smoke detector triggered killswitch based on esp-01 relay
Hello community,
i need some help on my project
I have an 3D printer in my basement and for some safety measures I want to setup an automatic killswitch triggered by an smoke detector.
There are two PINs (GND, Signal) on the smoke detector going HIGH 3,3v in case of smoke detection.
I want to connect the smoke detector directly to the esp-relay to cut off the power of the 3d printer in case of smoke or fire.
so i bought some of these esp-01 relays here
https://de.aliexpress.com/item/ESP8266- ... 21218.html
I also soldered an extra wire directly to the GPIO12 on ESP8266EX Chip, to be able to connect the smoke detector as the esp-01 has only two GPIO pins, so now i have 3 in total.
It was a hard piece of solderwork but fortunately i'm not an heavy drinker so i made it
Of course i could take another eps-01 and connect it to the smoke detector that griggers the other esp-1 on the relay but in case of an wifi connectionloss or any other problem it will just not work.
I think it would be the best and safest solution.
I have activated the "Rules-Tab" on EasyESP but unfortunately I'm not good at coding at all so i need your help to code the right logic
Re: smoke detector triggered killswitch based on esp-01 relay
You need to tell us the setup (task names and value names etc).
taskname=killswitch
fire as the valuename
And is it 1/0 for smoke detecting or a range value?
0=no smoke
1=smoke detected
1=smoke detected
On Killswitch#Smoke Do
If [Killswitch#Smoke]=1
GPIO,14,0
Else
GPIO,14,1
EndIf
EndOn
Thank you grovkillen, i will try it
Has anyone already tried those chinastuff relays? I mean i've already saw such things like weak soldered PCBs, cheapest components and stuff like this. It would be ironic if an safety measure would cause unsafety as its directly connected to 100-220V AC
So why using ESPeasy module?letsDIY4fun wrote: ↑10 Jan 2019, 20:23
Standalone relay driven directly by signal from smoke detector will work the same way.
Or your smoke detector is far away from printer?
Or you want report error state somewhere else?
Then using ESPeasy module is nesessery.
I want to report in case of any actions so i was thinking about to combine it with IFTT calling an IFTT trigger, what trigger would be the right one in EasyESP rules?
Users browsing this forum: No registered users and 54 guests
