ESP32 boards
Re: ESP32 boards
You are right, Lisa - build & deploy doesn't change. The problem must by in his custom makefile which overrides some variables from Makefile.
Regards from Bulgaria.
raptor
raptor
Re: ESP32 boards
No, it's my fault. The new binaries in the https://github.com/letscontrolit/uPyEasy/releases section should not have this reboot problem.
Re: ESP32 boards
It is not looping anymore.
But now I get this:
But now I get this:
rst:0x1 (POWERON_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0018,len:4
load:0x3fff001c,len:4364
load:0x40078000,len:0
load:0x40078000,len:10992
entry 0x4007a6c4
W (65) rtc_clk: Potentially bogus XTAL frequency: 35 MHz, guessing 40 MHz
I (447) cpu_start: Pro cpu up.
I (447) cpu_start: Single core mode
I (448) heap_init: Initializing. RAM available for dynamic allocation:
I (451) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
I (457) heap_init: At 3FFDCDD0 len 00003230 (12 KiB): DRAM
I (463) heap_init: At 3FFE0440 len 00003BC0 (14 KiB): D/IRAM
I (470) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (476) heap_init: At 4009005C len 0000FFA4 (63 KiB): IRAM
I (482) cpu_start: Pro cpu start user code
I (53) cpu_start: Starting scheduler on PRO CPU.
File "_boot.py", line 10, in <module>
File "inisetup.py", line 28, in setup
File "inisetup.py", line 6, in check_bootsec
File "flashbdev.py", line 13, in readblocks
OSError: [Errno 5] EIO
OSError: [Errno 1] EPERM
MicroPython v1.9.3-255-g979c688-dirty on 2018-03-21; ESP32 module with ESP32
Type "help()" for more information.
>>> import upyeasy
I (21537) modsocket: Initializing
>>> upyeasy.setwifi('xxxxxxxxxx', 'xxxxxxxx')
File "<stdin>", line 1, in <module>
File "upyeasy/__init__.py", line 29, in setwifi
File "upyeasy/utils.py", line 39, in setwifi
File "upyeasy/db.py", line 87, in getrow
File "filedb.py", line 91, in get
OSError: [Errno 19] ENODEV
Re: ESP32 boards
Bert, your wifi password is in there...BertB wrote: ↑21 Mar 2018, 22:15 It is not looping anymore.
But now I get this:rst:0x1 (POWERON_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT)
entry 0x4007a6c4
>>> import upyeasy
>>> upyeasy.setwifi('xxxxxx', 'xxxxxxxxxxxJ')
Did you use the 4096 or 2048 version?
If you used the 4096 version, can you also try using the 2048 version? It sounds like a flash drive error to me.
Re: ESP32 boards
I am getting tired ... thanks.
Ehm, I tried both.
Ehm, I tried both.
Re: ESP32 boards
It is also impossible to use ampy to upload main.py
D:\Program Files\Python\Python36>ampy --port COM6 put D:\Tools\uPython\main.py
File "d:\program files\python\python36\lib\runpy.py", line 193, in _run_module_as_main
"__main__", mod_spec)
File "d:\program files\python\python36\lib\runpy.py", line 85, in _run_code
exec(code, run_globals)
File "D:\Program Files\Python\Python36\Scripts\ampy.exe\__main__.py", line 9, in <module>
File "d:\program files\python\python36\lib\site-packages\click\core.py", line 722, in __call__
return self.main(*args, **kwargs)
File "d:\program files\python\python36\lib\site-packages\click\core.py", line 697, in main
rv = self.invoke(ctx)
File "d:\program files\python\python36\lib\site-packages\click\core.py", line 1066, in invoke
return _process_result(sub_ctx.command.invoke(sub_ctx))
File "d:\program files\python\python36\lib\site-packages\click\core.py", line 895, in invoke
return ctx.invoke(self.callback, **ctx.params)
File "d:\program files\python\python36\lib\site-packages\click\core.py", line 535, in invoke
return callback(*args, **kwargs)
File "d:\program files\python\python36\lib\site-packages\ampy\cli.py", line 213, in put
board_files.put(remote, infile.read())
File "d:\program files\python\python36\lib\site-packages\ampy\files.py", line 137, in put
self._pyboard.exec_("f = open('{0}', 'wb')".format(filename))
File "d:\program files\python\python36\lib\site-packages\ampy\pyboard.py", line 265, in exec_
raise PyboardError('exception', ret, ret_err)
ampy.pyboard.PyboardError: ('exception', b'', b'Traceback (most recent call last):\r\n File "<stdin>", line 1, in <module>\r\nOSError: [Errno 1] EPERM\r\n')
Re: ESP32 boards
No need to upload main.py! Main.py is 'frozen', meaning it's part of the firmware.BertB wrote: ↑21 Mar 2018, 22:38 It is also impossible to use ampy to upload main.py
Using 'import upyeasy' loads the uPyEasy module (which include main.py) into memory and 'upyeasy.main()' runs upyEasy.
Re: ESP32 boards
uiuiui, still a long way to go...
i’ll give it a try in the evening....
karl
karl
Re: ESP32 boards
Hello, Lisa The connection to my router is successful, but when i make request to 192.168.100.3 from my browser it tells me that is unable to connect.
This is what I got:
rst:0x10 (RTCWDT_RTC_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
load:0x3fff001c,len:4416
ho 0 tail 12 room 4
load:0x40078000,len:11816
entry 0x4007a9fc
I (265) cpu_start: Pro cpu up.
I (265) cpu_start: Single core mode
I (265) heap_init: Initializing. RAM available for dynamic allocation:
I (269) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
I (275) heap_init: At 3FFC4E80 len 0001B180 (108 KiB): DRAM
I (281) heap_init: At 3FFE0440 len 00003BC0 (14 KiB): D/IRAM
I (288) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (294) heap_init: At 4008DE34 len 000121CC (72 KiB): IRAM
I (300) cpu_start: Pro cpu start user code
I (20) cpu_start: Starting scheduler on PRO CPU.
OSError: [Errno 2] ENOENT
MicroPython v1.9.3-473-g22c693a-dirty on 2018-03-21; ESP32 module with ESP32
>>> import upyeasy
I (19363) modsocket: Initializing
>>> import network
>>> station = network.WLAN(network.STA_IF)
I (86893) wifi: wifi firmware version: ebd3e5d
I (86893) wifi: config NVS flash: enabled
I (86893) wifi: config nano formating: disabled
I (86893) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE
I (86903) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE
I (86923) wifi: Init dynamic tx buffer num: 32
I (86923) wifi: Init data frame dynamic rx buffer num: 64
I (86923) wifi: Init management frame dynamic rx buffer num: 64
I (86933) wifi: wifi driver task: 3ffcaf40, prio:23, stack:4096
I (86933) wifi: Init static rx buffer num: 10
I (86943) wifi: Init dynamic rx buffer num: 0
I (86943) wifi: wifi power manager task: 0x3ffcfb90 prio: 21 stack: 2560
I (87013) phy: phy_version: 383.0, 79a622c, Jan 30 2018, 15:38:06, 0, 0
I (87013) wifi: mode : null
>>> station.active(True)
I (98793) wifi: mode : sta (30:ae:a4:04:80:30)
I (98793) wifi: STA_START
True
>>> station.connect("my_ssid", "my_pass")
>>> I (132043) wifi: n:10 0, o:1 0, ap:255 255, sta:10 0, prof:1
I (132603) wifi: state: init -> auth (b0)
I (132603) wifi: state: auth -> assoc (0)
I (132613) wifi: state: assoc -> run (10)
I (132673) wifi: connected with OpenWrt2, channel 10
I (132673) network: event 4
I (133893) event: sta ip: 192.168.100.3, mask: 255.255.255.0, gw: 192.168.100.1
I (133893) network: GOT_IP
I (135613) wifi: pm start, type:0
>>> print('network config:', station.ifconfig())
network config: ('192.168.100.3', '255.255.255.0', '192.168.100.1', '192.168.100.1')
>>> station.isconnected()
True
I've got ping to 192.168.100.3, but seems web server isn't working.
What I'm missing?
