uPyEasy BETA-1 is available!
Re: uPyEasy BETA-1 is available!
tested plugin test ... same output. I neededd to reset ESP32.
Both bugs fixed and new firmware uploaded. Please log these bugs in github, in this thread i might lose track of them...BertB wrote: ↑29 Jan 2018, 19:4817 shows up in the devices list and it all seems to be ok, but then:
stack: 2000 out of 15360 GC: total: 96000, used: 72224, free: 23776 No. of 1-blocks: 1200, 2-blocks: 153, max blk sz: 901, max free sz: 617 570570373.535 <HTTPRequest object at 3ffbb2d0> <StreamWriter <socket>> "GET /devices" 2018-01-29 19:46:40 [debug] uPyEasy-uPyEasy: Pages: Authorize User!? 2018-01-29 19:46:40 [debug] uPyEasy-uPyEasy: Pages: Entering Devices Page 2018-01-29 19:46:40 [debug] uPyEasy-uPyEasy: Utils: uPyEasy Name 2018-01-29 19:46:41 [debug] uPyEasy-uPyEasy: Plugins: Read device test 2018-01-29 19:46:41 [debug] uPyEasy-uPyEasy: Plugin: test read stack: 2000 out of 15360 GC: total: 96000, used: 82224, free: 13776 No. of 1-blocks: 1293, 2-blocks: 167, max blk sz: 901, max free sz: 371 570570421.218 <HTTPRequest object at 3ffbfe40> <StreamWriter <socket>> "GET /static/upyeasy.css" stack: 2000 out of 15360 GC: total: 96000, used: 83840, free: 12160 No. of 1-blocks: 1339, 2-blocks: 174, max blk sz: 901, max free sz: 371 570570421.218 <HTTPRequest object at 3ffc5370> <StreamWriter <socket>> "GET /static/upyeasy.js" static/upyeasy.css static/upyeasy.js 2018-01-29 19:47:03 [debug] uPyEasy-uPyEasy: Plugin: test process Traceback (most recent call last): File "main.py", line 2, in <module> File "upyeasy/__init__.py", line 56, in main File "picoweb/__init__.py", line 275, in run File "uasyncio/core.py", line 138, in run_forever File "uasyncio/core.py", line 97, in run_forever File "upyeasy/plugins/test.py", line 107, in asyncprocess File "upyeasy/utils.py", line 277, in plugin_senddata NameError: name 'stype' is not defined MicroPython v1.9.3-255-g979c688-dirty on 2018-01-27; ESP32 module with ESP32 Type "help()" for more information. >>>
The stack trace is helping me a lot to find these bugs!
Hi Lisa,
Thank you for the great work.....
I am trying to set up upyeasy on the TTGO board (ESP32+display+battery):
I get this message at startup:
rst:0x10 (RTCWDT_RTC_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0018,len:4
load:0x3fff001c,len:4364
load:0x40078000,len:0
load:0x40078000,len:10992
entry 0x4007a6c4
I (440) cpu_start: Pro cpu up.
I (440) cpu_start: Single core mode
I (441) heap_init: Initializing. RAM available for dynamic allocation:
I (444) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
I (450) heap_init: At 3FFDCDD0 len 00003230 (12 KiB): DRAM
I (456) heap_init: At 3FFE0440 len 00003BC0 (14 KiB): D/IRAM
I (463) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (469) heap_init: At 4009005C len 0000FFA4 (63 KiB): IRAM
I (475) cpu_start: Pro cpu start user code
I (46) cpu_start: Starting scheduler on PRO CPU.
OSError: [Errno 2] ENOENT
MicroPython v1.9.3-255-g979c688-dirty on 2018-01-28; ESP32 module with ESP32
And I get this error messages when I try to setup wifi:
>>> import network
>>> sta_if = network.WLAN(network.STA_IF); sta_if.active(True)
I (42943) wifi: wifi firmware version: 111e74d
I (42943) wifi: config NVS flash: enabled
I (42943) wifi: config nano formating: disabled
I (42943) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE
I (42953) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE
I (42973) wifi: Init dynamic tx buffer num: 32
I (42973) wifi: Init data frame dynamic rx buffer num: 64
I (42973) wifi: Init management frame dynamic rx buffer num: 64
I (42983) wifi: wifi driver task: 3ffe15dc, prio:23, stack:4096
I (42983) wifi: Init static rx buffer num: 10
I (42993) wifi: Init dynamic rx buffer num: 0
I (42993) wifi: Init rx ampdu len mblock:7
I (43003) wifi: Init lldesc rx ampdu entry mblock:4
I (43003) wifi: wifi power manager task: 0x3ffe850c prio: 21 stack: 2560
W (43013) phy_init: failed to load RF calibration data (0x1102), falling back to full calibration
Brownout detector was triggered
Guru Meditation Error of type IllegalInstruction occurred on core 0. Exception was unhandled.
Any Idea ?
It looks like it can't set MAC Address.....
Paolo
entry 0x4007a6c4
>>> import network
Any Idea ?
Paolo
- download.jpg (5.87 KiB) Viewed 34262 times
There's your cause: you have a power problem. It may be caused by poor quality usb cable, bad solder joints or low power from USB connector. If you can monitor 5v and 3.3v voltage on esp32 during startup then you may have some clue. Use a better usb power source?
(If you see no power dip during startup of the esp32, you might try this:solder a 100nF ceramic or 220uF/16V capacitor on the 3,3V output on the esp32 to suppress the power peak.)
thx a lot, Lisa.
I'll check asap.
Paolo
I'll check asap.
Paolo
Houston, we have a go
Deeply impressed too, I am.
Works fine now, but it is very very very slooooooow. Lots of debug data on the serial output.
I guess this comes with the territory of being a beta tester?
Ohh you guys already have a delete option on the devices...
I wanted that on the V2.0/Mega for so long...
In uPyEasy, all data is just a record in a table in the database. All processes are reading from the database, so deleting device data from the database means the device's plugin no longer read by this device... Unloading the plugin the moment no device is using it anymore, is not implemented yet.
Hi @LisaM
Thanks for your hard work on this, I'm excited to give it a try today!
I notice the Wiki links seem to be dead, referenced from your gitHub page:
"Introduction and wiki: https://www.letscontrolit.com/wiki/inde ... troduction"
Have these pages moved?
Nope, not ready yet...jbishop129 wrote: ↑31 Jan 2018, 16:17 Hi @LisaM
