Wemos D1mini + Oled Shield Display Issue
I have Wemos D1mini + DTH22 + Oled Shield, temp/hum sensor work great, the oled shield display just an "easy" at startup, I'm on R78. any clue what happen?
Re: Wemos D1mini + Oled Shield Display Issue
yes for sure, missing something ?
the Screen Size is 64x48 and I'm unable to display temp and humidity, do I need to setup something in the skecht for this size of screen ?oups, I have to put on ! http://<ESP IP address>/control?cmd=oledcmd,on
unable to get my temp and humidity from dht22 shield displayed, tried with H: [DHT#Humidity]% T: [DHT#Temperature] C and [Dallas#Temperature]
Did you give the DHT a name in tasksettings?
It should be DHT to let the string [DHT#Temperature] display the value temperature, and for humidity the same.
Probably also you need to activate the box 'Send Data" and give IDX/Var a number >1
Many thanks Costo, name in task settings was missing !
Can I display distance from Ultrasonic Sensor - HC-SR04 ?
[DeviceName#ValueName]
Users browsing this forum: Bing [Bot] and 22 guests