This is what I got:
ho 0 tail 12 room 4
entry 0x4007a9fc
>>> import upyeasy
>>> import network
True
True
What I'm missing?
raptor
raptor
Re: ESP32 boards
It's working, cool!
The webserver doesn't work, because you're only connected to the wifi (which doesn't include a webserver).
To run uPyEasy:
>>> import upyeasy
>>> upyeasy.main()
Part of the uPyEasy module is a fully functional webserver, so you should be able to connect now...
Cheers,
Lisa
Re: ESP32 boards
Lisa, you are great Thank you, very much for your help! I have working ESP32 module with uPyEasy firmware. I will be glad to help in developing and popularization of this great firmware
- Screenshot from 2018-03-22 23-05-37.png (131.6 KiB) Viewed 89433 times
raptor
raptor
Re: ESP32 boards
yep, Installation was successful:
ets Jun 8 2016 00:22:57
rst:0x1 (POWERON_RESET),boot:0x33 (SPI_FAST_FLASH_BOOT)
entry 0x4007a6c4
I (442) cpu_start: Pro cpu up.
I (442) cpu_start: Single core mode
I (443) heap_init: Initializing. RAM available for dynamic allocation:
I (446) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
I (452) heap_init: At 3FFDCDD0 len 00003230 (12 KiB): DRAM
I (458) heap_init: At 3FFE0440 len 00003BC0 (14 KiB): D/IRAM
I (464) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (471) heap_init: At 4009005C len 0000FFA4 (63 KiB): IRAM
I (477) cpu_start: Pro cpu start user code
I (47) cpu_start: Starting scheduler on PRO CPU.
BUT, I can't set wifi Parameters accordingly via Python window:
>>> upyeasy.setwifi('xxxxx', 'yyyyyyy')
NameError: name 'upyeasy' is not defined
even when I do this, it doesn't work:
>>> import upyeasy
ModuleNotFoundError: No module named 'upyeasy'
Any Ideas?
thx
karl
entry 0x4007a6c4
>>> import upyeasy
Any Ideas?
thx
karl
Re: ESP32 boards
How can the webserver be started via autostart? what is the reason behind the logic of being startet not automatically?LisaM wrote: ↑22 Mar 2018, 15:48It's working, cool!
To run uPyEasy:
>>> import upyeasy
>>> upyeasy.main()
Cheers,
Lisa
thx
karl
Re: ESP32 boards
I followed all the steps of Raptor, no success:
rst:0x10 (RTCWDT_RTC_RESET),boot:0x3f (SPI_FAST_FLASH_BOOT)
entry 0x4007a6c4
NameError: name 'station' is not defined
>>> import upyeasy
I (51960) modsocket: Initializing
>>> import network
I (66090) wifi: wifi firmware version: 111e74d
I (66090) wifi: config NVS flash: enabled
I (66090) wifi: config nano formating: disabled
I (66100) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE
I (66120) wifi: Init dynamic tx buffer num: 32
I (66120) wifi: Init data frame dynamic rx buffer num: 64
I (66120) wifi: Init management frame dynamic rx buffer num: 64
I (66130) wifi: wifi driver task: 3ffddfb0, prio:23, stack:4096
I (66140) wifi: Init static rx buffer num: 10
I (66140) wifi: Init dynamic rx buffer num: 0
I (66140) wifi: Init rx ampdu len mblock:7
I (66150) wifi: Init lldesc rx ampdu entry mblock:4
I (66150) wifi: wifi power manager task: 0x3ffe85b4 prio: 21 stack: 2560
I (66180) phy: phy_version: 362.0, 61e8d92, Sep 8 2017, 18:48:11, 0, 0
I (66180) wifi: mode : null
I (75420) wifi: mode : sta (30:ae:a4:22:e8:1c)
I (75420) wifi: STA_START
True
>>> station.connect("xxxxxxx", "xxxxxxxxx")
>>> I (109500) wifi: n:7 1, o:1 0, ap:255 255, sta:7 1, prof:1
I (110060) wifi: state: init -> auth (b0)
I (110060) wifi: state: auth -> assoc (0)
I (110070) wifi: state: assoc -> run (10)
I (110080) wifi: connected with xxxxxxxx, channel 7
I (110080) network: event 4
I (110950) event: sta ip: -------------, mask: 255.255.255.0, gw: -----------
I (110950) network: GOT_IP
I (113070) wifi: pm start, type:0
network config: ('------------', '255.255.255.0', '----------', '-----------')
True
>>> upyeasy.main()
loaded sink log
loaded sink console
loaded sink syslog
2000-01-01T00:02:17.005 [debug] uPyEasy: Init: Init constructor
2000-01-01T00:02:17.005 [debug] uPyEasy: Init: Entering init
2000-01-01 00:02:17 [debug] uPyEasy: Init: Create directory config
2000-01-01 00:02:17 [debug] uPyEasy: Init: Create directory config exception: OSError(17,)
2000-01-01 00:02:17 [debug] uPyEasy: Init: Create directory plugins
2000-01-01 00:02:18 [debug] uPyEasy: Init: Create directory plugins exception: OSError(17,)
2000-01-01 00:02:18 [debug] uPyEasy: Init: Create directory protocols
2000-01-01 00:02:18 [debug] uPyEasy: Init: Create directory protocols exception: OSError(17,)
2000-01-01 00:02:18 [debug] uPyEasy: Init: Create directory scripts
2000-01-01 00:02:18 [debug] uPyEasy: Init: Create directory scripts exception: OSError(17,)
2000-01-01 00:02:18 [debug] uPyEasy: Init: Create directory rules
2000-01-01 00:02:18 [debug] uPyEasy: Init: Create directory rules exception: OSError(17,)
2000-01-01 00:02:18 [debug] uPyEasy: Init: config Table
2000-01-01 00:02:18 [debug] uPyEasy: Init: network Table
2000-01-01 00:02:18 [debug] uPyEasy: Init: protocol Table
2000-01-01 00:02:18 [debug] uPyEasy: Init: controller Table
2000-01-01 00:02:18 [debug] uPyEasy: Init: hardware Table
2000-01-01 00:02:18 [debug] uPyEasy: Init: dxpin Table
2000-01-01 00:02:18 [debug] uPyEasy: Init: dxmap Table
2000-01-01 00:02:18 [debug] uPyEasy: Init: plugin Table
2000-01-01 00:02:18 [debug] uPyEasy: Init: pluginstore Table
2000-01-01 00:02:18 [debug] uPyEasy: Init: device Table
2000-01-01 00:02:18 [debug] uPyEasy: Init: service Table
2000-01-01 00:02:18 [debug] uPyEasy: Init: notification Table
2000-01-01 00:02:18 [debug] uPyEasy: Init: advanced Table
2000-01-01 00:02:18 [debug] uPyEasy: Init: script Table
2000-01-01 00:02:18 [debug] uPyEasy: Init: rule Table
File "upyeasy/__init__.py", line 40, in main
File "upyeasy/init.py", line 158, in init
File "upyeasy/db.py", line 43, in public
File "upyeasy/db.py", line 1, in <listcomp>
Re: ESP32 boards
@karl222 @bertb
The errors in your log:
means that the flashdrive could not be initialized, so that the database isn't build (no dir) and upyeasy fails. Did you flash the 2048 or the 4096 version?File "flashbdev.py", line 13, in readblocks
Re: ESP32 boards
This is the sequence with the 2048 bin.
rst:0x1 (POWERON_RESET),boot:0x3f (SPI_FAST_FLASH_BOOT)
entry 0x4007a6c4
>>> import upyeasy
I (19590) modsocket: Initializing
flash read err, 1000
ets_main.c 371
entry 0x4007a6c4
I (465) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (48) cpu_start: Starting scheduler on PRO CPU.
