STM32 boards
Re: STM32 boards
>>> import upyeasy
>>> upyeasy.setnet(1,'A4','A3')
File "<stdin>", line 1, in <module>
File "upyeasy/__init__.py", line 23, in setnet
File "upyeasy/utils.py", line 30, in setnet
File "filedb.py", line 70, in update
AttributeError: type object 'networkTable' has no attribute '__fields__'
this is what i get
this is what i get
Re: STM32 boards
Hi Frank,frank wrote: ↑15 Feb 2018, 22:16 >>> import upyeasy
this is what i get
Does this also happen when you do:
upyeasy.setnet(1,'A4','A3','192.168.0.210', '255.255.255.0', '192.168.0.3', '8.8.8.8')
Cheers,
Lisa
Re: STM32 boards
Hi Lisa,LisaM wrote: ↑15 Feb 2018, 22:52Hi Frank,frank wrote: ↑15 Feb 2018, 22:16 >>> import upyeasy
this is what i get
Does this also happen when you do:?Code: Select all
Cheers,
Lisa
I'm having the same error as Frank...
And in answer to your question to him, if I do
>>> upyeasy.setnet(1,'A4','A3','192.168.1.77', '192.168.1.1', '255.255.255.0', '192.168.1.1')
When I do
import upyeasy
upyeasy.main()
Hope this helps!
Andrew
Re: STM32 boards
hi,LisaM wrote: ↑23 Dec 2017, 15:17 Firmware status: Beta
Firmware version: v0.2.0
For the PyBv3 with STM32F405 board:
BOM (Bill Of Materials):
- STM32F405RGT6 pyboard: https://www.aliexpress.com/item/STM32-S ... 71346.html
Wiring between Pyboard and W5500:
- W5500 ethernet card: https://nl.aliexpress.com/item/Free-shi ... 89406.html
MOSI connected to PA7
MISO connected to PA6
SCLK connected to PA5
nSS connected to PA4
nRESET connected to PA3
After flashing the firmware, the dfu-util tool will reboot your pyboard.Firmware upload instructions
Download the dfu-util tool here: http://dfu-util.sourceforge.net/
The uPyEasy FLASHBINARY file has this format: upyeasy_vXX_YYYYMMDD_test_esp32_2048.bin and is attached to this post as zip file.
The (latest) uPyEasy binary files can be downloaded here: https://github.com/letscontrolit/upyeasy/releases
Run this in REPL:Then you're kicked out of REPL due to boot mode.import pyb
pyb.bootloader()
Run this:LINUX: sudo dfu-util --alt 0 -D upyeasy-pybv3.dfuWINDOWS: dfu-util --alt 0 -D upyeasy-pybv3.dfu
After reboot, uPyEasy will auto-start.
If you have connected a W5500 as described above, no other steps are needed because uPyEasy is using DHCP to get the ip-address.
uPyEasy should be running on default port 80, so connect using your browser using: http://<your upyeasy ip address>:80
In linux you can use the following command to connect to the STM32: screen /dev/ttyACMx 115200,cs8
In Windows just use putty to connect to the com port COMx at 115200 baud speed.
The uPyEasy webserver response is about 10x faster then the ESP32 WiFi response, due to the wired (1GB) network.If you have wired the W5500 otherwise, you'll get this message (or get stuck at Network init, then press ctrl-c):Now, you'll need to set the correct parameters in REPL:Code: Select all
Exiting: Network not available, set network values!
And in the case of above wiring, it would be upyeasy.setnet(1,'A3','A4')Code: Select all
upyeasy.setnet(<spi number>,'<machine pin nss>','<machine pin rst>')
Then reboot using:Code: Select all
import machine machine.reset()
I was trying to wire up accordingly but couldn't find the nSS pin on the W5500. can someone help me on that...
thx
karl
Re: STM32 boards
Hi karl,hi,
thx
karl
I had the same issue. In the end, I used the one marked "SCS" on my W5500. It was a process of elimination for me, the others were pretty clear, so that seemed the nearest.
