ESP32 boards
Re: ESP32 boards
Hi BertB
It seems to me that problem is in your module. Can you try with another esp32 module?
My module works with this firmware.
Regards from Bulgaria.
raptor
raptor
Re: ESP32 boards
I already did.
Both modules, from different makers, fail.
Re: ESP32 boards
After you flashed with the 2048 firmware, can you post the start log after a reset?karl222 wrote: ↑23 Mar 2018, 21:39 I erased, then flashed with 2048 but no success....
E:\esp32>esptool.py --port COM7 erase_flash
esptool.py v2.3.2-dev
Connecting........_
Detecting chip type... ESP32
Chip is ESP32D0WDQ6 (revision 1)
Features: WiFi, BT, Dual Core
Uploading stub...
Running stub...
Stub running...
Erasing flash (this may take a while)...
Chip erase completed successfully in 9.2s
Hard resetting via RTS pin...
E:\esp32>esptool.py --chip esp32 --port COM7 --baud 460800 write_flash --flash_freq 40m --flash_mode dio --flash_size 2MB -z 0x1000 upyeasy_v021_20180321_test_esp32_2048.bin
Connecting....
Uploading stub...
Running stub...
Stub running...
Changing baud rate to 460800
Changed.
Configuring flash size...
Compressed 1207952 bytes to 698892...
Wrote 1207952 bytes (698892 compressed) at 0x00001000 in 21.5 seconds (effective 450.4 kbit/s)...
Hash of data verified.
Leaving...
and 4096:
rst:0x1 (POWERON_RESET),boot:0x33 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0018,len:4
load:0x3fff001c,len:4364
load:0x40078000,len:0
load:0x40078000,len:10992
entry 0x4007a6c4
I (442) cpu_start: Pro cpu up.
I (442) cpu_start: Single core mode
I (443) heap_init: Initializing. RAM available for dynamic allocation:
I (446) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
I (452) heap_init: At 3FFDCDD0 len 00003230 (12 KiB): DRAM
I (458) heap_init: At 3FFE0440 len 00003BC0 (14 KiB): D/IRAM
I (464) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (471) heap_init: At 4009005C len 0000FFA4 (63 KiB): IRAM
I (477) cpu_start: Pro cpu start user code
I (47) cpu_start: Starting scheduler on PRO CPU.
File "_boot.py", line 10, in <module>
File "inisetup.py", line 28, in setup
File "inisetup.py", line 6, in check_bootsec
File "flashbdev.py", line 13, in readblocks
OSError: [Errno 5] EIO
OSError: [Errno 1] EPERM
MicroPython v1.9.3-255-g979c688-dirty on 2018-03-21; ESP32 module with ESP32
Type "help()" for more information.
Re: ESP32 boards
This is with the 2048 bin
D:\Program Files>python python\python36\esptool-master\esptool.py --chip esp32 --port COM6 --baud 460800 write_flash --flash_freq 40m --flash_mode dio --flash_size 2MB -z 0x1000 D:\Tools\uPython\upyeasy-esp32\upyeasy_v021_2048.bin
I used this line to program. I changed the name of the bin somewhat.ets Jun 8 2016 00:22:57
rst:0x1 (POWERON_RESET),boot:0x3f (SPI_FAST_FLASH_BOOT)
entry 0x4007a6c4
I (442) heap_init: Initializing. RAM available for dynamic allocation:
Re: ESP32 boards
Now ... maybe of interest ...
When I use this:D:\Program Files>python python\python36\esptool-master\esptool.py --port COM6 write_flash --compress 0x1000 D:\Tools\uPython\upyeasy-esp32\upyeasy_un4096.bin
This is the kind of same command as in the very beginning of this item, page 1
I get this:
I get this:
load:0x3fff001c,len:4416
ho 0 tail 12 room 4
load:0x40078000,len:11816
entry 0x4007a9fc
I (452) cpu_start: Pro cpu up.
I (452) cpu_start: Single core mode
I (452) heap_init: Initializing. RAM available for dynamic allocation:
I (456) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
I (462) heap_init: At 3FFC4E80 len 0001B180 (108 KiB): DRAM
I (468) heap_init: At 3FFE0440 len 00003BC0 (14 KiB): D/IRAM
I (474) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (481) heap_init: At 4008DE34 len 000121CC (72 KiB): IRAM
I (487) cpu_start: Pro cpu start user code
I (57) cpu_start: Starting scheduler on PRO CPU.
OSError: [Errno 2] ENOENT
MicroPython v1.9.3-473-g22c693a-dirty on 2018-03-22; ESP32 module with ESP32
Re: ESP32 boards
Hi, all,
I tried the 2048 and 4096 binaries from Github (20180321 versions) on my Lolin32 Lite ESP32 board.
The good news: Neither had boot loops.
2048:
Got OSError128 first time (I always get that, it seems my system just doesn't like port 80!). I managed to get in quick to change to port 9000, stable after that.
Set up Domoticz MQTT controller
Connected BME280 sensor and configured in Devices.
Getting data in the Devices main page. (These don't update themselves, but I think that is just the way it is, it's the same in ESPEasy, you have to refresh to
see new values.)
No sign of Async processes running in the log (Domoticz, BME) which I'd expect to see. And no mqtt messages detected in MQTTspy.
4096:
Again, OSError128 at first, fixed by changing port in config page, then stable.
Configured BME280 in Devices (sensor still connected)
Getting data in Devices page, again need to refresh page to see new values.
Log shows Async processes running (Domoticz, BME, rules/scripts) and show mqtt messages apparently being sent - but can't see any mqtt messages in
MQTTspy.
Connected a DS18B20 sensor and tried to set up in Devices, but on selecting DS18B20 and clicking Submit, the web interface said page not working. Error shown in log, last line in traceback is "onewire.py line 17 in __init__, Attribute error 'NoneType' object has no attribute 'init' ". Despite this, uPyEasy continues to run and process the BME and Domoticz.
Hope this helps!
Andrew
@raptor, I'll try your binary later on.
2048:
see new values.)
4096:
MQTTspy.
Hope this helps!
Andrew
Re: ESP32 boards
So, that means the 2048 is NOT working for you. But the 4096 firmware is! The esptool should not override the flash_size baked in the 4096 firmware, but apparently it does.BertB wrote: ↑24 Mar 2018, 20:26 Now ... maybe of interest ...
I get this:ets Jun 8 2016 00:22:57
ho 0 tail 12 room 4
entry 0x4007a9fc
If you now do:
>>> import upyeasy
>>> upyeasy.main()
It should start (i hope).
Re: ESP32 boards
Ok, so use this command to flash the firmware:
esptool.py --port YYYY write_flash --compress 0x1000 xxxx.bin where YYYY is your comport (unix: /dev/ttyUSBx, windows COMx) and xxxx is your firmware name. Don't specify any other parameters as stated earlier in these post in this topic, but follow the first post in the topic.