>>> import upyeasy
I (86063) modsocket: Initializing
>>> import network
IndentationError: unexpected indent
I (149973) wifi: wifi firmware version: 111e74d
I (149973) wifi: config NVS flash: enabled
I (149973) wifi: config nano formating: disabled
I (149973) system_api: Base MAC address is not set, read default base MAC addres s from BLK0 of EFUSE
I (149983) system_api: Base MAC address is not set, read default base MAC addres s from BLK0 of EFUSE
I (150003) wifi: Init dynamic tx buffer num: 32
I (150003) wifi: Init data frame dynamic rx buffer num: 64
I (150003) wifi: Init management frame dynamic rx buffer num: 64
I (150013) wifi: wifi driver task: 3ffe15f4, prio:23, stack:4096
I (150023) wifi: Init static rx buffer num: 10
I (150023) wifi: Init dynamic rx buffer num: 0
I (150023) wifi: Init rx ampdu len mblock:7
I (150033) wifi: Init lldesc rx ampdu entry mblock:4
I (150033) wifi: wifi power manager task: 0x3ffe8508 prio: 21 stack: 2560
W (150043) phy_init: failed to load RF calibration data (0x1102), falling back t o full calibration
I (150203) phy: phy_version: 362.0, 61e8d92, Sep 8 2017, 18:48:11, 0, 2
I (150213) wifi: mode : null
I (166333) wifi: mode : sta (30:ae:a4:22:e8:1c)
I (166333) wifi: STA_START
True
>>> station.connect("xxxxx", "xxxxxx"
>>> I (207423) wifi: n:7 1, o:1 0, ap:255 255, sta:7 1, prof:1
I (207983) wifi: state: init -> auth (b0)
I (207983) wifi: state: auth -> assoc (0)
I (207993) wifi: state: assoc -> run (10)
I (208003) wifi: connected with Spoon, channel 7
I (208003) network: event 4
I (208673) event: sta ip: xxxxxxxxx, mask: xxxxx, gw: xxxxxxx
I (208673) network: GOT_IP
I (210993) wifi: pm start, type:0
network config: (xxxxxxxx', 'xxxxxxxxx', 'xxxxxxxx', 'xxxxxxxxxxx')
True
>>> upyeasy.main()
loaded sink log
loaded sink console
loaded sink syslog
2000-01-01T00:03:50.005 [debug] uPyEasy: Init: Init constructor
2000-01-01T00:03:50.005 [debug] uPyEasy: Init: Entering init
2000-01-01 00:03:50 [debug] uPyEasy: Init: Create directory config
2000-01-01 00:03:50 [debug] uPyEasy: Init: Create directory plugins
2000-01-01 00:03:50 [debug] uPyEasy: Init: Create directory protocols
2000-01-01 00:03:50 [debug] uPyEasy: Init: Create directory scripts
2000-01-01 00:03:51 [debug] uPyEasy: Init: Create directory rules
2000-01-01 00:03:51 [debug] uPyEasy: Init: config Table
2000-01-01 00:03:51 [debug] uPyEasy: Init: network Table
2000-01-01 00:03:52 [debug] uPyEasy: Init: protocol Table
2000-01-01 00:03:52 [debug] uPyEasy: Init: controller Table
2000-01-01 00:03:52 [debug] uPyEasy: Init: hardware Table
2000-01-01 00:03:52 [debug] uPyEasy: Init: dxpin Table
2000-01-01 00:03:53 [debug] uPyEasy: Init: dxmap Table
2000-01-01 00:03:53 [debug] uPyEasy: Init: plugin Table
2000-01-01 00:03:53 [debug] uPyEasy: Init: pluginstore Table
2000-01-01 00:03:53 [debug] uPyEasy: Init: device Table
2000-01-01 00:03:54 [debug] uPyEasy: Init: service Table
2000-01-01 00:03:54 [debug] uPyEasy: Init: notification Table
2000-01-01 00:03:54 [debug] uPyEasy: Init: advanced Table
2000-01-01 00:03:55 [debug] uPyEasy: Init: script Table
2000-01-01 00:03:55 [debug] uPyEasy: Init: rule Table
2000-01-01 00:03:55 [debug] uPyEasy: Init: Create Config Record
2000-01-01 00:03:56 [debug] uPyEasy: Init: Create Network Record
2000-01-01 00:03:56 [debug] uPyEasy: Init: Create Hardware Record
2000-01-01 00:03:56 [debug] uPyEasy: Hal: hardwaredb init
2000-01-01 00:03:56 [debug] uPyEasy: Hal: hardwaredb esp32
2000-01-01 00:03:56 [debug] uPyEasy: Init: Create dxpin Record
2000-01-01 00:03:57 [debug] uPyEasy: Hal: dxpins_init
2000-01-01 00:03:57 [debug] uPyEasy: Hal: dxpins_init esp32
2000-01-01 00:03:57 [debug] uPyEasy: Init: Create advanced Record
2000-01-01 00:03:58 [debug] uPyEasy: Hal: Init
2000-01-01 00:03:58 [debug] uPyEasy: Hal: init, network record present
2000-01-01 00:03:58 [debug] uPyEasy: Hal: esp32
2000-01-01 00:03:58 [debug] uPyEasy: Hal: esp32, ssid empty
I (256873) network: event 1
2000-01-01 00:04:00 [debug] uPyEasy: Hal: esp32, Scan: Ssid found: Spoon Strengt h: -73 dBm Security: 3
2000-01-01 00:04:00 [debug] uPyEasy: Hal: esp32, Scan: Ssid found: Lepelke Stren gth: -77 dBm Security: 3
2000-01-01 00:04:00 [debug] uPyEasy: Hal: esp32, Scan: Ssid found: torenvalk Str ength: -90 dBm Security: 3
2000-01-01 00:04:00 [debug] uPyEasy: Hal: esp32, Scan: Ssid found: Ziggo9D8234B Strength: -91 dBm Security: 3
2000-01-01 00:04:01 [debug] uPyEasy: Hal: esp32, Scan: Ssid found: Ziggo Strengt h: -91 dBm Security: 5
2000-01-01 00:04:01 [debug] uPyEasy: Hal: esp32, Scan: Ssid found: Ziggo Strengt h: -93 dBm Security: 5
2000-01-01 00:04:01 [debug] uPyEasy: Hal: esp32, Scan: Ssid found: HZN240406906 Strength: -93 dBm Security: 3
2000-01-01 00:04:01 [debug] uPyEasy: Hal: esp32, Scan: Ssid found: CelenoInitial AP8A186F Strength: -94 dBm Security: 3
2000-01-01 00:04:01 [debug] uPyEasy: Protocols: Load
2000-01-01 00:04:01 [debug] uPyEasy: Protocols: Init protocol records
2000-01-01 00:04:01 [debug] uPyEasy: Protocols: Load protocol domoticz_mqtt
2000-01-01 00:04:01 [debug] uPyEasy: Protocols: Create protocol Record: domoticz _mqtt
2000-01-01 00:04:01 [debug] uPyEasy: Protocols: Load protocol domoticz_http
2000-01-01 00:04:01 [debug] uPyEasy: Protocols: Create protocol Record: domoticz _http
2000-01-01 00:04:02 [debug] uPyEasy: Protocols: Init protocol records, run async loop
2000-01-01 00:04:02 [debug] uPyEasy: Plugins: Load
2000-01-01 00:04:02 [debug] uPyEasy: Plugins: init plugin records
2000-01-01 00:04:02 [debug] uPyEasy: Plugins: Register frozen plugin switch
2000-01-01 00:04:02 [debug] uPyEasy: Plugin: switch contruction
2000-01-01 00:04:02 [debug] uPyEasy: Plugins: Create frozen plugin Record: switc h
2000-01-01 00:04:02 [debug] uPyEasy: Plugins: Register frozen plugin bme280
2000-01-01 00:04:03 [debug] uPyEasy: Plugins: Create frozen plugin Record: bme28 0
2000-01-01 00:04:03 [debug] uPyEasy: Plugins: Register frozen plugin test
2000-01-01 00:04:03 [debug] uPyEasy: Plugins: Create frozen plugin Record: test
2000-01-01 00:04:03 [debug] uPyEasy: Plugins: Register frozen plugin ds18
2000-01-01 00:04:03 [debug] uPyEasy: Plugin: ds18 contruction
2000-01-01 00:04:03 [debug] uPyEasy: Plugins: Create frozen plugin Record: ds18
2000-01-01 00:04:04 [debug] uPyEasy: Plugins: Init plugin records, run async loo p
2000-01-01 00:04:04 [debug] uPyEasy: Init: Init devices
2000-01-01 00:04:04 [debug] uPyEasy: Scripts: Load
2000-01-01 00:04:04 [debug] uPyEasy: Scripts: Init
2000-01-01 00:04:04 [debug] uPyEasy: Plugins: GetQueue
2000-01-01 00:04:04 [debug] uPyEasy: Scripts: init scripts records
2000-01-01 00:04:04 [debug] uPyEasy: Scripts: init rules records
2000-01-01 00:04:04 [debug] uPyEasy: Scripts: Init script/rule records, run asyn c loop
2000-01-01 00:04:04 [debug] uPyEasy: Utils: Sys hostname
2000-01-01 00:04:05 [debug] uPyEasy: Utils: uPyEasy Name
Set syslog hostname 0.0.0.0
reloaded sink syslog
2000-01-01 00:04:05 [debug] uPyEasy-uPyEasy: Hal: Entering SetTime
2000-01-01 00:04:05 [debug] uPyEasy-uPyEasy: Hal: Entering GetNtpTime
2000-01-01 00:04:05 [debug] uPyEasy-uPyEasy: Hal: network Table
2000-01-01 00:04:05 [debug] uPyEasy-uPyEasy: Hal: Using NTP Hostname: pool.ntp.o rg
2000-01-01 00:04:05 [debug] uPyEasy-uPyEasy: Hal: TimeZome offset: 60
2000-01-01 00:04:05 [debug] uPyEasy-uPyEasy: Hal: Received UTC NTP Time: 5751363 35
2000-01-01 00:04:05 [debug] uPyEasy-uPyEasy: Hal: Timezone corrected NTP Time: 5 75139935
2000-01-01 00:04:05 [debug] uPyEasy-uPyEasy: Hal: DST corrected NTP Time: 575139 935
2000-01-01 00:04:05 [debug] uPyEasy-uPyEasy: Hal: Received NTP Time: 575139935
2000-01-01 00:04:05 [debug] uPyEasy-uPyEasy: Hal: StartTime: 575139935
2018-03-23 17:05:35 [debug] uPyEasy-uPyEasy: Set time: 2018-03-23T17:05:35
Exiting: Network not available, set network values!
