uPyEasy
Re: uPyEasy
when might there be support for MQTT for openhab?
Re: uPyEasy
Scripts have grown to become almost normal, but changeable, micropython programs. Despite it's great benefit, everything is now possible with scripts, it has a big downside: you'll need to program Python.LisaM wrote: ↑22 Oct 2017, 12:55How about an example script that resembles the old rules script as close as possible? It will basically act as a template for rule based scripting, simple but leaving the option open of making it complex. Will something like that help you?
For example this old rule part:will be turned into this:Code: Select all
On TurnOn do gpio,12,1 EndOn
if TurnOn: gpio (12,1) endif
So... i've kept Scripts, but re-introduced rules.
Rule example:
if event['test#temperature'] > 15 :
gpio('d12',1)
event['timer1'] = 60 # seconds
if timer1:
gpio('d12',0)
if turnon:
gpio('d12',1)
Is that still exceptable?
Re: uPyEasy
See the Rules: /forum/viewtopic.php?f=23&t=4732
Re: uPyEasy
uPyEasy beta-1 is also having the menu's Scripts, Rules and Notifications hidden by default to make the menu bar less complex. They can be enabled in the advanced menu:
Re: uPyEasy
Hi Lisa,
very nice work.
Is there an alpha version compatible with Wemos D1 Mini with ESP 8266 and/or D1 Mini Lite ESP 8285?
thanks
very nice work.
thanks
Re: uPyEasy
Hi LisaM,
I would also love to test it on a WeMOS D1 mini ...
Re: uPyEasy
any version for ESP8266 to try yet?
Re: uPyEasy
Lisa what ever happened to this? Will you be releasing an ESP8266 version? I think this firmware would be perfect for a project i have
Re: uPyEasy
Hi iiot,
The source code has grown to such a size that it's using to much heap memory to be able to use it on a ESP8266, so minimal requirements is still the ESP32.
Cheers,
Lisa
