LisaM wrote: ↑26 Mar 2018, 22:26
V0.2.2 released, firmware can be found in the release section.
Issues solved:
- Async ESP32 not working (work-around implemented: devices should be sending data to domoticz now)
Features added:
- Fixed IP Address possible for ESP32
Hi Lisa,
Thanks for all your hard work on this!
I just tried the latest (20180326) binaries for ESP32 on my Lolin32 Lite board. Getting closer but still some issues.
2048.bin:
Working with only the BME280 and DomoticzMQTT, can see Async processes running, values being updated - all good.
BUT, when I tried to add DS18B20, after clicking Submit to select DS18B20 the bottom two thirds of the screen was the one for BME280 (I2C address, three value settings (Temp, Press, Hum)!
I tried 'Submit' at the bottom anyway...
The main Devices page showed the "real" BME280, plus a device with three values (Temperature, Pressue, Humidity)! (It's a mutant!!
4096.bin:
Similar to above. OK with Domoticz and BME280, Async process running, values being updated, all good.
This time when I tried to add DS18B20, it crashed as soon as I clicked 'Submit' to select it. See log below.
2018-03-27 15:06:20 [debug] uPyEasy-uPyEasy: Pages: Entering Device Settings Page
2018-03-27 15:06:20 [debug] uPyEasy-uPyEasy: Pages: POST
2018-03-27 15:06:20 [debug] uPyEasy-uPyEasy: id
2018-03-27 15:06:20 [debug] uPyEasy-uPyEasy: 0
2018-03-27 15:06:20 [debug] uPyEasy-uPyEasy: New Plugin: 4
2018-03-27 15:06:20 [debug] uPyEasy-uPyEasy: Pages: Create Device
2018-03-27 15:06:20 [debug] uPyEasy-uPyEasy: Pages: New Device and plugin choosen: 4
2018-03-27 15:06:21 [debug] uPyEasy-uPyEasy: Utils: uPyEasy Name
2018-03-27 15:06:22 [debug] uPyEasy-uPyEasy: Plugins: Init device: dummy with plugin: 4
2018-03-27 15:06:22 [debug] uPyEasy-uPyEasy: Protocols: GetQueue controller 192.168.1.12-Domoticz MQTT-1
2018-03-27 15:06:22 [debug] uPyEasy-uPyEasy: Plugin: ds18 contruction
2018-03-27 15:06:23 [debug] uPyEasy-uPyEasy: Plugin: ds18 contruction
2018-03-27 15:06:23 [debug] uPyEasy-uPyEasy: Plugins: Init device: dummy ,instantiate plugin: DS18B20
2018-03-27 15:06:23 [debug] uPyEasy-uPyEasy: Utils: uPyEasy Name
2018-03-27 15:06:23 [debug] uPyEasy-uPyEasy: Plugin: ds18 init
2018-03-27 15:06:23 [debug] uPyEasy-uPyEasy: Plugins: Read device store: dummy
2018-03-27 15:06:23 [debug] uPyEasy-uPyEasy: Plugin: ds18 init, pin used:
2018-03-27 15:06:23 [debug] uPyEasy-uPyEasy: Hal: pin =
File "boot.py", line 3, in <module>
File "upyeasy/__init__.py", line 65, in main
File "picoweb/__init__.py", line 298, in run
File "uasyncio/core.py", line 146, in run_forever
File "uasyncio/core.py", line 101, in run_forever
File "picoweb/__init__.py", line 210, in _handle
AttributeError: 'Log' object has no attribute 'exc'
OSError: [Errno 2] ENOENT
MicroPython v1.9.3-479-gb63cc1e-dirty on 2018-03-26; ESP32 module with ESP32
Type "help()" for more information.
Hope this helps to hunt down the problem.
So it looks like Async processes are fixed now, but an issue with DS18B20.
I really appreciate all the work you are doing on this. If there's any more information you'd like, let me know. Can I help in any way with debugging?
Cheers
Andrew
