Hi everyone,
I tried getting a HC-SR501 to work on a regular esp8266 but nothing shows up in the logs, and if I refresh devices, the pin states stay the same.
Connected both VCC to 5V and GND to my psu, and the output to GPIO0. If I check the pins with my multimeter it shows 5V on the
VCC and 3.2V output when there's movement so I think the PIR is good.
Decided to try get input from a regular momentary push button switch connected to GPIO0 and GND, but also had no luck.
I know the state should go on with press and off as soon as you let go of the switch, so I'd hold it down for a while and refresh page.
Device setup:
What am I missing?
Help connecting a PIR and or pushbutton
Re: Help connecting a PIR and or pushbutton
Disable the pull-up on your input.
if this doesn't work try to force GPIO0 to 0 (for example with an external MQTT client. i use mqtTool for iPhone).
-run your ESP.
-disable inversed
-Send a command to force GPIO0 to 0 (you must maintain pull up in this case because on reboot gpio0 must be set to 1)
-check in the log if the command had success.
-Reboot.
Try again with your PIR
-run your ESP.
-disable inversed
-Reboot.
I had a PIR connected to GPIO0, but the behavior was erratic, full of false positives... Since Domoticz had an event to turn on a light, associated with 2 other devices (a door contact and a LDR input), you can imagine the result at night, when the lux was low... The light was going nuts, blinking hundreds of times per second...
I tried all possible settings: Pull up, inversed, set the boot mode on hardware tab... nothing worked. The same problem happened when using gpio-0 with a push button.
To solve my problem, I was forced to change the PIR to another GPIO, and now it's running fine, without a single false positive. My event is working.
The only problem is that I have another unusable Gpio sitting on the corner, together with Gpios 9 and 16, leaving only 10 really usable GPIOS for devices (plus 1 ADC).
Users browsing this forum: No registered users and 101 guests