Re: ESP32 boards
Hello raptor,raptor wrote: ↑24 Mar 2018, 14:54 Hello, guys! You can try my 4096 binary https://drive.google.com/file/d/1p1JFrk ... sp=sharing
It work for my esp-wroom-32 v2 board. If flashing is successful then insert these commands:
If there is no errors you should have working boardCode: Select all
import upyeasy import network station = network.WLAN(network.STA_IF) station.active(True) station.connect("your_ssid", "your_pass") upyeasy.main()
Many thanks for posting this. I gave it a try on my Lolin32 Lite board, and this is how it went for me....
- I erased flash, then flashed your binary with esptool.py - no problems.
- started the board and put in the commands you recommended - all good, no errors.
- on first run of upyeasy.main() it ended with OSError 128 - this is "normal" for me, for some reason running on port 80 for more than a few seconds doesn't work for me, but i haven't been able to diagnose it. Anyway, corrected by changing port to 9000, then running stable.
- Configured Domoticz MQTT controller and enabled it.
- set hardware for I2C
- Added BME280, working
- Async processes are running as seen in the log (Domoticz, BME) but I'm not seeing mqtt data in MQTTspy.
- Tried to add DS18B20, Got further than with Lisa's version, was able to configure the device and save, but it keeps giving an error "Onewire.py line 22 in reset, Onewire Error: " and data value is wrong (75 degrees in my room! ).
So in summary it's getting there but not yet quite all the way.
Best wishes, Andrew
Re: ESP32 boards
hi,
i have tried on both platforms but was not able to get it running. I have no clue to identify why it doesn't work. Installation of firmware obviously worked but I can't reach it via browser. I am concerned by the last line of the protocol (see below):
rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
ho 0 tail 12 room 4
entry 0x4007a9fc
I (450) cpu_start: Pro cpu up.
I (450) cpu_start: Single core mode
I (450) heap_init: Initializing. RAM available for dynamic allocation:
I (454) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
I (460) heap_init: At 3FFC4E80 len 0001B180 (108 KiB): DRAM
I (466) heap_init: At 3FFE0440 len 00003BC0 (14 KiB): D/IRAM
I (472) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (479) heap_init: At 4008DE34 len 000121CC (72 KiB): IRAM
I (485) cpu_start: Pro cpu start user code
I (55) cpu_start: Starting scheduler on PRO CPU.
>>> import upyeasy
I (11577) modsocket: Initializing
>>> import network
I (30677) wifi: wifi firmware version: ebd3e5d
I (30677) wifi: config NVS flash: enabled
I (30677) wifi: config nano formating: disabled
I (30677) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE
I (30687) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE
I (30717) wifi: Init dynamic tx buffer num: 32
I (30717) wifi: Init data frame dynamic rx buffer num: 64
I (30717) wifi: Init management frame dynamic rx buffer num: 64
I (30717) wifi: wifi driver task: 3ffc9780, prio:23, stack:4096
I (30727) wifi: Init static rx buffer num: 10
I (30727) wifi: Init dynamic rx buffer num: 0
I (30727) wifi: wifi power manager task: 0x3ffcfb04 prio: 21 stack: 2560
W (30737) phy_init: failed to load RF calibration data (0x1102), falling back to full calibration
I (30897) phy: phy_version: 383.0, 79a622c, Jan 30 2018, 15:38:06, 0, 2
I (30907) wifi: mode : null
I (43367) wifi: mode : sta (30:ae:a4:1f:27:94)
I (43367) wifi: STA_START
True
>>> station.connect("xxxxxx", "yyyyyyyyy")
>>> I (77617) wifi: n:1 0, o:1 0, ap:255 255, sta:1 0, prof:1
I (78177) wifi: state: init -> auth (b0)
I (78187) wifi: state: auth -> assoc (0)
I (78187) wifi: state: assoc -> run (10)
I (78207) wifi: connected with xxxxxx, channel 1
I (78207) network: event 4
I (79157) event: sta ip: 10.0.0.64, mask: 255.255.255.0, gw: 10.0.0.138
I (79157) network: GOT_IP
I (81187) wifi: pm start, type:0
>>> upyeasy.main()
loaded sink log
loaded sink console
loaded sink syslog
2000-01-01T00:02:12.005 [debug] uPyEasy: Init: Init constructor
2000-01-01T00:02:12.005 [debug] uPyEasy: Init: Entering init
2000-01-01 00:02:12 [debug] uPyEasy: Init: Create directory config
2000-01-01 00:02:13 [debug] uPyEasy: Init: Create directory plugins
2000-01-01 00:02:13 [debug] uPyEasy: Init: Create directory protocols
2000-01-01 00:02:13 [debug] uPyEasy: Init: Create directory scripts
2000-01-01 00:02:13 [debug] uPyEasy: Init: Create directory rules
2000-01-01 00:02:13 [debug] uPyEasy: Init: config Table
2000-01-01 00:02:13 [debug] uPyEasy: Init: network Table
2000-01-01 00:02:14 [debug] uPyEasy: Init: protocol Table
2000-01-01 00:02:14 [debug] uPyEasy: Init: controller Table
2000-01-01 00:02:14 [debug] uPyEasy: Init: hardware Table
2000-01-01 00:02:14 [debug] uPyEasy: Init: dxpin Table
2000-01-01 00:02:14 [debug] uPyEasy: Init: dxmap Table
2000-01-01 00:02:14 [debug] uPyEasy: Init: plugin Table
2000-01-01 00:02:15 [debug] uPyEasy: Init: pluginstore Table
2000-01-01 00:02:15 [debug] uPyEasy: Init: device Table
2000-01-01 00:02:15 [debug] uPyEasy: Init: service Table
2000-01-01 00:02:15 [debug] uPyEasy: Init: notification Table
2000-01-01 00:02:15 [debug] uPyEasy: Init: advanced Table
2000-01-01 00:02:15 [debug] uPyEasy: Init: script Table
2000-01-01 00:02:16 [debug] uPyEasy: Init: rule Table
2000-01-01 00:02:16 [debug] uPyEasy: Init: Create Config Record
2000-01-01 00:02:16 [debug] uPyEasy: Init: Create Network Record
2000-01-01 00:02:16 [debug] uPyEasy: Init: Create Hardware Record
2000-01-01 00:02:16 [debug] uPyEasy: Hal: hardwaredb init
2000-01-01 00:02:16 [debug] uPyEasy: Hal: hardwaredb esp32
2000-01-01 00:02:17 [debug] uPyEasy: Init: Create dxpin Record
2000-01-01 00:02:17 [debug] uPyEasy: Hal: dxpins_init
2000-01-01 00:02:17 [debug] uPyEasy: Hal: dxpins_init esp32
2000-01-01 00:02:17 [debug] uPyEasy: Init: Create advanced Record
2000-01-01 00:02:17 [debug] uPyEasy: Hal: Init
2000-01-01 00:02:17 [debug] uPyEasy: Hal: init, network record present
2000-01-01 00:02:18 [debug] uPyEasy: Hal: esp32
2000-01-01 00:02:18 [debug] uPyEasy: Hal: esp32, ssid empty
