OLED Scrolling Display
Re: OLED Scrolling Display
recompiled, added reserve command, and just got 78 min without reboot !
regards...
paolo
regards...
paolo
this is working but has a problem
continues to reset itself
and does more to navigate the menus
I have made some changes to this plugin to match the changes in ESPEasy R99. New version V0.3 is available in the playground.
N
N
cool work - thank you! That is what i'm looking for. But after spending some days to compile it - can you tell me which constellation of software / versions (Arduino IDE,Libs ...) you are using?
I'm using Linux / Mac OSX and only able to compile ESPEasy R78 under Linux/OSX with Arduino IDE 1.6.5 and ESP8266 Community version 2.0.0.
Can you describe in short words what i have to install (yes, you've described i above), but what do i have to copy where to and configure it correctly?
Or - can you share me a compiled binary?
Kind regard, machnetz
Got it!
I'm using Arduino IDE 1.6.5 and ESP8266 Community v2.1.0 on OSX and Linux, but *renaming* the old oled-file to _P023_OLED.ino.bak. After compiling and uploading it's up and running now !
Regards, machnetz
Regards, machnetz
Hello everyone. I love this plug-in and I would also like to know if you can post a value to a particular row. I have a heating control which scrolls between Current Temperature and Humidity (local DHT11) but would like to send the Heating Setpoint value (Temp) to another scrolling screen. So it would scroll: Temp (20C), Humidity (40%), Setpoint (21). Is it possible to post a http command which populates a variable which could be substituted in one of the rows? Like %IP% does, etc. Many thanks for your hard work. Andymorle wrote:Hi,
I am able to control the Display with these commands:But displaying some text seems different. With this command for example:Code: Select all
http://<ESP IP address>/control?cmd=oledcmd,on http://<ESP IP address>/control?cmd=oledcmd,off
When using 4 lines i see the word "Test" in the third row in the floating part which is shown right now.Code: Select all
http://<ESP IP address>/control?cmd=oled,4,1,Test
If i use row 6 it is the same.
When using 4 lines i see the word "Test" in the first row in the floating part which is shown right now.Code: Select all
http://<ESP IP address>/control?cmd=oled,1,1,Test
Is there a way to control not only the row and colum but also the screen number which is shown.
Hubert
hi,
i played with my oled on the espeasy.
little boring to be limited to text-lines...but someone experienced this and expanded the plugin. cool!
now i found this lib:
https://vimeo.com/152737421
https://github.com/squix78/esp8266-oled-ssd1306
may an experienced dev can use it to expand the plugin "more"..
Me too. This plugin will be so useful if only we can change the text dynamically by sending HTTP or MQTT messages. Is this currently supported or planned functionality?Allycat1972 wrote:morle wrote:Hello everyone. I love this plug-in and I would also like to know if you can post a value to a particular row. I have a heating control which scrolls between Current Temperature and Humidity (local DHT11) but would like to send the Heating Setpoint value (Temp) to another scrolling screen. So it would scroll: Temp (20C), Humidity (40%), Setpoint (21). Is it possible to post a http command which populates a variable which could be substituted in one of the rows? Like %IP% does, etc. Many thanks for your hard work. Andy
Thanks for your brilliant work!
FYI. If you use the MQTT import function in the ESP Playground you can subscribe to MQTT topics and use the values in the OLED display. I have it working showing a Temperature Setpoint from OpenHAB.jsilver wrote:Me too. This plugin will be so useful if only we can change the text dynamically by sending HTTP or MQTT messages. Is this currently supported or planned functionality?Allycat1972 wrote:morle wrote:Hello everyone. I love this plug-in and I would also like to know if you can post a value to a particular row. I have a heating control which scrolls between Current Temperature and Humidity (local DHT11) but would like to send the Heating Setpoint value (Temp) to another scrolling screen. So it would scroll: Temp (20C), Humidity (40%), Setpoint (21). Is it possible to post a http command which populates a variable which could be substituted in one of the rows? Like %IP% does, etc. Many thanks for your hard work. Andy
Do you mean you're displaying the values in the original ESPEasy OLED tiny-font multi-line plugin, or this wonderful big-font multi-page scrolling one?Allycat1972 wrote:FYI. If you use the MQTT import function in the ESP Playground you can subscribe to MQTT topics and use the values in the OLED display. I have it working showing a Temperature Setpoint from OpenHAB.
