Try to copy it in ".micropython/lib directory" instead. It should work.
Questions about components of uPyEasy
Re: Questions about components of uPyEasy
Hmm,
For the error 17's I;ve found if I delete the folders mentioned in each line (or rename to folder.bkp if you prefer) the first set of errors is removed. You'll probably have to do this again if you have to restart more than once.
For the _onewire error, double check that _onewire (as distinct from onewire) is in the .micropython/lib folder. If it is, I'm out of ideas - hopefuly @LisaM will be able to advise. I have found anyway that the _onewire module doesn't seem to work fully - if I try to add a DS18 device plugin in the unix port, it doesn't work for me.
Having said all that, it is early days for the uPyEasy system and we will surely get through these problems.
Andrew.
Andrew.
[/quote]
[/quote]
Sorry, mistake from me.
It is ib ".micropython/lib directory", but the error remains.
[/quote]
Hi Edu,Edu.Uy wrote: ↑06 Feb 2018, 20:15 Good you have it working.
Just to clarify my comment, the config file is the upyeasy file... this config files are generated automatically by upyeasy the first tie you run it.
Is not Linux version dependent. Just internal uPyEasy config. The default one is in port 80.
Regards.
Edu
Just getting back to you on this. I found your suggestion most useful today, when I ended up reinstalling micropython and upyeasy on my Linux PC.
I found the config file (although it took me a while at first!). The full path, on my PC at least, is
~/micropython/ports/unix/config/config/2018-02-09_15-30-181062930438
The actual filename will vary based on date and time of first running upyeasy.
So I changed the port= 80 to 9000, saved the file, restarted upyeasy.... and it went right onto port 9000. Brilliant. Thank you!
Best wishes
Andrew
Hi Andrew, the contractor for the house remodeling (repairing cracks in the walls) is finally done and i'm having more time now.AndrewJ wrote: ↑06 Feb 2018, 20:44 1517945318.103 <HTTPRequest object at 7fa4ea795500> <StreamWriter <_socket 27>> OSError(13,)
File "/home/andrew/.micropython/lib/picoweb/__init__.py", line 186, in _handle
File "upyeasy/pages.py", line 1247, in devicesettingpage
File "upyeasy/plugin.py", line 118, in initdevice
File "upyeasy/plugins/ds18.py", line 79, in init
File "upyeasy/hal.py", line 741, in pin
File "/home/andrew/.micropython/lib/machine/pin.py", line 14, in __init__
OSError: [Errno 13] EACCES
The EACCES error (Error ACCESS) is often due to the Unix security layer, unless you give yourself more rights you can't access the unix hardware directly.
For the http port 80 you get the same problem, on unix everything under port 1024 is restricted and normal users can't access it (that's why 8000 or 9000 does work for you).
So you either use sudo:
OR give your user more rights.sudo micropython -m upyeasy
Cheers,
Lisa
The FileDB database where all uPyEasy data is stored is indeed located on
Each table (entity) is in FileDB a directory under the config dir, for example hardware or config.
Each table record is a separate file in this (hardware,config, etc) directory with an unique datetimestamp as filename. The datetimestamp is the primary key for the record and is referenced when updating the record. See also the code for pages, like line 260:
Since every record is text based, it's save to change the contents of the record using a file editor.
Cheers,
Lisa
.~/.micropython/lib/upyeasy/config
# Update config
cid = db.configTable.update({"timestamp":config['timestamp']},name=config['name'],unit=config['unit'],password=config['password'],sleepenable=config['sleepenable'],sleeptime=config['sleeptime'],sleepfailure=config['sleepfailure'],port=config['port'])
Cheers,
Lisa
Hi Lisa,
Thanks for both your replies, that's good information!
I'll do some more tomorrow. I have a feeling that I might have a few more questions.
Glad to hear the work on your house is done, that can be very disruptive.
Cheers,
Andrew.
Cheers,
Andrew.