I (146227) network: event 1
2000-01-01 00:02:20 [debug] uPyEasy: Hal: esp32, Scan: Ssid found: xxxxxx Strength: -79 dBm Security: 4
2000-01-01 00:02:20 [debug] uPyEasy: Hal: esp32, Scan: Ssid found: xxxxxx Strength: -80 dBm Security: 3
2000-01-01 00:02:20 [debug] uPyEasy: Hal: esp32, Scan: Ssid found: xxxxxxGast Strength: -82 dBm Security: 4
2000-01-01 00:02:20 [debug] uPyEasy: Hal: esp32, Scan: Ssid found: A1-1cfeb1 Strength: -92 dBm Security: 3
2000-01-01 00:02:20 [debug] uPyEasy: Protocols: Load
2000-01-01 00:02:20 [debug] uPyEasy: Protocols: Init protocol records
2000-01-01 00:02:20 [debug] uPyEasy: Protocols: Load protocol domoticz_mqtt
2000-01-01 00:02:20 [debug] uPyEasy: Protocols: Create protocol Record: domoticz_mqtt
2000-01-01 00:02:21 [debug] uPyEasy: Protocols: Load protocol domoticz_http
2000-01-01 00:02:21 [debug] uPyEasy: Protocols: Create protocol Record: domoticz_http
2000-01-01 00:02:21 [debug] uPyEasy: Protocols: Init protocol records, run async loop
2000-01-01 00:02:21 [debug] uPyEasy: Plugins: Load
2000-01-01 00:02:21 [debug] uPyEasy: Plugins: init plugin records
2000-01-01 00:02:21 [debug] uPyEasy: Plugins: Register frozen plugin switch
2000-01-01 00:02:21 [debug] uPyEasy: Plugin: switch contruction
2000-01-01 00:02:21 [debug] uPyEasy: Plugins: Create frozen plugin Record: switch
2000-01-01 00:02:21 [debug] uPyEasy: Plugins: Register frozen plugin bme280
2000-01-01 00:02:22 [debug] uPyEasy: Plugins: Create frozen plugin Record: bme280
2000-01-01 00:02:22 [debug] uPyEasy: Plugins: Register frozen plugin test
2000-01-01 00:02:22 [debug] uPyEasy: Plugins: Create frozen plugin Record: test
2000-01-01 00:02:22 [debug] uPyEasy: Plugins: Register frozen plugin ds18
2000-01-01 00:02:22 [debug] uPyEasy: Plugin: ds18 contruction
2000-01-01 00:02:22 [debug] uPyEasy: Plugins: Create frozen plugin Record: ds18
2000-01-01 00:02:22 [debug] uPyEasy: Plugins: Init plugin records, run async loop
2000-01-01 00:02:22 [debug] uPyEasy: Scripts: Load
2000-01-01 00:02:23 [debug] uPyEasy: Scripts: Init
2000-01-01 00:02:23 [debug] uPyEasy: Plugins: GetQueue
2000-01-01 00:02:23 [debug] uPyEasy: Scripts: init scripts records
2000-01-01 00:02:23 [debug] uPyEasy: Scripts: init rules records
2000-01-01 00:02:23 [debug] uPyEasy: Scripts: Init script/rule records, run async loop
2000-01-01 00:02:23 [debug] uPyEasy: Utils: Sys hostname
2000-01-01 00:02:23 [debug] uPyEasy: Utils: uPyEasy Name
Set syslog hostname 0.0.0.0
reloaded sink syslog
2000-01-01 00:02:23 [debug] uPyEasy-uPyEasy: Hal: Entering SetTime
2000-01-01 00:02:23 [debug] uPyEasy-uPyEasy: Hal: Entering GetNtpTime
2000-01-01 00:02:23 [debug] uPyEasy-uPyEasy: Hal: network Table
2000-01-01 00:02:23 [debug] uPyEasy-uPyEasy: Hal: Using NTP Hostname: pool.ntp.org
2000-01-01 00:02:24 [debug] uPyEasy-uPyEasy: Hal: TimeZome offset: 60
2000-01-01 00:02:24 [debug] uPyEasy-uPyEasy: Hal: Received UTC NTP Time: 575243202
2000-01-01 00:02:24 [debug] uPyEasy-uPyEasy: Hal: Timezone corrected NTP Time: 575246802
2000-01-01 00:02:24 [debug] uPyEasy-uPyEasy: Hal: DST corrected NTP Time: 575246802
2000-01-01 00:02:24 [debug] uPyEasy-uPyEasy: Hal: Received NTP Time: 575246802
2000-01-01 00:02:24 [debug] uPyEasy-uPyEasy: Hal: StartTime: 575246802
2018-03-24 22:46:42 [debug] uPyEasy-uPyEasy: Set time: 2018-03-24T22:46:42
Exiting: Network not available, set network values!
ho 0 tail 12 room 4
entry 0x4007a9fc
>>> import upyeasy
>>> import network
True
>>> upyeasy.main()
loaded sink log
loaded sink console
loaded sink syslog
Re: ESP32 boards
Don't do the import network stuff, uPyEasy has it's own.karl222 wrote: ↑24 Mar 2018, 22:54 hi,
Just do:
>>> import upyeasy
>>> upyeasy.main()
>>> upyeasy.setwifi('<YOUR_SSID>', '<YOUR_SSID_PW>','', '')
Replace <your_ssid> and <your_ssid_pw> with your own ssid and pw, reboot and it should work.
Just maybe... i should change this in the code (not done yet!):
>>> upyeasy.main()
to this (the first time):
>>> upyeasy.main('<YOUR_SSID>', '<YOUR_SSID_PW>')
Would that be be easier?
- budman1758
Re: ESP32 boards
OK. Installed ESP tool on a different computer. (non win 10) Windows 7 ult.
Got pyserial working ok.
Set up a brand new module on a protoboard.
https://www.ebay.com/itm/ESP-WROOM-32-E ... 2749.l2649
https://www.ebay.com/itm/5X7-7X9CM-Prot ... 2749.l2649
Was able to erase flash the first try!
Was able to flash the firmware the first try! Latest ESP32 firmware from the release page on git. Renamed the file to upyeasy-esp32.bin.
Used this command from post 31 in this thread. The command for Windows from post 1 does NOT work.
Was able to start with "import upyeasy" and "upyeasy.main()" on the first try!
Was able to set wifi creds the first try!
Module starts up and after using "import upyeasy" and "upyeasy.main()" each and every time it connects to wifi and web config pages are up and running every time!
Now..... How do I get it to autostart each time?
Tried the Ampy method to upload a main file to autostart. No workie
The tools page that shows the file system shows the file system ok. Edit and upload buttons take me to blank web pages. No workie.
Want to continue testing but don't want to have to manual start each time.
Methinks that if we have easy in the name it should start easily.... Just sayin....
Please show/tell me how to get it to autostart. Once we get there I will start hanging some hardware on it.
esptool.py --port COM5 write_flash 0x1000 upyeasy-esp32.bin --compress
Re: ESP32 boards
Hi Lisa,LisaM wrote: ↑25 Mar 2018, 01:31Don't do the import network stuff, uPyEasy has it's own.karl222 wrote: ↑24 Mar 2018, 22:54 hi,
Just do:
>>> import upyeasy
>>> upyeasy.main()
Just maybe... i should change this:
>>> upyeasy.main()
I tried it your way, left out the network stuff and just went ahead with "Import upyeasy" but it didn't work.
also getting Errors when trying to set wifi credentials wit upyeasy.main(xxxx)
Lisa, are you really sure you've got it up and running on your Hardware
Thanks to everyone for being Patient...!