Ok to answer myself, I've now explored further and found I can display variables from onboard sensors or even other ESP8266 units in the framed OLED plugin, which is amazing! But it only works with numbers.jsilver wrote:Do you mean you're displaying the values in the original ESPEasy OLED tiny-font multi-line plugin, or this wonderful big-font multi-page scrolling one?
But I was also hoping to send strings via mqtt for the unit to display on its OLED. If I get around to it I might try implementing this myself. It'd be interesting to have a room message board which can display useful room data as well as messages.
I have some trouble to compile
_P103_Event.ino: In function 'void Plugin_103_Action(byte, byte, int, int, byte)':
_P103_Event:522: error: invalid conversion from 'char*' to 'byte {aka unsigned char}' [-fpermissive]
_P103_Event:522: error: too few arguments to function 'void ExecuteCommand(byte, const char*)'
Command.ino:2:6: note: declared here
Exception in thread "AWT-EventQueue-0" java.lang.IndexOutOfBoundsException: len=-149
at sun.font.FontDesignMetrics.charsWidth(FontDesignMetrics.java:501)
at org.fife.ui.rsyntaxtextarea.TokenImpl.getWidthUpTo(TokenImpl.java:528)
at org.fife.ui.rsyntaxtextarea.TokenImpl.getWidth(TokenImpl.java:499)
at org.fife.ui.rsyntaxtextarea.RSyntaxUtilities.getTokenListWidth(RSyntaxUtilities.java:1142)
at org.fife.ui.rsyntaxtextarea.RSyntaxUtilities.getTokenListWidth(RSyntaxUtilities.java:1121)
at org.fife.ui.rsyntaxtextarea.SyntaxView.getLineWidth(SyntaxView.java:304)
at org.fife.ui.rsyntaxtextarea.SyntaxView.calculateLongestLine(SyntaxView.java:110)
at org.fife.ui.rsyntaxtextarea.SyntaxView.updateMetrics(SyntaxView.java:892)
at org.fife.ui.rsyntaxtextarea.SyntaxView.setSize(SyntaxView.java:802)
at javax.swing.plaf.basic.BasicTextUI$RootView.setSize(BasicTextUI.java:1722)
at javax.swing.plaf.basic.BasicTextUI.getPreferredSize(BasicTextUI.java:912)
at javax.swing.plaf.basic.BasicTextAreaUI.getPreferredSize(BasicTextAreaUI.java:120)
at javax.swing.JComponent.getPreferredSize(JComponent.java:1662)
at javax.swing.JTextArea.getPreferredSize(JTextArea.java:619)
at javax.swing.ScrollPaneLayout.layoutContainer(ScrollPaneLayout.java:791)
at java.awt.Container.layout(Container.java:1508)
at java.awt.Container.doLayout(Container.java:1497)
at java.awt.Container.validateTree(Container.java:1693)
at java.awt.Container.validate(Container.java:1628)
at javax.swing.RepaintManager$3.run(RepaintManager.java:704)
at javax.swing.RepaintManager$3.run(RepaintManager.java:702)
at java.security.AccessController.doPrivileged(Native Method)
at java.security.ProtectionDomain$1.doIntersectionPrivilege(ProtectionDomain.java:75)
at javax.swing.RepaintManager.validateInvalidComponents(RepaintManager.java:701)
at javax.swing.RepaintManager$ProcessingRunnable.run(RepaintManager.java:1719)
at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:311)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:756)
at java.awt.EventQueue.access$500(EventQueue.java:97)
at java.awt.EventQueue$3.run(EventQueue.java:709)
at java.awt.EventQueue$3.run(EventQueue.java:703)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:726)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:201)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:105)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:93)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:82)
Exception in thread "Thread-29" java.lang.IndexOutOfBoundsException: len=-149
at javax.swing.JViewport.getViewSize(JViewport.java:999)
at javax.swing.plaf.basic.BasicScrollPaneUI.syncScrollPaneWithViewport(BasicScrollPaneUI.java:278)
at javax.swing.plaf.basic.BasicScrollPaneUI$Handler.stateChanged(BasicScrollPaneUI.java:1033)
at javax.swing.JViewport.fireStateChanged(JViewport.java:1369)
at javax.swing.JViewport.setView(JViewport.java:969)
at javax.swing.JScrollPane.setViewportView(JScrollPane.java:1007)
at org.fife.ui.rtextarea.RTextScrollPane.setViewportView(RTextScrollPane.java:253)
at processing.app.Editor.setCode(Editor.java:1766)
at processing.app.Sketch.setCurrentCode(Sketch.java:1000)
at processing.app.Sketch.setCurrentCode(Sketch.java:980)
at processing.app.Editor.statusError(Editor.java:2670)
at processing.app.Editor$DefaultExportHandler.run(Editor.java:2396)
at java.lang.Thread.run(Thread.java:745)
what is your environment?