>>> upyeasy.setwifi('xxxxxxxxxxx','xxxxxxxxxxxxx')
File "upyeasy/utils.py", line 46, in setwifi
File "filedb.py", line 73, in update
Re: ESP32 boards
@bertb: and now a reboot and only do:
>>> import upyeasy
>>> upyeasy.main()
Still a network not found error?
Ps. Thx! line 46 of utils.py had a bug! It stated
But it should have been:
Found it due to the micropython error trail!
>>> import upyeasy
>>> upyeasy.main()
db.configTable.update({"timestamp":network['timestamp']},port = wport)
db.configTable.update({"timestamp":config['timestamp']},port = wport)
Re: ESP32 boards
Great, it runs.
But ...
First I added the BME280. That went good.
Znd then, when I ad a DS18B20 device, the interface looses connection and this is the trace:
But ...
After that I rebooted and tried it again with the DS18B20 and it worked.stack: 2032 out of 15360
GC: total: 96000, used: 90224, free: 5776
No. of 1-blocks: 1468, 2-blocks: 179, max blk sz: 902, max free sz: 360
575145912.170 <HTTPRequest object at 3ffc9250> <StreamWriter <socket>> "POST /device_setting?id=0"
2018-03-23 18:44:49 [debug] uPyEasy-uPyEasy: Pages: Authorize User!?
2018-03-23 18:44:49 [debug] uPyEasy-uPyEasy: Pages: Entering Device Settings Page
2018-03-23 18:44:49 [debug] uPyEasy-uPyEasy: Pages: POST
2018-03-23 18:44:49 [debug] uPyEasy-uPyEasy: id
2018-03-23 18:44:49 [debug] uPyEasy-uPyEasy: 0
2018-03-23 18:44:50 [debug] uPyEasy-uPyEasy: New Plugin: 4
2018-03-23 18:44:50 [debug] uPyEasy-uPyEasy: Pages: Create Device
2018-03-23 18:44:50 [debug] uPyEasy-uPyEasy: Pages: New Device and plugin choosen: 4
2018-03-23 18:44:50 [debug] uPyEasy-uPyEasy: Utils: uPyEasy Name
2018-03-23 18:44:51 [debug] uPyEasy-uPyEasy: Plugins: Init device: dummy with plugin: 4
2018-03-23 18:44:51 [debug] uPyEasy-uPyEasy: Protocols: GetQueue controller 192.168.0.243-Domoticz HTTP-1
2018-03-23 18:44:52 [debug] uPyEasy-uPyEasy: Plugin: ds18 contruction
2018-03-23 18:44:52 [debug] uPyEasy-uPyEasy: Plugins: Init device: dummy ,instantiate plugin: DS18B20
2018-03-23 18:44:52 [debug] uPyEasy-uPyEasy: Utils: uPyEasy Name
2018-03-23 18:44:52 [debug] uPyEasy-uPyEasy: Plugin: ds18 init
2018-03-23 18:44:52 [debug] uPyEasy-uPyEasy: Plugins: Read device store: dummy
2018-03-23 18:44:52 [debug] uPyEasy-uPyEasy: Plugin: ds18 init, pin used:
2018-03-23 18:44:52 [debug] uPyEasy-uPyEasy: Hal: pin =
575145912.170 <HTTPRequest object at 3ffc9250> <StreamWriter <socket>> AttributeError("'NoneType' object has no attribute 'init'",)
File "picoweb/__init__.py", line 186, in _handle
File "upyeasy/pages.py", line 1249, in devicesettingpage
File "upyeasy/plugin.py", line 118, in initdevice
File "upyeasy/plugins/ds18.py", line 84, in init
File "onewire.py", line 17, in __init__
AttributeError: 'NoneType' object has no attribute 'init'
Re: ESP32 boards
having said that, There still is no automatic update of the devices and no value is written to Domoticz.
Re: ESP32 boards
hi,
have tried it with both files, both sShow the same issues... still not running...
I don't know what to do with BertB's findings... I would love to see a working .bin
regards
karl
Re: ESP32 boards
The bin is good, but some ESP32's want to have the 4096 version and others the 2048. Can you try to do an erase before using the 2048 version?
esptool.py erase_flash
Re: ESP32 boards
I erased, then flashed with 2048 but no success....
E:\esp32>esptool.py --port COM7 erase_flash
esptool.py v2.3.2-dev
Connecting........_
Detecting chip type... ESP32
Chip is ESP32D0WDQ6 (revision 1)
Features: WiFi, BT, Dual Core
Uploading stub...
Running stub...
Stub running...
Erasing flash (this may take a while)...
Chip erase completed successfully in 9.2s
Hard resetting via RTS pin...
E:\esp32>esptool.py --chip esp32 --port COM7 --baud 460800 write_flash --flash_freq 40m --flash_mode dio --flash_size 2MB -z 0x1000 upyeasy_v021_20180321_test_esp32_2048.bin
Connecting....
Uploading stub...
Running stub...
Stub running...
Changing baud rate to 460800
Changed.
Configuring flash size...
Compressed 1207952 bytes to 698892...
Wrote 1207952 bytes (698892 compressed) at 0x00001000 in 21.5 seconds (effective 450.4 kbit/s)...
Hash of data verified.
Leaving...
and 4096:
entry 0x4007a6c4
Connecting........_
Uploading stub...
Running stub...
Stub running...
Connecting....
Uploading stub...
Running stub...
Stub running...
Changed.
Leaving...
and 4096:
entry 0x4007a6c4
Re: ESP32 boards
I tried both files on my second board, an esp32 wroom NODEMCU ESP-32S V1 as well, but didn't work either...
Re: ESP32 boards
With the 4096 bin, I get the:
errors.
errors.
Re: ESP32 boards
Hello, guys! You can try my 4096 binary https://drive.google.com/file/d/1p1JFrk ... sp=sharing
It work for my esp-wroom-32 v2 board. If flashing is successful then insert these commands:
If there is no errors you should have working board
import upyeasy
import network
station.connect("your_ssid", "your_pass")
upyeasy.main()
raptor
raptor
Re: ESP32 boards
Hi Raptor
Sorry to say, but nope:
ho 0 tail 12 room 4
entry 0x4007a9fc
I (450) cpu_start: Pro cpu up.