I'm still not sure if that was right, as I have been unable to access uPyEasy over my network, even though the log shows that uPyEasy has made a connection. But it may work for you, I hope so.
Good luck, let us know how it goes!
Andrew
Re: STM32 boards
Can you post your W5500 also?AndrewJ wrote: ↑15 Mar 2018, 19:14Hi karl,hi,
thx
karl
Andrew
Re: STM32 boards
Mine is the same part.
Some additional info..,
I tried the same W5500 with a STM32F103 "Blue Pill" board using one of the example sketches (web server) and it worked fine. Connected to network, no problem connecting from my browser, and it supplied data to my browser, able to ping. In this scenario, I used the same SCS pin.
Re: STM32 boards
For the STM32F103 to work, you'll need the STM32F103RG/STM32F103VG/STM32F103ZG because these have 1MB on board.AndrewJ wrote: ↑16 Mar 2018, 20:27 Mine is the same part.
Re: STM32 boards
Attached pictures of my config, please adjust your config.
Run
(replace ip-addresses by your own ip, gateway, mask, dns)
Cheers,
Lisa
Run
upyeasy.setnet(1,'A3','A4','192.168.178.135', '192.168.178.1', '255.255.255.0', '192.168.178.1')
Cheers,
Lisa
- IMG_4096.JPG (1.94 MiB) Viewed 101255 times
- IMG_4098.JPG (2.32 MiB) Viewed 101255 times
- IMG_4102.JPG (3.26 MiB) Viewed 101255 times
Re: STM32 boards
HI Lisa, Thanks for that info. My Blue Pill is a STM32F103C8T6 (with 128k flash), so not one of the models you mentioned. I bought it as a first step with STM32's (not uPyEasy).LisaM wrote: ↑18 Mar 2018, 16:04For the STM32F103 to work, you'll need the STM32F103RG/STM32F103VG/STM32F103ZG because these have 1MB on board.AndrewJ wrote: ↑16 Mar 2018, 20:27 Mine is the same part.
BTW, I wasn't trying to get uPyEasy to work on the Blue Pill board (perhaps my post may have seemed that way). I wanted to test that the W5500 itself was capable of working by using it on another board (although it's different code). And in that setup it is ok, and my browser and network can connect to it.
So the issue seems to be my Pyboard clones (x2) and/or something in uPyEasy. The clones are the same as the ones you linked to at AliExpress in the first post of the STM32 thread, except I ordered through the AliExpress English site not the Dutch one.
When I get a bit more time, I'll try again with one of the Pyboard clones and uPyEasy, and connect a logic analyser to try to see what data is being transferred to/from the W5500.
Andrew
Re: STM32 boards
I am not born for this...
1. I installed WinUSB via Zadig which works now.
2. I downloaded dfu-util. I have to use the win32 Version. When I doubleclick on dfu-util.exe a black cmd-window appears and disappeary shortly after and that's it.
or is it intended to use REPL commands first. This is not clear to me when I read the "manual'
Then I get failure Messages:
>>> import upyeasy
ModuleNotFoundError: No module named 'upyeasy'
alternatively:
>>> import pyb
ModuleNotFoundError: No module named 'pyb'
What's the Problem? Any ideas?
Many thanks
Karl
p.s. LisaM: it is really a pitty with these dumb-users, I know. I hope we get with upyeasy to a point where evry idiot can handle it - even me . this is what espeasy makes so successfull
>>> import upyeasy
alternatively:
>>> import pyb
Many thanks
Karl
Re: STM32 boards
Hi Lisa,LisaM wrote: ↑18 Mar 2018, 16:34 Attached pictures of my config, please adjust your config.
Run(replace ip-addresses by your own ip, gateway, mask, dns)Code: Select all
Cheers,
Lisa
Thanks for the information. I've set my system up to match yours (I think!), After running the command you gave, it starts up and gets to the end of messages where it says it has connected to an IP address and is running the Async processes, but it is still not letting me connect from my browser. (unreachable) and I can't ping it successfully.