>>> import upyeasy
I (10677) modsocket: Initializing
File "<stdin>", line 1, in <module>
NameError: name 'network' is not defined
NameError: name 'station' is not defined
>>> import network
I (73137) wifi: wifi firmware version: ebd3e5d
I (73147) wifi: config NVS flash: enabled
I (73147) wifi: config nano formating: disabled
I (73147) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE
I (73157) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE
I (73177) wifi: Init dynamic tx buffer num: 32
I (73177) wifi: Init data frame dynamic rx buffer num: 64
I (73177) wifi: Init management frame dynamic rx buffer num: 64
I (73177) wifi: wifi driver task: 3ffc9780, prio:23, stack:4096
I (73187) wifi: Init static rx buffer num: 10
I (73187) wifi: Init dynamic rx buffer num: 0
I (73197) wifi: wifi power manager task: 0x3ffcfb04 prio: 21 stack: 2560
W (73197) phy_init: failed to load RF calibration data (0x1102), falling back to full calibration
I (73357) phy: phy_version: 383.0, 79a622c, Jan 30 2018, 15:38:06, 0, 2
I (73367) wifi: mode : null
I (78847) wifi: mode : sta (30:ae:a4:1f:27:94)
I (78847) wifi: STA_START
True
>>> station.connect("xxxxxx", "yyyyyyy")
>>> I (85617) wifi: n:1 0, o:1 0, ap:255 255, sta:1 0, prof:1
I (86177) wifi: state: init -> auth (b0)
I (86187) wifi: state: auth -> assoc (0)
I (86187) wifi: state: assoc -> run (10)
I (86207) wifi: connected with xxxxxx, channel 1
I (86207) network: event 4
I (86757) event: sta ip: 10.0.0.64, mask: 255.255.255.0, gw: 10.0.0.138
I (86757) network: GOT_IP
I (89187) wifi: pm start, type:0
>>> upyeasy.main('xxxxxx', 'yyyyyy')
TypeError: function takes 0 positional arguments but 2 were given
>>> upyeasy.main("xxxxxx", "yyyyyyy")
Re: ESP32 boards
Let's go thru this step by step, cause I am loosing itLisaM wrote: ↑24 Mar 2018, 20:48 Ok, so use this command to flash the firmware:
First I do:
So far so good:D:\Program Files\Python\Python36>python esptool-master\esptool.py --port COM6 erase_flash
esptool.py v2.3-dev
Connecting.....
Uploading stub...
Running stub...
Stub running...
Chip erase completed successfully in 4.9s
Hard resetting...
Then I do:
Also good.D:\Program Files\Python\Python36>python esptool-master\esptool.py --port COM6 write_flash --compress 0x1000 D:\Tools\uPython\upyeasy-esp32\upyeasy_v021_20180321_test_esp32_2048.bin
esptool.py v2.3-dev
Connecting........_
Uploading stub...
Running stub...
Stub running...
Auto-detected Flash size: 4MB
Flash params set to 0x0220
Wrote 1207952 bytes (698892 compressed) at 0x00001000 in 61.6 seconds (effective 156.8 kbit/s)...
Leaving...
Hard resetting...
Then I open a com port session with PuTTY:
It says:
So, I do the follwing steps, according to the first post. I think ...ets Jun 8 2016 00:22:57
entry 0x4007a6c4
So, now I think the device is not connected to any network.>>> import upyeasy
I (198213) modsocket: Initializing
>>> upyeasy.main()
loaded sink log
loaded sink console
loaded sink syslog
2000-01-01T00:03:28.005 [debug] uPyEasy: Init: Init constructor
2000-01-01T00:03:28.005 [debug] uPyEasy: Init: Entering init
2000-01-01 00:03:28 [debug] uPyEasy: Init: Create directory config
2000-01-01 00:03:28 [debug] uPyEasy: Init: Create directory plugins
2000-01-01 00:03:28 [debug] uPyEasy: Init: Create directory protocols
2000-01-01 00:03:29 [debug] uPyEasy: Init: Create directory scripts
2000-01-01 00:03:29 [debug] uPyEasy: Init: Create directory rules
2000-01-01 00:03:29 [debug] uPyEasy: Init: config Table
2000-01-01 00:03:29 [debug] uPyEasy: Init: network Table
2000-01-01 00:03:30 [debug] uPyEasy: Init: protocol Table
2000-01-01 00:03:30 [debug] uPyEasy: Init: controller Table
2000-01-01 00:03:30 [debug] uPyEasy: Init: hardware Table
2000-01-01 00:03:30 [debug] uPyEasy: Init: dxpin Table
2000-01-01 00:03:31 [debug] uPyEasy: Init: dxmap Table
2000-01-01 00:03:31 [debug] uPyEasy: Init: plugin Table
2000-01-01 00:03:31 [debug] uPyEasy: Init: pluginstore Table
2000-01-01 00:03:32 [debug] uPyEasy: Init: device Table
2000-01-01 00:03:32 [debug] uPyEasy: Init: service Table
2000-01-01 00:03:32 [debug] uPyEasy: Init: notification Table
2000-01-01 00:03:32 [debug] uPyEasy: Init: advanced Table
2000-01-01 00:03:33 [debug] uPyEasy: Init: script Table
2000-01-01 00:03:33 [debug] uPyEasy: Init: rule Table
2000-01-01 00:03:33 [debug] uPyEasy: Init: Create Config Record
2000-01-01 00:03:34 [debug] uPyEasy: Init: Create Network Record
2000-01-01 00:03:34 [debug] uPyEasy: Init: Create Hardware Record
2000-01-01 00:03:34 [debug] uPyEasy: Hal: hardwaredb init
2000-01-01 00:03:34 [debug] uPyEasy: Hal: hardwaredb esp32
2000-01-01 00:03:34 [debug] uPyEasy: Init: Create dxpin Record
2000-01-01 00:03:35 [debug] uPyEasy: Hal: dxpins_init
2000-01-01 00:03:35 [debug] uPyEasy: Hal: dxpins_init esp32
2000-01-01 00:03:35 [debug] uPyEasy: Init: Create advanced Record
2000-01-01 00:03:36 [debug] uPyEasy: Hal: Init
2000-01-01 00:03:36 [debug] uPyEasy: Hal: init, network record present
2000-01-01 00:03:36 [debug] uPyEasy: Hal: esp32
I (225953) wifi: wifi firmware version: 111e74d
I (225953) wifi: config NVS flash: enabled
I (225953) wifi: config nano formating: disabled
I (225963) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE
I (225973) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE
I (225993) wifi: Init dynamic tx buffer num: 32
I (225993) wifi: Init data frame dynamic rx buffer num: 64
I (225993) wifi: Init management frame dynamic rx buffer num: 64
