Level_Control Device plugin21
Hi all
It is possible to change de value of the field "Set_Value" WITH a command or via http or mttq?? To use it as a thermostat???
Thank for your help
Thank for your help
Re: Level_Control Device plugin21
I'd also like to know... +1
- paveleremin
+1 Same question
Or manage/link it some how with additional Dummy Device?
Have a look at the rule example using system variables - http://www.letscontrolit.com/wiki/index ... _Variables
this is how I did it.. first create dummy device [img]
then create a dummy thermostat in domoticz (I named this test-thermostat )
Create a lua script
Then create a Rule in your ESP
[/img]then create a dummy thermostat in domoticz (I named this test-thermostat )
Create a lua script
commandArray = {}
if devicechanged['test-thermostat'] then
DomDevice = 'test-thermostat'
DomValue = otherdevices_svalues[DomDevice]
CalcValue = (DomValue*1)
print(CalcValue)
url= 'http://192.168.0.68/control?cmd=event,dumb1='..(CalcValue)..''
commandArray['OpenURL']= url
end
on dumb1 do
TaskValueSet 1,1,%eventvalue%
if [tempsensor#Temperature]<[dumb#temp] do
mcpgpio,5,0
mcpgpio,5,1
I don't use domoticz. It the a way to do it without domoticz ?
It should still work without Domoticz just using the rule + 'http://192.168.0.68/control?cmd=event,d ... CalcValue)..'' where CalcValue is your new setpointFranckkyDoo wrote:I don't use domoticz. It the a way to do it without domoticz ?
So if I understand, I don't need to use the level control with your method?
Not my method, its hamsters method , I just commented on the necessity of domoticz. But the way I understand it, you would not need a level device, correct.FranckkyDoo wrote:So if I understand, I don't need to use the level control with your method?
I just try a better way to change the target temperature. It work with the level device but not easy to change the "Set Value" With rules.
Thank you !!
Thank you !!
How can i change the Set Value over Mqtt or command or rule?
I guess it impossible.
first of all, I would like to thank everybody for their great work on this project.
I'm also using this plugin with a DS18b20 sensor as a thermostat and I would like to invert the logic for the output relay as it is on the "Switch input" device.
thanks
thanks
Users browsing this forum: Google [Bot] and 100 guests