It's actually a bit hard to be sure from the photos which wire goes where. Some are almost hidden. Could you possibly list the connections between the STM32 and W5500?
Thanks in advance
Andrew
Re: STM32 boards
Andrew, don't give up, we'll get there
Re: STM32 boards
Hi Karl,
Yes, you're right, we will get there! What is good is that several of us are trying it, so we can all help each other.
Have you been able to try again since Lisa's photos? Were you able to tell which wires went where? Any luck?
I hope you have success!!
Andrew
Andrew
Re: STM32 boards
No, wasn’t successful either. I don’t have mr gadgets goggles to see through wires
I did my next (unsuccessful) attempt with esp32 wrover, which I received today...
Maybe you can have a look on my thread in esp32 section...
Don’t give up, don’t give up, don’t give up, ...
Re: STM32 boards
Hi @LisaM,LisaM wrote: ↑18 Mar 2018, 16:34 Attached pictures of my config, please adjust your config.
Cheers,
Lisa
Thanks for posting these pictures. I've followed them as far as I can see, but my 2 STM32 boards with W5500 are still not allowing me to connect.
The log says it's connected but I can't see it in my router, ping it, or connect from web browser.
I'm using the dfu file from the Github releases page.
Yet when I tested my W5500 with a Blue Pill board and an Arduino-IDE sketch (webserver) it worked fine. So the problem seems to lie with the Pyboard clone, or the firmware, or the connections.
Could you please help me? I want to double-check that I'm connecting it right, as some of the wires are a bit hidden at the ends. My interpretation of your pictures is this - please could you confirm or make any corrrections?
Pyboard clone W5500 wire colour
PA3 SCS light blue/green
PA4 RST white
PA5 SCLK purple
PA6 MISO orange
PA7 MOSI yellow
3v3 3v3 red
Gnd GND black
I'm really keen to get something (anything! ) working so I can test my OpenHAB MQTT on a real board!
Cheers,
Andrew
Re: STM32 boards
@andrewj: The colors are good, the wiring is good...
@karl222: Since the ESP32 is now, i'm currently looking at the STM32
STM32's are great, because the interrupts are hardware bound while the ESP32's have a software bound interrupt. Meaning that the STM32 latency is WAY lower then that of the ESP's, that also makes the ethernet way faster then wifi.
Pffffff, after update i ran into bugs. Filed them @micropython for help...
Re: STM32 boards
Thanks for the update, Lisa.LisaM wrote: ↑27 Mar 2018, 19:47 @andrewj: The colors are good, the wiring is good...
Good luck with the bugs!! (life is never simple, is it?)
Re: STM32 boards
Bug is stated here: https://github.com/micropython/micropython/pull/3379
Re: STM32 boards
Hi Lisa,LisaM wrote: ↑27 Mar 2018, 19:47 @andrewj: The colors are good, the wiring is good...
Any news about the bugs on STM32?
Also, I think I notice some small changes in the source code in recent version which may affect the CS pin etc. Would these changes allow the latest code to be built and to run on STM32, do you think? Is it worth me giving it a try?
Andrew
Re: STM32 boards
No update, this weekend i'll give it a try to work-around the bug so that we can build the STM32 version again...AndrewJ wrote: ↑04 Apr 2018, 22:40Hi Lisa,LisaM wrote: ↑27 Mar 2018, 19:47 @andrewj: The colors are good, the wiring is good...
Andrew
Cheers,
Lisa
Re: STM32 boards
OK, thanks for the update. Good luck!
I'm ready to help with testing or any other way I can.
Andrew
Andrew
Re: STM32 boards
Hi Lisa,LisaM wrote: ↑05 Apr 2018, 01:08No update, this weekend i'll give it a try to work-around the bug so that we can build the STM32 version again...AndrewJ wrote: ↑04 Apr 2018, 22:40Hi Lisa,LisaM wrote: ↑27 Mar 2018, 19:47 @andrewj: The colors are good, the wiring is good...