I (225993) wifi: wifi driver task: 3ffde13c, prio:23, stack:4096
I (226003) wifi: Init static rx buffer num: 10
I (226003) wifi: Init dynamic rx buffer num: 0
I (226013) wifi: Init rx ampdu len mblock:7
I (226013) wifi: Init lldesc rx ampdu entry mblock:4
I (226023) wifi: wifi power manager task: 0x3ffe8734 prio: 21 stack: 2560
W (226023) phy_init: failed to load RF calibration data (0x1102), falling back to full calibration
I (226183) phy: phy_version: 362.0, 61e8d92, Sep 8 2017, 18:48:11, 0, 2
I (226193) wifi: mode : null
I (226193) wifi: mode : sta (30:ae:a4:22:e8:1c)
I (226193) wifi: STA_START
2000-01-01 00:03:36 [debug] uPyEasy: Hal: esp32, ssid empty
I (228633) network: event 1
2000-01-01 00:03:39 [debug] uPyEasy: Hal: esp32, Scan: Ssid found:xxxxxx Strength: -79 dBm Security: 3
2000-01-01 00:03:39 [debug] uPyEasy: Hal: esp32, Scan: Ssid found: xxxxxx Strength: -79 dBm Security: 3
2000-01-01 00:03:39 [debug] uPyEasy: Hal: esp32, Scan: Ssid found:xxxxxxxxx Strength: -88 dBm Security: 5
2000-01-01 00:03:39 [debug] uPyEasy: Hal: esp32, Scan: Ssid found: xxxxxxxx Strength: -88 dBm Security: 5
2000-01-01 00:03:39 [debug] uPyEasy: Hal: esp32, Scan: Ssid found:xxxxxxxxx Strength: -89 dBm Security: 3
2000-01-01 00:03:39 [debug] uPyEasy: Hal: esp32, Scan: Ssid found: xxxxxxxxx Strength: -90 dBm Security: 3
2000-01-01 00:03:39 [debug] uPyEasy: Hal: esp32, Scan: Ssid found: xxxxxxxxxx Strength: -90 dBm Security: 3
2000-01-01 00:03:39 [debug] uPyEasy: Protocols: Load
2000-01-01 00:03:39 [debug] uPyEasy: Protocols: Init protocol records
2000-01-01 00:03:39 [debug] uPyEasy: Protocols: Load protocol domoticz_mqtt
2000-01-01 00:03:39 [debug] uPyEasy: Protocols: Create protocol Record: domoticz_mqtt
2000-01-01 00:03:40 [debug] uPyEasy: Protocols: Load protocol domoticz_http
2000-01-01 00:03:40 [debug] uPyEasy: Protocols: Create protocol Record: domoticz_http
2000-01-01 00:03:40 [debug] uPyEasy: Protocols: Init protocol records, run async loop
2000-01-01 00:03:40 [debug] uPyEasy: Plugins: Load
2000-01-01 00:03:40 [debug] uPyEasy: Plugins: init plugin records
2000-01-01 00:03:40 [debug] uPyEasy: Plugins: Register frozen plugin switch
2000-01-01 00:03:40 [debug] uPyEasy: Plugin: switch contruction
2000-01-01 00:03:40 [debug] uPyEasy: Plugins: Create frozen plugin Record: switch
2000-01-01 00:03:41 [debug] uPyEasy: Plugins: Register frozen plugin bme280
2000-01-01 00:03:41 [debug] uPyEasy: Plugins: Create frozen plugin Record: bme280
2000-01-01 00:03:41 [debug] uPyEasy: Plugins: Register frozen plugin test
2000-01-01 00:03:41 [debug] uPyEasy: Plugins: Create frozen plugin Record: test
2000-01-01 00:03:42 [debug] uPyEasy: Plugins: Register frozen plugin ds18
2000-01-01 00:03:42 [debug] uPyEasy: Plugin: ds18 contruction
2000-01-01 00:03:42 [debug] uPyEasy: Plugins: Create frozen plugin Record: ds18
2000-01-01 00:03:42 [debug] uPyEasy: Plugins: Init plugin records, run async loop
2000-01-01 00:03:42 [debug] uPyEasy: Init: Init devices
2000-01-01 00:03:42 [debug] uPyEasy: Scripts: Load
2000-01-01 00:03:42 [debug] uPyEasy: Scripts: Init
2000-01-01 00:03:42 [debug] uPyEasy: Plugins: GetQueue
2000-01-01 00:03:42 [debug] uPyEasy: Scripts: init scripts records
2000-01-01 00:03:42 [debug] uPyEasy: Scripts: init rules records
2000-01-01 00:03:43 [debug] uPyEasy: Scripts: Init script/rule records, run async loop
2000-01-01 00:03:43 [debug] uPyEasy: Utils: Sys hostname
2000-01-01 00:03:43 [debug] uPyEasy: Utils: uPyEasy Name
2000-01-01 00:03:43 [debug] uPyEasy-uPyEasy: Hal: Entering SetTime
2000-01-01 00:03:43 [debug] uPyEasy-uPyEasy: Hal: Entering GetNtpTime
2000-01-01 00:03:43 [debug] uPyEasy-uPyEasy: Hal: network Table
2000-01-01 00:03:43 [debug] uPyEasy-uPyEasy: Hal: Using NTP Hostname: pool.ntp.org
2000-01-01 00:03:43 [debug] uPyEasy-uPyEasy: Hal: TimeZome offset: 60
File "upyeasy/__init__.py", line 40, in main
File "upyeasy/init.py", line 249, in init
File "upyeasy/hal.py", line 338, in settime
File "upyeasy/hal.py", line 272, in getntptime
File "upyeasy/hal.py", line 264, in getntptime
IndexError: list index out of range
So, I enter the setwifi thing:
>>> upyeasy.setwifi('xxxxx','xxxxxxx')
File "upyeasy/__init__.py", line 29, in setwifi
File "upyeasy/utils.py", line 46, in setwifi
File "filedb.py", line 73, in update
Don't know what to do now.
Re: ESP32 boards
I also decided to give uPyEasy a try on one of my ESP32 modules. Using a Wemos Lolin32 Lite module.
Install was quite easy:
I was able to read the connected DS18B20 sensor. So far so good.
But after reboot, it does not start automatically. It is mentioned to put the startup commands in boot.py.
But how? Pressing the edit button in the webgui does nothing.
esptool.py --port COM3 erase_flash
esptool.py --port COM3 write_flash --compress 0x1000 upyeasy_v021_20180321_test_esp32_4096.bin
import upyeasy
upyeasy.main()
upyeasy.setwifi('xxx', 'yyy')
Re: ESP32 boards
Happy to see this working, but it is yet another approach of getting started.
Re: ESP32 boards
Figured out how:
created boot.py on desktop, then:
But there might be an easier way?
ampy --port COM3 put boot.py
Re: ESP32 boards
Hi Karl222,karl222 wrote: ↑25 Mar 2018, 10:53 >>> upyeasy.main('xxxxxx', 'yyyyyy')
To fast! I haven't changed this yet. My question was whether this was a good idea or not...
For now you can start upyeasy by using:
>>> import upyeasy
upyeasy.main()
THEN use this command:Exiting: Network not available, set network values!