arduino ide version, plattform version? ...
maybe check working versions here: http://www.esp8266.nu/forum/viewtopic.php?p=7763#p7763
i have Problems to compile your mod.
Arduino IDE 1.6.9
ESP8266 Library 2.3.0
OLED Library 2.0.0 (Your Library from Github)
Arduino IDE 1.6.9
/Users/Chris/Documents/Arduino/Projects/ESPEasy/ESPEasy/_P205_FrameOLED.ino: In function 'boolean Plugin_205(byte, EventStruct*, String&)':
_P205_FrameOLED:386: error: 'string2Integer' was not declared in this scope
int intPayload=string2Integer(Payload);
_P205_FrameOLED:390: error: 'getValueNameIndex' was not declared in this scope
int ValueNameIndex=getValueNameIndex(event->TaskIndex,string);
_P205_FrameOLED:430: error: 'CheckParam' was not declared in this scope
if (! CheckParam("Line Number",Line,1,8)) {
exit status 1
There an update to OLED Scrolling Display plugin in the Playground which should hopefully play nicely with ESPEasy 114+, Core 2.3 - it still needs the same OLED library from the Playground as before.
There is one new input parameter which allows you to change the scroll speed - from very slow (about 1.5s) to almost instant. The scrolling routine blocks the main Arduino loop and it could be that sometimes the longer slower scrolls will cause some timing problems - this issue can be reduced by using faster scrolls.
N
N
R118 has compiled here fine. Thanks Neil!namirda wrote:There an update to OLED Scrolling Display plugin in the Playground which should hopefully play nicely with ESPEasy 114+, Core 2.3
Is there any chance of being able to send the OLED string values to display?
yes:Is there any chance of being able to send the OLED string values to display?
http://www.esp8266.nu/index.php/OLEDDisplay
--> oled,1,1,test
but we need a change on _P210_MQTTImport.ino
@jsilver,
OK - I have just uploaded yet another new version of the scrolling display to the playground which includes a write option.
The command syntax is either:
a) tskname,Line,String - where tskname is the name you have given to the scrolling oled task,
Line is the line number which must be an integer between 1 and 12,
String is the string to be displayed.
b) taskname,on or taskname,off To switch the display on or off
You can send the command using either http or mqtt or even via the webserver. To use mqtt, you should publish to the normal subscription topic of your esp followed by /cmd - e.g. /ESP01/cmd.
@timsson,
I think the above should satisfy all requirements - what is it exactly that you want?
Let me know how you get on....
N
@timsson,
N
That sounds incredibly useful, Neil... and very comprehensive functionality which should give everyone everything they need. I shall give it a go hopefully today.namirda wrote:OK - I have just uploaded yet another new version of the scrolling display to the playground which includes a write option.
A LITTLE LATER ON THAT DAY...
Well, everything seems to be working really well, except for one thing. I got MQTT commands working, but when I send a string with a space, only the first word is displayed. Is that a limitation of the Command module rather than your Framed OLED module?
LATER STILL...
Not sure if there's a better way to send commands with spaces, but I tried using the Unicode non-breaking space or hard-space character U+00A0 instead of space, and it worked, displaying fine on my OLED as a normal space. To get this character from your keyboard, hold down Alt and type 0160 on the numeric keypad.
