It is a single PCB containing an 8/16 channel 24-bit ADC (LTC2499) coupled with a 16 channel digital I/O (MCP23017).
support of INA219 and ADS1115
Re: support of INA219 and ADS1115
But is the LTC2499 supported by espeasy? Haven’t seen that in the wiki...
The LTC2499 is connected to the MCP23017 and the latter is supported by ESPEasy!
The link above also has the gerber files, so you could simply have the pcb made by an online pcb maker.
I also downloaded and attached the zip file here which also contains the BOM.
Or you can order it here: https://oshpark.com/shared_projects/zHmwP8eC
Cheers,
Lisa
- TempController.zip
- (48.71 KiB) Downloaded 622 times
Oh
Thx for that!
Thx for that!
Maybe I‘m too dumb for that. I checked the espeasy wiki on the mcp23017 https://www.letscontrolit.com/wiki/index.php/MCP23017
How the hell can I read analog values via the mcp23017 when a ltc2499 is connected to it.
I would use udp as a protocoll for sending data. In that case, following schematics of the pcb attached by you, are then analog values pushed to udp... this seems too easy going to me
Best
Karl
Best
Karl
At closer look, i can see why it's confusing. The board provides both analog inputs through the ltc2499 AND digital inputs through the mcp23017...karl222 wrote: ↑24 Apr 2018, 11:28 Maybe I‘m too dumb for that. I checked the espeasy wiki on the mcp23017 https://www.letscontrolit.com/wiki/index.php/MCP23017
Best
Karl
The ltc2499 can communicate directly using i2c so the mcp23017 is not needed then. That would require you to write a ltc2499 uPyEasy (micropython) plugin using I2C...
Hahahahahahahaha, you are funny. I‘d rather climb the mounteverest as I do the programming of a plugin
Well, in that case you'll need one ESP per 16 channels (4x ADS1115 I2C per ESP). Since it requires switching I2C addresses, essentially building a new communication channel to the ADS115 for retrieving sampled analog data, sampling rate might not be optimal.
I assume sample rate is set by default?
I don’t mind, I’m happy with a value every second... as i send it from esp to nodered via mqtt, it doesn’t matter.
Karl
But support of INA219 would make me happy on esp32 still
Karl