>>> upyeasy.setwifi('<your ssid>', '<your ssid password>','<your backup ssid, if any>', '<your backup ssid pw>',<your port>)
Re: ESP32 boards
It should have created an autostart entry in boot.py, but due to a bug it was ommitted (and fixed currently).budman1758 wrote: ↑25 Mar 2018, 05:37 OK. Installed ESP tool on a different computer. (non win 10) Windows 7 ult.
Used this command from post 31 in this thread. The command for Windows from post 1 does NOT work.Was able to start with "import upyeasy" and "upyeasy.main()" on the first try!Code: Select all
Autostart can be done by adding this:
import upyeasy
upyeasy.main()
For those of you building your own firmware, please change in the ports/esp32/modules directory the file initsetup.py!
From this:
def setup():
check_bootsec()
print("Performing initial setup")
uos.VfsFat.mkfs(bdev)
vfs = uos.VfsFat(bdev)
uos.mount(vfs, '/flash')
uos.chdir('/flash')
with open("boot.py", "w") as f:
f.write("""\
# This file is executed on every boot (including wake-boot from deepsleep)
return vfs
def setup():
check_bootsec()
uos.chdir('/flash')
f.write("""\
import upyeasy
upyeasy.main()
return vfs
Re: ESP32 boards
Seems its running again, with the 4096 bin.
But, it does not pass the data to Domoticz, using HTTP, nor does it auto update once every 60 seconds.
After a manual update (by clicking Devices) I getnew values, as expected and this:
stack: 2032 out of 15360
GC: total: 96000, used: 75856, free: 20144
No. of 1-blocks: 1295, 2-blocks: 154, max blk sz: 902, max free sz: 185
575303220.748 <HTTPRequest object at 3ffbc640> <StreamWriter <socket>> "GET /devices"
2018-03-25 14:27:43 [debug] uPyEasy-uPyEasy: Pages: Authorize User!?
2018-03-25 14:27:43 [debug] uPyEasy-uPyEasy: Pages: Entering Devices Page
2018-03-25 14:27:43 [debug] uPyEasy-uPyEasy: Utils: uPyEasy Name
2018-03-25 14:27:43 [debug] uPyEasy-uPyEasy: Plugins: Read device DS1
2018-03-25 14:27:44 [debug] uPyEasy-uPyEasy: Plugin: ds18 read
2018-03-25 14:27:44 [debug] uPyEasy-uPyEasy: Plugins: Read device BME1
2018-03-25 14:27:44 [debug] uPyEasy-uPyEasy: Plugin: bme280 read
GC: total: 96000, used: 85072, free: 10928
No. of 1-blocks: 1307, 2-blocks: 158, max blk sz: 902, max free sz: 408
575303316.116 <HTTPRequest object at 3ffbd430> <StreamWriter <socket>> "GET /static/upyeasy.css"
GC: total: 96000, used: 86624, free: 9376
No. of 1-blocks: 1352, 2-blocks: 165, max blk sz: 902, max free sz: 385
575303316.116 <HTTPRequest object at 3ffc2ed0> <StreamWriter <socket>> "GET /static/upyeasy.js"
static/upyeasy.css
static/upyeasy.js
Re: ESP32 boards
So, now I think the device is not connected to any network.BertB wrote: ↑25 Mar 2018, 11:51 2000-01-01 00:03:43 [debug] uPyEasy-uPyEasy: Hal: Entering SetTime
[/quote]
Hi Bert,
Actually everything is now working at your ESP32. But... you seem to have run into a bug (of all things!). Which is good and bad, good because it means finally everything is working at your ESP32, bad because seems to be a bug in there. I'll give it a look and fix it right now. The setwifi error you can ignore, that's another bug also fixed (which doesn't have any impact on setting the wifi parameters).
Just a sec, and i'll fix this bug for you and upload a new firmware version.
Re: ESP32 boards
So it's running (you can connect to the upyeasy webserver) but no updates are send to domoticz? Neither using http or mqtt?BertB wrote: ↑25 Mar 2018, 15:29 Seems its running again, with the 4096 bin.
After a manual update (by clicking Devices) I getnew values, as expected and this:stack: 2032 out of 15360
static/upyeasy.css
static/upyeasy.js
Re: ESP32 boards
Re: ESP32 boards
The web log only shows this:
2018-03-25 14:34:04 [debug] uPyEasy-uPyEasy: Utils: uPyEasy Name
2018-03-25 14:34:14 [debug] uPyEasy-uPyEasy: Pages: Authorize User!?
2018-03-25 14:34:14 [debug] uPyEasy-uPyEasy: Pages: Entering Devices Page
2018-03-25 14:34:14 [debug] uPyEasy-uPyEasy: Utils: uPyEasy Name
2018-03-25 14:34:14 [debug] uPyEasy-uPyEasy: Plugins: Read device test
2018-03-25 14:34:15 [debug] uPyEasy-uPyEasy: Plugin: ds18 read
2018-03-25 14:34:16 [debug] uPyEasy-uPyEasy: Plugins: Read device demo
2018-03-25 14:34:16 [debug] uPyEasy-uPyEasy: Plugin: switch read
2018-03-25 14:34:20 [debug] uPyEasy-uPyEasy: Pages: Authorize User!?
2018-03-25 14:34:20 [debug] uPyEasy-uPyEasy: Pages: Entering Advanced Page
2018-03-25 14:34:20 [debug] uPyEasy-uPyEasy: Pages: Display Advanced Page
2018-03-25 14:34:20 [debug] uPyEasy-uPyEasy: Utils: uPyEasy Name
2018-03-25 14:42:59 [debug] uPyEasy-uPyEasy: Pages: Authorize User!?
2018-03-25 14:43:00 [debug] uPyEasy-uPyEasy: Pages: Display Rules Page
2018-03-25 14:43:00 [debug] uPyEasy-uPyEasy: Utils: uPyEasy Name
2018-03-25 14:43:02 [debug] uPyEasy-uPyEasy: Pages: Authorize User!?
2018-03-25 14:43:03 [debug] uPyEasy-uPyEasy: Pages: Entering Tools Page
2018-03-25 14:43:03 [debug] uPyEasy-uPyEasy: Pages: Display Tools Page
2018-03-25 14:43:03 [debug] uPyEasy-uPyEasy: Utils: uPyEasy Name
2018-03-25 14:43:05 [debug] uPyEasy-uPyEasy: Pages: Authorize User!?
2018-03-25 14:43:06 [debug] uPyEasy-uPyEasy: Pages: Entering Tools Page
2018-03-25 14:43:06 [debug] uPyEasy-uPyEasy: ucmd
2018-03-25 14:43:06 [debug] uPyEasy-uPyEasy: Pages: cmd: log
2018-03-25 14:43:06 [debug] uPyEasy-uPyEasy: Pages: Log command given
2018-03-25 14:43:06 [debug] uPyEasy-uPyEasy: Utils: uPyEasy Name
close
Re: ESP32 boards
PLEASE note that due to an header bug the file edit only works with the firmware release 20180325 and higher (put in the releases section a few minutes ago)Martinus wrote: ↑25 Mar 2018, 14:24 Figured out how:
But there might be an easier way?Code: Select all
when flashing,the filesystem with your config files will not be deleted, so no need to redo config!