Also there's an odd artefact in the serial log... this message, over and over again, after sending just one command to a newly booted device... the command is something like Disp,1,Hello!
- OLED : Syntax Error in OLED command - Disp
Jon
I would like import/send mqtt messages to the oled, but it is a mqt-plugin "problem"...@timsson,I think the above should satisfy all requirements - what is it exactly that you want?
like this:
Oled:
Floor: open/closed
(MQTT-plugin Name: Window1 -- Topic 1:/ESP_03/window1 -- Value Name 1: -- Formula Value1: string(open/closed)
-> still only dezimal..
R119 has compiled here fine. Thank You!
@JSilver
Yes indeed! The routine I used for splitting the command into component parts was an ESPEasy routine from misc.ino and I had not noticed that it used both comma and space as delimiter - hence your problem when trying to display strings with spaces. Now fixed in the playground.
The problem with the recurring syntax errors is partly due to you talking to yourself Jon!
I rather suspect that you have set your mqtt subscribe topic in such a way that your ESP listens to its own output - recursive confirmation bias! MQTT pubsub gets very confusing if you do this - even 'living fossils' should try to avoid the practise! The scrolling oled plugin by default outputs the status of the display and if you are not careful with your subscriptions, this output will subsequently be read as a command which could possibly cause a recurring syntax error as you have noted. I have made a small change in the software which should reduce this problem but it is even better to avoid it completely by modifying your pub and sub strings.
I use the following pub/sub strings to avoid the 'feedback' problem:
subscribe /%sysname%-IN/#
publish /%sysname%/%tskname%/%valname%
I really hope it works for you now.
N
N
@timsson
Sorry but I still don't think I understand your problem.
However, I think you are asking for MQTTImport to import strings and not only floating point values?? If that is the case then I don't think it is possible without major overhaul of ESPEasy - the whole framework is designed around sensors which output numerical values.
MQTTImport works in just the same way as all other sensors except that it reads it's numerical data from the MQTT broker rather than a locally attached device.
If you want to display an Open/Closed string on the OLED then this is not something MQTTImport can help you with.Instead you will simply have to send the strings directly to the Scrolling OLED plugin.
You might want to take a look at MQTTWARN which is a little python utility which is excellent at modifying and retransmitting MQTT messages - I think it could probably help you here.
Hope this helps
N
Hope this helps
N
I'll let you know shortly...namirda wrote:Now fixed in the playground.
Trying it now!
Damn. The madness is getting to me.namirda wrote:The problem with the recurring syntax errors is partly due to you talking to yourself Jon!
Oi! Leave us elderly folks alone!MQTT pubsub gets very confusing if you do this - even 'living fossils' should try to avoid the practise!
I see you found the in-joke my colleague left on our web site!
Good tip!subscribe /%sysname%-IN/#
A LITTLE LATER ON...
Yes. All seems perfect. And since my ESP sensors were all publishing to sensors/%sysname%...etc, I've just changed the root of the MQTT topic for subscribing, which makes a lot more sense anyway. Thanks again Neil!
Okay, I am trying this on the "adafruit Oled feather" and it works better than the standard plug in. It is 128 x 32 so with the Header and footer you can only get 1 line in and be able to read it. It has 3 buttons on the board, I tested "C" which goes to GPIO2 and it works perfect. On this display the header is wasted, you can't read it at all. If i could figure out a way to remove the header and footer I would check to see if 2 lines would fit, and maybe insert the header info as a scrolling divider between the frames but drop the footer altogether.
One other interesting difference, everything is upside down... On the adafruit site they show the buttons on the left, but with this plugin, they are on the right. Not a problem just different.
Now to see if I can get the 8 channel PWM controller for it to work as well.
Ok, now i use openhab and send this via http - it worksnamirda wrote:@timsson
...Instead you will simply have to send the strings directly to the display
Hope this helps
N
- rename displayname: 03_oled and send:
http://ip/tools?cmd=03_oled%2C1%2CWindows+open%3A
http://ip/tools?cmd=03_oled%2C2%2C4
Delay:6
is it possible that somebody integrate an other driver?