Andrew
Cheers,
Lisa
I noticed your post on MicroPython forum about a workaround for the bug...
https://forum.micropython.org/viewtopic ... 929#p26929
Does this mean that uPyEasy can be used now on STM32 simply by applying those patch commands (and I guess rebuilding Micropython?), or does something more need to happen first?
Cheers
Andrew
Re: STM32 boards
I've tried to fix the bugs, but they have change so much on the stm32 port that i lost track.
So, the work-around now is to roll back before they started to change the stm32 port on 31/1:
This builds the firmware.dfu again, without the errors.
However... i now run into the problem:
Pfffff.
git clone https://github.com/micropython/micropython.git micropython-stm32
cd micropython-stm32/
git submodule update --init
git checkout a275cb0f487cd6517760271dc01d369c32600c63
git pull origin pull/3379/head
>>> import upyeasy
>>> upyeasy.main()
AttributeError: 'module' object has no attribute 'main'
Re: STM32 boards
Hmm, that's frustrating!LisaM wrote: ↑13 Apr 2018, 18:14 I've tried to fix the bugs, but they have change so much on the stm32 port that i lost track.
So, the work-around now is to roll back before they started to change the stm32 port on 31/1:This builds the firmware.dfu again, without the errors.Code: Select all
git clone https://github.com/micropython/micropython.git micropython-stm32 cd micropython-stm32/ git submodule update --init git checkout a275cb0f487cd6517760271dc01d369c32600c63 git pull origin pull/3379/head
However... i now run into the problem:Pfffff.Code: Select all
>>> import upyeasy >>> upyeasy.main() Traceback (most recent call last): File "<stdin>", line 1, in <module> AttributeError: 'module' object has no attribute 'main'
In the meantime I've been having a go. Here's what I did.
I used the commands you gave above, and it built without errors as you found.
Next, I re-built everything using the "new" micopython-stm32,
- I copied the upyeasy src contents into micropython-stm32/ports/stm32/modules/upyeasy
- copied modules contents into ....stm32/modules (had one or two duplicates where I chose the 'upyeasy' version)
- from repo root, did make -C mpy-cross
- in ...ports/stm32 I did
- make MICROPY_PY_WIZNET5K=5500 BOARD=PYBV3 (as I'm using the AliExpress clone board)
- then I connected 3v3 to BOOT0 and did
- sudo make MICROPY_PY_WIZNET5K=5500 BOARD=PYBV3 USE_PYDFU=0 deploy
(all of the above from your excellent document "uPyEasy Building Environment" with a few variations).
Reset and reconnected to USB and was able to connect to REPL
import upyeasy
upyeasy.main()
This worked ok for me, I didn't get the error you have, but it did stop with an error further on, which I'm sure is because I wanted to try it and hadn't connected the W5500
Good luck!
Andrew
Re: STM32 boards
The problem was that script.py imports re.py which is actually an unix library, script.py should import ure library which is a default micropython library. I fixed this, so it's working again. Apparently is main.py not findable if one the imports fails...
Cheers,
Lisa
Cheers,
Lisa
Re: STM32 boards
Ah, glad you've found that!LisaM wrote: ↑14 Apr 2018, 00:11 The problem was that script.py imports re.py which is actually an unix library, script.py should import ure library which is a default micropython library. I fixed this, so it's working again. Apparently is main.py not findable if one the imports fails...
Cheers,
Lisa
Which version of uPyEasy are you using? I realised belatedly that I was still using a previous version, not the latest with OpenHABmqtt. And did you find you needed to go through the whole building process like I was doing?
EDIT: forgot to ask, is W5500 now working for you?
Cheers
Andrew
Re: STM32 boards
uPyEasy does compile but doesn't work, it doesn't repond to web requests. I'm trying to figure out why, i suspect that the asyncio changes in uPyEasy have something to do with it.AndrewJ wrote: ↑14 Apr 2018, 08:39Ah, glad you've found that!LisaM wrote: ↑14 Apr 2018, 00:11 The problem was that script.py imports re.py which is actually an unix library, script.py should import ure library which is a default micropython library. I fixed this, so it's working again. Apparently is main.py not findable if one the imports fails...
