After a second attempt with one of the boards, with the 2048 version, I got:
rst:0x1 (POWERON_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0018,len:4
load:0x3fff001c,len:4464
ho 0 tail 12 room 4
load:0x40078000,len:0
load:0x40078000,len:11816
entry 0x4007a9fc
I (465) cpu_start: Pro cpu up.
I (465) cpu_start: Single core mode
I (466) heap_init: Initializing. RAM available for dynamic allocation:
I (469) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
I (475) heap_init: At 3FFC4E98 len 0001B168 (108 KiB): DRAM
I (481) heap_init: At 3FFE0440 len 00003BC0 (14 KiB): D/IRAM
I (488) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (494) heap_init: At 4008DE34 len 000121CC (72 KiB): IRAM
I (500) cpu_start: Pro cpu start user code
I (71) cpu_start: Starting scheduler on PRO CPU.
I (140) modsocket: Initializing
File "boot.py", line 3, in <module>
File "upyeasy/__init__.py", line 46, in main
File "upyeasy/init.py", line 206, in init
File "upyeasy/db.py", line 593, in getrow
File "upyeasy/db.py", line 591, in getrow
File "filedb.py", line 111, in get
ValueError: syntax error in JSON
OSError: [Errno 2] ENOENT
MicroPython v1.9.3-549-gbe9277b-dirty on 2018-05-06; ESP32 module with ESP32
Type "help()" for more information.
>>> upyeasy.setwifi('xxxxxx','yyyyyyyyy')
cache deleted: _config
>>> import machine
>>> machine.reset()
Guru Meditation Error: Core 0 panic'ed (IllegalInstruction)
. Exception was unhandled.
Guru Meditation Error: Core 0 panic'ed (|▒?22@P▒?s▒?▒▒?▒▒?22@3)
? Exception w22@3Guru Meditation Error: Core 0 panic'ed (|▒?22@P▒?s▒?▒▒?▒▒?22@3 )
? Exception w22@3Guru Meditation Error: Core 0 panic'ed #|▒?22@P▒?s▒?▒▒?▒▒?22@3 ? Exception w22@3Guru Meditation Error: Core 0 panic'ed #|▒?22@P▒?s▒?▒▒?▒▒?22@3 ? Exception w22@3Guru Meditation Error: Core 0 panic'ed #|▒?22@P▒?s▒?▒▒?▒▒?22@3 ? Exception w22@3Guru Meditation Error: Core 0 panic'ed #|▒?22@P▒?s▒?▒▒?▒▒?22@3 ? Exception w22@3Guru Meditation Error: Core 0 panic'ed #|▒?22@P▒?s▒?▒▒?▒▒?22@3 ? Exception w22@3Guru Meditation Error: Core 0 panic'ed #|▒?22@P▒?s▒?▒▒?▒▒?22@3 ? Exception w22@3Guru Meditation Error: Core 0 panic'ed #|▒?22@P▒?s▒?▒▒?▒▒?22@3 ? Exception w22@3Guru Meditation Error: Core 0 panic'ed #|▒?22@P▒?s▒?▒▒?▒▒?22@3 ? Exception w22@3Guru Meditation Error: Core 0 panic'ed #|▒?22@P▒?s▒?▒▒?▒▒?22@3 ? Exception w22@3Guru Meditation Error: Core 0 panic'ed #|▒?22@P▒?s▒?▒▒?▒▒?22@3 ? Exception w22@3Guru Meditation Error: Core 0 panic'ed #|▒?22@P▒?s▒?▒▒?▒▒?22@3 ? Exception w22@3Guru Meditation Error: Core 0 panic'ed #|▒?22@P▒?s▒?▒▒?▒▒?22@3 ? Exception w22@3Guru Meditation Error: Core 0 panic'ed #Guru Meditation Error: Core 0 panic'ed #Guru Meditation Error: Core 0 panic'ed #Guru Meditation Erro r: Core 0 panic'ed #Guru Meditation Error: Core 0 panic'ed #Guru Meditation Er ror: Core 0 panic'ed #Guru Meditation Error: Core 0 panic'ed #Guru Meditation Error: Core 0 panic'ed #Guru Meditation Error: Core 0 panic'ed #Guru Meditatio n Error: Core 0 panic'ed #Guru Meditation Error: Core 0 panic'ed #Guru Meditat ion Error: Core 0 panic'ed #Guru Meditation Error: Core 0 panic'ed #Guru Medit ation Error: Core 0 panic'ed #Guru Meditation Error: Core 0 panic'ed #Guru Med itation Error: Core 0 panic'ed #Guru Meditation Error: Core 0 panic'ed #Guru M editation Error: Core 0 panic'ed #Guru Meditation Error: Core 0 panic'ed #Guru Meditation Error: Core 0 panic'ed #Guru Meditation Error: Core 0 panic'ed #Gu ru Meditation Error: Core 0 panic'ed #Guru Meditation Error: Core 0 panic'ed # Guru Meditation Error: Core 0 panic'ed #Guru Meditation Error: Core 0 panic'ed #Guru Meditation Error: Core 0 panic'ed #Guru Meditation Error: Core 0 panic' ed #Guru Meditation Error: Core 0 panic'ed #Guru Meditation Error: Core 0 pani c'ed #▒▒?22@3Guru Meditation Error: Core 0 panic'ed #Guru Meditation Error: Cor e 0 panic'ed #Guru Meditation Error: Core 0 panic'ed #Guru Meditation Error: C ore 0 panic'ed #Guru Meditation Error: Core 0 panic'ed #Guru Meditation Error: Core 0 panic'ed #Guru Meditation Error: Core 0 panic'ed #Guru Meditation Erro r: Core 0 panic'ed #Guru Meditation Error: Core 0 panic'ed #Guru Meditation Er ror: Core 0 panic'ed #Guru Meditation Error: Core 0 panic'ed #Guru Meditation Error: Core 0 panic'ed #Guru Meditation Error: Core 0 panic'ed #Guru Meditatio n Error: Core 0 panic'ed #Guru Meditation Error: Core 0 panic'ed #Guru Meditat ion Error: Core 0 panic'ed #Guru Meditation Error: Core 0 panic'ed #Guru Medit ation Error: Core 0 panic'ed #Guru Meditation Error: Core 0 panic'ed #Guru Med itation Error: Core 0 panic'ed #Guru Meditation Error: Core 0 panic'ed #Guru M editation Error: Core 0 panic'ed #Guru Meditation Error: Core 0 panic'ed #Guru Meditation Error: Core 0 panic'ed #▒▒?22@3Guru Meditation Error: Core 0 panic 'ed #▒▒?22@3Guru Meditation Error: Core 0 panic'ed #Guru Meditation Error: Core 0 panic'ed #Guru Meditation Error: Core 0 panic'ed #Unknown reasonGuru Medita tion Error: Core 0 panic'ed #Unknown reasonGuru Meditation Error: Core 0 panic 'ed #Unknown reasonGuru Meditation Error: Core 0 panic'ed #▒@pT▒?? Exception w2 2@3ets Jun 8 2016 00:22:57
rst:0x10 (RTCWDT_RTC_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT)
ho 0 tail 12 room 4
entry 0x4007a9fc
I (466) cpu_start: Pro cpu up.
I (466) cpu_start: Single core mode
I (470) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
I (476) heap_init: At 3FFC4E98 len 0001B168 (108 KiB): DRAM
I (482) heap_init: At 3FFE0440 len 00003BC0 (14 KiB): D/IRAM
I (495) heap_init: At 4008DE34 len 000121CC (72 KiB): IRAM
I (501) cpu_start: Pro cpu start user code
