I have a problem with the ESPEasy Firmware version 147RC8. I made a wrong config and now the chip does not startup anymore. I already tried re-flashing the firmware ut it loads the old config being stored in the chip (I rarely can ping the chip for some ms within some minutes)
Currently I try to run wget infinitely to call the reset command but it never gets the url...
Is there a possibility to erase the settings to factory reset via serial programming?
PS: This is a little urgent because the heating system is failing and I don't have a spare board (and resoldering a chip is only the last chance). Configs are backed up
Edit: Just to let you know in case you have the same problem: This solved my problem
http://www.esp8266.com/viewtopic.php?p=27517
In my case:
esptool.py --port /dev/ttyUSB1 --baud 1152000 erase_flash