Cheers,
Lisa
Cheers
Andrew
However this code works, so the W5500 is also working:
import picoweb, uasyncio as asyncio
CONTENT = """\
<html>
<head>
</head>
<body>
<p>Hello #%d from uPyEasy!</p>
</body>
</html>
app = picoweb.WebApp(__name__)
@app.route("/")
def index(req, resp):
yield from picoweb.start_response(resp)
yield from resp.awrite(CONTENT)
class plugins(object):
def __init__(self) :
print("init")
async def asyncdevices(self):
print("async")
import network,pyb
nic = network.WIZNET5K(pyb.SPI(1), pyb.Pin.board.A3, pyb.Pin.board.A4)
while not nic.isconnected():
pass
nic.active(1)
nic.ifconfig(('192.168.178.100', '255.255.255.0', '192.168.178.1', '192.168.178.1'))
loop = asyncio.get_event_loop()
_plugins = plugins()
loop.create_task(_plugins.asyncdevices())
app.run(host="0.0.0.0", port=80,debug=False)
Re: STM32 boards
Solved the mystery, it was a single line of code! Changing this in the hal.py file from:
to
Solved the problem. In hindsight it makes sense, the nic was there, even with an ip-address, but not active so it couldn't receive data...
Uploaded new version.
Cheers,
Lisa
#core._nic.active(1)
core._nic.active(1)
Cheers,
Lisa
Re: STM32 boards
Fantastic! Good spot!!LisaM wrote: ↑14 Apr 2018, 14:40 Solved the mystery, it was a single line of code! Changing this in the hal.py file from:toCode: Select all
Solved the problem. In hindsight it makes sense, the nic was there, even with an ip-address, but not active so it couldn't receive data...Code: Select all
core._nic.active(1)
Cheers,
Lisa
Re: STM32 boards. How to determine which boards will work
Difficult to see in this forum topic which board specs will and won’t work. Ie. memory required for code, etc.
Will this board work?
STM32 ARM Mini System - 72Mhz
https://www.robotics.org.za/6970622930693
And the pycom lopy?
https://www.robotics.org.za/AF3339
And the pycom lopy?
I totally forgot the Lopy was ESP32. Since I have a couple of those, I will have to plug one in and see if it works.....JR01 wrote: ↑19 May 2018, 14:54 Difficult to see in this forum topic which board specs will and won’t work. Ie. memory required for code, etc.
And the pycom lopy?
Re: STM32 boards
I gave the LoPy a try, the 2048 version loads and runs. I need to play with it more, but it appears to have issue keeping the AP information but that could be me not doing something correctly.. There were some other errors, something about MAC address not set, but that could be the LoPy comm module. Hard to say.
I was able to access several of the menus as well..
Re: STM32 boards
Thank you drum, I will wait until someone get there t working.
And the other STM32 I showed? Does it have enough memory?
Re: STM32 boards
No Idea. I only have 1 and I have not been able to get it to work yet. It may work in mine, I just have not spent a lot of time on it.
You have to remember uPyEasy is still in beta and is not perfect on anything yet. Los of potential but it's not there yet.
Re: STM32 boards
Thank you!
The mini doesn work, you'll need at least 1MB of flash memory! Also at least 196K of ram.JR01 wrote: ↑19 May 2018, 14:54 Difficult to see in this forum topic which board specs will and won’t work. Ie. memory required for code, etc.
And the pycom lopy?
The pycom is using an ESP32 and hsould work, although untested since i don't have it.
Re: STM32 boards
Can you post the errors? i'm interested in the error.Drum wrote: ↑21 May 2018, 17:55 I gave the LoPy a try, the 2048 version loads and runs. I need to play with it more, but it appears to have issue keeping the AP information but that could be me not doing something correctly.. There were some other errors, something about MAC address not set, but that could be the LoPy comm module. Hard to say.