I (450) cpu_start: Single core mode
I (451) heap_init: Initializing. RAM available for dynamic allocation:
I (454) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
I (460) heap_init: At 3FFC4E80 len 0001B180 (108 KiB): DRAM
I (466) heap_init: At 3FFE0440 len 00003BC0 (14 KiB): D/IRAM
I (473) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (479) heap_init: At 4008DE34 len 000121CC (72 KiB): IRAM
I (485) cpu_start: Pro cpu start user code
I (56) cpu_start: Starting scheduler on PRO CPU.
MicroPython v1.9.3-473-g22c693a-dirty on 2018-03-22; ESP32 module with ESP32
Re: ESP32 boards
Hi BertB
It seems to me that problem is in your module. Can you try with another esp32 module?
My module works with this firmware.
raptor
raptor
Re: ESP32 boards
I already did.
Both modules, from different makers, fail.
Re: ESP32 boards
After you flashed with the 2048 firmware, can you post the start log after a reset?karl222 wrote: ↑23 Mar 2018, 21:39 I erased, then flashed with 2048 but no success....
Connecting........_
Uploading stub...
Running stub...
Stub running...
Connecting....
Uploading stub...
Running stub...
Stub running...
Changed.
Leaving...
and 4096:
entry 0x4007a6c4
Re: ESP32 boards
This is with the 2048 bin
D:\Program Files>python python\python36\esptool-master\esptool.py --chip esp32 --port COM6 --baud 460800 write_flash --flash_freq 40m --flash_mode dio --flash_size 2MB -z 0x1000 D:\Tools\uPython\upyeasy-esp32\upyeasy_v021_2048.bin
I used this line to program. I changed the name of the bin somewhat.ets Jun 8 2016 00:22:57
entry 0x4007a6c4
I (442) heap_init: Initializing. RAM available for dynamic allocation:
Re: ESP32 boards
Now ... maybe of interest ...
When I use this:D:\Program Files>python python\python36\esptool-master\esptool.py --port COM6 write_flash --compress 0x1000 D:\Tools\uPython\upyeasy-esp32\upyeasy_un4096.bin
This is the kind of same command as in the very beginning of this item, page 1
I get this:
I get this:
ho 0 tail 12 room 4
entry 0x4007a9fc
I (452) cpu_start: Pro cpu up.
I (452) cpu_start: Single core mode
I (452) heap_init: Initializing. RAM available for dynamic allocation:
I (456) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
I (462) heap_init: At 3FFC4E80 len 0001B180 (108 KiB): DRAM
I (468) heap_init: At 3FFE0440 len 00003BC0 (14 KiB): D/IRAM
I (474) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (481) heap_init: At 4008DE34 len 000121CC (72 KiB): IRAM
I (487) cpu_start: Pro cpu start user code
I (57) cpu_start: Starting scheduler on PRO CPU.
Re: ESP32 boards
Hi, all,
I tried the 2048 and 4096 binaries from Github (20180321 versions) on my Lolin32 Lite ESP32 board.
The good news: Neither had boot loops.
2048:
Got OSError128 first time (I always get that, it seems my system just doesn't like port 80!). I managed to get in quick to change to port 9000, stable after that.
Set up Domoticz MQTT controller
Connected BME280 sensor and configured in Devices.
Getting data in the Devices main page. (These don't update themselves, but I think that is just the way it is, it's the same in ESPEasy, you have to refresh to
see new values.)
No sign of Async processes running in the log (Domoticz, BME) which I'd expect to see. And no mqtt messages detected in MQTTspy.
4096:
Again, OSError128 at first, fixed by changing port in config page, then stable.
Configured BME280 in Devices (sensor still connected)
Getting data in Devices page, again need to refresh page to see new values.
Log shows Async processes running (Domoticz, BME, rules/scripts) and show mqtt messages apparently being sent - but can't see any mqtt messages in
MQTTspy.
Connected a DS18B20 sensor and tried to set up in Devices, but on selecting DS18B20 and clicking Submit, the web interface said page not working. Error shown in log, last line in traceback is "onewire.py line 17 in __init__, Attribute error 'NoneType' object has no attribute 'init' ". Despite this, uPyEasy continues to run and process the BME and Domoticz.
Hope this helps!
Andrew
@raptor, I'll try your binary later on.
2048:
see new values.)
4096:
MQTTspy.
Hope this helps!
Andrew
Re: ESP32 boards
So, that means the 2048 is NOT working for you. But the 4096 firmware is! The esptool should not override the flash_size baked in the 4096 firmware, but apparently it does.BertB wrote: ↑24 Mar 2018, 20:26 Now ... maybe of interest ...
I get this:ets Jun 8 2016 00:22:57
ho 0 tail 12 room 4
entry 0x4007a9fc
If you now do:
>>> import upyeasy
>>> upyeasy.main()
It should start (i hope).
Re: ESP32 boards
Ok, so use this command to flash the firmware:
esptool.py --port YYYY write_flash --compress 0x1000 xxxx.bin where YYYY is your comport (unix: /dev/ttyUSBx, windows COMx) and xxxx is your firmware name. Don't specify any other parameters as stated earlier in these post in this topic, but follow the first post in the topic.
Re: ESP32 boards
Hello raptor,raptor wrote: ↑24 Mar 2018, 14:54 Hello, guys! You can try my 4096 binary https://drive.google.com/file/d/1p1JFrk ... sp=sharing
If there is no errors you should have working boardCode: Select all
import upyeasy import network station = network.WLAN(network.STA_IF) station.active(True) station.connect("your_ssid", "your_pass") upyeasy.main()
Many thanks for posting this. I gave it a try on my Lolin32 Lite board, and this is how it went for me....
- I erased flash, then flashed your binary with esptool.py - no problems.
- started the board and put in the commands you recommended - all good, no errors.
- on first run of upyeasy.main() it ended with OSError 128 - this is "normal" for me, for some reason running on port 80 for more than a few seconds doesn't work for me, but i haven't been able to diagnose it. Anyway, corrected by changing port to 9000, then running stable.
- Configured Domoticz MQTT controller and enabled it.
- set hardware for I2C
- Added BME280, working
- Async processes are running as seen in the log (Domoticz, BME) but I'm not seeing mqtt data in MQTTspy.
- Tried to add DS18B20, Got further than with Lisa's version, was able to configure the device and save, but it keeps giving an error "Onewire.py line 22 in reset, Onewire Error: " and data value is wrong (75 degrees in my room! ).
So in summary it's getting there but not yet quite all the way.
Best wishes, Andrew
Re: ESP32 boards
hi,
i have tried on both platforms but was not able to get it running. I have no clue to identify why it doesn't work. Installation of firmware obviously worked but I can't reach it via browser. I am concerned by the last line of the protocol (see below):
rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
ho 0 tail 12 room 4
entry 0x4007a9fc
I (450) heap_init: Initializing. RAM available for dynamic allocation:
I (472) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (55) cpu_start: Starting scheduler on PRO CPU.