I have several 1.3oled with SH1106.. who can help me
http://www.esp8266.nu/forum/viewtopic.p ... 8650#p8650
Hi Namirda,
Thank you for your work on all these plugins. I am going to use all of them for my project.I would like to request a useful feature to this plugin which i am missing in my project.I would like to control some 4 dimmers with rotary encoder locally which will show target pwm set on oled screen for few seconds and then start doing the scrolling routine.some people uses menu system to do it. I have seen few example of this here :
https://www.youtube.com/watch?v=iHOKVtHnfko
https://www.youtube.com/watch?v=MzO__HCKP8I (using menu)
I do not have experience and capacity to do it myself and I do not know how difficult this will be to implement but it will sure be nice addition to scrolling display plugin.
Neil, a weird problem has arisen... and I'm not sure who to direct this at...
On recent builds, with OLED Framed included, I get "Low memory available, stability problems may occur" when compiling.
Whenever I go into the Devices page and do anything to do with OLED Framed, the device crashes.
I've tried your fix to webserver.ino, but to no avail.
Any ideas?
Any ideas?
@ jsilver
Try to remove some plugins you do not use, so you have more free memory and your device will not crash.
Sorry Jon - no idea.
I've never seen a compiler warning like that - does it come from the normal Arduino IDE or are you using VS?
I have just downloaded R124 to give it a try and it seems to work OK for me.
Does the same config run properly on an earlier version of ESPEasy but not on R124?
Costo seems to think it is a shortage of memory and he may well be right - both MQTT Import and Framed OLED are memory hogs! Do you have a lot of other active plugins in your sketch?
Sorry I can't be more help - I will play with it a bit more and get back to you if I find anything.
N
N
... a litte bug:
If you use the same topic twice or 3 time - the oled show nothing
(i use openhab mqtt - R131, frameOled v0.4)
Line 1: [sys#wifi]
Line 2: [sys#uptime]
Line 3: [sys#freeram]
Line 1: [sys#wifi]
namirda,
I can confirm that it works. Wemos D1 Mini, Wemos D1 Oled shield, BME280. Display cycles through temperature, humidity, air pressure and time.
The only issue is, that the Wemos Oled display is smaller than the normal ones, it has only 64 x 48 pixels.
The standard Oled plugin has now an option for those small displays, do you think you could add that also in your plugin?
Many thanks
Uhrheber
Many thanks
Uhrheber
I try to compile the FrameOLED plugin for using it with a SH1106 based display.
No success at this point
I'm able to compile the *regular* source (I tried with R147 and it seems to work : no errors when compiled)
I'm a perfect newbie in the Arduino world, and I don't know how to modify the source for that purpose.
Is there anybody to help for adding SH1106 support to that plugin ?
ESPEasy running on ESP-12F self-made modules (with various sensors) and talking to Domoticz (hosted on RPi2)
Maybe someone could post a link to compilled firmware with this plugin?
Bart
Bart
bart_l wrote:Hello,
Bart
Ohh man that would be great! Please!
Give this a try....
https://dl.dropboxusercontent.com/u/357 ... edOLED.bin
This is ESP Easy R147 including MQTTImport and FramedOLED compiled for 4Mb Flash with 1Mb SPIFFS.
I don't understand where the problem is to compile this yourself??
Good luck.
n
Give this a try....
Good luck.
n
Hi all,
@ namirda
I love your plugin. I use it as replacement for the 'standard' OLED plugin.
I would like to use it with a SH1106 based 1.3" OLED, but it doesn't work. Garbage on screen, only few lines on top & bottom are readable.
I'm able to compile the source code, butI don't know how to modify your code to make it work with that kind of display.
Do you have time to help me ?
@ namirda
Hi NightBird,
It's not so much that I don't have time - it's more that I don't have a SH1106 device to play with!
A quick Google search tells me that they are very similar to the SSD1306 and there is at least one library out there which would probably work for you. For example, take a look at
https://github.com/wonho-maker/Adafruit_SH1106
There is also a discussion on the differences between the two here
https://forum.arduino.cc/index.php?topic=256374.0
I'm sure you can make it work - it would make a nice little learning exercise. If not then just buy a 1306 - they are so very cheap!!