I'm going to order the pycom GPy since it supports nb-iot.
Re: STM32 boards
I (2715) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE
I (2725) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE
This is all I get consistently today.
Re: STM32 boards
Is this an ESP32 or a STM32F4?
It looks like this is a brown-out, meaning your power supply isn't strong enough.
Can i have the entire log?
Cheers,
Lisa
Re: STM32 boards
Well it is a ESP32 based LoPy. Power is coming from the computer, but that could be part of the problem. I will see if I can figure out how fix that and get a copy of the log file.
I just got a couple of ESP32 Nano boards I will try it on too..
Re: STM32 boards
Here is the log after updating to the latest version
The LoPy works much better with an antenna attached
rst:0x10 (RTCWDT_RTC_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0018,len:4
load:0x3fff001c,len:4464
ho 0 tail 12 room 4
load:0x40078000,len:0
load:0x40078000,len:11816
entry 0x4007a9fc
I (290) cpu_start: Pro cpu up.
I (290) cpu_start: Single core mode
I (290) heap_init: Initializing. RAM available for dynamic allocation:
I (294) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
I (300) heap_init: At 3FFC5120 len 0001AEE0 (107 KiB): DRAM
I (306) heap_init: At 3FFE0440 len 00003BC0 (14 KiB): D/IRAM
I (312) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (319) heap_init: At 4008E0E8 len 00011F18 (71 KiB): IRAM
I (325) cpu_start: Pro cpu start user code
I (44) cpu_start: Starting scheduler on PRO CPU.
I (113) modsocket: Initializing
I (3053) wifi: wifi firmware version: c202b34
I (3053) wifi: config NVS flash: enabled
I (3053) wifi: config nano formating: disabled
I (3063) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE
I (3073) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE
I (3093) wifi: Init dynamic tx buffer num: 32
I (3093) wifi: Init data frame dynamic rx buffer num: 64
I (3093) wifi: Init management frame dynamic rx buffer num: 64
I (3103) wifi: wifi driver task: 3ffd1194, prio:23, stack:4096
I (3103) wifi: Init static rx buffer num: 10
I (3113) wifi: Init dynamic rx buffer num: 0
I (3113) wifi: wifi power manager task: 0x3ffd5de4 prio: 21 stack: 2560
I (3183) phy: phy_version: 383.0, 79a622c, Jan 30 2018, 15:38:06, 0, 0
I (3183) wifi: mode : null
I (3193) wifi: mode : sta (24:0a:c4:00:90:72)
I (3193) wifi: STA_START
I (3313) wifi: n:1 0, o:1 0, ap:255 255, sta:1 0, prof:1
I (3873) wifi: state: init -> auth (b0)
I (3873) wifi: state: auth -> assoc (0)
I (3883) wifi: state: assoc -> run (10)
I (3893) wifi: connected with devolo, channel 1
I (3893) network: event 4
I (5063) event: sta ip: 192.168.1.114, mask: 255.255.255.0, gw: 192.168.1.1
I (5063) network: GOT_IP
I (6883) wifi: pm start, type:0
2018-07-11 16:03:54 [info] uPyEasy-uPyEasy: Main: Async loop, log level: 2
2018-07-11 16:03:54 [info] uPyEasy-uPyEasy: Main: uPyEasy running in Station mode
ho 0 tail 12 room 4
entry 0x4007a9fc
Re: STM32 boards
I am still getting
How can I get the log without being connected to the computer?
Re: STM32 boards
But, you do get an ip-address:Drum wrote: ↑11 Jul 2018, 17:11 I am still getting
You should be able to connect to it...I (5063) event: sta ip: 192.168.1.114, mask: 255.255.255.0, gw: 192.168.1.1
I
Re: STM32 boards
Yes, and I have it running with syslog set to debug, but it is not what I see on "Screen".
Is it possible the
is related to the LoRa radio and not the esp32? Or perhaps LoRa and Bluetooth?
New version is much faster on this.
Is it possible the