>>> import upyeasy
I (11577) modsocket: Initializing
>>> import network
I (30677) wifi: wifi firmware version: ebd3e5d
I (30677) wifi: config NVS flash: enabled
I (30677) wifi: config nano formating: disabled
I (30677) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE
I (30687) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE
I (30717) wifi: Init dynamic tx buffer num: 32
I (30717) wifi: Init data frame dynamic rx buffer num: 64
I (30717) wifi: Init management frame dynamic rx buffer num: 64
I (30717) wifi: wifi driver task: 3ffc9780, prio:23, stack:4096
I (30727) wifi: Init static rx buffer num: 10
I (30727) wifi: Init dynamic rx buffer num: 0
I (30727) wifi: wifi power manager task: 0x3ffcfb04 prio: 21 stack: 2560
W (30737) phy_init: failed to load RF calibration data (0x1102), falling back to full calibration
I (30897) phy: phy_version: 383.0, 79a622c, Jan 30 2018, 15:38:06, 0, 2
I (30907) wifi: mode : null
I (43367) wifi: mode : sta (30:ae:a4:1f:27:94)
I (43367) wifi: STA_START
True
>>> station.connect("xxxxxx", "yyyyyyyyy")
>>> I (77617) wifi: n:1 0, o:1 0, ap:255 255, sta:1 0, prof:1
I (78177) wifi: state: init -> auth (b0)
I (78187) wifi: state: auth -> assoc (0)
I (78187) wifi: state: assoc -> run (10)
I (78207) wifi: connected with xxxxxx, channel 1
I (78207) network: event 4
I (79157) event: sta ip: 10.0.0.64, mask: 255.255.255.0, gw: 10.0.0.138
I (79157) network: GOT_IP
I (81187) wifi: pm start, type:0
>>> upyeasy.main()
loaded sink log
loaded sink console
loaded sink syslog
2000-01-01T00:02:12.005 [debug] uPyEasy: Init: Init constructor
2000-01-01T00:02:12.005 [debug] uPyEasy: Init: Entering init
2000-01-01 00:02:12 [debug] uPyEasy: Init: Create directory config
2000-01-01 00:02:13 [debug] uPyEasy: Init: Create directory plugins
2000-01-01 00:02:13 [debug] uPyEasy: Init: Create directory protocols
2000-01-01 00:02:13 [debug] uPyEasy: Init: Create directory scripts
2000-01-01 00:02:13 [debug] uPyEasy: Init: Create directory rules
2000-01-01 00:02:13 [debug] uPyEasy: Init: config Table
2000-01-01 00:02:13 [debug] uPyEasy: Init: network Table
2000-01-01 00:02:14 [debug] uPyEasy: Init: protocol Table
2000-01-01 00:02:14 [debug] uPyEasy: Init: controller Table
2000-01-01 00:02:14 [debug] uPyEasy: Init: hardware Table
2000-01-01 00:02:14 [debug] uPyEasy: Init: dxpin Table
2000-01-01 00:02:14 [debug] uPyEasy: Init: dxmap Table
2000-01-01 00:02:14 [debug] uPyEasy: Init: plugin Table
2000-01-01 00:02:15 [debug] uPyEasy: Init: pluginstore Table
2000-01-01 00:02:15 [debug] uPyEasy: Init: device Table
2000-01-01 00:02:15 [debug] uPyEasy: Init: service Table
2000-01-01 00:02:15 [debug] uPyEasy: Init: notification Table
2000-01-01 00:02:15 [debug] uPyEasy: Init: advanced Table
2000-01-01 00:02:15 [debug] uPyEasy: Init: script Table
2000-01-01 00:02:16 [debug] uPyEasy: Init: rule Table
2000-01-01 00:02:16 [debug] uPyEasy: Init: Create Config Record
2000-01-01 00:02:16 [debug] uPyEasy: Init: Create Network Record
2000-01-01 00:02:16 [debug] uPyEasy: Init: Create Hardware Record
2000-01-01 00:02:16 [debug] uPyEasy: Hal: hardwaredb init
2000-01-01 00:02:16 [debug] uPyEasy: Hal: hardwaredb esp32
2000-01-01 00:02:17 [debug] uPyEasy: Init: Create dxpin Record
2000-01-01 00:02:17 [debug] uPyEasy: Hal: dxpins_init
2000-01-01 00:02:17 [debug] uPyEasy: Hal: dxpins_init esp32
2000-01-01 00:02:17 [debug] uPyEasy: Init: Create advanced Record
2000-01-01 00:02:17 [debug] uPyEasy: Hal: Init
2000-01-01 00:02:17 [debug] uPyEasy: Hal: init, network record present
2000-01-01 00:02:18 [debug] uPyEasy: Hal: esp32
2000-01-01 00:02:18 [debug] uPyEasy: Hal: esp32, ssid empty
I (146227) network: event 1
2000-01-01 00:02:20 [debug] uPyEasy: Hal: esp32, Scan: Ssid found: xxxxxx Strength: -79 dBm Security: 4
2000-01-01 00:02:20 [debug] uPyEasy: Hal: esp32, Scan: Ssid found: xxxxxx Strength: -80 dBm Security: 3
2000-01-01 00:02:20 [debug] uPyEasy: Hal: esp32, Scan: Ssid found: xxxxxxGast Strength: -82 dBm Security: 4
2000-01-01 00:02:20 [debug] uPyEasy: Hal: esp32, Scan: Ssid found: A1-1cfeb1 Strength: -92 dBm Security: 3
2000-01-01 00:02:20 [debug] uPyEasy: Protocols: Load
2000-01-01 00:02:20 [debug] uPyEasy: Protocols: Init protocol records
2000-01-01 00:02:20 [debug] uPyEasy: Protocols: Load protocol domoticz_mqtt
2000-01-01 00:02:20 [debug] uPyEasy: Protocols: Create protocol Record: domoticz_mqtt
2000-01-01 00:02:21 [debug] uPyEasy: Protocols: Load protocol domoticz_http
2000-01-01 00:02:21 [debug] uPyEasy: Protocols: Create protocol Record: domoticz_http
2000-01-01 00:02:21 [debug] uPyEasy: Protocols: Init protocol records, run async loop
2000-01-01 00:02:21 [debug] uPyEasy: Plugins: Load
2000-01-01 00:02:21 [debug] uPyEasy: Plugins: init plugin records
2000-01-01 00:02:21 [debug] uPyEasy: Plugins: Register frozen plugin switch
2000-01-01 00:02:21 [debug] uPyEasy: Plugin: switch contruction
2000-01-01 00:02:21 [debug] uPyEasy: Plugins: Create frozen plugin Record: switch
2000-01-01 00:02:21 [debug] uPyEasy: Plugins: Register frozen plugin bme280
2000-01-01 00:02:22 [debug] uPyEasy: Plugins: Create frozen plugin Record: bme280
2000-01-01 00:02:22 [debug] uPyEasy: Plugins: Register frozen plugin test
2000-01-01 00:02:22 [debug] uPyEasy: Plugins: Create frozen plugin Record: test
2000-01-01 00:02:22 [debug] uPyEasy: Plugins: Register frozen plugin ds18
2000-01-01 00:02:22 [debug] uPyEasy: Plugin: ds18 contruction
2000-01-01 00:02:22 [debug] uPyEasy: Plugins: Create frozen plugin Record: ds18
2000-01-01 00:02:22 [debug] uPyEasy: Plugins: Init plugin records, run async loop
2000-01-01 00:02:22 [debug] uPyEasy: Scripts: Load
2000-01-01 00:02:23 [debug] uPyEasy: Scripts: Init
2000-01-01 00:02:23 [debug] uPyEasy: Plugins: GetQueue
2000-01-01 00:02:23 [debug] uPyEasy: Scripts: init scripts records
2000-01-01 00:02:23 [debug] uPyEasy: Scripts: init rules records
2000-01-01 00:02:23 [debug] uPyEasy: Scripts: Init script/rule records, run async loop
2000-01-01 00:02:23 [debug] uPyEasy: Utils: Sys hostname
2000-01-01 00:02:23 [debug] uPyEasy: Utils: uPyEasy Name
2000-01-01 00:02:23 [debug] uPyEasy-uPyEasy: Hal: Entering SetTime
2000-01-01 00:02:23 [debug] uPyEasy-uPyEasy: Hal: Entering GetNtpTime
2000-01-01 00:02:23 [debug] uPyEasy-uPyEasy: Hal: network Table
2000-01-01 00:02:23 [debug] uPyEasy-uPyEasy: Hal: Using NTP Hostname: pool.ntp.org
2000-01-01 00:02:24 [debug] uPyEasy-uPyEasy: Hal: TimeZome offset: 60
2000-01-01 00:02:24 [debug] uPyEasy-uPyEasy: Hal: Received UTC NTP Time: 575243202
2000-01-01 00:02:24 [debug] uPyEasy-uPyEasy: Hal: Timezone corrected NTP Time: 575246802
2000-01-01 00:02:24 [debug] uPyEasy-uPyEasy: Hal: DST corrected NTP Time: 575246802
2000-01-01 00:02:24 [debug] uPyEasy-uPyEasy: Hal: Received NTP Time: 575246802
2000-01-01 00:02:24 [debug] uPyEasy-uPyEasy: Hal: StartTime: 575246802
2018-03-24 22:46:42 [debug] uPyEasy-uPyEasy: Set time: 2018-03-24T22:46:42
ho 0 tail 12 room 4
entry 0x4007a9fc
>>> import upyeasy
>>> import network
True
>>> upyeasy.main()
loaded sink log
loaded sink console
loaded sink syslog
Re: ESP32 boards
Don't do the import network stuff, uPyEasy has it's own.karl222 wrote: ↑24 Mar 2018, 22:54 hi,
Just do:
>>> import upyeasy
>>> upyeasy.main()
>>> upyeasy.setwifi('<YOUR_SSID>', '<YOUR_SSID_PW>','', '')
Replace <your_ssid> and <your_ssid_pw> with your own ssid and pw, reboot and it should work.