Good luck
n
Good luck
n
Thanks, I will try to play with that stuff.
I'm not a developer (especially on Arduino platform), but if I can get success, I will share the code here, if someone is interested
I already have some SSD1306 displays, but these are 0.96", which is a little small. Unfortunately, the 1.3" models seem to use only the SH1106 controller (and are cheap, too !)
So I will do my best...
NightBird, I modify the original OLED display for use with SH1106 OLED.
SH1106 has 4 more rows, it is a 132*64 OLED.
Screen has to be properly cleared, all 132 rows, which must be done like this in the OLED plugin:
change line 415 : for (i = 0; i < 128; i++) //clear all COL
into this line 415: for (i = 0; i < 132; i++) //clear 132 COL
The first 2 rows are normally not visible, causing misformed characters therefor the text has to shift 2 pixels to the right by:
change line 473 : Plugin_023_sendcommand(0x00 + (8 * col & 0x0f)); //set low col address
into this line 473: Plugin_023_sendcommand(0x02 + (8 * col & 0x0f)); //set low col address + 0x02 pixels offset
I guess this should work and maybe this can be done in the scrolling OLED plugin too.
Hi Costo,
thank you very much for that tip. I will try by myself.
Thanks for this scrolling option it works OK with one display! When you add another second OLED display (3C & 3D) it doesn't work and one display displayed only the WIFI logo. Can you fix this so that everyone can use two of this displays?
Namirda,
Thank you for this plugin, I used it for my CO2 / Temperature / Humidity meter to create a local display. Now it is no longer required to pick up the phone and look at the values in Domoticz
Have you been able to get the Feather OLED working with 2 lines of display and scrolling header?Drum wrote:Okay, I am trying this on the "adafruit Oled feather" and it works better than the standard plug in. It is 128 x 32 so with the Header and footer you can only get 1 line in and be able to read it. It has 3 buttons on the board, I tested "C" which goes to GPIO2 and it works perfect. On this display the header is wasted, you can't read it at all. If i could figure out a way to remove the header and footer I would check to see if 2 lines would fit, and maybe insert the header info as a scrolling divider between the frames but drop the footer altogether.
A feature request: it would be great if it was possible to send pixel data to the OLED display.
Plain text is already great, but having the option to draw icons/images through web commands would be a wonderful extension.
Got the scrolling display working fine, i like te big fonts !
However i want to be able to change / add a message to the display via a linux machine in this network.
I am able to turn the display on/off via the curl command, sending a text via "curl IP_esp_easy/control?cmd=oled,1,1,text" does show the text in small font. How can i send this text to be displayed in the big font?
Hope someone can help me ...
i just figured it out, maybe it helps others so i post it here:
Note the name you give the OLED display on the Devices page, in my case i named it "Display".
To change a text on line 4 via http:
http://IP_number_ESP_device/control?cmd=Display,4,text_without_spaces
To switch off :
http://IP_number_ESP_device/control?cmd=Display,off
To switch on:
http://IP_number_ESP_device/control?cmd=Display,on
Be aware that every update of text is done via a write procedure on the Flash memory of the module, as you know flash memory has a limit on the times you can write to it.
Have FUN with this nice product!
To switch off :
To switch on:
rlust wrote:Have you been able to get the Feather OLED working with 2 lines of display and scrolling header?Drum wrote:Okay, I am trying this on the "adafruit Oled feather" and it works better than the standard plug in. It is 128 x 32 so with the Header and footer you can only get 1 line in and be able to read it. It has 3 buttons on the board, I tested "C" which goes to GPIO2 and it works perfect. On this display the header is wasted, you can't read it at all. If i could figure out a way to remove the header and footer I would check to see if 2 lines would fit, and maybe insert the header info as a scrolling divider between the frames but drop the footer altogether.
No, not yet. I have not had time to get back in to this for a couple of months. The header needs to go, and for the standard plugin the font is too big. Hopefully I can get back into this next month.
Users browsing this forum: No registered users and 109 guests
