of arduino coding.
How do I adjust this scripts so that every command repeat one time (of two)?
* This sketch reads a command through a http connection
* depending on the text received it will send open, stop or close
* commands to the Esp8266. the ESP8266 is connected to the Axa Remote 2.0 electric window opener
#include <ESP8266WiFi.h>
const char* ssid = "your SSID here";
const char* password = "";
// Create an instance of the server
// specify the port to listen on as an argument
WiFiServer server(80);
void setup() {
Serial.begin(19200,SERIAL_8N1);
delay(10);
// Connect to WiFi network
WiFi.begin(ssid, password);
while (WiFi.status() != WL_CONNECTED) {
delay(500);
// Start the server
server.begin();
void loop() {
// Check if a client has connected
WiFiClient client = server.available();
if (!client) {
return;
// Wait until the client sends some data
while(!client.available()){
delay(1);
// Read the first line of the request
String req = client.readStringUntil('\r');
client.flush();
// Match the request
int val;
if (req.indexOf("/open") != -1)
open_axa();
if (req.indexOf("/close") != -1)
close_axa();
else if (req.indexOf("/stop") != -1)
stop_axa();
else {
Serial.println("invalid request");
client.stop();
return;
void open_axa() {
Serial.print("O");
delay(20);
Serial.print("P");
delay(20);
Serial.print("E");
delay(20);
Serial.print("N");
delay(20);
Serial.println("\r");
delay(2000);
void close_axa() {
Serial.print("C");
delay(20);
Serial.print("L");
delay(20);
Serial.print("O");
delay(20);
Serial.print("S");
delay(20);
Serial.print("E");
delay(20);
delay(2000);
void stop_axa() {
Serial.print("S");
delay(20);
Serial.print("T");
delay(20);
Serial.print("O");
delay(20);
Serial.print("P");
delay(20);
Users browsing this forum: No registered users and 59 guests