Just maybe... i should change this in the code (not done yet!):
>>> upyeasy.main()
to this (the first time):
>>> upyeasy.main('<YOUR_SSID>', '<YOUR_SSID_PW>')
Would that be be easier?
- budman1758
Re: ESP32 boards
OK. Installed ESP tool on a different computer. (non win 10) Windows 7 ult.
Got pyserial working ok.
Set up a brand new module on a protoboard.
https://www.ebay.com/itm/ESP-WROOM-32-E ... 2749.l2649
https://www.ebay.com/itm/5X7-7X9CM-Prot ... 2749.l2649
Was able to erase flash the first try!
Was able to flash the firmware the first try! Latest ESP32 firmware from the release page on git. Renamed the file to upyeasy-esp32.bin.
Used this command from post 31 in this thread. The command for Windows from post 1 does NOT work.
Was able to start with "import upyeasy" and "upyeasy.main()" on the first try!
Was able to set wifi creds the first try!
Module starts up and after using "import upyeasy" and "upyeasy.main()" each and every time it connects to wifi and web config pages are up and running every time!
Now..... How do I get it to autostart each time?
Tried the Ampy method to upload a main file to autostart. No workie
The tools page that shows the file system shows the file system ok. Edit and upload buttons take me to blank web pages. No workie.
Want to continue testing but don't want to have to manual start each time.
Methinks that if we have easy in the name it should start easily.... Just sayin....
Please show/tell me how to get it to autostart. Once we get there I will start hanging some hardware on it.
esptool.py --port COM5 write_flash 0x1000 upyeasy-esp32.bin --compress
Re: ESP32 boards
Hi Lisa,LisaM wrote: ↑25 Mar 2018, 01:31Don't do the import network stuff, uPyEasy has it's own.karl222 wrote: ↑24 Mar 2018, 22:54 hi,
Just do:
>>> import upyeasy
>>> upyeasy.main()
Just maybe... i should change this:
>>> upyeasy.main()
I tried it your way, left out the network stuff and just went ahead with "Import upyeasy" but it didn't work.
also getting Errors when trying to set wifi credentials wit upyeasy.main(xxxx)
Lisa, are you really sure you've got it up and running on your Hardware
Thanks to everyone for being Patient...!
>>> import upyeasy
I (10677) modsocket: Initializing
NameError: name 'network' is not defined
>>> import network
I (73137) wifi: wifi firmware version: ebd3e5d
I (73147) wifi: config NVS flash: enabled
I (73147) wifi: config nano formating: disabled
I (73147) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE
I (73157) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE
I (73177) wifi: Init dynamic tx buffer num: 32
I (73177) wifi: Init data frame dynamic rx buffer num: 64
I (73177) wifi: Init management frame dynamic rx buffer num: 64
I (73177) wifi: wifi driver task: 3ffc9780, prio:23, stack:4096
I (73187) wifi: Init static rx buffer num: 10
I (73187) wifi: Init dynamic rx buffer num: 0
I (73197) wifi: wifi power manager task: 0x3ffcfb04 prio: 21 stack: 2560
W (73197) phy_init: failed to load RF calibration data (0x1102), falling back to full calibration
I (73357) phy: phy_version: 383.0, 79a622c, Jan 30 2018, 15:38:06, 0, 2
I (73367) wifi: mode : null
I (78847) wifi: mode : sta (30:ae:a4:1f:27:94)
I (78847) wifi: STA_START
True
>>> station.connect("xxxxxx", "yyyyyyy")
>>> I (85617) wifi: n:1 0, o:1 0, ap:255 255, sta:1 0, prof:1
I (86177) wifi: state: init -> auth (b0)
I (86187) wifi: state: auth -> assoc (0)
I (86187) wifi: state: assoc -> run (10)
I (86207) wifi: connected with xxxxxx, channel 1
I (86207) network: event 4
I (86757) event: sta ip: 10.0.0.64, mask: 255.255.255.0, gw: 10.0.0.138
I (86757) network: GOT_IP
I (89187) wifi: pm start, type:0
>>> upyeasy.main('xxxxxx', 'yyyyyy')
TypeError: function takes 0 positional arguments but 2 were given
>>> upyeasy.main("xxxxxx", "yyyyyyy")
Re: ESP32 boards
Let's go thru this step by step, cause I am loosing itLisaM wrote: ↑24 Mar 2018, 20:48 Ok, so use this command to flash the firmware:
First I do:
So far so good:D:\Program Files\Python\Python36>python esptool-master\esptool.py --port COM6 erase_flash
esptool.py v2.3-dev
Connecting.....
Uploading stub...
Running stub...
Stub running...
Chip erase completed successfully in 4.9s
Hard resetting...
Then I do:
Also good.D:\Program Files\Python\Python36>python esptool-master\esptool.py --port COM6 write_flash --compress 0x1000 D:\Tools\uPython\upyeasy-esp32\upyeasy_v021_20180321_test_esp32_2048.bin
esptool.py v2.3-dev
Connecting........_
Uploading stub...
Running stub...
Stub running...
Auto-detected Flash size: 4MB
Flash params set to 0x0220
Wrote 1207952 bytes (698892 compressed) at 0x00001000 in 61.6 seconds (effective 156.8 kbit/s)...
Leaving...
Hard resetting...