The easy way:
Select tools menu, filessystem/files: klik on boot.py's edit button: Add the two lines into the text field: Click on the submit button: done!
Re: ESP32 boards
I have the same thing, the asyncio timing is NOT kicking off. Searching for the cause!Martinus wrote: ↑25 Mar 2018, 15:44The web log only shows this:Code: Select all
2018-03-25 14:34:04 [debug] uPyEasy-uPyEasy: Utils: uPyEasy Name 2018-03-25 14:34:14 [debug] uPyEasy-uPyEasy: Pages: Authorize User!? 2018-03-25 14:34:14 [debug] uPyEasy-uPyEasy: Pages: Entering Devices Page 2018-03-25 14:34:14 [debug] uPyEasy-uPyEasy: Utils: uPyEasy Name 2018-03-25 14:34:14 [debug] uPyEasy-uPyEasy: Plugins: Read device test 2018-03-25 14:34:15 [debug] uPyEasy-uPyEasy: Plugin: ds18 read 2018-03-25 14:34:16 [debug] uPyEasy-uPyEasy: Plugins: Read device demo 2018-03-25 14:34:16 [debug] uPyEasy-uPyEasy: Plugin: switch read 2018-03-25 14:34:20 [debug] uPyEasy-uPyEasy: Pages: Authorize User!? 2018-03-25 14:34:20 [debug] uPyEasy-uPyEasy: Pages: Entering Advanced Page 2018-03-25 14:34:20 [debug] uPyEasy-uPyEasy: Pages: Display Advanced Page 2018-03-25 14:34:20 [debug] uPyEasy-uPyEasy: Utils: uPyEasy Name 2018-03-25 14:42:59 [debug] uPyEasy-uPyEasy: Pages: Authorize User!? 2018-03-25 14:43:00 [debug] uPyEasy-uPyEasy: Pages: Display Rules Page 2018-03-25 14:43:00 [debug] uPyEasy-uPyEasy: Utils: uPyEasy Name 2018-03-25 14:43:02 [debug] uPyEasy-uPyEasy: Pages: Authorize User!? 2018-03-25 14:43:03 [debug] uPyEasy-uPyEasy: Pages: Entering Tools Page 2018-03-25 14:43:03 [debug] uPyEasy-uPyEasy: 2018-03-25 14:43:03 [debug] uPyEasy-uPyEasy: Pages: Display Tools Page 2018-03-25 14:43:03 [debug] uPyEasy-uPyEasy: Utils: uPyEasy Name 2018-03-25 14:43:05 [debug] uPyEasy-uPyEasy: Pages: Authorize User!? 2018-03-25 14:43:06 [debug] uPyEasy-uPyEasy: Pages: Entering Tools Page 2018-03-25 14:43:06 [debug] uPyEasy-uPyEasy: ucmd 2018-03-25 14:43:06 [debug] uPyEasy-uPyEasy: Pages: cmd: log 2018-03-25 14:43:06 [debug] uPyEasy-uPyEasy: Pages: Log command given 2018-03-25 14:43:06 [debug] uPyEasy-uPyEasy: Utils: uPyEasy Name close
UPDATE 1: It is working on linux, there a sensor is read and kicked to domoticz every 10 seconds. Investigating why it doesn't work on a ESP32...
2018-03-25 17:14:53 [debug] uPyEasy-Ubuntu: Plugin: test process
2018-03-25 17:14:53 [debug] uPyEasy-Ubuntu: Plugins: Scheduling Async processing plugin: Test
2018-03-25 17:14:54 [debug] uPyEasy-Ubuntu: Protocol Domoticz HTTP
2018-03-25 17:14:54 [debug] uPyEasy-Ubuntu: Protocol Domoticz HTTP: send SENSOR_TYPE_SWITCH
2018-03-25 17:14:54 [debug] uPyEasy-Ubuntu: Protocol Domoticz HTTP: SENSOR_TYPE_SWITCH
2018-03-25 17:14:54 [debug] uPyEasy-Ubuntu: Protocol Domoticz HTTP message: http://192.168.178.115:8000/json.htm?type=command¶m=switchlight&idx=1245&switchcmd=On
2018-03-25 17:14:54 [debug] uPyEasy-Ubuntu: Protocol Domoticz HTTP response: {
"status" : "OK",
"title" : "SwitchLight"
Re: ESP32 boards
Just did a fresh install of the latest firmware. Now it automatically connects to my neighbors Wifi printer (!).
It does not seem to listen to serial input. How to get it connect to my network again?
Re: ESP32 boards
Oops, , that's because in absence of the network config uPyEasy connects to the strongest open wifi network.
Just do a crtl-c so you end up on the REPL interface ( the '>>>') and do the setwifi command again. Reboot after that.
uPyEasy connects to the strongest open wifi network as part of an experiment i was conducting: if you make an open wifi network on your phone, uPyEasy connects to that one. Maybe that would make first time config easier.
Re: ESP32 boards
Ok, i fixed it using crtl-c to get into repl again.
But wouldn't it be easier to launch an AP if no SSID is set, like we do with ESPEasy?
Re: ESP32 boards
UPDATE2: I suspect this has something to do with the problem:LisaM wrote: ↑25 Mar 2018, 16:30I have the same thing, the asyncio timing is NOT kicking off. Searching for the cause!Martinus wrote: ↑25 Mar 2018, 15:44The web log only shows this:Code: Select all
UPDATE 1: It is working on linux, there a sensor is read and kicked to domoticz every 10 seconds. Investigating why it doesn't work on a ESP32...Code: Select all
2018-03-25 17:14:53 [debug] uPyEasy-Ubuntu: Plugin: test process 2018-03-25 17:14:53 [debug] uPyEasy-Ubuntu: Plugins: Scheduling Async processing plugin: Test 2018-03-25 17:14:54 [debug] uPyEasy-Ubuntu: Protocol Domoticz HTTP 2018-03-25 17:14:54 [debug] uPyEasy-Ubuntu: Protocol Domoticz HTTP: send SENSOR_TYPE_SWITCH 2018-03-25 17:14:54 [debug] uPyEasy-Ubuntu: Protocol Domoticz HTTP: SENSOR_TYPE_SWITCH 2018-03-25 17:14:54 [debug] uPyEasy-Ubuntu: Protocol Domoticz HTTP message: http://192.168.178.115:8000/json.htm?type=command¶m=switchlight&idx=1245&switchcmd=On 2018-03-25 17:14:54 [debug] uPyEasy-Ubuntu: Protocol Domoticz HTTP response: { "status" : "OK", "title" : "SwitchLight" }
2000-01-01 00:00:16 [debug] uPyEasy-ESP32-DOIT: Hal: StartTime: 575307160
2018-03-25 15:32:40 [debug] uPyEasy-ESP32-DOIT: Set time: 2018-03-25T15:32:40
UPDATE3: Nope, didn't work....
Re: ESP32 boards
What version is uploaded last? What time was that?
Just installed a version, say 10 minutes back.
It had the boot.py stuff on board
First created a BME280. That went fine.
Then I wanted to create a DS18B20 and, right after the submit the browser told me that the connection got re inititialized.
After reboot (reset button) the browser continued in the DS18B20 config page and I could complete the setup.stack: 2032 out of 15360
GC: total: 96000, used: 73984, free: 22016
No. of 1-blocks: 1253, 2-blocks: 153, max blk sz: 902, max free sz: 128
575313997.268 <HTTPRequest object at 3ffba410> <StreamWriter <socket>> "GET /dev ice_setting?id=0"
2018-03-25 17:26:39 [debug] uPyEasy-uPyEasy: Pages: Authorize User!?
2018-03-25 17:26:39 [debug] uPyEasy-uPyEasy: Pages: Entering Device Settings Pag e
2018-03-25 17:26:40 [debug] uPyEasy-uPyEasy: Pages: GET
2018-03-25 17:26:40 [debug] uPyEasy-uPyEasy: id
2018-03-25 17:26:40 [debug] uPyEasy-uPyEasy: 0
2018-03-25 17:26:40 [debug] uPyEasy-uPyEasy: Pages: id: 0
2018-03-25 17:26:40 [debug] uPyEasy-uPyEasy: Pages: New Device, choose plugin
2018-03-25 17:26:40 [debug] uPyEasy-uPyEasy: Utils: uPyEasy Name
GC: total: 96000, used: 80368, free: 15632
No. of 1-blocks: 1297, 2-blocks: 162, max blk sz: 902, max free sz: 238
575313997.268 <HTTPRequest object at 3ffc0d50> <StreamWriter <socket>> "GET /sta tic/upyeasy.css"
GC: total: 96000, used: 81920, free: 14080
No. of 1-blocks: 1342, 2-blocks: 169, max blk sz: 902, max free sz: 238
575313997.268 <HTTPRequest object at 3ffc4e00> <StreamWriter <socket>> "GET /sta tic/upyeasy.js"
static/upyeasy.css
static/upyeasy.js
GC: total: 96000, used: 92864, free: 3136
No. of 1-blocks: 1520, 2-blocks: 191, max blk sz: 902, max free sz: 195
575313997.268 <HTTPRequest object at 3ffc9ca0> <StreamWriter <socket>> "POST /de vice_setting?id=0"
2018-03-25 17:26:47 [debug] uPyEasy-uPyEasy: Pages: Authorize User!?
2018-03-25 17:26:47 [debug] uPyEasy-uPyEasy: Pages: Entering Device Settings Pag e
2018-03-25 17:26:47 [debug] uPyEasy-uPyEasy: Pages: POST
2018-03-25 17:26:47 [debug] uPyEasy-uPyEasy: id
2018-03-25 17:26:47 [debug] uPyEasy-uPyEasy: 0
2018-03-25 17:26:47 [debug] uPyEasy-uPyEasy: New Plugin: 4
2018-03-25 17:26:47 [debug] uPyEasy-uPyEasy: Pages: Create Device
2018-03-25 17:26:47 [debug] uPyEasy-uPyEasy: Pages: New Device and plugin choose n: 4
2018-03-25 17:26:48 [debug] uPyEasy-uPyEasy: Utils: uPyEasy Name
2018-03-25 17:26:49 [debug] uPyEasy-uPyEasy: Plugins: Init device: dummy with pl ugin: 4
2018-03-25 17:26:49 [debug] uPyEasy-uPyEasy: Protocols: GetQueue controller 192. 168.0.243-Domoticz HTTP-1
2018-03-25 17:26:49 [debug] uPyEasy-uPyEasy: Plugin: ds18 contruction
2018-03-25 17:26:49 [debug] uPyEasy-uPyEasy: Plugins: Init device: dummy ,instan tiate plugin: DS18B20
2018-03-25 17:26:49 [debug] uPyEasy-uPyEasy: Utils: uPyEasy Name
2018-03-25 17:26:50 [debug] uPyEasy-uPyEasy: Plugin: ds18 init
2018-03-25 17:26:50 [debug] uPyEasy-uPyEasy: Plugins: Read device store: dummy
2018-03-25 17:26:50 [debug] uPyEasy-uPyEasy: Plugin: ds18 init, pin used:
2018-03-25 17:26:50 [debug] uPyEasy-uPyEasy: Hal: pin =
575313997.268 <HTTPRequest object at 3ffc9ca0> <StreamWriter <socket>> Attribute Error("'NoneType' object has no attribute 'init'",)
File "picoweb/__init__.py", line 186, in _handle
File "upyeasy/pages.py", line 1249, in devicesettingpage
File "upyeasy/plugin.py", line 118, in initdevice
File "upyeasy/plugins/ds18.py", line 88, in init
File "onewire.py", line 17, in __init__
AttributeError: 'NoneType' object has no attribute 'init'
Re: ESP32 boards
Can you pls post your steps to success
Re: ESP32 boards
What can I say. It looks good, but there are no updates.
Probable has something to do with beta testing
Re: ESP32 boards
Yeah, I have a running esp32!!!!!
Here are the steps that got my esp32 up and running:
press RST button before plugging in usb
Cmd window:
esptool.py --port COM4 erase_flash
esp32>esptool.py --port COM4 write_flash --compress 0x1000 upyeasy_v021_20180325_test_esp32_4096.bin
putty:
import upyeasy
upyeasy.main()
Thanks to all and Special thanks to Lisa!!!!!!
regards
Karl
Cmd window:
putty:
import upyeasy
upyeasy.main()
regards
Karl
Re: ESP32 boards
It is not possible to set IP Settings in Config tab. Can this somehow be changed.
regards
karl
regards
karl
Re: ESP32 boards
Hi Karl,
Great news!
Out of interest, which ESP32 model is it you are using there?
I agree with you, special thanks to LisaM for all her hard work on this!
Andrew
Great news!
Andrew
Re: ESP32 boards
Hmmm, checking...
@karl: can you verify the correct values are written in the config?
"ssid": and "key": should have the right values!To verify:
- Goto webgui
- tools
- filesystem - files
- click on config
- click on network
- click the edit button
After changing the ssid values, a reboot is necessary.
I'm also busy with finding out why on all platforms async is work, except for the esp32...
Re: ESP32 boards
Ssid and pw do have the right values, but i can’t enter values in ip settings field, they are greyed out...
Re: ESP32 boards
Generally yes, i do most of stuff with fixed ip but i can do it via fixing on router level as well...
Karl
Karl
Re: ESP32 boards
Hi Lisa,
Just chipping in here if I may. In my case I would like to specify a fixed IP-address within the ESP32, please, as my wireless router only allows a limited number of fixed addresses in its table.
Cheers
Andrew
Re: ESP32 boards
V0.2.2 released, firmware can be found in the release section.
Issues solved:
- Async ESP32 not working (work-around implemented: devices should be sending data to domoticz now)
Features added:
- Fixed IP Address possible for ESP32
Issues solved:
Features added:
Re: ESP32 boards
yep, it works
But there still is something funny going on.
When I first create a BME280 device and then a Dallas device, right after the selection of the dallas and clicking submit, the WEB connection with the ESP is broken and a have to reset the ESP board.
After that, I can continue setting up the dallas device.