Then I open a com port session with PuTTY:
It says:
So, I do the follwing steps, according to the first post. I think ...ets Jun 8 2016 00:22:57
entry 0x4007a6c4
So, now I think the device is not connected to any network.>>> import upyeasy
I (198213) modsocket: Initializing
>>> upyeasy.main()
loaded sink log
loaded sink console
loaded sink syslog
2000-01-01T00:03:28.005 [debug] uPyEasy: Init: Init constructor
2000-01-01T00:03:28.005 [debug] uPyEasy: Init: Entering init
2000-01-01 00:03:28 [debug] uPyEasy: Init: Create directory config
2000-01-01 00:03:28 [debug] uPyEasy: Init: Create directory plugins
2000-01-01 00:03:28 [debug] uPyEasy: Init: Create directory protocols
2000-01-01 00:03:29 [debug] uPyEasy: Init: Create directory scripts
2000-01-01 00:03:29 [debug] uPyEasy: Init: Create directory rules
2000-01-01 00:03:29 [debug] uPyEasy: Init: config Table
2000-01-01 00:03:29 [debug] uPyEasy: Init: network Table
2000-01-01 00:03:30 [debug] uPyEasy: Init: protocol Table
2000-01-01 00:03:30 [debug] uPyEasy: Init: controller Table
2000-01-01 00:03:30 [debug] uPyEasy: Init: hardware Table
2000-01-01 00:03:30 [debug] uPyEasy: Init: dxpin Table
2000-01-01 00:03:31 [debug] uPyEasy: Init: dxmap Table
2000-01-01 00:03:31 [debug] uPyEasy: Init: plugin Table
2000-01-01 00:03:31 [debug] uPyEasy: Init: pluginstore Table
2000-01-01 00:03:32 [debug] uPyEasy: Init: device Table
2000-01-01 00:03:32 [debug] uPyEasy: Init: service Table
2000-01-01 00:03:32 [debug] uPyEasy: Init: notification Table
2000-01-01 00:03:32 [debug] uPyEasy: Init: advanced Table
2000-01-01 00:03:33 [debug] uPyEasy: Init: script Table
2000-01-01 00:03:33 [debug] uPyEasy: Init: rule Table
2000-01-01 00:03:33 [debug] uPyEasy: Init: Create Config Record
2000-01-01 00:03:34 [debug] uPyEasy: Init: Create Network Record
2000-01-01 00:03:34 [debug] uPyEasy: Init: Create Hardware Record
2000-01-01 00:03:34 [debug] uPyEasy: Hal: hardwaredb init
2000-01-01 00:03:34 [debug] uPyEasy: Hal: hardwaredb esp32
2000-01-01 00:03:34 [debug] uPyEasy: Init: Create dxpin Record
2000-01-01 00:03:35 [debug] uPyEasy: Hal: dxpins_init
2000-01-01 00:03:35 [debug] uPyEasy: Hal: dxpins_init esp32
2000-01-01 00:03:35 [debug] uPyEasy: Init: Create advanced Record
2000-01-01 00:03:36 [debug] uPyEasy: Hal: Init
2000-01-01 00:03:36 [debug] uPyEasy: Hal: init, network record present
2000-01-01 00:03:36 [debug] uPyEasy: Hal: esp32
I (225953) wifi: wifi firmware version: 111e74d
I (225953) wifi: config NVS flash: enabled
I (225953) wifi: config nano formating: disabled
I (225963) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE
I (225973) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE
I (225993) wifi: Init dynamic tx buffer num: 32
I (225993) wifi: Init data frame dynamic rx buffer num: 64
I (225993) wifi: Init management frame dynamic rx buffer num: 64
I (225993) wifi: wifi driver task: 3ffde13c, prio:23, stack:4096
I (226003) wifi: Init static rx buffer num: 10
I (226003) wifi: Init dynamic rx buffer num: 0
I (226013) wifi: Init rx ampdu len mblock:7
I (226013) wifi: Init lldesc rx ampdu entry mblock:4
I (226023) wifi: wifi power manager task: 0x3ffe8734 prio: 21 stack: 2560
W (226023) phy_init: failed to load RF calibration data (0x1102), falling back to full calibration
I (226183) phy: phy_version: 362.0, 61e8d92, Sep 8 2017, 18:48:11, 0, 2
I (226193) wifi: mode : null
I (226193) wifi: mode : sta (30:ae:a4:22:e8:1c)
I (226193) wifi: STA_START
2000-01-01 00:03:36 [debug] uPyEasy: Hal: esp32, ssid empty
I (228633) network: event 1
2000-01-01 00:03:39 [debug] uPyEasy: Hal: esp32, Scan: Ssid found:xxxxxx Strength: -79 dBm Security: 3
2000-01-01 00:03:39 [debug] uPyEasy: Hal: esp32, Scan: Ssid found: xxxxxx Strength: -79 dBm Security: 3
2000-01-01 00:03:39 [debug] uPyEasy: Hal: esp32, Scan: Ssid found:xxxxxxxxx Strength: -88 dBm Security: 5
2000-01-01 00:03:39 [debug] uPyEasy: Hal: esp32, Scan: Ssid found: xxxxxxxx Strength: -88 dBm Security: 5
2000-01-01 00:03:39 [debug] uPyEasy: Hal: esp32, Scan: Ssid found:xxxxxxxxx Strength: -89 dBm Security: 3
2000-01-01 00:03:39 [debug] uPyEasy: Hal: esp32, Scan: Ssid found: xxxxxxxxx Strength: -90 dBm Security: 3
2000-01-01 00:03:39 [debug] uPyEasy: Hal: esp32, Scan: Ssid found: xxxxxxxxxx Strength: -90 dBm Security: 3
2000-01-01 00:03:39 [debug] uPyEasy: Protocols: Load
2000-01-01 00:03:39 [debug] uPyEasy: Protocols: Init protocol records
2000-01-01 00:03:39 [debug] uPyEasy: Protocols: Load protocol domoticz_mqtt
2000-01-01 00:03:39 [debug] uPyEasy: Protocols: Create protocol Record: domoticz_mqtt
2000-01-01 00:03:40 [debug] uPyEasy: Protocols: Load protocol domoticz_http
2000-01-01 00:03:40 [debug] uPyEasy: Protocols: Create protocol Record: domoticz_http
2000-01-01 00:03:40 [debug] uPyEasy: Protocols: Init protocol records, run async loop
2000-01-01 00:03:40 [debug] uPyEasy: Plugins: Load
2000-01-01 00:03:40 [debug] uPyEasy: Plugins: init plugin records
2000-01-01 00:03:40 [debug] uPyEasy: Plugins: Register frozen plugin switch
2000-01-01 00:03:40 [debug] uPyEasy: Plugin: switch contruction
2000-01-01 00:03:40 [debug] uPyEasy: Plugins: Create frozen plugin Record: switch
2000-01-01 00:03:41 [debug] uPyEasy: Plugins: Register frozen plugin bme280
2000-01-01 00:03:41 [debug] uPyEasy: Plugins: Create frozen plugin Record: bme280
2000-01-01 00:03:41 [debug] uPyEasy: Plugins: Register frozen plugin test
2000-01-01 00:03:41 [debug] uPyEasy: Plugins: Create frozen plugin Record: test
2000-01-01 00:03:42 [debug] uPyEasy: Plugins: Register frozen plugin ds18
2000-01-01 00:03:42 [debug] uPyEasy: Plugin: ds18 contruction
2000-01-01 00:03:42 [debug] uPyEasy: Plugins: Create frozen plugin Record: ds18
2000-01-01 00:03:42 [debug] uPyEasy: Plugins: Init plugin records, run async loop
2000-01-01 00:03:42 [debug] uPyEasy: Init: Init devices
2000-01-01 00:03:42 [debug] uPyEasy: Scripts: Load
2000-01-01 00:03:42 [debug] uPyEasy: Scripts: Init
2000-01-01 00:03:42 [debug] uPyEasy: Plugins: GetQueue
2000-01-01 00:03:42 [debug] uPyEasy: Scripts: init scripts records
2000-01-01 00:03:42 [debug] uPyEasy: Scripts: init rules records
2000-01-01 00:03:43 [debug] uPyEasy: Scripts: Init script/rule records, run async loop
2000-01-01 00:03:43 [debug] uPyEasy: Utils: Sys hostname
2000-01-01 00:03:43 [debug] uPyEasy: Utils: uPyEasy Name
2000-01-01 00:03:43 [debug] uPyEasy-uPyEasy: Hal: Entering SetTime
2000-01-01 00:03:43 [debug] uPyEasy-uPyEasy: Hal: Entering GetNtpTime
2000-01-01 00:03:43 [debug] uPyEasy-uPyEasy: Hal: network Table
2000-01-01 00:03:43 [debug] uPyEasy-uPyEasy: Hal: Using NTP Hostname: pool.ntp.org
2000-01-01 00:03:43 [debug] uPyEasy-uPyEasy: Hal: TimeZome offset: 60
File "upyeasy/init.py", line 249, in init
File "upyeasy/hal.py", line 338, in settime
File "upyeasy/hal.py", line 272, in getntptime
File "upyeasy/hal.py", line 264, in getntptime
IndexError: list index out of range
So, I enter the setwifi thing:
>>> upyeasy.setwifi('xxxxx','xxxxxxx')
Don't know what to do now.
Re: ESP32 boards
I also decided to give uPyEasy a try on one of my ESP32 modules. Using a Wemos Lolin32 Lite module.
Install was quite easy:
I was able to read the connected DS18B20 sensor. So far so good.
But after reboot, it does not start automatically. It is mentioned to put the startup commands in boot.py.
But how? Pressing the edit button in the webgui does nothing.
esptool.py --port COM3 erase_flash
esptool.py --port COM3 write_flash --compress 0x1000 upyeasy_v021_20180321_test_esp32_4096.bin
import upyeasy
upyeasy.main()
upyeasy.setwifi('xxx', 'yyy')
Re: ESP32 boards
Happy to see this working, but it is yet another approach of getting started.
Re: ESP32 boards
Figured out how:
created boot.py on desktop, then:
But there might be an easier way?
ampy --port COM3 put boot.py
